  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
    1.0k
    6.1k
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 77 Kommentatoren 1.1m Aufrufe 77 Beobachtet
  • SKBS SKB
    @stephan61 Dann bist Du im falschen Thread. Hier ist die 0.4.x :)
    Was erscheint denn mit F12 in der Browserkonsole?
    @Homoran -> Kannst du nochmals bewegen?
    #241
    @skb sagte in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
    hier hin 😁 ?
    SKBS 1 Antwort Letzte Antwort
      hier hin 😁 ?
      SKBS Offline
      SKBS Offline
      SKB
      #242
      @homoran Alle Wege führen zur Alpha 🐕
      • SKBS SKB
        stephan61
        #243
        @skb
        es kommt folgende Meldung
        The page keeping the extension port is moved into back/forward cache, so the message channel is closed.
        Unchecked runtime.lastError: The page keeping the extension port is moved into back/forward cache, so the message channel is closed.
        Unchecked runtime.lastError: No last-focused window
        functions.min.js?v=0.5.4:1 Object
        functions.min.js?v=0.5.4:1 [Config] Using Instance: energiefluss-erweitert.0
        functions.min.js?v=0.5.4:1 [Language] Detected System-Languag: de-DE
        functions.min.js?v=0.5.4:1 [Socket] connected at 8.8.2024, 12:06:14
        functions.min.js?v=0.5.4:1 [Config] Using /thumbnail/ for userFiles!
        functions.min.js?v=0.5.4:1 [Language] Got from ioBroker! Translating Texts to locale de!
        functions.min.js?v=0.5.4:1 [Config] Loading config for instance: 0
        functions.min.js?v=0.5.4:1 [Version] Installed Version: 0.5.1-alpha.4
        functions.min.js?v=0.5.4:1 [Version] Github Version: 0.5.1-alpha.4
        functions.min.js?v=0.5.4:1 [Config] Trying to load configuration from state!
        functions.min.js?v=0.5.4:1 [Config] Using direct load via iconify-API!
        functions.min.js?v=0.5.4:1 Uncaught TypeError: Cannot convert undefined or null to object
        at Function.keys (<anonymous>)
        at functions.min.js?v=0.5.4:1:28361
        at Array.forEach (<anonymous>)
        at setLoadedConfig (functions.min.js?v=0.5.4:1:28293)
        at r.<anonymous> (functions.min.js?v=0.5.4:1:16940)
        at r.onack (index.js:83:1)
        at r.onpacket (index.js:83:1)
        at r.<anonymous> (index.js:83:1)
        at r.emit (index.js:83:1)
        at r.ondecoded (index.js:83:1)
        functions.min.js?v=0.5.4:1 Loaded additional file: js/iconify.min.js
        inlineForm.html:13 Unchecked runtime.lastError: You do not have a background page.
        configuration.html:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
        configuration.html:1 Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
        inlineForm.html:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
        inlineForm.html:1 Error in event handler: Error: invalid arguments to extensionAdapter.sendMessageToTab
        at e.sendMessageToTab (chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:65501)
        at e.handleMessage (chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:106817)
        at chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:103083
        at chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:78040
        • S stephan61
          @skb
          SKBS Offline
          SKBS Offline
          SKB
          #244
          @stephan61 Hast Du nach der Installation einen Upload gemacht?
          • SKBS SKB
            stephan61
            #245
            @skb
            ja habe upload gemacht
            ich wollte die Hintergrundfarbe ändern. habe ich dabei bei etwas zerstörrt
            • S stephan61
              @skb
              SKBS Offline
              SKBS Offline
              SKB
              #246
              @stephan61 Sieht für mich so aus, als wenn dort irgendwas nicht richtig geladen wird.
              Welchen Browser verwendest Du?
              Kannst Du die Konsole mal als Screenshot posten?
              • SKBS SKB
                stephan61
                #247
                @skb
                verwende chrome ist aber auch unter firefox oder opera
                • S stephan61
                  @skb
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #248
                  @stephan61 Könntest Du mal den ersten Teil aus dem Datenpunkt configuration einstellen?
