  4. Test Adapter rpi2 2.x
    6.6k
519 Beiträge 29 Kommentatoren 195.0k Aufrufe 20 Beobachtet
  • L Laser
    @janga Nur die Instanz gelöscht. Werde das noch mal wiederholen.
    JanGa
    schrieb am zuletzt editiert von JanGa
    #101
    @laser Wenn du sichergehen willst, dass du den richtigen Adapter hast, dann installier den über die Shell mit
    iob upgrade rpi2@2.0.0
    bzw. wenn er gerade deinstalliert ist
    iob add rpi2@2.0.0
    L 1 Antwort Letzte Antwort
    • J JanGa
      iob add rpi2@2.0.0
      Laser
      #102
      @janga Noch mal den Adapter über die Shell installiert (vorher libgiod und Adapter gelöscht, rebot).
      rpi2.0
      2024-09-05 11:45:59.188	error	GPIO is not initialized!
      rpi2.0
      2024-09-05 11:45:56.857	error	GPIO is not initialized!
      rpi2.0
      2024-09-05 11:45:53.430	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
      rpi2.0
      2024-09-05 11:45:52.715	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 5.0.19
      rpi2.0
      2024-09-05 11:45:49.713	info	terminating
      rpi2.0
      2024-09-05 11:45:49.268	info	Terminated (NO_ERROR): Without reason
      rpi2.0
      2024-09-05 11:45:49.266	info	terminating
      rpi2.0
      2024-09-05 11:45:49.213	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
      rpi2.0
      2024-09-05 11:45:48.419	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 5.0.19
      rpi2.0
      2024-09-05 11:45:44.350	info	terminating
      rpi2.0
      2024-09-05 11:45:43.853	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      rpi2.0
      2024-09-05 11:45:43.851	info	terminating
      rpi2.0
      2024-09-05 11:45:43.845	info	Got terminate signal TERMINATE_YOURSELF
      rpi2.0
      2024-09-05 11:45:02.810	warn	Port 23 is configured as input and not writable
      rpi2.0
      2024-09-05 11:45:01.121	warn	Port 23 is configured as input and not writable
      rpi2.0
      2024-09-05 11:44:59.273	warn	Port 23 is configured as input and not writable
      rpi2.0
      2024-09-05 11:44:58.352	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
      Zuerst den GPIO23 falsch eingestellt, dann korrigiert. Versucht, den Ausgang zu setzen und den Eingang abzufragen. Klappt Beides nicht.
      J 1 Antwort Letzte Antwort
      • L Laser
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        rpi2.0
        JanGa
        #103
        @laser an der Stelle weiß ich jetzt leider auch nicht mehr weiter. Wir müssen da wohl eine Wortmeldung von @Garfonso warten.
        • J JanGa
          @searcher57 ist libgiod-dev auf dem System installiert? War es schon installiert, als der Adapter installiert wurde? Wenn nicht, Adapter deinstallieren, libgiod-dev installieren und Adapter wieder installieren!
          searcher57
          #104
          @janga said in Test Adapter rpi2 2.x:
          Danke, ja das habe ich alles schon gemacht.
          • S searcher57
            JanGa
            #105
            @searcher57 Was für einen Raspberry Pi benutzt du?
            • J JanGa
              searcher57
              #106
              Ich habe einen Raspi 5 im Einsatz. Aber mein Raspi 4 verhält sich genauso. Leider funktioniert nach wenigen Monaten der Freude über eine erfolgreiche Nachbesserung von @garfonso die APP wieder nicht!
              • S searcher57
                Laser
                #107
                @searcher57 Wird schon werden! Bevor ich jetzt Klimmzüge mit Scripten auf Debian Ebene mache, warte ich ab.
                • J Offline
                  JanGa
                  #108
                  @laser Es gibt auch noch die Möglichkeit eines Javascripts in IOBroker. Habe die Tage irgendwo einen Eintrag gesehen von jemanden, der GPIO ohne den Adapter benutzt hat. Finde das nur leider im Moment nicht...
                  Bei mir selbst geht der Kram im Moment auch nicht. In meinem Fall liegt es aber an der Art und Weise wie der Adapter bestimmt, welcher Raspberry Pi verwendet wird, und wie er diese Information dann so umsetzt, dass die verwendete GPIO-Bibliothek weiß, wie sie den Chip ansteuern muss. Ich habe einen Raspberry Pi Zero 2 W in einem Schalkasten im Garten und steuere damit die Beleuchtung. Leider kann man Zero 2 W nicht mit dem gleichen Regex in eine Nummer umwandeln wie Raspberry Pi 1,2,3,4 oder 5. Ich habe da auch schon eine Lösung für und habe einen Pull Request auf Github eingereicht. Ich bin nur leider zu unfähig, um meinen eigenen Fix bei mir einzuspielen ohne dass er im Repository ist. Bzw. ich hab einfach zu wenig Zeit, um mich in die IOBroker Adapterentwicklung tief genug einzuarbeiten. Stattdessen muss ich jetzt genau wie du warten, dass @Garfonso meinen oder einen anderen Fix einbaut. Schon bitter, wie hilflos man da ist. :D
                  L mcm1957M 2 Antworten Letzte Antwort
                  • J JanGa
                    Laser
                    #109
                    @janga Man kann Linux Befehle vom IO Broker ausführen. Aber das tue ich nur, wenn nichts Anderes geht. Das wird schnell unübersichtlich, wenn man das System neu aufsetzen muß, grübelt man erst mal, was man Alles umgestrickt hat. Adapter sind sind die bessere Lösung. Wenn Sie funktionieren.
                    • J JanGa
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #110
                      Ähmm
                      Blöde Frage - aber wie hast du den PR gestestet ohne die Codeänderung zu installieren ???
                      Installieren kannst du den von dir geänderten Adpapter jederzeit via "install from Github" von deinem geforkten Repository in dem du die Änderungen vorgenommen hast. (https://github.com/jangatzke/ioBroker.rpi2 ?)
