  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Nach dem Full-Upgrade Befehl kommt am Schluss:
    apt-listchanges: News
    cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
      This release addresses a security issue (CVE-2023-32360) which allows
      unauthorized users to fetch documents over local or remote networks.
      Since this is a configuration fix, it might be that it does not reach you if you
      are updating 'cups-daemon' (rather than doing a fresh installation).
      Please double check your /etc/cups/cupsd.conf file, whether it limits the access
      to CUPS-Get-Document with something like the following
      >  <Limit CUPS-Get-Document>
      >    AuthType Default
      >    Require user @OWNER @SYSTEM
      >    Order deny,allow
      >   </Limit>
      (The important line is the 'AuthType Default' in this section)
     -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
    (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
    E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
    dogfight76@iobroker:~ $
    Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
    dogfight76D Offline
    dogfight76D Offline
    dogfight76
    @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
      >    AuthType Default
      >    Order deny,allow
      >   </Limit>
    Trotz der Meldung also den Reboot Befehl eingeben ?
        >    AuthType Default
        >    Order deny,allow
        >   </Limit>
      @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
      Keine Ahnung warum apt-listchanges da bei dir rumzickt.
      Deinstallier das mal:
      sudo apt remove apt-listchanges
      sudo apt update
      sudo apt upgrade
      • dogfight76D Offline
        dogfight76D Offline
        dogfight76
        Wollte ich jetzt eingeben, da steht das in Putty:
        dogfight76@iobroker:~ $ sudo apt full-upgrade
        Reading package lists... Done
        Calculating upgrade... Done
        The following packages were automatically installed and are no longer required:
          libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
        Use 'sudo apt autoremove' to remove them.
        The following NEW packages will be installed:
          kms++-utils raspi-utils
        The following packages will be upgraded:
          adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
          chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
          cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
          dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
          exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
          ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
          gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
          gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
          libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
          libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
          libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
          libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
          libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
          libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
          libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
          libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
          libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
          libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
          liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
          libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
          libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
          libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
          librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
          libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
          libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
          libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
          locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
          lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
          mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
          openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
          python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
          python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
          python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
          raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
          systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
          vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
          vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
          xwayland
        320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
        Need to get 0 B/488 MB of archives.
        After this operation, 319 MB of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Reading changelogs... Done
            xwayland
          @dogfight76
          Ja, so soll das.
          Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
          Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
            dogfight76D Offline
            dogfight76
            Das Update/Upgrade nach der deinstallation läuft.
            Die Installation, gibt es da ein How-To hier im Forum ?
              @dogfight76
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                dogfight76D Offline
                dogfight76
                Nach dem Update und dem Upgrade Befehl kam das:
                Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                dogfight76@iobroker:~ $ sudo apt upgrade
                  libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  sudo apt autoremove
                  Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                  iob update
                  iob upgrade all
                  iob stop
                  iob upgrade self
                  iob start
                  iob update
                  iob upgrade all
                    dogfight76D Offline
                    dogfight76
                    Bin dabei........