                  So in etwas sieht das aus:
                  "basic": {
                          "enable_grid": true,
                          "enable_animation": false,
                          "enable_area_catch": true,
                          "enable_config_icon": true,
                          "enable_fullscreen": false,
                          "enable_last_id": false,
                          "enable_icon_proxy": false,
                          "enable_low_performance": false,
                          "enable_ds_autocomplete": false,
                          "height": 540,
                          "width": 530,
                          "animation_timer": 1000,
                          "background_color": "",
                          "styles": "",
                          "font": {
                              "family": "\"Arial\", sans-serif",
                              "size": 20,
                              "align": "middle"
                          "rect": {
                              "height": 100,
                              "width": 100,
                              "corners": 10
                          "circle": {
                              "radius": 50
                          "elm": {
                              "stroke_width": 5,
                              "pos_x": 50,
                              "pos_y": 50
                          "icon": {
                              "width": 24,
                              "height": 24
                  • SKBS SKB
                    @peter666666 Habe noch etwas verfeinert - du kannst gerne nochmals drüber installieren. Dann sollte der Fehler nicht mehr kommen (hoffe ich) ;)
                    Peter666666
                    #249
                    @skb Super hat geklappt!!
                    LG Peter
                    Intel NUC i5 / 16GB RAM / 512GB SSD
                    Synology DS220+ 10GB RAM / 8TB
                    • SKBS SKB
                      "basic": {
                              "height": 540,
                              "width": 530,
                              "styles": "",
                              "font": {
                                  "size": 20,
                                  "align": "middle"
                              "rect": {
                                  "height": 100,
                                  "width": 100,
                                  "corners": 10
                              "circle": {
                                  "radius": 50
                              "elm": {
                                  "stroke_width": 5,
                                  "pos_x": 50,
                                  "pos_y": 50
                              "icon": {
                                  "width": 24,
                                  "height": 24
                      stephan61
                      schrieb am zuletzt editiert von stephan61
                      #250
                      @skb
                      Hallo SKB Background_color war null habe es auf "" geändert
                      jetzt geht es wieder
                      Habe es in Vis mit i Frame eingebunden
                      kann man das Zahnrad da entfernen?
                      • S stephan61
                        @skb
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #251
                        @stephan61 Danke für den Hinweis. Habe eine Kontrolle angelegt, die prüft, ob die Werte vorhanden sind.
                        Das Zahnrad kann man in den Einstellungen ausblenden.
                        • SKBS SKB
                          @ralle Wir könnten auch fix versuchen, das Problem zu finden und dann kannst Du auch diese nutzen ;)
                          ralleR Offline
                          ralleR Offline
                          ralle
                          #252
                          @skb
                          @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                          Kann ich da irgend was zu Beitragen, brauchst du noch was ?
                          • ralleR ralle
                            @skb
                            SKBS Offline
                            SKBS Offline
                            SKB
                            schrieb am zuletzt editiert von SKB
                            #253
                            @ralle Gerne einmal den Datenpunkt configuration in Code-Tags einstellen. Schaue mir dann an, wo es klemmt.
                            ralleR 1 Antwort Letzte Antwort
                            • SKBS SKB
                              ralleR Offline
                              ralleR Offline
                              ralle
                              #254
                              wo finde ich diese, wie komme ich da dran ?
                              • ralleR ralle
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #255
                                @ralle Datenpunkt -> Objekte, energiefluss-erweitert, Instanz, configuration
                                Den Inhalt hier her kopieren.
                                • SKBS SKB
                                  ralleR Offline
                                  ralleR Offline
                                  ralle
                                  #256
                                  ich bin verwirrt.... ich find nix. meinst du im IOBroker oder auf der SD Karte?
                                  ralleR SKBS 2 Antworten Letzte Antwort
                                  • ralleR ralle
                                    ralleR Offline
                                    ralleR Offline
                                    ralle
                                    #257
                                    @ralle said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                                    Wenn ich im IoB auf die Übersicht schaue sehe ich auch 2x den Adapter in der Version 0.5.1 alpha4!
                                    • ralleR ralle
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #258
                                      @ralle korrekt. Einmal iot und einmal lokal.
                                      • ralleR ralle
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #259
                                        @ralle in den Objekten von ioBroker. Admin-Ansicht.
                                        • SKBS SKB
                                          ralleR Offline
                                          ralleR Offline
                                          ralle
                                          #260
                                          meinst du das hier?
                                          nu hörts fast auf bei mir.... ich bin Anfänger in diesem Bereich mit dem Ras Pi.
                                          Wenn es einfacher ist würd ich lieber eine neue Version Installieren und die alte Config übernehmen. Ich glaube das mach dir weniger Kopfschmerzen.
                                          Ich habe verucht die alte Konfig zu speichern über den Button im Adapter, wenn ich dann aber unten auf wiederherstellen gehe erscheint nichts , bleibt leer.
                                          2)
                                          Wie oben mit Bild schon beschrieben warum habe ich auf einmal 2 mal den Adapter in der Übersicht, wie bekomme ich davon einen wieder weg ?