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      HomoranH J 2 Antworten Letzte Antwort
                      • mcm1957M mcm1957
                        Ähmm
                        #111
                        @mcm1957 sagte in Test Adapter rpi2 2.x:
                        reicht es nicht die Instanz zu stoppen, die geänderte Datei im Adapterverzeichnis zu tauschen, dann ein upload zu machen und die Instanz wieder zu starten?
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #112
                          Natürlich - nur sollte man vermeiden direkt im Codetree rumzuwerken. Via GH Installtion hat man in diesem Fall die Sicherheit dass das was man vie PR einreicht auch selbst bei einem läuft :-)
                          • mcm1957M mcm1957
                            Ähmm
                            JanGa
                            #113
                            @mcm1957 Getestet habe ich das gar nicht. Nur weil ich in der Lage bin, drei Zeilen code zu verstehen und anzupassen, heißt das noch lange nicht, dass ich nicht zu dumm bin, diese Änderung in meine Installation einzuspielen. :D
                            Mit Install from Github hatte ich es schonmal versucht, habe aber nicht gerafft, wie ich da z.B. einen bestimmten Branch auswähle oder so. Das wirkte jedenfalls nicht selbsterklärend für mich und ich hab da außer Fehlermeldungen nichts zustande gebracht oder gar installiert. Ich habe fest vor mich da einzuarbeiten, werde das aber erst im Herbst angehen können, denke ich. Ich hänge auch noch als letzter aktiver "Entwickler" irgendwie beim MySensors Adapter mit drin und will den eigentlich auch nicht sterben lassen, Motivation ist also reichlich vorhanden, Knowhow aber fast keins.
                            • J JanGa
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #114
                              Sorry, wenn das so rübergekommen ist. Ich würde nie jemand als (zu) dumm bezeichnen. Das wär völlig unangemessen. Das einzige was ich mit meinem Post hinterfragen wollte ist ob du die Änderung getestest hast. Sorry - hätt ich höflicher formulieren können.
                              cli: iob install jangatzke/ioBroker.rpi2#new-gpio-lib
                              ui:
                              .. sollte gehen. UI Url wie auf der Github Seite wenn du den Branch selektierts.
                              Kanns aber konkret nicht testen, da mein Testsystem Windows basierend ist und da haperts mit den GPIOs ein wenig :-)
                              DANKE jedenfalls dass du dein Wissen einbringst.
                              mcm1957M J 2 Antworten Letzte Antwort
                              • mcm1957M mcm1957
                                ui:
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #115
                                Und wenn du Entwicklerhilfe suchst schau in den Telegramm Channels vorbei. Invites auf www.iobroker.dev.
                                • mcm1957M mcm1957
                                  ui:
                                  JanGa
                                  #116
                                  @mcm1957 Da war nichts negativ rübergekommen, das "dumm" war reine Selbstkritik von mir. Da habe ich mich wohl eher nicht gut ausgedrückt. :)
                                  Der Tipp mit der Raute dazwischen hilft schonmal. Ich werden mir das am Wochenende nochmal anschauen, danke für die Starthilfe!
                                  • J Offline
                                    JanGa
                                    #117
                                    @mcm1957 said in Test Adapter rpi2 2.x:
                                    Das ging bei mir nicht:
                                    jan@gartenhaus:/opt/iobroker $ iob install jangatzke/ioBroker.rpi2#new-gpio-lib
                                    Invalid adapter name for install
                                    iobroker install <adapter>
                                    Installs a specified adapter
                                    Options:
                                      --help  Show help  [boolean]
                                    Was ging:
                                    jan@gartenhaus:/opt/iobroker $ iob url https://github.com/jangatzke/ioBroker.rpi2/tree/new-gpio-lib
                                    NPM version: 10.8.2
                                    Installing jangatzke/ioBroker.rpi2#new-gpio-lib... (System call)
                                    changed 1 package in 17s
                                    72 packages are looking for funding
                                      run `npm fund` for details
                                    upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                                    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                    Bei mir hat es danach funktioniert mit dem dreckigen Patch für den Pi 2 Zero W, den ich geschrieben habe. Licht im Garten lässt sich wieder schalten. Ich habe noch einen Tippfehler korrigieren müssen (warm statt warn), von daher hat sich der Test gelohnt. Danke nochmal für die Hilfe.
