  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 78 Kommentatoren 1.1m Aufrufe 78 Beobachtet
    @skb sagte in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
    Kannst du nochmals bewegen?
    hier hin 😁 ?
    SKBS Offline
    SKBS Offline
    SKB
    #242
    @homoran Alle Wege führen zur Alpha 🐕
    • SKBS SKB
      stephan61
      #243
      @skb
      es kommt folgende Meldung
      The page keeping the extension port is moved into back/forward cache, so the message channel is closed.
      Unchecked runtime.lastError: The page keeping the extension port is moved into back/forward cache, so the message channel is closed.
      Unchecked runtime.lastError: No last-focused window
      functions.min.js?v=0.5.4:1 Object
      functions.min.js?v=0.5.4:1 [Config] Using Instance: energiefluss-erweitert.0
      functions.min.js?v=0.5.4:1 [Language] Detected System-Languag: de-DE
      functions.min.js?v=0.5.4:1 [Socket] connected at 8.8.2024, 12:06:14
      functions.min.js?v=0.5.4:1 [Config] Using /thumbnail/ for userFiles!
      functions.min.js?v=0.5.4:1 [Language] Got from ioBroker! Translating Texts to locale de!
      functions.min.js?v=0.5.4:1 [Config] Loading config for instance: 0
      functions.min.js?v=0.5.4:1 [Version] Installed Version: 0.5.1-alpha.4
      functions.min.js?v=0.5.4:1 [Version] Github Version: 0.5.1-alpha.4
      functions.min.js?v=0.5.4:1 [Config] Trying to load configuration from state!
      functions.min.js?v=0.5.4:1 [Config] Using direct load via iconify-API!
      functions.min.js?v=0.5.4:1 Uncaught TypeError: Cannot convert undefined or null to object
      at Function.keys (<anonymous>)
      at functions.min.js?v=0.5.4:1:28361
      at Array.forEach (<anonymous>)
      at setLoadedConfig (functions.min.js?v=0.5.4:1:28293)
      at r.<anonymous> (functions.min.js?v=0.5.4:1:16940)
      at r.onack (index.js:83:1)
      at r.onpacket (index.js:83:1)
      at r.<anonymous> (index.js:83:1)
      at r.emit (index.js:83:1)
      at r.ondecoded (index.js:83:1)
      functions.min.js?v=0.5.4:1 Loaded additional file: js/iconify.min.js
      inlineForm.html:13 Unchecked runtime.lastError: You do not have a background page.
      configuration.html:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
      configuration.html:1 Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
      inlineForm.html:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
      inlineForm.html:1 Error in event handler: Error: invalid arguments to extensionAdapter.sendMessageToTab
      at e.sendMessageToTab (chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:65501)
      at e.handleMessage (chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:106817)
      at chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:103083
      at chrome-extension://caljgklbbfbcjjanaijlacgncafpegll/js/content/app/inlineForm/index.js:80:78040
      SKBS 1 Antwort Letzte Antwort
      • S stephan61
        @skb
        SKBS Offline
        SKBS Offline
        SKB
        #244
        @stephan61 Hast Du nach der Installation einen Upload gemacht?
        • SKBS SKB
          stephan61
          #245
          @skb
          ja habe upload gemacht
          ich wollte die Hintergrundfarbe ändern. habe ich dabei bei etwas zerstörrt
          • S stephan61
            @skb
            SKBS Offline
            SKBS Offline
            SKB
            #246
            @stephan61 Sieht für mich so aus, als wenn dort irgendwas nicht richtig geladen wird.
            Welchen Browser verwendest Du?
            Kannst Du die Konsole mal als Screenshot posten?
            • SKBS SKB
              stephan61
              #247
              @skb
              verwende chrome ist aber auch unter firefox oder opera
              • S stephan61
                @skb
                SKBS Offline
                SKBS Offline
                SKB
                #248
                @stephan61 Könntest Du mal den ersten Teil aus dem Datenpunkt configuration einstellen?
                So in etwas sieht das aus:
                "basic": {
                        "enable_grid": true,
                        "enable_animation": false,
                        "enable_area_catch": true,
                        "enable_config_icon": true,
                        "enable_fullscreen": false,
                        "enable_last_id": false,
                        "enable_icon_proxy": false,
                        "enable_low_performance": false,
                        "enable_ds_autocomplete": false,
                        "height": 540,
                        "width": 530,
                        "animation_timer": 1000,
                        "background_color": "",
                        "styles": "",
                        "font": {
                            "family": "\"Arial\", sans-serif",
                            "size": 20,
                            "align": "middle"
                        "rect": {
                            "height": 100,
                            "width": 100,
                            "corners": 10
                        "circle": {
                            "radius": 50
                        "elm": {
                            "stroke_width": 5,
                            "pos_x": 50,
                            "pos_y": 50
                        "icon": {
                            "width": 24,
                            "height": 24
                • SKBS SKB
                  @peter666666 Habe noch etwas verfeinert - du kannst gerne nochmals drüber installieren. Dann sollte der Fehler nicht mehr kommen (hoffe ich) ;)
                  Peter666666
                  #249
                  @skb Super hat geklappt!!