                      dogfight76D Offline
                      dogfight76
                      Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                      dogfight76@iobroker:~ $ iob update
                      Used repository: stable
                      Adapter    "admin"        : 7.1.5    , installed 7.1.5
                      Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                      Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                      Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                      Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                      Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                      Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                      Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                      dogfight76@iobroker:~ $ iob upgrade all
                      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                      This upgrade of "javascript" will at least introduce the following changes:
                      -> 8.8.3:
                      Fixed object selector in rules
                      -> 8.8.2:
                      updated dependencies
                      -> 8.8.1:
                      -> 8.8.0:
                      Added option to register notifications via scripts
                      Fixed sendTo block with empty name list
                      -> 8.7.7:
                      Fixed import scripts dialog
                      Allow to remove all custom packages (empty list)
                      -> 8.7.6:
                      fix error with subpath imports in scripts
                      -> 8.7.5:
                      Fixed right aligned script names when using multiple instances
                      added fallback for all require calls in scripts
                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                      Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                      Update javascript from @7.1.4 to @8.8.3
                      NPM version: 10.8.2
                      Installing iobroker.javascript@8.8.3... (System call)
                      added 2 packages, removed 25 packages, and changed 10 packages in 1m
                      197 packages are looking for funding
                        run `npm fund` for details
                      Update "system.adapter.javascript.0"
                      upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                      upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                      upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                      upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                      upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                      upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                      upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                      upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                      upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                      upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                      upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                      upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                      upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                      upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                      upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                      upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                      upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                      upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                      upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                      upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                      upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                      upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                      This upgrade of "hm-rega" will at least introduce the following changes:
                      -> 5.1.0:
                      added notification if devices are low on battery
                      -> 5.0.0:
                      required node 18
                      -> 4.0.0:
                      required node 16 due to adapter-core 3.x.x
                      removed deprecated package - `request`
                      -> 3.0.47:
                      Updated packages
                      -> 3.0.46:
                      fix for controller v5 (closes #368)
                      -> 3.0.44:
                      compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                      also sync enums for maintenance channel of rfd devices (closes #320)
                      -> 3.0.43:
                      if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                      Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                      Update hm-rega from @3.0.40 to @5.1.0
                      NPM version: 10.8.2
                      Installing iobroker.hm-rega@5.1.0... (System call)
                      added 1 package, removed 1 package, and changed 1 package in 10s
                      Update "system.adapter.hm-rega.0"
                      upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                      upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                      upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                      upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                      This upgrade of "fritzdect" will at least introduce the following changes:
                      -> 2.5.11:
                      update devDeps, linting error correction
                      -> 2.5.10:
                      more loggimg for issue #500 of restart loop
                      -> 2.5.9:
                      new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                      Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                      Update fritzdect from @2.2.6 to @2.5.11
                      NPM version: 10.8.2
                      Installing iobroker.fritzdect@2.5.11... (System call)
                      added 181 packages, removed 8 packages, and changed 9 packages in 29s
                      208 packages are looking for funding
                      Adapter "system.adapter.vis.0" restarted.
                      Update "system.adapter.fritzdect.0"
                      upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                      upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                      upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                      upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                      upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                      upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                      This upgrade of "discovery" will at least introduce the following changes:
                      -> 5.0.0:
                      Packages updated
                      Minimum node.js version is 18.x
                      Updated licenses for knx and jarvis
                      -> 4.5.0:
                      Added Air-Q
                      -> 4.4.0:
                      Added WLED
                      Added LaMetric
                      Removed net-tools from proposals
                      -> 4.3.0:
                      Replaced vis with vis-2