                                    • J Offline
                                      JanGa
                                      #118
                                      @Laser @searcher57 Ich habe mich jetzt nochmal mit eurem Problem beschäftigt und ich bin mir sicher, dass bei euch beiden die Instanz nicht auf Debug eingestellt war, als ihr die Logs gezogen habt. Bei mir sieht ein Start so aus, wenn ich das Logging auf Debug stelle:
                                      2024-09-09 20:52:28.789  - info: host.powercount instance system.adapter.rpi2.0 in version "2.0.0" (non-npm: jangatzke/ioBroker.rpi2#new-gpio-lib) started with pid 58038
                                      2024-09-09 20:52:34.191  - debug: rpi2.0 (58038) Redis Objects: Use Redis connection: 192.168.69.227:9001
                                      2024-09-09 20:52:34.284  - debug: rpi2.0 (58038) Objects client ready ... initialize now
                                      2024-09-09 20:52:34.293  - debug: rpi2.0 (58038) Objects create System PubSub Client
                                      2024-09-09 20:52:34.296  - debug: rpi2.0 (58038) Objects create User PubSub Client
                                      2024-09-09 20:52:34.415  - debug: rpi2.0 (58038) Objects client initialize lua scripts
                                      2024-09-09 20:52:34.459  - debug: rpi2.0 (58038) Objects connected to redis: 192.168.69.227:9001
                                      2024-09-09 20:52:34.646  - debug: rpi2.0 (58038) Redis States: Use Redis connection: 192.168.69.227:9000
                                      2024-09-09 20:52:34.736  - debug: rpi2.0 (58038) States create System PubSub Client
                                      2024-09-09 20:52:34.739  - debug: rpi2.0 (58038) States create User PubSub Client
                                      2024-09-09 20:52:34.860  - debug: rpi2.0 (58038) States connected to redis: 192.168.69.227:9000
                                      2024-09-09 20:52:35.672  - info: rpi2.0 (58038) starting. Version 2.0.0 (non-npm: jangatzke/ioBroker.rpi2#new-gpio-lib) in /opt/iobroker/node_modules/iobroker.rpi2, node: v20.16.0, js-controller: 6.0.11
                                      2024-09-09 20:52:35.956  - debug: rpi2.0 (58038) received all objects
                                      2024-09-09 20:52:35.968  - debug: rpi2.0 (58038) cpu is enabled
                                      2024-09-09 20:52:35.972  - debug: rpi2.0 (58038) start parsing
                                      2024-09-09 20:52:35.975  - debug: rpi2.0 (58038) PARSING: cpu
                                      2024-09-09 20:52:35.977  - debug: rpi2.0 (58038)     PARSING: cpu_frequency
                                      2024-09-09 20:52:35.978  - debug: rpi2.0 (58038) ---> test -r /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq || test -r /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq || echo -1000
                                      2024-09-09 20:52:35.991  - debug: rpi2.0 (58038) ------------- 1000000
                                      2024-09-09 20:52:35.993  - debug: rpi2.0 (58038) ---> REGEXP: /(.*)/
                                      2024-09-09 20:52:35.994  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:35.996  - debug: rpi2.0 (58038) ---> POST:   $1/1000
                                      2024-09-09 20:52:35.997  - debug: rpi2.0 (58038)     PARSING: load1,load5,load15
                                      2024-09-09 20:52:35.998  - debug: rpi2.0 (58038) ---> cat /proc/loadavg
                                      2024-09-09 20:52:36.008  - debug: rpi2.0 (58038) ------------- 0.43 0.18 0.05 1/179 58056
                                      2024-09-09 20:52:36.010  - debug: rpi2.0 (58038) ---> REGEXP: /^(\S+)\s(\S+)\s(\S+)/
                                      2024-09-09 20:52:36.011  - debug: rpi2.0 (58038) GROUPS: 4
                                      2024-09-09 20:52:36.011  - debug: rpi2.0 (58038) MATCHING: 0.43
                                      2024-09-09 20:52:36.012  - debug: rpi2.0 (58038) NAME: load1, VALULE: 0.43
                                      2024-09-09 20:52:36.013  - debug: rpi2.0 (58038) MATCHING: 0.18
                                      2024-09-09 20:52:36.013  - debug: rpi2.0 (58038) NAME: load5, VALULE: 0.18
                                      2024-09-09 20:52:36.014  - debug: rpi2.0 (58038) MATCHING: 0.05
                                      2024-09-09 20:52:36.016  - debug: rpi2.0 (58038) NAME: load15, VALULE: 0.05
                                      2024-09-09 20:52:36.017  - debug: rpi2.0 (58038)     PARSING: scaling_governor
                                      2024-09-09 20:52:36.017  - debug: rpi2.0 (58038) ---> cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
                                      2024-09-09 20:52:36.030  - debug: rpi2.0 (58038) ------------- ondemand
                                      2024-09-09 20:52:36.031  - debug: rpi2.0 (58038) ---> REGEXP: /(.*)/
                                      2024-09-09 20:52:36.032  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.033  - debug: rpi2.0 (58038) ---> POST:
                                      2024-09-09 20:52:36.034  - debug: rpi2.0 (58038) PARSING: raspberry
                                      2024-09-09 20:52:36.034  - debug: rpi2.0 (58038)     PARSING: cpu_voltage
                                      2024-09-09 20:52:36.035  - debug: rpi2.0 (58038) ---> vcgencmd measure_volts core
                                      2024-09-09 20:52:36.049  - debug: rpi2.0 (58038) ------------- volt=1.2563V
                                      2024-09-09 20:52:36.050  - debug: rpi2.0 (58038) ---> REGEXP: /(\d+.\d+)V/
                                      2024-09-09 20:52:36.052  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.053  - debug: rpi2.0 (58038) ---> POST:
                                      2024-09-09 20:52:36.053  - debug: rpi2.0 (58038)     PARSING: mem_arm
                                      2024-09-09 20:52:36.054  - debug: rpi2.0 (58038) ---> vcgencmd get_mem arm
                                      2024-09-09 20:52:36.064  - debug: rpi2.0 (58038) ------------- arm=448M
                                      2024-09-09 20:52:36.066  - debug: rpi2.0 (58038) ---> REGEXP: /(\d+)/
                                      2024-09-09 20:52:36.066  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.067  - debug: rpi2.0 (58038) ---> POST:
                                      2024-09-09 20:52:36.068  - debug: rpi2.0 (58038)     PARSING: mem_gpu
                                      2024-09-09 20:52:36.068  - debug: rpi2.0 (58038) ---> vcgencmd get_mem gpu
                                      2024-09-09 20:52:36.078  - debug: rpi2.0 (58038) ------------- gpu=64M
                                      2024-09-09 20:52:36.080  - debug: rpi2.0 (58038) ---> REGEXP: /(\d+)/
                                      2024-09-09 20:52:36.081  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.081  - debug: rpi2.0 (58038) ---> POST:
                                      2024-09-09 20:52:36.082  - debug: rpi2.0 (58038) PARSING: memory
                                      2024-09-09 20:52:36.083  - debug: rpi2.0 (58038) PARSING: network
                                      2024-09-09 20:52:36.087  - debug: rpi2.0 (58038) PARSING: sdcard
                                      2024-09-09 20:52:36.087  - debug: rpi2.0 (58038) PARSING: swap
                                      2024-09-09 20:52:36.088  - debug: rpi2.0 (58038)     PARSING: swap_total
                                      2024-09-09 20:52:36.089  - debug: rpi2.0 (58038) ---> cat /proc/meminfo
                                      2024-09-09 20:52:36.099  - debug: rpi2.0 (58038) ------------- MemTotal:         427072 kB
                                      MemFree:          135832 kB
                                      MemAvailable:     183856 kB
                                      Buffers:            5216 kB
                                      Cached:            78648 kB
                                      SwapCached:        14512 kB
                                      Active:           164920 kB
                                      Inactive:          59784 kB
                                      Active(anon):     102728 kB
                                      Inactive(anon):    38276 kB
                                      Active(file):      62192 kB
                                      Inactive(file):    21508 kB
                                      Unevictable:           0 kB
                                      Mlocked:               0 kB
                                      SwapTotal:        204796 kB
