  4. iobroker neu installation... befehl geht nicht
68 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
    @klaris sagte in iobroker neu installation... befehl geht nicht:
    meinst das ist ein fehlerhafter raspberry pi 5 ? soll ich den zurück senden ?
    Haste die Datei jetzt angepasst? Und den Service mal neugestartet (oder gleich die ganze Kiste)?
    sudo systemctl restart systemd-timesyncd.service
    klaris
    @thomas-braun ich lerne erst mal mit den nano editor zu arbeiten ...
      was kommt bei sudo apt update und sudo apt upgrade?
      was hattest du denn da virhin umkonfiguriert?
      klaris
      @homoran said in iobroker neu installation... befehl geht nicht:
      sudo apt upgrade
      pi@raspberrydi:~ $ sudo apt update
      Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB]
      Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
      Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
      Get:4 http://archive.raspberrypi.com/debian bookworm InRelease [39.0 kB]
      Reading package lists... Done
      E: Release file for http://deb.debian.org/debian/dists/bookworm/InRelease is not        valid yet (invalid for another 58d 8h 32min 8s). Updates for this repository wi        ll not be applied.
      E: Release file for http://deb.debian.org/debian-security/dists/bookworm-securit        y/InRelease is not valid yet (invalid for another 58d 16h 43min 27s). Updates fo        r this repository will not be applied.
      E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InReleas        e is not valid yet (invalid for another 58d 13h 30min 28s). Updates for this rep        ository will not be applied.
      E: Release file for http://archive.raspberrypi.com/debian/dists/bookworm/InRelea        se is not valid yet (invalid for another 55d 10h 36min 47s). Updates for this re        pository will not be applied.
      pi@raspberrydi:~ $ sudo apt upgrade
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@raspberrydi:~ $
      • K klaris
        sudo apt upgrade
        pi@raspberrydi:~ $
        @klaris du bist gerade erst am Anfang!
        lad dir das RaspberryPi OS lite neu runter, und fang noch mal neu an.
        • K klaris
          sudo apt upgrade
          pi@raspberrydi:~ $
          E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InRelease is not valid yet (invalid for another 58d 13h 30min 28s). Updates for this repository will not be applied.
          Solange die Zeit nicht stimmt funktioniert da halt nicht viel. Deswegen ist die Zeit ja auch so wichtig.
            klaris
            @thomas-braun said in iobroker neu installation... befehl geht nicht:
            aber sowas muss automatisch funktionieren .. nicht jeder kommt damit klar ....
            • K klaris
              Tut es ja auch. Aus irgendwelchen Gründen nur bei dir halt nicht.
                klaris
                defektes gerät ??
                • K klaris
                  defektes gerät ??
                  @klaris
                  Kann ich dir nicht sagen.
                  Stell halt die entsprechenden Dinge richtig ein und schau wie sich die Uhrzeit verhält.
                    klaris
                    schrieb am zuletzt editiert von klaris
                    datei angepasst
                    [Time]
                    NTP=fritz.box 0.de.pool.ntp.org 1.de.pool.ntp.org 2.de.pool.ntp.org
                    FallbackNTP=0.debian.pool.ntp.org 1.debian.pool.ntp.org 2.debian.pool.ntp.org 3.debian.pool.ntp.org
                    #RootDistanceMaxSec=5
                    #PollIntervalMinSec=32
                    #PollIntervalMaxSec=2048
                    #ConnectionRetrySec=30
                    #SaveIntervalSec=60
                    • K klaris
                      datei angepasst
                      [Time]
                      #SaveIntervalSec=60
                      @klaris
                      Läuft auf deiner fritz.box denn nun der Dienst?
                        @klaris
                        klaris
                        @klaris
                        fritzbox zeitsynchronisation auch aktiviert !!
                        ich bin mit meinen latein am ende
                        • K klaris
                          defektes gerät ??
                          defektes gerät ??
                          nein, defekte Software!
                          @homoran sagte in iobroker neu installation... befehl geht nicht:
                          • K klaris
                            @klaris
                            @klaris
                            Jetzt muss der Service neugestartet werden.
                            Kann aber auch sein, dass der Sprung zu groß ist. Sollte aber gemeldet werden.
                              defektes gerät ??
                              klaris
                              defektes gerät ??
                              nach jeden neustart kommt immer das datum und die uhrzeit Thu Jul 4 03:34:35 2024 !!!
                              habe ein mal die lite und dann die vollversion gleiches ergebnis....
                              Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                              • K klaris
                                defektes gerät ??
                                @klaris
                                Die Änderungen in der timesyncd.conf sind noch drin?
                                • K klaris
                                  defektes gerät ??
                                  und was hat deine fritzbox als Systemzeit?
                                  hast du eine Batteriegepufferte RTC am pi?
                                  • K klaris
                                    defektes gerät ??
                                    @klaris
                                    Hier finden sich noch Kommandos wie man die Zeit richtig setzt:
                                    https://wiki.ubuntuusers.de/Systemzeit/
                                      klaris
                                      Batteriegepufferte RTC nein
                                      fritzbox zeit ist ok
                                        klaris
                                        andere speicherkarte neues image gleiches problem ..ich sende das gerät zurück..so kompliziert kann es nicht sein hole mir das raspeberry 4
                                        pi@raspberrydi:~ $ timedatectl
                                                       Local time: Thu 2024-07-04 02:22:01 CEST
                                                   Universal time: Thu 2024-07-04 00:22:01 UTC
                                                         RTC time: Thu 1970-01-01 00:08:48
                                        System clock synchronized: no
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        • K klaris
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          @klaris
                                          Wäre interessant zu sehen was passiert wenn du die Zeit zunächst mal grob manuell setzt.
