  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    An den Inhalt komme ich ja nicht mehr. Ist nur das übrig geblieben......wie kopiere ich die Langfassung dann ?
    @dogfight76
    Dann lass es nochmal laufen.
    Und es kommt eine Tastaturabfrage, bevor die Zusammenfassung eingeblendet wird.
    Da halt nix drücken und die Langfassung kopieren.
    • dogfight76D Offline
      dogfight76D Offline
      dogfight76
      Ok, bin dran !
      Moment bitte.......
        dogfight76D Offline
        dogfight76
        Langversion:
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.61-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         13:39:34 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-11-03 13:39:34 CET
                   Universal time: Sun 2024-11-03 12:39:34 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dogfight76
        HOME=/home/dogfight76
        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.8G        573M        962M         35M        2.3G        3.1G
        Swap:            99M          0B         99M
        Total:          3.9G        573M        1.1G
        Active iob-Instances:   1
                 3794 M total memory
                  573 M used memory
                  799 M active memory
                 1661 M inactive memory
                  961 M free memory
                  232 M buffer memory
                 2025 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 13:39:35 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
        Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3794.4 total,    961.7 free,    574.0 used,   2258.7 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3054.2 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       59G  6.4G   50G  12% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Sat Oct 14 21:37:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sat Oct 14 21:37:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sat Oct 14 21:37:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sat Oct 14 21:37:20 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.6G    /var/
        1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
        1.1G    /var/log
        259M    /var/cache
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        91M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        216M    /opt/iobroker/iobroker-data/
        169M    /opt/iobroker/iobroker-data/files
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        40M     /opt/iobroker/iobroker-data/backup-objects
        34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
        6.4M    /opt/iobroker/iobroker-data/objects.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        nodejs:                 N/A
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
             20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
         *** 16.20.2-deb-1nodesource1 100
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 197)
        Core adapters versions
        js-controller:  5.0.12
        admin:          7.1.5
        javascript:     7.1.4
        nodejs modules from github:     2
        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
          system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
          system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
          system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
          system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
          system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
        Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
        Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
        Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
        Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        989
        States:         790
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 319
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11229      559/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18069559   3929826/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11240      559/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18069558   3929826/cupsd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11154      399/avahi-daemon: r
        udp        0      0 0.0.0.0:53292           0.0.0.0:*                           108        11156      399/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      479/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18068882   3929827/cups-browse
        udp6       0      0 :::48058                :::*                                108        11157      399/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        11155      399/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          17537999   479/dhcpcd
        2024-11-03 13:26:15.900  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
        2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
        2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 send kill signal
        2024-11-03 13:26:15.902  - info: host.iobroker stopInstance system.adapter.time-switch.0 send kill signal
        2024-11-03 13:26:15.904  - info: mqtt.0 (3937682) Terminated (NO_ERROR): Without reason
        2024-11-03 13:26:16.249  - info: cloud.0 (3937725) terminating
        2024-11-03 13:26:16.259  - info: vis-inventwo.0 (3937817) terminating
        2024-11-03 13:26:16.259  - info: backitup.0 (3937750) terminating
        2024-11-03 13:26:16.267  - info: web.0 (3937775) terminating
        2024-11-03 13:26:16.266  - info: admin.0 (3937625) terminating
        2024-11-03 13:26:16.270  - info: web.0 (3937775) Terminated (NO_ERROR): Without reason
        2024-11-03 13:26:16.273  - info: time-switch.0 (3937843) terminating
        2024-11-03 13:26:16.275  - info: mqtt.0 (3937682) terminating
        2024-11-03 13:26:16.276  - info: javascript.0 (3937647) terminating
        2024-11-03 13:26:16.601  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.603  - info: host.iobroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.604  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.644  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.727  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.753  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.831  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
        2024-11-03 13:26:16.831  - info: host.iobroker All instances are stopped.
        2024-11-03 13:26:17.064  - info: host.iobroker terminated
        iob diag has finished.
        Press any key for a summary
          Langversion:
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          dogfight76
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                    573 M used memory
                    799 M active memory
                    961 M free memory
                    232 M buffer memory
                   2025 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.6G    /var/
          1.1G    /var/log
          259M    /var/cache
          USB-Devices by-id:
          nodejs:                 N/A
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.1.5
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        989
          States:         790
          @dogfight76
          Bring das ganze Ding beizeiten auf das aktuelle Release 'Bookworm'.
          Geht aber bei RaspberryOS nur per kompletter Neuinstallation.
          Die Zeit ist jedenfalls richtig konfiguriert.
          Warum nicht?
          sudo systemctl set-default multi-user.target
          Glückwunsch... Dein Betriebssystem möchte so dann und wann mal etwas Pflege erfahren...
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          Wenn die Kiste wieder läuft:
          iob update
          iob upgrade all -y
          iob stop
          iob upgrade self
          iob start
          dogfight76D 1 Antwort Letzte Antwort
            @dogfight76
            Warum nicht?
            sudo apt update
            sudo reboot
            iob update
            iob upgrade all -y
            iob stop
            iob upgrade self
            iob start
            dogfight76D Offline
            dogfight76D Offline
            dogfight76
            @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
            Dann kam das hier:
            dogfight76@iobroker:~ $ sudo systemctl set-default multi-user.target
            Removed /etc/systemd/system/default.target.
            Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
              Dann kam das hier:
              @dogfight76
              Ja, das ist richtig.
                dogfight76D Offline
                dogfight76
                Dann ist der PI jetzt beim full-upgrade !