                                      SwapFree:         123228 kB
                                      Zswap:                 0 kB
                                      Zswapped:              0 kB
                                      Dirty:                48 kB
                                      Writeback:             0 kB
                                      AnonPages:        139332 kB
                                      Mapped:            61836 kB
                                      Shmem:               164 kB
                                      KReclaimable:      19016 kB
                                      Slab:              41388 kB
                                      SReclaimable:      19016 kB
                                      SUnreclaim:        22372 kB
                                      KernelStack:        2916 kB
                                      PageTables:         2768 kB
                                      SecPageTables:         0 kB
                                      NFS_Unstable:          0 kB
                                      Bounce:                0 kB
                                      WritebackTmp:          0 kB
                                      CommitLimit:      418332 kB
                                      Committed_AS:     500112 kB
                                      VmallocTotal:   257687552 kB
                                      VmallocUsed:       10436 kB
                                      VmallocChunk:          0 kB
                                      Percpu:              672 kB
                                      CmaTotal:         262144 kB
                                      CmaFree:          100824 kB
                                      2024-09-09 20:52:36.101  - debug: rpi2.0 (58038) ---> REGEXP: /SwapTotal:\s+(\d+)/m
                                      2024-09-09 20:52:36.102  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.103  - debug: rpi2.0 (58038) ---> POST:   $1/1024
                                      2024-09-09 20:52:36.103  - debug: rpi2.0 (58038)     PARSING: swap_used
                                      2024-09-09 20:52:36.104  - debug: rpi2.0 (58038) ---> cat /proc/meminfo
                                      2024-09-09 20:52:36.115  - debug: rpi2.0 (58038) ------------- MemTotal:         427072 kB
                                      MemFree:          135708 kB
                                      MemAvailable:     183744 kB
                                      Buffers:            5216 kB
                                      Cached:            78660 kB
                                      Active:           164932 kB
                                      Inactive:          59784 kB
                                      Active(file):      62204 kB
                                      Unevictable:           0 kB
                                      Mlocked:               0 kB
                                      SwapFree:         123228 kB
                                      Zswap:                 0 kB
                                      Zswapped:              0 kB
                                      Dirty:                48 kB
                                      Writeback:             0 kB
                                      AnonPages:        139356 kB
                                      Mapped:            61836 kB
                                      Shmem:               164 kB
                                      Slab:              41388 kB
                                      KernelStack:        2912 kB
                                      PageTables:         2768 kB
                                      SecPageTables:         0 kB
                                      NFS_Unstable:          0 kB
                                      Bounce:                0 kB
                                      WritebackTmp:          0 kB
                                      VmallocChunk:          0 kB
                                      Percpu:              672 kB
                                      CmaTotal:         262144 kB
                                      CmaFree:          100824 kB
                                      2024-09-09 20:52:36.116  - debug: rpi2.0 (58038) ---> REGEXP: /SwapFree:\s+(\d+)/m
                                      2024-09-09 20:52:36.117  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.118  - debug: rpi2.0 (58038) ---> POST:   (rpi.swap_total - $1)/1024
                                      2024-09-09 20:52:36.118  - debug: rpi2.0 (58038) PARSING: temperature
                                      2024-09-09 20:52:36.119  - debug: rpi2.0 (58038)     PARSING: soc_temp
                                      2024-09-09 20:52:36.120  - debug: rpi2.0 (58038) ---> cat /sys/devices/virtual/thermal/thermal_zone0/temp
                                      2024-09-09 20:52:36.131  - debug: rpi2.0 (58038) ------------- 49388
                                      2024-09-09 20:52:36.132  - debug: rpi2.0 (58038) ---> REGEXP: /(.*)/
                                      2024-09-09 20:52:36.133  - debug: rpi2.0 (58038) GROUPS: 2
                                      2024-09-09 20:52:36.134  - debug: rpi2.0 (58038) ---> POST:   $1/1000
                                      2024-09-09 20:52:36.134  - debug: rpi2.0 (58038) PARSING: uptime
                                      2024-09-09 20:52:36.135  - debug: rpi2.0 (58038) PARSING: wlan
                                      2024-09-09 20:52:36.136  - debug: rpi2.0 (58038) CURRENT = cpu true
                                      2024-09-09 20:52:36.136  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:36.195  - debug: rpi2.0 (58038) ---> POST:   $1/1000 for cpu_frequency in [object Object]
                                      2024-09-09 20:52:36.196  - debug: rpi2.0 (58038) VALUE: 1000000 POST: $1/1000
                                      2024-09-09 20:52:36.197  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1000
                                      2024-09-09 20:52:36.297  - debug: rpi2.0 (58038) ---> POST:    for load1,load5,load15 in [object Object]
                                      2024-09-09 20:52:36.299  - debug: rpi2.0 (58038) MATCHING: 0.43
                                      2024-09-09 20:52:36.299  - debug: rpi2.0 (58038) NAME: load1 VALUE: 0.43
                                      2024-09-09 20:52:36.300  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0.43
                                      2024-09-09 20:52:36.391  - debug: rpi2.0 (58038) MATCHING: 0.18
                                      2024-09-09 20:52:36.392  - debug: rpi2.0 (58038) NAME: load5 VALUE: 0.18
                                      2024-09-09 20:52:36.392  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.18
                                      2024-09-09 20:52:36.502  - debug: rpi2.0 (58038) MATCHING: 0.05
                                      2024-09-09 20:52:36.504  - debug: rpi2.0 (58038) NAME: load15 VALUE: 0.05
                                      2024-09-09 20:52:36.505  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.05
                                      2024-09-09 20:52:36.588  - debug: rpi2.0 (58038) ---> POST:    for scaling_governor in [object Object]
                                      2024-09-09 20:52:36.590  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
                                      2024-09-09 20:52:36.665  - debug: rpi2.0 (58038) CURRENT = raspberry true
                                      2024-09-09 20:52:36.667  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:36.689  - debug: rpi2.0 (58038) ---> POST:    for cpu_voltage in [object Object]
                                      2024-09-09 20:52:36.690  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.raspberry.cpu_voltage VALUE = 1.26
                                      2024-09-09 20:52:36.785  - debug: rpi2.0 (58038) ---> POST:    for mem_arm in [object Object]
                                      2024-09-09 20:52:36.787  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.raspberry.mem_arm VALUE = 448
                                      2024-09-09 20:52:37.062  - debug: rpi2.0 (58038) ---> POST:    for mem_gpu in [object Object]
                                      2024-09-09 20:52:37.063  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.raspberry.mem_gpu VALUE = 64
                                      2024-09-09 20:52:37.156  - debug: rpi2.0 (58038) CURRENT = memory false
                                      2024-09-09 20:52:37.157  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.158  - debug: rpi2.0 (58038) memory disabled -> clean up.