                      -> 4.2.0:
                      Changed detection of myvbus and resol
                      -> 4.1.0:
                      Added detection of myvbus and resol
                      -> 4.0.0:
                      Added: frontier_silicon, sma-em, and speedwire
                      Dropped node14 support, refactoring
                      Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                      Update discovery from @3.1.0 to @5.0.0
                      NPM version: 10.8.2
                      Installing iobroker.discovery@5.0.0... (System call)
                      added 2 packages, removed 1 package, and changed 19 packages in 13s
                      210 packages are looking for funding
                      Update "system.adapter.discovery.0"
                      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                      This upgrade of "chromecast" will introduce the following changes:
                      -> 3.4.1:
                      migrated binary state to file
                      -> 3.4.0:
                      Support for devices located in different subnets has been added. [#154, #160]
                      Dependencies have been updated
                      -> 3.3.0:
                      Adapter requires node.js 18 and js-controller >= 5 now
                      -> 3.2.0:
                      changed: Testing has been updated to use node.js 16/18/20
                      changed: Dependencies have been updated
                      YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                      AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                      Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                      -> 3.1.0:
                      Refactoring done
                      Removed dependency with nettools
                      Added support of web port other than 8082
                      -> 3.0.3:
                      Breaking change: Object IDs are now mac addresses instead names
                      set album name as song if provided in icy-name
                      Make compatible with Node.js 16+
                      Add Sentry for crash reporting
                      Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                      Update chromecast from @2.3.1 to @3.4.1
                      NPM version: 10.8.2
                      Installing iobroker.chromecast@3.4.1... (System call)
                      added 3 packages, removed 232 packages, and changed 1 package in 12s
                      207 packages are looking for funding
                      Update "system.adapter.chromecast.0"
                      upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                      upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                      upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                      upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                        -> 8.8.3:
                        -> 8.8.2:
                        -> 8.8.1:
                        -> 8.8.0:
                        -> 8.7.7:
                        -> 8.7.6:
                        -> 8.7.5:
                        NPM version: 10.8.2
                        -> 5.1.0:
                        -> 5.0.0:
                        required node 18
                        -> 4.0.0:
                        -> 3.0.47:
                        Updated packages
                        -> 3.0.46:
                        -> 3.0.44:
                        -> 3.0.43:
                        NPM version: 10.8.2
                        -> 2.5.11:
                        -> 2.5.10:
                        -> 2.5.9:
                        NPM version: 10.8.2
                        -> 5.0.0:
                        Packages updated
                        -> 4.5.0:
                        Added Air-Q
                        -> 4.4.0:
                        Added WLED
                        Added LaMetric
                        -> 4.3.0:
                        -> 4.2.0:
                        -> 4.1.0:
                        -> 4.0.0:
                        NPM version: 10.8.2
                        -> 3.4.1:
                        -> 3.4.0:
                        -> 3.3.0:
                        -> 3.2.0:
                        -> 3.1.0:
                        Refactoring done
                        -> 3.0.3:
                        NPM version: 10.8.2
                        hast du den noch nicht aktualisiert?
                          -> 8.8.3:
                          -> 8.8.2:
                          -> 8.8.1:
                          -> 8.8.0:
                          -> 8.7.7:
                          -> 8.7.6:
                          -> 8.7.5:
                          NPM version: 10.8.2
                          -> 5.1.0:
                          -> 5.0.0:
                          required node 18
                          -> 4.0.0:
                          -> 3.0.47:
                          Updated packages
                          -> 3.0.46:
                          -> 3.0.44:
                          -> 3.0.43:
                          NPM version: 10.8.2
                          -> 2.5.11:
                          -> 2.5.10:
                          -> 2.5.9:
                          NPM version: 10.8.2
                          -> 5.0.0:
                          Packages updated
                          -> 4.5.0:
                          Added Air-Q
                          -> 4.4.0:
                          Added WLED
                          Added LaMetric
                          -> 4.3.0:
                          -> 4.2.0:
                          -> 4.1.0:
                          -> 4.0.0:
                          NPM version: 10.8.2
                          -> 3.4.1:
                          -> 3.4.0:
                          -> 3.3.0:
                          -> 3.2.0:
                          -> 3.1.0:
                          Refactoring done
                          -> 3.0.3:
                          NPM version: 10.8.2
                          @dogfight76
                          Gib die Befehle in der Abfolge wie oben gepostet ein.
                          Fehlermeldungen sind jetzt irrelevant und erwartet.
                          dogfight76D 2 Antworten Letzte Antwort
                            dogfight76D Offline
                            dogfight76
                            Damit fing das Problem doch an........
                            Ich wollte im ioBroker das Update des js-controller anstoßen
                              @dogfight76
                              dogfight76D Offline
                              dogfight76D Offline
                              dogfight76
                              @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                              @dogfight76
                              Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                              Arbeite die Befehlsliste gerade ab
                                @dogfight76
                                dogfight76D Offline
                                dogfight76D Offline
                                dogfight76
                                @thomas-braun Fertig. Ohne Fehlermeldung
                                  da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                    @dogfight76
                                    Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                                    iob diag
                                    anschauen.
