  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Da kommt das:
    dogfight76@iobroker:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    320 packages can be upgraded. Run 'apt list --upgradable' to see them.
    dogfight76@iobroker:~ $ iob stop
    dogfight76@iobroker:~ $ sudo apt full-upgrade
    @dogfight76
    Die 320 Updates müssen rein.
    Nach dem full-upgrade die Kiste sauber rebooten.
      Nach dem Full-Upgrade Befehl kommt am Schluss:
      apt-listchanges: News
      cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
        This release addresses a security issue (CVE-2023-32360) which allows
        unauthorized users to fetch documents over local or remote networks.
        Since this is a configuration fix, it might be that it does not reach you if you
        are updating 'cups-daemon' (rather than doing a fresh installation).
        Please double check your /etc/cups/cupsd.conf file, whether it limits the access
        to CUPS-Get-Document with something like the following
        >  <Limit CUPS-Get-Document>
        >    AuthType Default
        >    Require user @OWNER @SYSTEM
        >    Order deny,allow
        >   </Limit>
        (The important line is the 'AuthType Default' in this section)
       -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
      (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
      E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
      Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
      dogfight76D Offline
      dogfight76D Offline
      dogfight76
      @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
        >    AuthType Default
        >    Order deny,allow
        >   </Limit>
      Trotz der Meldung also den Reboot Befehl eingeben ?
          >    AuthType Default
          >    Order deny,allow
          >   </Limit>
        @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
        Keine Ahnung warum apt-listchanges da bei dir rumzickt.
        Deinstallier das mal:
        sudo apt remove apt-listchanges
        sudo apt update
        sudo apt upgrade
        • dogfight76D Offline
          dogfight76D Offline
          dogfight76
          Wollte ich jetzt eingeben, da steht das in Putty:
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
          Use 'sudo apt autoremove' to remove them.
          The following NEW packages will be installed:
            kms++-utils raspi-utils
          The following packages will be upgraded:
            adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
            chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
            cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
            dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
            exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
            ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
            gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
            gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
            libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
            libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
            libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
            libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
            libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
            libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
            libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
            libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
            libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
            libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
            liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
            libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
            libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
            libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
            librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
            libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
            libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
            libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
            locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
            lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
            mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
            openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
            python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
            python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
            python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
            raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
            systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
            vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
            vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
            xwayland
          320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/488 MB of archives.
          After this operation, 319 MB of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Reading changelogs... Done
              xwayland
            @dogfight76
            Ja, so soll das.
            Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
            Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
              dogfight76D Offline
              dogfight76
              Das Update/Upgrade nach der deinstallation läuft.
              Die Installation, gibt es da ein How-To hier im Forum ?
                @dogfight76
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  dogfight76D Offline
                  dogfight76
                  Nach dem Update und dem Upgrade Befehl kam das:
                  Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                  Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                  Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                  Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                  Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                  dogfight76@iobroker:~ $ sudo apt upgrade
                    libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    sudo apt autoremove
                    Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                    iob update
                    iob upgrade all
                    iob stop
                    iob upgrade self
                    iob start
                    iob update
                    iob upgrade all
                      dogfight76D Offline
                      dogfight76
                      Bin dabei........
                        dogfight76D Offline
                        dogfight76
                        Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                        dogfight76@iobroker:~ $ iob update
                        Used repository: stable
                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                        Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                        Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                        Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                        Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                        Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                        Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                        Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                        Adapter    "web"          : 6.2.5    , installed 6.2.5
                        dogfight76@iobroker:~ $ iob upgrade all
                        Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                        This upgrade of "javascript" will at least introduce the following changes:
                        -> 8.8.3:
                        Fixed object selector in rules
                        -> 8.8.2:
                        updated dependencies
                        -> 8.8.1:
                        -> 8.8.0:
                        Added option to register notifications via scripts
                        Fixed sendTo block with empty name list
                        -> 8.7.7:
                        Fixed import scripts dialog
                        Allow to remove all custom packages (empty list)
                        -> 8.7.6:
                        fix error with subpath imports in scripts
                        -> 8.7.5:
                        Fixed right aligned script names when using multiple instances
                        added fallback for all require calls in scripts
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                        Update javascript from @7.1.4 to @8.8.3
                        NPM version: 10.8.2
                        Installing iobroker.javascript@8.8.3... (System call)
                        added 2 packages, removed 25 packages, and changed 10 packages in 1m
                        197 packages are looking for funding
                          run `npm fund` for details
                        Update "system.adapter.javascript.0"
                        upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                        upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                        upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                        upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                        upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                        upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                        upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                        upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                        upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                        upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                        upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                        upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                        upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                        upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                        upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                        upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                        upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                        upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                        upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                        upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                        upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                        upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                        This upgrade of "hm-rega" will at least introduce the following changes:
                        -> 5.1.0:
                        added notification if devices are low on battery
                        -> 5.0.0:
                        required node 18
                        -> 4.0.0:
                        required node 16 due to adapter-core 3.x.x
                        removed deprecated package - `request`
                        -> 3.0.47:
                        Updated packages
                        -> 3.0.46:
                        fix for controller v5 (closes #368)
                        -> 3.0.44:
                        compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                        also sync enums for maintenance channel of rfd devices (closes #320)
                        -> 3.0.43:
                        if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                        Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                        Update hm-rega from @3.0.40 to @5.1.0
                        NPM version: 10.8.2
                        Installing iobroker.hm-rega@5.1.0... (System call)
                        added 1 package, removed 1 package, and changed 1 package in 10s
                        Update "system.adapter.hm-rega.0"
                        upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                        upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                        upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                        upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                        This upgrade of "fritzdect" will at least introduce the following changes:
                        -> 2.5.11:
                        update devDeps, linting error correction
                        -> 2.5.10:
                        more loggimg for issue #500 of restart loop
                        -> 2.5.9:
                        new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                        Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                        Update fritzdect from @2.2.6 to @2.5.11
                        NPM version: 10.8.2
                        Installing iobroker.fritzdect@2.5.11... (System call)
                        added 181 packages, removed 8 packages, and changed 9 packages in 29s
                        208 packages are looking for funding
                        Adapter "system.adapter.vis.0" restarted.