                                      2024-09-09 20:52:37.158  - debug: rpi2.0 (58038) CURRENT = network false
                                      2024-09-09 20:52:37.159  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.159  - debug: rpi2.0 (58038) network disabled -> clean up.
                                      2024-09-09 20:52:37.160  - debug: rpi2.0 (58038) CURRENT = sdcard false
                                      2024-09-09 20:52:37.161  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.161  - debug: rpi2.0 (58038) sdcard disabled -> clean up.
                                      2024-09-09 20:52:37.162  - debug: rpi2.0 (58038) CURRENT = swap true
                                      2024-09-09 20:52:37.162  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.207  - debug: rpi2.0 (58038) ---> POST:   $1/1024 for swap_total in [object Object]
                                      2024-09-09 20:52:37.209  - debug: rpi2.0 (58038) VALUE: 204796 POST: $1/1024
                                      2024-09-09 20:52:37.210  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.swap.swap_total VALUE = 200
                                      2024-09-09 20:52:37.278  - debug: rpi2.0 (58038) ---> POST:   (rpi.swap_total - $1)/1024 for swap_used in [object Object]
                                      2024-09-09 20:52:37.279  - debug: rpi2.0 (58038) VALUE: 123228 POST: (rpi.swap_total - $1)/1024
                                      2024-09-09 20:52:37.281  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.swap.swap_used VALUE = 79.66
                                      2024-09-09 20:52:37.356  - debug: rpi2.0 (58038) CURRENT = temperature true
                                      2024-09-09 20:52:37.357  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.391  - debug: rpi2.0 (58038) ---> POST:   $1/1000 for soc_temp in [object Object]
                                      2024-09-09 20:52:37.392  - debug: rpi2.0 (58038) VALUE: 49388 POST: $1/1000
                                      2024-09-09 20:52:37.393  - debug: rpi2.0 (58038) SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 49.39
                                      2024-09-09 20:52:37.729  - debug: rpi2.0 (58038) CURRENT = uptime false
                                      2024-09-09 20:52:37.731  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.732  - debug: rpi2.0 (58038) uptime disabled -> clean up.
                                      2024-09-09 20:52:37.733  - debug: rpi2.0 (58038) CURRENT = wlan false
                                      2024-09-09 20:52:37.734  - debug: rpi2.0 (58038) -1
                                      2024-09-09 20:52:37.735  - debug: rpi2.0 (58038) wlan disabled -> clean up.
                                      2024-09-09 20:52:39.558  - debug: rpi2.0 (58038) Creating gpio.17.isInput
                                      2024-09-09 20:52:40.718  - debug: rpi2.0 (58038) class Default extends classes_1.Device {
                                      2024-09-09 20:52:40.734  - debug: rpi2.0 (58038) CPU Info: Raspberry Pi Zero 2 W Rev 1.0
                                      2024-09-09 20:52:40.736  - debug: rpi2.0 (58038) STDERR:
                                      2024-09-09 20:52:40.737  - debug: rpi2.0 (58038) Got 1 from Raspberry Pi Zero 2 W Rev 1.0.
                                      2024-09-09 20:52:40.738  - debug: rpi2.0 (58038) Inputs are pull down.
                                      2024-09-09 20:52:40.738  - debug: rpi2.0 (58038) Buttons are pull down.
                                      2024-09-09 20:52:40.739  - debug: rpi2.0 (58038) Got chip: class Default extends classes_1.Device {
                                      2024-09-09 20:52:40.739  - debug: rpi2.0 (58038) GPIO chip undefined initialized
                                      2024-09-09 20:52:40.740  - debug: rpi2.0 (58038) Port 17 direction: in
                                      2024-09-09 20:52:40.756  - debug: rpi2.0 (58038) Setting state for port 17 to false
                                      2024-09-09 20:52:40.828  - debug: rpi2.0 (58038) Adding event listener for port 17
                                      Bei euch sehe ich keinen einzigen Eintrag der Stufe "debug". Ihr müsst unter Instanzen bei aktiviertem Expertenmodus das Loglevel der Instanz auf Debug stellen!
                                      Der Adapter startet dann neu und beim Start sollten entsprechende Einträge angezeigt werden. Eventuell sehen wir dann etwas, das uns dabei weiterhilft, das Problem einzugrenzen.
