  4. beta admin (v7.2.1) Cannot find i18n und Gui Fehler
adminbetabrowserconsoleerror in gui
22 Beiträge 9 Kommentatoren 3.4k Aufrufe 8 Beobachtet
  • crunchipC Offline
    crunchipC Offline
    beim Update heut morgen von v7.2.0 auf 7.2.1 ist mir diese Error Meldung aufgefallen, soweit funktioniert alles bzw noch nichts negatives aufgefallen, bis auf folgendes, siehe unter dem Log
    2024-10-06 09:05:47.538 - info: host.IoBroker "system.adapter.admin.0" disabled
    2024-10-06 09:05:47.538 - info: host.IoBroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2024-10-06 09:05:47.547 - info: admin.0 (149) Got terminate signal TERMINATE_YOURSELF
    2024-10-06 09:05:47.548 - info: admin.0 (149) terminating http server on port 8081
    2024-10-06 09:05:47.550 - info: admin.0 (149) terminating
    2024-10-06 09:05:47.550 - info: admin.0 (149) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2024-10-06 09:05:47.581 - info: host.IoBroker stopInstance system.adapter.admin.0 send kill signal
    2024-10-06 09:05:48.051 - info: admin.0 (149) terminating
    2024-10-06 09:05:48.163 - info: host.IoBroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-10-06 09:05:50.552 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Server is running on http://localhost:8081
    2024-10-06 09:06:01.710 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Successfully upgraded admin to version 7.2.1
    2024-10-06 09:06:02.503 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Final information delivered
    2024-10-06 09:06:02.541 - info: host.IoBroker "system.adapter.admin.0" enabled
    2024-10-06 09:06:02.543 - info: host.IoBroker [WEBSERVER_UPGRADE] (admin) Successfully started adapter
    2024-10-06 09:06:02.833 - info: host.IoBroker instance system.adapter.admin.0 in version "7.2.1" started with pid 5819
    2024-10-06 09:06:06.464 - info: admin.0 (5819) starting. Version 7.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
    2024-10-06 09:06:06.488 - info: admin.0 (5819) requesting all objects
    2024-10-06 09:06:06.521 - error: admin.0 (5819) Cannot init i18n: Error: Cannot find i18n directory
    2024-10-06 09:06:07.567 - info: admin.0 (5819) received all objects
    2024-10-06 09:06:07.820 - info: admin.0 (5819) socket.io server listening on port 8081
    2024-10-06 09:06:07.821 - info: admin.0 (5819) http server listening on port 8081
    2024-10-06 09:06:07.821 - info: admin.0 (5819) Use link "http://127.0.0.1:8081" to configure.
    geht man auf den Reiter Dateien, läde es für ein paar Sekunden, anschließend erschein folgende Seite
    entsprechende Browserconsole zeigt
    AdminUtils.tsx:244 Please add to "system.adapter.vis-inventwo" common.adminUI={"config":"materialize","custom":"json","tab":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-jqui-mfd" common.adminUI={"config":"none"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-keyboard" common.adminUI={"config":"html"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-material-webfont" common.adminUI={"config":"none"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-material" common.adminUI={"config":"none"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-materialdesign" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-players" common.adminUI={"config":"none"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-plumb" common.adminUI={"config":"none"}
    AdminUtils.tsx:244 Please add to "system.adapter.vis-rgraph" common.adminUI={"config":"html"}
    AdminUtils.tsx:244 Please add to "system.adapter.wallpanel" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.weatherunderground" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.whatsapp-cmb" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.wiffi-wz" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.wiobrowser" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.wled" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:244 Please add to "system.adapter.yeelight-2" common.adminUI={"config":"materialize"}
    AdminUtils.tsx:292 Please modify "system.adapter.zigbee2mqtt" common.adminUI={"config":"json","tab":"html"}
    App.tsx:1654 Could not process news: Error: timeout
       at http://10.1.1.10:8081/static/js/491.f791ce33.chunk.js:2:162707
       at r (http://10.1.1.10:8081/static/js/491.f791ce33.chunk.js:2:229865)
    FileBrowser.tsx:804 Cannot read folder 0_userdata.0: undefined
    console.ts:40 Cannot read folder 0_userdata.0: undefined
    console.ts:40