                  LG Peter
                  Intel NUC i5 / 16GB RAM / 512GB SSD
                  Synology DS220+ 10GB RAM / 8TB
                  • SKBS SKB
                    "basic": {
                            "height": 540,
                            "width": 530,
                            "styles": "",
                            "font": {
                                "size": 20,
                                "align": "middle"
                            "rect": {
                                "height": 100,
                                "width": 100,
                                "corners": 10
                            "circle": {
                                "radius": 50
                            "elm": {
                                "stroke_width": 5,
                                "pos_x": 50,
                                "pos_y": 50
                            "icon": {
                                "width": 24,
                                "height": 24
                    stephan61
                    schrieb am zuletzt editiert von stephan61
                    #250
                    @skb
                    Hallo SKB Background_color war null habe es auf "" geändert
                    jetzt geht es wieder
                    Habe es in Vis mit i Frame eingebunden
                    kann man das Zahnrad da entfernen?
                    • S stephan61
                      @skb
                      SKBS Offline
                      SKBS Offline
                      SKB
                      #251
                      @stephan61 Danke für den Hinweis. Habe eine Kontrolle angelegt, die prüft, ob die Werte vorhanden sind.
                      Das Zahnrad kann man in den Einstellungen ausblenden.
                      • SKBS SKB
                        @ralle Wir könnten auch fix versuchen, das Problem zu finden und dann kannst Du auch diese nutzen ;)
                        ralleR Offline
                        ralleR Offline
                        ralle
                        #252
                        @skb
                        @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                        Kann ich da irgend was zu Beitragen, brauchst du noch was ?
                        • ralleR ralle
                          @skb
                          SKBS Offline
                          SKBS Offline
                          SKB
                          #253
                          @ralle Gerne einmal den Datenpunkt configuration in Code-Tags einstellen. Schaue mir dann an, wo es klemmt.
                          ralleR 1 Antwort Letzte Antwort
                          • SKBS SKB
                            ralleR Offline
                            ralleR Offline
                            ralle
                            #254
                            wo finde ich diese, wie komme ich da dran ?
                            • ralleR ralle
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #255
                              @ralle Datenpunkt -> Objekte, energiefluss-erweitert, Instanz, configuration
                              Den Inhalt hier her kopieren.
                              • SKBS SKB
                                ralleR Offline
                                ralleR Offline
                                ralle
                                #256
                                ich bin verwirrt.... ich find nix. meinst du im IOBroker oder auf der SD Karte?
                                ralleR SKBS 2 Antworten Letzte Antwort
                                • ralleR ralle
                                  ralleR Offline
                                  ralleR Offline
                                  ralle
                                  #257
                                  @ralle said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                                  Wenn ich im IoB auf die Übersicht schaue sehe ich auch 2x den Adapter in der Version 0.5.1 alpha4!
                                  • ralleR ralle
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #258
                                    @ralle korrekt. Einmal iot und einmal lokal.
                                    • ralleR ralle
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #259
                                      @ralle in den Objekten von ioBroker. Admin-Ansicht.
                                      • SKBS SKB
                                        ralleR Offline
                                        ralleR Offline
                                        ralle
                                        #260
                                        meinst du das hier?
                                        nu hörts fast auf bei mir.... ich bin Anfänger in diesem Bereich mit dem Ras Pi.
                                        Wenn es einfacher ist würd ich lieber eine neue Version Installieren und die alte Config übernehmen. Ich glaube das mach dir weniger Kopfschmerzen.
                                        Ich habe verucht die alte Konfig zu speichern über den Button im Adapter, wenn ich dann aber unten auf wiederherstellen gehe erscheint nichts , bleibt leer.
                                        2)
                                        Wie oben mit Bild schon beschrieben warum habe ich auf einmal 2 mal den Adapter in der Übersicht, wie bekomme ich davon einen wieder weg ?
                                        • ralleR ralle
                                          meinst du das hier?
                                          2)
                                          SKBS Offline
                                          SKBS Offline
                                          SKB
                                          #261
                                          @ralle ja, auf der rechten Seite steht der Inhalt des Datenpunkt. Den brauche ich.
                                          Es sind 2 Instanzen da, weil du wohl auch 2 WebAdapter hast.
                                          Speichern in der Config heißt "Speichern" im Datenpunkt. Da wird keine Datei wie bei Word oder Excel lokal "gespeichert".