                                      • J JanGa
                                        MemFree:          135832 kB
                                        Buffers:            5216 kB
                                        Cached:            78648 kB
                                        Active:           164920 kB
                                        Inactive:          59784 kB
                                        Unevictable:           0 kB
                                        Mlocked:               0 kB
                                        SwapFree:         123228 kB
                                        Zswap:                 0 kB
                                        Zswapped:              0 kB
                                        Dirty:                48 kB
                                        Writeback:             0 kB
                                        Mapped:            61836 kB
                                        Shmem:               164 kB
                                        Slab:              41388 kB
                                        PageTables:         2768 kB
                                        SecPageTables:         0 kB
                                        NFS_Unstable:          0 kB
                                        Bounce:                0 kB
                                        WritebackTmp:          0 kB
                                        VmallocChunk:          0 kB
                                        Percpu:              672 kB
                                        CmaTotal:         262144 kB
                                        CmaFree:          100824 kB
                                        MemFree:          135708 kB
                                        Buffers:            5216 kB
                                        Cached:            78660 kB
                                        Active:           164932 kB
                                        Inactive:          59784 kB
                                        Unevictable:           0 kB
                                        Mlocked:               0 kB
                                        SwapFree:         123228 kB
                                        Zswap:                 0 kB
                                        Zswapped:              0 kB
                                        Dirty:                48 kB
                                        Writeback:             0 kB
                                        Mapped:            61836 kB
                                        Shmem:               164 kB
                                        Slab:              41388 kB
                                        PageTables:         2768 kB
                                        SecPageTables:         0 kB
                                        NFS_Unstable:          0 kB
                                        Bounce:                0 kB
                                        WritebackTmp:          0 kB
                                        VmallocChunk:          0 kB
                                        Percpu:              672 kB
                                        CmaTotal:         262144 kB
                                        CmaFree:          100824 kB
                                        Laser
                                        #119
                                        @janga erwischt. Nach dem Neuinstallieren habe ich das tatsächlich vergessen!
                                        rpi2.0
                                        2024-09-10 09:51:44.645	debug	SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 0
                                        rpi2.0
                                        2024-09-10 09:51:44.645	debug	---> POST: for wifi_send in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.594	debug	SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = 0
                                        rpi2.0
                                        2024-09-10 09:51:44.594	debug	VALUE: 0 POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:51:44.593	debug	---> POST: $1*-1 for wifi_received in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.593	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.593	debug	CURRENT = wlan true
                                        rpi2.0
                                        2024-09-10 09:51:44.542	debug	SETSTATE FOR rpi2.0.uptime.uptime VALUE = 425931.67
                                        rpi2.0
                                        2024-09-10 09:51:44.542	debug	---> POST: for uptime in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.541	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.541	debug	CURRENT = uptime true
                                        rpi2.0
                                        2024-09-10 09:51:44.492	debug	SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 44.3
                                        rpi2.0
                                        2024-09-10 09:51:44.492	debug	VALUE: 44303 POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:51:44.491	debug	---> POST: $1/1000 for soc_temp in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.490	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.489	debug	CURRENT = temperature true
                                        rpi2.0
                                        2024-09-10 09:51:44.438	debug	SETSTATE FOR rpi2.0.swap.swap_used VALUE = 193.64
                                        rpi2.0
                                        2024-09-10 09:51:44.437	debug	VALUE: 6512 POST: (rpi.swap_total - $1)/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.437	debug	---> POST: (rpi.swap_total - $1)/1024 for swap_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.386	debug	SETSTATE FOR rpi2.0.swap.swap_total VALUE = 200
                                        rpi2.0
                                        2024-09-10 09:51:44.386	debug	VALUE: 204796 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.385	debug	---> POST: $1/1024 for swap_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.385	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.385	debug	CURRENT = swap true
                                        rpi2.0
                                        2024-09-10 09:51:44.334	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_boot_used VALUE = 63.14
                                        rpi2.0
                                        2024-09-10 09:51:44.333	debug	VALUE: 64654 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.333	debug	---> POST: $1/1024 for sdcard_boot_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.282	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_root_used VALUE = 5695.19
                                        rpi2.0
                                        2024-09-10 09:51:44.281	debug	VALUE: 5831872 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.281	debug	---> POST: $1/1024 for sdcard_root_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.230	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_boot_total VALUE = 509.99
                                        rpi2.0
                                        2024-09-10 09:51:44.230	debug	VALUE: 522230 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.229	debug	---> POST: $1/1024 for sdcard_boot_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.178	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_root_total VALUE = 29433.42
                                        rpi2.0
                                        2024-09-10 09:51:44.178	debug	VALUE: 30139824 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.177	debug	---> POST: $1/1024 for sdcard_root_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.177	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.177	debug	CURRENT = sdcard true
                                        rpi2.0
                                        2024-09-10 09:51:44.129	debug	SETSTATE FOR rpi2.0.network.net_send VALUE = 162852985
                                        rpi2.0
                                        2024-09-10 09:51:44.129	debug	---> POST: for net_send in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.078	debug	SETSTATE FOR rpi2.0.network.net_received VALUE = -148363631
                                        rpi2.0
                                        2024-09-10 09:51:44.078	debug	VALUE: 148363631 POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:51:44.077	debug	---> POST: $1*-1 for net_received in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:44.077	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:44.077	debug	CURRENT = network true
                                        rpi2.0
                                        2024-09-10 09:51:44.026	debug	SETSTATE FOR rpi2.0.memory.memory_available VALUE = 1060.11
                                        rpi2.0
                                        2024-09-10 09:51:44.025	debug	VALUE: 1085556 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:44.025	debug	---> POST: $1/1024 for memory_available in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.976	debug	SETSTATE FOR rpi2.0.memory.memory_free VALUE = 518.15
                                        rpi2.0
                                        2024-09-10 09:51:43.975	debug	VALUE: 530588 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.973	debug	---> POST: $1/1024 for memory_free in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.919	debug	SETSTATE FOR rpi2.0.memory.memory_total VALUE = 1846.94
                                        rpi2.0
                                        2024-09-10 09:51:43.919	debug	VALUE: 1891264 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.919	debug	---> POST: $1/1024 for memory_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.919	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:43.918	debug	CURRENT = memory true
                                        rpi2.0
                                        2024-09-10 09:51:43.918	debug	raspberry disabled -> clean up.