                Werde den Rest dann so abarbeiten. Dann ist alles erledigt ?
                  @dogfight76
                  Wenn du damit durch bist nochmal die Langfassung posten.
                    dogfight76D Offline
                    dogfight76
                    schrieb am zuletzt editiert von dogfight76
                    Es kam jetzt das hier:
                    Fetched 387 MB in 1min 21s (4,757 kB/s)
                    Reading changelogs... Done
                    apt-listchanges: News
                    cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
                      This release addresses a security issue (CVE-2023-32360) which allows
                      unauthorized users to fetch documents over local or remote networks.
                      Since this is a configuration fix, it might be that it does not reach you if you
                      are updating 'cups-daemon' (rather than doing a fresh installation).
                      Please double check your /etc/cups/cupsd.conf file, whether it limits the access
                      to CUPS-Get-Document with something like the following
                      >  <Limit CUPS-Get-Document>
                      >    AuthType Default
                      >    Require user @OWNER @SYSTEM
                      >    Order deny,allow
                      >   </Limit>
                      (The important line is the 'AuthType Default' in this section)
                     -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
                    (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
                    E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
                    Trotzdem deine Liste weiter abarebiten ?
                        >    AuthType Default
                        >    Order deny,allow
                        >   </Limit>
                      @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                      Ja, das ist eines der von dir vernachlässigten Sicherheitsupdates...
                      Und ganz eigentlich sollte CUPS auch gar nicht auf dem System laufen, außer du betreibst da einen Drucker dran.
                        dogfight76D Offline
                        dogfight76
                        Nein, kein Drucker angeschlossen.
                        Nach Abschluss aller Befehle:
                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        Update chromecast from @2.3.1 to @3.4.1
                        NPM version: 8.19.4
                        Installing iobroker.chromecast@3.4.1... (System call)
                        Adapter "system.adapter.vis.0" restarted.
                        upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                        upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                        upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                        upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                        Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                        dogfight76@iobroker:~ $ iob stop
                        dogfight76@iobroker:~ $ iob upgrade self
                        Update js-controller from @5.0.12 to @6.0.11
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 8.19.4
                        Installing iobroker.js-controller@6.0.11... (System call)
                        dogfight76@iobroker:~ $ iob start
                          NPM version: 8.19.4
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 8.19.4
                          ...möchte ich einen frischen Lauf von iob diag sehen.
                            dogfight76D Offline
                            dogfight76
                            Da ist er:
                            ```bash
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                            CPU threads: 4
                            Current issues:
                                           Local time: Sun 2024-11-03 14:13:55 CET
                                       Universal time: Sun 2024-11-03 13:13:55 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            dogfight76
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
                            Swap:            99M          0B         99M
                            Total:          3.9G        748M        2.6G
                            Active iob-Instances:   9
                                     3794 M total memory
                                      748 M used memory
                                      197 M active memory
                                      938 M inactive memory
                                     2546 M free memory
                                       49 M buffer memory
                                      449 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                            Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       59G  6.8G   50G  13% /
                            tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                            [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                            /var:
                            2.0G    /var/
                            1.1G    /var/log
                            628M    /var/cache
                            217M    /opt/iobroker/iobroker-data/
                            6.7M    /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            nodejs:                 N/A
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
                            admin:          7.1.5
                            javascript:     7.1.4
                            Adapter State
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            + instance is alive
                            Objects and States
                            Objects:        989
                            States:         798
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
                            tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
                            udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                            udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
                            udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                            2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
                            2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
                            2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                            2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                            2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                            2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                              Da ist er:
                              ```bash
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              dogfight76
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        748 M used memory
                                        197 M active memory
                                       2546 M free memory
                                         49 M buffer memory
                                        449 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.0G    /var/
                              1.1G    /var/log
                              628M    /var/cache
                              USB-Devices by-id:
                              nodejs:                 N/A
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              javascript:     7.1.4
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        989
                              States:         798
                              und
                              sudo apt update
                              iob stop
                              sudo reboot
                                dogfight76D Offline
                                dogfight76
                                Nach dem Full-Upgrade Befehl kommt am Schluss:
                                  >    AuthType Default
                                  >    Order deny,allow
                                  >   </Limit>
                                Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
                                Thomas BraunT dogfight76D 2 Antworten Letzte Antwort
                                    >    AuthType Default
                                    >    Order deny,allow
                                    >   </Limit>
                                  @dogfight76
                                  sudo apt update
                                  sagt?
                                    dogfight76D Offline
                                    dogfight76
                                    Da kommt das:
                                    dogfight76@iobroker:~ $ sudo apt update
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Reading package lists... Done
                                    320 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                    dogfight76@iobroker:~ $ sudo apt full-upgrade
                                      Da kommt das:
                                      @dogfight76
                                      Die 320 Updates müssen rein.
                                      Nach dem full-upgrade die Kiste sauber rebooten.
                                          >    AuthType Default
                                          >    Order deny,allow
                                          >   </Limit>
                                        dogfight76D Offline
                                        dogfight76D Offline
                                        dogfight76
                                        @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                          >    AuthType Default
                                          >    Order deny,allow
                                          >   </Limit>
                                        Trotz der Meldung also den Reboot Befehl eingeben ?
                                            >    AuthType Default
                                            >    Order deny,allow
                                            >   </Limit>
                                          Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                                          Deinstallier das mal:
                                          sudo apt remove apt-listchanges
                                          sudo apt update
                                          sudo apt upgrade