    Error: Minified React error #62; visit https://reactjs.org/docs/error-decoder.html?invariant=62 for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
       at ye (react-dom.production.min.js:50:341)
       at Ko (react-dom.production.min.js:229:311)
       at ks (react-dom.production.min.js:280:85)
       at bs (react-dom.production.min.js:279:450)
       at vs (react-dom.production.min.js:279:320)
       at gs (react-dom.production.min.js:279:180)
       at as (react-dom.production.min.js:270:88)
       at is (react-dom.production.min.js:272:300)
       at Hl (react-dom.production.min.js:127:105)
       at react-dom.production.min.js:266:273
    auch nach mehrmaligem Browser refresh
    wenn man allerdings beim laden kurz vorher die Ansicht ändert, läd die Seite
    allerdings beim öffnen des Benutzerdaten Ordners
    mit anschließender Meldung in der console
    klickt man erneut auf Ansichtsmodus umschalten, erscheint sofort wieder obiger screen "Error in Gui"
    CPU: 49.17 %
    RAM: 34 %
    Betriebszeit: 9h
    Verfügbar: 6.0.11
    Installiert: 6.0.11
    Ereignisse: ⇥45 / ↦13
    Plattform: docker (official image - v10.0.0)
    Betriebssystem: linux
    Architektur: x64
    CPUs: 16
    Geschwindigkeit: 4540 MHz
    Modell: AMD Ryzen 9 6900HX with Radeon Graphics
    RAM: 30.6 GB
    System-Betriebszeit: 10 T. 05:25:09
    Node.js: v20.17.0
    time: 1728210429259
    timeOffset: -120
    NPM: 10.8.2
    Adapter-Anzahl: 634
    Datenträgergröße: 953.9 GB
    Freier Festplattenspeicher: 492.8 GB
    Aktive Instanzen: 45
    Pfad: /opt/iobroker/
    Betriebszeit: 09:24:41
    auf github hab ich`s noch nicht gemeldet
      console.ts:40
      CPU: 49.17 %
      RAM: 34 %
      Betriebszeit: 9h
      Verfügbar: 6.0.11
      Installiert: 6.0.11
      Architektur: x64
      CPUs: 16
      RAM: 30.6 GB
      Node.js: v20.17.0
      time: 1728210429259
      timeOffset: -120
      NPM: 10.8.2
      Adapter-Anzahl: 634
      @crunchip
      Die Meldung mit dem i18n-Verzeichnis habe ich auch, allerdings lädt auf meiner Kiste der Reiter 'Dateien' einwandfrei. Kein GUI-Fehler hier.
      Edit: Genauer lesen... Wenn man den Ansichtsmodus ändert lädt es sich bei mir auch tot. Ein GUI-Fehler erscheint aber nicht.
        @crunchip
        crunchipC Offline
        crunchipC Offline
        @thomas-braun sagte in beta admin (v7.2.1) Cannot find i18n directory:
        ja Ursprünglich fällt es nicht auf, ich hatte ja heute morgen schon probiert, allerdings war bei mir noch der Ansichtsmodus umgestellt, default wird ja der andere Ansichtsmodus geladen
        • FeuersturmF Offline
          FeuersturmF Offline
          Feuersturm
          Hier ist das dazugehörige issue https://github.com/ioBroker/ioBroker.admin/issues/2726 zur Verfolgung des Problems.
          • FeuersturmF Feuersturm
            crunchipC Offline
            crunchipC Offline
            @feuersturm ok und erstmal danke fürs raussuchen, jedoch hatte ich weder bei 7.2.0 diese "i18n" Fehlermeldung und auch kein js-controller v7 in Verwendung, daher auch das eigentliche Problem was darunter geschildert ist, im ersten Beitrag,
            allerdings weiß ich nicht seit wann dieses Problem mit dem Dateien/Gui Fehler besteht.
            Deswegen war meine Vermutung, es gibt einen Zusammenhang.
            Vllt sollte ich den Titel anpassen und aufs Dateien-Problem beschränken.
            Nach wie vor vermisse ich im Forum einen offiziellen Admin stable/beta Thread bezogen auf v7.x.
            Wenn es um admin Probleme geht, liest man immer unzählig viele Einzel Threads
            edit
            das issue dazu zwecks Gui Fehler ist ebenfalls zu finden, siehe https://github.com/ioBroker/ioBroker.admin/issues/2648
              edit
              CodierknechtC Offline
              Codierknecht
              @crunchip
              Das Problem tritt in dieser Form in allen bislang getesteten Versionen von 7.1.0 bis 7.2.2 auf.
              Ich teste mal weiter ... Issue ist kommentiert.
              Edit
              ... auch auf meinem Produktivsystem mit Admin 7.1.5 und JS-Controller 6.0.11.
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • CodierknechtC Codierknecht
                @crunchip
                Edit
                da_WoodyD Offline
                da_WoodyD Offline
                da_Woody
                @codierknecht hmm, ich kenne die Error in GUI Fehler. Sehe ich eigentlich nur wenn ich ein Update mache und dann auf einem anderen Rechner (Männer Höhle oder Werkstatt Büro) den Tab aufrufe. Nach einem reload kommt sofort alles normal.