                        Update "system.adapter.fritzdect.0"
                        upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                        upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                        upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                        upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                        upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                        upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                        This upgrade of "discovery" will at least introduce the following changes:
                        -> 5.0.0:
                        Packages updated
                        Minimum node.js version is 18.x
                        Updated licenses for knx and jarvis
                        -> 4.5.0:
                        Added Air-Q
                        -> 4.4.0:
                        Added WLED
                        Added LaMetric
                        Removed net-tools from proposals
                        -> 4.3.0:
                        Replaced vis with vis-2
                        -> 4.2.0:
                        Changed detection of myvbus and resol
                        -> 4.1.0:
                        Added detection of myvbus and resol
                        -> 4.0.0:
                        Added: frontier_silicon, sma-em, and speedwire
                        Dropped node14 support, refactoring
                        Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                        Update discovery from @3.1.0 to @5.0.0
                        NPM version: 10.8.2
                        Installing iobroker.discovery@5.0.0... (System call)
                        added 2 packages, removed 1 package, and changed 19 packages in 13s
                        210 packages are looking for funding
                        Update "system.adapter.discovery.0"
                        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                        upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                        upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                        upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                        This upgrade of "chromecast" will introduce the following changes:
                        -> 3.4.1:
                        migrated binary state to file
                        -> 3.4.0:
                        Support for devices located in different subnets has been added. [#154, #160]
                        Dependencies have been updated
                        -> 3.3.0:
                        Adapter requires node.js 18 and js-controller >= 5 now
                        -> 3.2.0:
                        changed: Testing has been updated to use node.js 16/18/20
                        changed: Dependencies have been updated
                        YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                        AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                        Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                        -> 3.1.0:
                        Refactoring done
                        Removed dependency with nettools
                        Added support of web port other than 8082
                        -> 3.0.3:
                        Breaking change: Object IDs are now mac addresses instead names
                        set album name as song if provided in icy-name
                        Make compatible with Node.js 16+
                        Add Sentry for crash reporting
                        Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                        Update chromecast from @2.3.1 to @3.4.1
                        NPM version: 10.8.2
                        Installing iobroker.chromecast@3.4.1... (System call)
                        added 3 packages, removed 232 packages, and changed 1 package in 12s
                        207 packages are looking for funding
                        Update "system.adapter.chromecast.0"
                        upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                        upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                        upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                        upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                        upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                        upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                        upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                        upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                        upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                        upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                        upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                        upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                          -> 8.8.3:
                          -> 8.8.2:
                          -> 8.8.1:
                          -> 8.8.0:
                          -> 8.7.7:
                          -> 8.7.6:
                          -> 8.7.5:
                          NPM version: 10.8.2
                          -> 5.1.0:
                          -> 5.0.0:
                          required node 18
                          -> 4.0.0:
                          -> 3.0.47:
                          Updated packages
                          -> 3.0.46:
                          -> 3.0.44:
                          -> 3.0.43:
                          NPM version: 10.8.2
                          -> 2.5.11:
                          -> 2.5.10:
                          -> 2.5.9:
                          NPM version: 10.8.2
                          -> 5.0.0:
                          Packages updated
                          -> 4.5.0:
                          Added Air-Q
                          -> 4.4.0:
                          Added WLED
                          Added LaMetric
                          -> 4.3.0:
                          -> 4.2.0:
                          -> 4.1.0:
                          -> 4.0.0:
                          NPM version: 10.8.2
                          -> 3.4.1:
                          -> 3.4.0:
                          -> 3.3.0:
                          -> 3.2.0:
                          -> 3.1.0:
                          Refactoring done
                          -> 3.0.3:
                          NPM version: 10.8.2
                          hast du den noch nicht aktualisiert?
