  4. bekomme den Sonoff 3 USB Dongle auch nicht auf grün.
39 Beiträge 6 Kommentatoren 3.8k Aufrufe 2 Beobachtet
  • werner2000xW werner2000x
    @haselchen Den EZSP gibt es in zwei versionen.
    Wieder Fehler:
    zigbee.0
    2024-10-14 18:27:58.032	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"3a137e30f6e6ed11a179cf770b2af5ab","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    2024-10-14 18:27:57.884	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2024-10-14 18:27:08.051	info	Installed Version: ioBroker/ioBroker.zigbee
    zigbee.0
    2024-10-14 18:27:07.719	info	Starting Zigbee npm ...
    zigbee.0
    2024-10-14 18:27:07.717	info	delete old Backup files. keep only last 10
    zigbee.0
    2024-10-14 18:27:07.618	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
    zigbee.0
    2024-10-14 18:26:52.141	info	terminating
    zigbee.0
    2024-10-14 18:26:51.658	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2024-10-14 18:26:51.655	info	terminating
    zigbee.0
    2024-10-14 18:26:51.642	info	Zigbee: disabling joining new devices.
    zigbee.0
    2024-10-14 18:26:51.637	info	cleaned everything up...
    zigbee.0
    2024-10-14 18:26:51.634	info	Got terminate signal TERMINATE_YOURSELF
    @werner2000x
    Nix /dev/USB...
    Der Link 'by-id' war doch schon richtig:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3a137e30f6e6ed11a179cf770b2af5ab-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Wieder Fehler:
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @werner2000x
      Da ist kein Fehler . Das sind Infos .
      Zeig mal jetzt bitte deine komplette Einstellungsseite vom Adapter
      Edit : in deinem Screenshot gibt es nur einen EZSP zur Auswahl
      werner2000xW 1 Antwort Letzte Antwort
        @werner2000x
        Nix /dev/USB...
        haselchenH Offline
        haselchenH Offline
        haselchen
        Niemand hat dev/USB geraten.
        Ansonsten wäre es auch tty/USB0
        • haselchenH haselchen
          @haselchen
          Es wäre /dev/ttyUSB0.
          Und nicht die beste Lösung, wenn es mit dem 'by-id' doch schon lief.
          Mit der EZSP-Version läuft es ja nun wohl.
            @haselchen
            haselchenH Offline
            haselchenH Offline
            haselchen
            Da ich nicht weiß welche FW auf dem Stick läuft , würde ich mit dem Multitool die geforderte 7.2.xx
            aufspielen und bei 0 beginnen.
              @werner2000x
              werner2000xW Offline
              werner2000x
              @haselchen Ja, stimmt nur einen, aber zwei EFR32:
              Raspi4 8 GB mit Aqara Zigbee USB, iob
              Innogy Smarthome
              Bosch Bridge 2
              HUE Bridge
              OpenWB Wallbox mit EVU Kit
              Google Nest Pro Hub
              HA auf uGreen dxp4800
                haselchenH Offline
                haselchenH Offline
                haselchen
                @werner2000x
                Nimm den EZSP bitte .
                Die baudrate spielt glaube ich nur beim Conbee ne Rolle .
                Schreib da trotzdem 115200 rein .
                Ansonsten müsste alles passen.
                Ich hatte auch solche Probleme.
                Hab mit dem Multitool den Stick resettet und neu angefangen .
                Vielleicht solltest du das genauso machen .
                Aber auf jeden Fall solltest du deine FW herausbekommen .
                Wenn die nicht zur EZSP Einstellung passt , musste die dann noch flashen .
                • bjoernbB bjoernb
                  @thomas-braun Manachmal verstehe ich Computer ja schon nicht. Jetzt hab ich den Adapter deinstalliert und einfach nochmal die Version 1.9.5. installiert, dann konnte er den Stick verbinden. Upgrade auf die aktuelle Version, immernoch grün.
                  Sozusagen "solved"...
                  Meister MopperM Online
                  Meister Mopper
                  @bjoernb sagte in [gelöst] Sonoff Zigbee 3.0 Dongle E startet nicht (mehr):
                  @Homoran (lieber Hausmeister 😉 )
                  Kannst Du das bitte separieren? Der erste Teil hat meiner Ansicht nach nichts mehr mit dem zweiten zu tun.