                                        rpi2.0
                                        2024-09-10 09:51:43.918	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:43.917	debug	CURRENT = raspberry false
                                        rpi2.0
                                        2024-09-10 09:51:43.869	debug	SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
                                        rpi2.0
                                        2024-09-10 09:51:43.869	debug	---> POST: for scaling_governor in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.817	debug	SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.09
                                        rpi2.0
                                        2024-09-10 09:51:43.817	debug	NAME: load15 VALUE: 0.09
                                        rpi2.0
                                        2024-09-10 09:51:43.817	debug	MATCHING: 0.09
                                        rpi2.0
                                        2024-09-10 09:51:43.766	debug	SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.23
                                        rpi2.0
                                        2024-09-10 09:51:43.766	debug	NAME: load5 VALUE: 0.23
                                        rpi2.0
                                        2024-09-10 09:51:43.766	debug	MATCHING: 0.23
                                        rpi2.0
                                        2024-09-10 09:51:43.715	debug	SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0.45
                                        rpi2.0
                                        2024-09-10 09:51:43.714	debug	NAME: load1 VALUE: 0.45
                                        rpi2.0
                                        2024-09-10 09:51:43.714	debug	MATCHING: 0.45
                                        rpi2.0
                                        2024-09-10 09:51:43.713	debug	---> POST: for load1,load5,load15 in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.592	debug	SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1000
                                        rpi2.0
                                        2024-09-10 09:51:43.592	debug	VALUE: 1000000 POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:51:43.591	debug	---> POST: $1/1000 for cpu_frequency in [object Object]
                                        rpi2.0
                                        2024-09-10 09:51:43.591	debug	-1
                                        rpi2.0
                                        2024-09-10 09:51:43.591	debug	CURRENT = cpu true
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:51:43.591	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.590	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.590	debug	------------- 0
                                        rpi2.0
                                        2024-09-10 09:51:43.584	debug	---> cat /sys/class/net/wl*/statistics/tx_bytes
                                        rpi2.0
                                        2024-09-10 09:51:43.583	debug	PARSING: wifi_send
                                        rpi2.0
                                        2024-09-10 09:51:43.583	debug	---> POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:51:43.583	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.583	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.582	debug	------------- 0
                                        rpi2.0
                                        2024-09-10 09:51:43.576	debug	---> cat /sys/class/net/wl*/statistics/rx_bytes
                                        rpi2.0
                                        2024-09-10 09:51:43.576	debug	PARSING: wifi_received
                                        rpi2.0
                                        2024-09-10 09:51:43.576	debug	PARSING: wlan
                                        rpi2.0
                                        2024-09-10 09:51:43.576	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:51:43.575	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.575	debug	---> REGEXP: /(^\S+)/
                                        rpi2.0
                                        2024-09-10 09:51:43.574	debug	------------- 425931.67 1682350.61
                                        rpi2.0
                                        2024-09-10 09:51:43.569	debug	---> cat /proc/uptime
                                        rpi2.0
                                        2024-09-10 09:51:43.568	debug	PARSING: uptime
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:51:43.568	debug	---> POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:51:43.568	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.567	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.567	debug	------------- 44303
                                        rpi2.0
                                        2024-09-10 09:51:43.561	debug	---> cat /sys/devices/virtual/thermal/thermal_zone0/temp
                                        rpi2.0
                                        2024-09-10 09:51:43.561	debug	PARSING: soc_temp
                                        rpi2.0
                                        2024-09-10 09:51:43.561	debug	PARSING: temperature
                                        rpi2.0
                                        2024-09-10 09:51:43.560	debug	---> POST: (rpi.swap_total - $1)/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.560	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.560	debug	---> REGEXP: /SwapFree:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:51:43.559	debug	------------- MemTotal: 1891264 kB MemFree: 530476 kB MemAvailable: 1085244 kB Buffers: 81316 kB Cached: 503460 kB SwapCached: 1752 kB Active: 518280 kB Inactive: 732276 kB Active(anon): 463680 kB Inactive(anon): 202124 kB Active(file): 54600 kB Inactive(file): 530152 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6512 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 8 kB Writeback: 0 kB AnonPages: 664072 kB Mapped: 86884 kB Shmem: 24 kB KReclaimable: 38220 kB Slab: 62988 kB SReclaimable: 38220 kB SUnreclaim: 24768 kB KernelStack: 4392 kB PageTables: 6528 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553468 kB VmallocTotal: 257687552 kB VmallocUsed: 12016 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:51:43.553	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:51:43.552	debug	PARSING: swap_used
                                        rpi2.0
                                        2024-09-10 09:51:43.552	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.551	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.551	debug	---> REGEXP: /SwapTotal:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:51:43.550	debug	------------- MemTotal: 1891264 kB MemFree: 530728 kB MemAvailable: 1085496 kB Buffers: 81316 kB Cached: 503460 kB SwapCached: 1752 kB Active: 518180 kB Inactive: 732276 kB Active(anon): 463580 kB Inactive(anon): 202124 kB Active(file): 54600 kB Inactive(file): 530152 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6512 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 8 kB Writeback: 0 kB AnonPages: 663972 kB Mapped: 86884 kB Shmem: 24 kB KReclaimable: 38220 kB Slab: 62988 kB SReclaimable: 38220 kB SUnreclaim: 24768 kB KernelStack: 4392 kB PageTables: 6428 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553468 kB VmallocTotal: 257687552 kB VmallocUsed: 12016 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:51:43.542	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:51:43.541	debug	PARSING: swap_total
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:51:43.541	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.540	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.540	debug	---> REGEXP: /\S+\s+\d+\s+(\d+).*\/boot/m
