  4. iobroker neu installation... befehl geht nicht
68 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • K klaris
    @homoran said in iobroker neu installation... befehl geht nicht:
    sudo apt upgrade
    pi@raspberrydi:~ $ sudo apt update
    Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB]
    Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
    Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
    Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [39.0 kB]
    Reading package lists... Done
    E: Release file for http://deb.debian.org/debian/dists/bookworm/InRelease is not        valid yet (invalid for another 58d 8h 32min 8s). Updates for this repository wi        ll not be applied.
    E: Release file for http://deb.debian.org/debian-security/dists/bookworm-securit        y/InRelease is not valid yet (invalid for another 58d 16h 43min 27s). Updates fo        r this repository will not be applied.
    E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InReleas        e is not valid yet (invalid for another 58d 13h 30min 28s). Updates for this rep        ository will not be applied.
    E: Release file for http://archive.raspberrypi.com/debian/dists/bookworm/InRelea        se is not valid yet (invalid for another 55d 10h 36min 47s). Updates for this re        pository will not be applied.
    pi@raspberrydi:~ $ sudo apt upgrade
    Building dependency tree... Done
    Calculating upgrade... Done
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@raspberrydi:~ $
    #41
    @klaris du bist gerade erst am Anfang!
    lad dir das RaspberryPi OS lite neu runter, und fang noch mal neu an.
    • K klaris
      sudo apt upgrade
      pi@raspberrydi:~ $
      #42
      @klaris sagte in iobroker neu installation... befehl geht nicht:
      E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InRelease is not valid yet (invalid for another 58d 13h 30min 28s). Updates for this repository will not be applied.
      Solange die Zeit nicht stimmt funktioniert da halt nicht viel. Deswegen ist die Zeit ja auch so wichtig.
      K 1 Antwort Letzte Antwort
        klaris
        #43
        @thomas-braun said in iobroker neu installation... befehl geht nicht:
        aber sowas muss automatisch funktionieren .. nicht jeder kommt damit klar ....
        • K klaris
          #44
          Tut es ja auch. Aus irgendwelchen Gründen nur bei dir halt nicht.
            klaris
            #45
            defektes gerät ??
            • K klaris
              defektes gerät ??
              #46
              @klaris
              Kann ich dir nicht sagen.
              Stell halt die entsprechenden Dinge richtig ein und schau wie sich die Uhrzeit verhält.
              • K Offline
                klaris
                schrieb am zuletzt editiert von klaris
                #47
                datei angepasst
                [Time]
                NTP=fritz.box 0.de.pool.ntp.org 1.de.pool.ntp.org 2.de.pool.ntp.org
                FallbackNTP=0.debian.pool.ntp.org 1.debian.pool.ntp.org 2.debian.pool.ntp.org 3.debian.pool.ntp.org
                #RootDistanceMaxSec=5
                #PollIntervalMinSec=32
                #PollIntervalMaxSec=2048
                #ConnectionRetrySec=30
                #SaveIntervalSec=60
                • K klaris
                  datei angepasst
                  [Time]
                  #SaveIntervalSec=60
                  #48
                  @klaris
                  Läuft auf deiner fritz.box denn nun der Dienst?
                    @klaris
                    klaris
                    #49
                    @klaris
                    fritzbox zeitsynchronisation auch aktiviert !!
                    ich bin mit meinen latein am ende
                    • K klaris
                      defektes gerät ??
                      #50
                      defektes gerät ??
                      nein, defekte Software!
                      @homoran sagte in iobroker neu installation... befehl geht nicht:
                      • K klaris
                        @klaris
                        #51
                        @klaris
                        Jetzt muss der Service neugestartet werden.
                        sudo systemctl restart systemd-timesyncd.service
                        Kann aber auch sein, dass der Sprung zu groß ist. Sollte aber gemeldet werden.
                          defektes gerät ??
                          klaris
                          #52
                          defektes gerät ??
                          nach jeden neustart kommt immer das datum und die uhrzeit Thu Jul 4 03:34:35 2024 !!!
                          habe ein mal die lite und dann die vollversion gleiches ergebnis....
                          Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                          • K klaris
                            defektes gerät ??
                            #53
                            @klaris
                            Die Änderungen in der timesyncd.conf sind noch drin?
                            • K klaris
                              defektes gerät ??
                              #54
                              und was hat deine fritzbox als Systemzeit?
                              hast du eine Batteriegepufferte RTC am pi?
                              • K klaris
                                defektes gerät ??
                                #55
                                @klaris
                                Hier finden sich noch Kommandos wie man die Zeit richtig setzt:
                                https://wiki.ubuntuusers.de/Systemzeit/
                                  klaris
                                  #56
                                  Batteriegepufferte RTC nein
                                  fritzbox zeit ist ok
                                  • K Offline
                                    klaris
                                    #57
                                    andere speicherkarte neues image gleiches problem ..ich sende das gerät zurück..so kompliziert kann es nicht sein hole mir das raspeberry 4
                                    pi@raspberrydi:~ $ timedatectl
                                                   Local time: Thu 2024-07-04 02:22:01 CEST
                                               Universal time: Thu 2024-07-04 00:22:01 UTC
                                                     RTC time: Thu 1970-01-01 00:08:48
                                    System clock synchronized: no
                                                  NTP service: active
                                              RTC in local TZ: no
                                    • K klaris
                                                    NTP service: active
                                                RTC in local TZ: no
                                      #58
                                      @klaris
                                      Wäre interessant zu sehen was passiert wenn du die Zeit zunächst mal grob manuell setzt.
                                        @klaris
                                        klaris
                                        #59
                                        @klaris
                                        läuft !!timesyncd.conf war das problem !!!
                                        -1
                                        • K klaris
                                          @klaris
                                          #60
                                          @klaris
                                          timedatectl
                                          sagt?
                                          Was genau war das Problem nun?