                  Proxmox und HA ...
                    @meister-mopper sagte in bekomme den Sonoff 3 USB Dongle auch nicht auf grün.:
                    Kann ich!
                    Hab ich sogar gemacht 😁
                    @werner2000x bitte provisorischen Threadtitel anpassen
                    • werner2000xW Offline
                      werner2000x
                      @homoran Habe heute neu geflashed mit NabuCasa_SkyConnect_EZSP_v7.2.3.0_ncp-uart-hw_115200.hex
                      Kein Erfolg :-(
                      zigbee.0
                      2024-10-15 13:33:42.243	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      2024-10-15 13:33:42.183	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-10-15 13:33:42.182	info	Try to reconnect. 1 attempts left
                      zigbee.0
                      2024-10-15 13:33:32.176	error	Error herdsman start
                      zigbee.0
                      2024-10-15 13:33:32.175	error	Failed to start Zigbee
                      zigbee.0
                      2024-10-15 13:33:32.174	error	Starting zigbee-herdsman problem : "Failure to connect"
                      zigbee.0
                      2024-10-15 13:32:21.468	info	Installed Version: ioBroker/ioBroker.zigbee
                      zigbee.0
                      2024-10-15 13:32:21.120	info	Starting Zigbee npm ...
                      zigbee.0
                      2024-10-15 13:32:21.118	info	delete old Backup files. keep only last 10
                      zigbee.0
                      2024-10-15 13:32:21.015	info	starting. Version 1.10.9 (non-npm: ioBroker/ioBroker.zigbee) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.0, js-controller: 6.0.11
                      Innogy Smarthome
                      Bosch Bridge 2
                      HUE Bridge
                      Google Nest Pro Hub
                        Kein Erfolg :-(
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        zigbee.0
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @werner2000x
                        Warum nicht ne für den Stick vorgesehene Firmware ?
                        https://github.com/itead/Sonoff_Zigbee_Dongle_Firmware/tree/master/Dongle-E
                        Oder von hier:
                          @werner2000x
                          Oder von hier:
                          werner2000x
                          @hase Ich habe den Sonoff Model: ZBDongle-P
                          Innogy Smarthome
                          Bosch Bridge 2
                          HUE Bridge
                          Google Nest Pro Hub
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @werner2000x
                            Guck dir dann den 2.Link an .
                            Edit : dann haben wir eigentlich den gleichen Stick
                            Dann musste im Adapter als Coordinator anscheinend doch CC…. nehmen
                              @werner2000x
                              werner2000x
                              @haselchen Dort finde ich nur den Dongle- E
                              Innogy Smarthome
                              Bosch Bridge 2
                              HUE Bridge
                              Google Nest Pro Hub
                              haselchenH C 3 Antworten Letzte Antwort
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @werner2000x
                                Und dann kann ich dir auch den Link für die richtige Software gleich geben.
                                Das flasht du mit dem Multitool
                                  chris299
                                  @werner2000x ich verwende den P mit dieser Firmware: https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator (das ist dann der TI stack )
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @werner2000x
                                    https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0/bin
                                    Erster Eintrag mit Launchpad
                                      @werner2000x
                                      werner2000x
                                      schrieb am zuletzt editiert von werner2000x
                                      @haselchen Der Adapter ist jetzt grün. D a n k e !!!
                                      Jetzt muss ich noch herausfinden wie man Geräte findet. Ich habe jede Menge Geräte aus dem innogy Umfeld und einen Aquara TVCO Air Quality Monitor der schon gefunden wurde.
                                      Innogy Smarthome
                                      Bosch Bridge 2
                                      HUE Bridge
                                      Google Nest Pro Hub
                                        haselchenH Offline
                                        haselchenH Offline
                                        haselchen
                                        @werner2000x
                                        Was ne Geburt 😂😂
                                        Aber 🎉🎉🎉🎉, es darf gefeiert werden.
                                        Anlernen machst du über den Button ganz rechts.
                                        Und meistens musst du für 5 sek auf den Anlernknopf dann am Gerät drücken .
                                        Viel Spaß mit Deinem neuen Spielzeug !!