                Darum hab ich mir das noch nie wirklich durchgelesen. Nächstes mal mach ich einen Screenshot...
                7.2.1 macht bei mir keine Probleme.
                gruß vom Woody
                • da_WoodyD da_Woody
                  Codierknecht
                  @da_woody sagte in beta admin (v7.2.1) Cannot find i18n und Gui Fehler:
                  Prinzipiell bei mir auch nicht.
                  Ohne diesen Beitrag wäre ich aber auch nie auf die Idee gekommen, den Ansichtsmodus im Tab "Dateien" mal umzuschalten ;-)
                  da_WoodyD 3 Antworten Letzte Antwort
                    da_WoodyD Offline
                    da_WoodyD Offline
                    da_Woody
                    @codierknecht hab ich latürnich auch getestet. Kein Problem. Kann's aber gerne zu Mittag noch mal probieren..
                    gruß vom Woody
                    hotspot_2H 1 Antwort Letzte Antwort
                      hotspot_2H Offline
                      hotspot_2H Offline
                      hotspot_2
                      schrieb am zuletzt editiert von hotspot_2
                      ich habe mir gerade 7.2.1 installiert und konnte mich nun nicht mehr einloggen. Ich habe ein Update über die Konsole auf 7.2.2 gemacht aber auch da kann ich mich nicht mehr einloggen. Das ioBroker Logo dreht sich dauerhaft im Kreis.
                      Hat jemand einen Tipp was ich tun kann?
                      • hotspot_2H hotspot_2
                        @hotspot_2 sagte in beta admin (v7.2.1) Cannot find i18n und Gui Fehler:
                        Schalt mal die Authentifizierung per https/ssl ab.
                          hotspot_2H Offline
                          hotspot_2H Offline
                          hotspot_2
                          @thomas-braun Wie geht das?
                            @hotspot_2 sagte: Wie geht das?
                            Siehe Doku
                              Siehe Doku
                              hotspot_2H Offline
                              hotspot_2H Offline
                              hotspot_2
                              vielen Dank, geht wieder.
                              Für alle die nicht in der Doku suchen möchten und das gleiche Problem haben:
                              iobroker set admin --auth false
                              da_WoodyD hotspot_2H 2 Antworten Letzte Antwort
                                da_WoodyD Offline
                                da_WoodyD Offline
                                da_Woody
                                woody@ioBroker:~$ iobroker set admin --auth false
                                please specify instance, like "admin.0"
                                woody@ioBroker:~$ iobroker set admin.0 --auth false
                                New auth for "admin.0" is: false
                                Instance settings for "admin.0" are changed.
                                gruß vom Woody
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  da_Woody
                                  @codierknecht so, getestet. ja spinnt, aber kein gui-error.
                                  gruß vom Woody
                                    TT-Tom
                                    @da_woody
                                    es liegt nicht am https sondern nur an der Authentifizierung, habe es mal durch getestet. siehe hier
                                    Gruß Tom
                                    Public Transport
                                    NSPanel Adapter Wiki
                                    • T TT-Tom
                                      @da_woody
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      da_Woody
                                      @tt-tom ok, die auth hab ich nicht angehakt, auch keine verschlüsselung.
                                      mag auch daran liegen, daß ich mich nie abmelde. die 2 wichtigen rechner laufen 24/7 und die tabs sind immer offen.
                                      gerade reingekommen:
                                      gruß vom Woody
                                        da_WoodyD Offline
                                        da_WoodyD Offline
                                        da_Woody
                                        @codierknecht ha! gerade bekommen vor dem update!
                                        unten dran noch:
                                        Loading chunk 2534 failed. (error: http://192.168.0.250:8081/static/js/2534.b7665a2f.chunk.js)
                                        t.f.j@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:14218
                                        t.e/<@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:1161
                                        t.e@http://192.168.0.250:8081/static/js/main.7300b7a8.js:1:1139
                                        44321/Pa<@http://192.168.0.250:8081/static/js/4684.e66c5656.chunk.js:1:1647587
                                        P@http://192.168.0.250:8081/static/js/4905.33747b16.chunk.js:2:3345
                                        xi@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:120729
                                        bs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109363
                                        vs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109291
                                        gs@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:109152
                                        is@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:106270
                                        Hl@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:46915
                                        62280/rs/<@http://192.168.0.250:8081/static/js/5096.3a6e8bdb.chunk.js:2:103865
                                        gruß vom Woody
                                          unten dran noch:
                                          TT-Tom
                                          @da_Woody
                                          GUI Fehler hatte ich beim Update nicht, erst als ich versucht hatte die Auth wieder zu aktivieren
                                          Gruß Tom
                                          Public Transport