                                      dogfight76D Offline
                                      dogfight76
                                      Hier das Ergebnis:
                                      ```bash
                                      Script v.2024-10-19
                                      *** BASE SYSTEM ***
                                         Static hostname: iobroker
                                               Icon name: computer
                                        Operating System: Debian GNU/Linux 11 (bullseye)
                                                  Kernel: Linux 5.15.61-v8+
                                            Architecture: arm64
                                      OS is similar to:
                                      Model           : Raspberry Pi 4 Model B Rev 1.2
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                       15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      This system needs to be REBOOTED!
                                      *** TIME AND TIMEZONES ***
                                                     Local time: Sun 2024-11-03 15:20:43 CET
                                                 Universal time: Sun 2024-11-03 14:20:43 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      dogfight76
                                      HOME=/home/dogfight76
                                      GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      *** DISPLAY-SERVER SETUP ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                                      Swap:            99M        2.0M         97M
                                      Total:          3.9G        804M        215M
                                      Active iob-Instances:   11
                                               3794 M total memory
                                                802 M used memory
                                                934 M active memory
                                               2452 M inactive memory
                                                117 M free memory
                                                178 M buffer memory
                                               2696 M swap cache
                                                 99 M total swap
                                                  2 M used swap
                                                 97 M free swap
                                      top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                      Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                                      MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      /dev/root      ext4       59G  8.6G   48G  16% /
                                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                      [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                      [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                      [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                      [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                      Show mounted filesystems:
                                      TARGET  SOURCE         FSTYPE OPTIONS
                                      /       /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      2.0G    /var/
                                      1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                                      1.1G    /var/log
                                      634M    /var/cache
                                      Archived and active journals take up 1.0G in the file system.
                                      /opt/iobroker/backups:
                                      91M     /opt/iobroker/backups/
                                      /opt/iobroker/iobroker-data:
                                      815M    /opt/iobroker/iobroker-data/
                                      761M    /opt/iobroker/iobroker-data/files
                                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                                      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                      USB-Devices by-id:
                                      No Devices found 'by-id'
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v20.18.0
                                      /usr/bin/node           v20.18.0
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.29.3
                                      nodejs:
                                        Installed: 20.18.0-1nodesource1
                                        Candidate: 20.18.0-1nodesource1
                                        Version table:
                                       *** 20.18.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                           20.17.0-1nodesource1 1001
                                           20.16.0-1nodesource1 1001
                                           20.15.1-1nodesource1 1001
                                           20.15.0-1nodesource1 1001
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                           12.22.12~dfsg-1~deb11u5 500
                                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                           12.22.12~dfsg-1~deb11u4 500
                                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                                      Core adapters versions
                                      js-controller:  6.0.11
                                      admin:          7.1.5
                                      javascript:     8.8.3
                                      nodejs modules from github:     2
                                      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                                      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                      Adapter State
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                        system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                        system.adapter.history.0                : history               : iobroker                                 - disabled
                                        system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                                        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                                        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                                        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                        system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                                      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Upgrade policy: none
                                      Installed ioBroker-Instances
                                      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                      Controller "js-controller": 6.0.11   , installed 6.0.11
                                      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                      Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                      Objects and States
                                      Objects:        1050
                                      States:         801
                                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                                      tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                                      udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                                      udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                                      udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                      2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                                      2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                      2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                      2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                                      iob diag has finished.
                                      Press any key for a summary
                                        Hier das Ergebnis:
                                        ```bash
                                        Script v.2024-10-19
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        dogfight76
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:            99M        2.0M         97M
                                                 3794 M total memory
                                                  802 M used memory
                                                  934 M active memory
                                                  117 M free memory
                                                  178 M buffer memory
                                                 2696 M swap cache
                                                   99 M total swap
                                                    2 M used swap
                                                   97 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        2.0G    /var/
                                        1.1G    /var/log
                                        634M    /var/cache
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.1.5
                                        javascript:     8.8.3
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        1050
                                        States:         801
                                        Pending Updates: 0
                                          dogfight76D Offline
                                          dogfight76
                                          Reboot isr durch