                            -> 8.8.3:
                            -> 8.8.2:
                            -> 8.8.1:
                            -> 8.8.0:
                            -> 8.7.7:
                            -> 8.7.6:
                            -> 8.7.5:
                            NPM version: 10.8.2
                            -> 5.1.0:
                            -> 5.0.0:
                            required node 18
                            -> 4.0.0:
                            -> 3.0.47:
                            Updated packages
                            -> 3.0.46:
                            -> 3.0.44:
                            -> 3.0.43:
                            NPM version: 10.8.2
                            -> 2.5.11:
                            -> 2.5.10:
                            -> 2.5.9:
                            NPM version: 10.8.2
                            -> 5.0.0:
                            Packages updated
                            -> 4.5.0:
                            Added Air-Q
                            -> 4.4.0:
                            Added WLED
                            Added LaMetric
                            -> 4.3.0:
                            -> 4.2.0:
                            -> 4.1.0:
                            -> 4.0.0:
                            NPM version: 10.8.2
                            -> 3.4.1:
                            -> 3.4.0:
                            -> 3.3.0:
                            -> 3.2.0:
                            -> 3.1.0:
                            Refactoring done
                            -> 3.0.3:
                            NPM version: 10.8.2
                            @dogfight76
                            Gib die Befehle in der Abfolge wie oben gepostet ein.
                            Fehlermeldungen sind jetzt irrelevant und erwartet.
                            dogfight76D 2 Antworten Letzte Antwort
                              dogfight76D Offline
                              dogfight76
                              Damit fing das Problem doch an........
                              Ich wollte im ioBroker das Update des js-controller anstoßen
                                @dogfight76
                                dogfight76D Offline
                                dogfight76D Offline
                                dogfight76
                                @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                @dogfight76
                                Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                Arbeite die Befehlsliste gerade ab
                                  @dogfight76
                                  dogfight76D Offline
                                  dogfight76D Offline
                                  dogfight76
                                  @thomas-braun Fertig. Ohne Fehlermeldung
                                    da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                      @dogfight76
                                      Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                                      iob diag
                                      anschauen.
                                        dogfight76D Offline
                                        dogfight76
                                        Hier das Ergebnis:
                                        ```bash
                                        Script v.2024-10-19
                                        *** BASE SYSTEM ***
                                           Static hostname: iobroker
                                                 Icon name: computer
                                          Operating System: Debian GNU/Linux 11 (bullseye)
                                                    Kernel: Linux 5.15.61-v8+
                                              Architecture: arm64
                                        OS is similar to:
                                        Model           : Raspberry Pi 4 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        This system needs to be REBOOTED!
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Sun 2024-11-03 15:20:43 CET
                                                   Universal time: Sun 2024-11-03 14:20:43 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        dogfight76
                                        HOME=/home/dogfight76
                                        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                                        Swap:            99M        2.0M         97M
                                        Total:          3.9G        804M        215M
                                        Active iob-Instances:   11
                                                 3794 M total memory
                                                  802 M used memory
                                                  934 M active memory
                                                 2452 M inactive memory
                                                  117 M free memory
                                                  178 M buffer memory
                                                 2696 M swap cache
                                                   99 M total swap
                                                    2 M used swap
                                                   97 M free swap
                                        top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                        Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                                        MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       59G  8.6G   48G  16% /
                                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                        [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                        [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET  SOURCE         FSTYPE OPTIONS
                                        /       /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        2.0G    /var/
                                        1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                                        1.1G    /var/log
                                        634M    /var/cache
                                        Archived and active journals take up 1.0G in the file system.
                                        /opt/iobroker/backups:
                                        91M     /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        815M    /opt/iobroker/iobroker-data/
                                        761M    /opt/iobroker/iobroker-data/files
                                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                        13M     /opt/iobroker/iobroker-data/objects.jsonl
                                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.18.0
                                        /usr/bin/node           v20.18.0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.3
                                        nodejs:
                                          Installed: 20.18.0-1nodesource1
                                          Candidate: 20.18.0-1nodesource1
                                          Version table:
                                         *** 20.18.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             12.22.12~dfsg-1~deb11u5 500
                                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                             12.22.12~dfsg-1~deb11u4 500
                                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                                        Core adapters versions
                                        js-controller:  6.0.11
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        nodejs modules from github:     2
                                        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                                        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                        Adapter State
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                          system.adapter.history.0                : history               : iobroker                                 - disabled
                                          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                                          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                                          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                                          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                                        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        Active repo(s): stable
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                        Controller "js-controller": 6.0.11   , installed 6.0.11
                                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                        Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                        Objects and States
                                        Objects:        1050
                                        States:         801
                                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                                        tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                                        udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                                        udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                                        udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                        2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                                        2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                        2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                        2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                                        iob diag has finished.
                                        Press any key for a summary
                                          Hier das Ergebnis:
                                          ```bash
                                          Script v.2024-10-19
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          dogfight76
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M        2.0M         97M
                                                   3794 M total memory
                                                    802 M used memory
                                                    934 M active memory
                                                    117 M free memory
                                                    178 M buffer memory
                                                   2696 M swap cache
                                                     99 M total swap
                                                      2 M used swap
                                                     97 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          2.0G    /var/
                                          1.1G    /var/log
                                          634M    /var/cache
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        1050
                                          States:         801
                                          Pending Updates: 0