                                        rpi2.0
                                        2024-09-10 09:51:43.538	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% /
                                        rpi2.0
                                        2024-09-10 09:51:43.528	debug	---> df /boot/*
                                        rpi2.0
                                        2024-09-10 09:51:43.528	debug	PARSING: sdcard_boot_used
                                        rpi2.0
                                        2024-09-10 09:51:43.528	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.527	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.527	debug	---> REGEXP: /\S+\s+\d+\s+(\d+).*\/$/m
                                        rpi2.0
                                        2024-09-10 09:51:43.526	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831872 22757424 21% /
                                        rpi2.0
                                        2024-09-10 09:51:43.517	debug	---> df /
                                        rpi2.0
                                        2024-09-10 09:51:43.516	debug	PARSING: sdcard_root_used
                                        rpi2.0
                                        2024-09-10 09:51:43.516	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.516	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.515	debug	---> REGEXP: /\S+\s+(\d+).*\/boot/m
                                        rpi2.0
                                        2024-09-10 09:51:43.513	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% / /dev/mmcblk0p2 30139824 5831872 22757424 21% /
                                        rpi2.0
                                        2024-09-10 09:51:43.504	debug	---> df /boot/*
                                        rpi2.0
                                        2024-09-10 09:51:43.503	debug	PARSING: sdcard_boot_total
                                        rpi2.0
                                        2024-09-10 09:51:43.503	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.502	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.501	debug	---> REGEXP: /\S+\s+(\d+).*\/$/m
                                        rpi2.0
                                        2024-09-10 09:51:43.500	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831872 22757424 21% /
                                        rpi2.0
                                        2024-09-10 09:51:43.490	debug	---> df /
                                        rpi2.0
                                        2024-09-10 09:51:43.489	debug	PARSING: sdcard_root_total
                                        rpi2.0
                                        2024-09-10 09:51:43.488	debug	PARSING: sdcard
                                        rpi2.0
                                        2024-09-10 09:51:43.484	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:51:43.481	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.480	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.480	debug	------------- 162852985
                                        rpi2.0
                                        2024-09-10 09:51:43.470	debug	---> cat /sys/class/net/e*/statistics/tx_bytes
                                        rpi2.0
                                        2024-09-10 09:51:43.470	debug	PARSING: net_send
                                        rpi2.0
                                        2024-09-10 09:51:43.469	debug	---> POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:51:43.469	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.469	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.468	debug	------------- 148363631
                                        rpi2.0
                                        2024-09-10 09:51:43.460	debug	---> cat /sys/class/net/e*/statistics/rx_bytes
                                        rpi2.0
                                        2024-09-10 09:51:43.460	debug	PARSING: net_received
                                        rpi2.0
                                        2024-09-10 09:51:43.459	debug	PARSING: network
                                        rpi2.0
                                        2024-09-10 09:51:43.459	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.459	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.458	debug	---> REGEXP: /MemAvailable:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:51:43.457	debug	------------- MemTotal: 1891264 kB MemFree: 530788 kB MemAvailable: 1085556 kB Buffers: 81316 kB Cached: 503460 kB SwapCached: 1752 kB Active: 518080 kB Inactive: 732276 kB Active(anon): 463480 kB Inactive(anon): 202124 kB Active(file): 54600 kB Inactive(file): 530152 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6512 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 8 kB Writeback: 0 kB AnonPages: 663772 kB Mapped: 86884 kB Shmem: 24 kB KReclaimable: 38220 kB Slab: 62988 kB SReclaimable: 38220 kB SUnreclaim: 24768 kB KernelStack: 4364 kB PageTables: 6428 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553468 kB VmallocTotal: 257687552 kB VmallocUsed: 12000 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:51:43.448	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:51:43.448	debug	PARSING: memory_available
                                        rpi2.0
                                        2024-09-10 09:51:43.447	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.447	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.447	debug	---> REGEXP: /MemFree:\s+(\d+)/
                                        rpi2.0
                                        2024-09-10 09:51:43.445	debug	------------- MemTotal: 1891264 kB MemFree: 530588 kB MemAvailable: 1085356 kB Buffers: 81316 kB Cached: 503460 kB SwapCached: 1752 kB Active: 517780 kB Inactive: 732276 kB Active(anon): 463180 kB Inactive(anon): 202124 kB Active(file): 54600 kB Inactive(file): 530152 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6512 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 8 kB Writeback: 0 kB AnonPages: 663672 kB Mapped: 86884 kB Shmem: 24 kB KReclaimable: 38220 kB Slab: 62988 kB SReclaimable: 38220 kB SUnreclaim: 24768 kB KernelStack: 4364 kB PageTables: 6428 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553468 kB VmallocTotal: 257687552 kB VmallocUsed: 12000 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:51:43.437	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:51:43.436	debug	PARSING: memory_free
                                        rpi2.0
                                        2024-09-10 09:51:43.436	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:51:43.436	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.435	debug	---> REGEXP: /MemTotal:\s+(\d+)/
                                        rpi2.0
                                        2024-09-10 09:51:43.434	debug	------------- MemTotal: 1891264 kB MemFree: 530840 kB MemAvailable: 1085608 kB Buffers: 81316 kB Cached: 503460 kB SwapCached: 1752 kB Active: 517680 kB Inactive: 732276 kB Active(anon): 463080 kB Inactive(anon): 202124 kB Active(file): 54600 kB Inactive(file): 530152 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6512 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 8 kB Writeback: 0 kB AnonPages: 663572 kB Mapped: 86884 kB Shmem: 24 kB KReclaimable: 38220 kB Slab: 62988 kB SReclaimable: 38220 kB SUnreclaim: 24768 kB KernelStack: 4364 kB PageTables: 6428 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553468 kB VmallocTotal: 257687552 kB VmallocUsed: 11984 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:51:43.425	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:51:43.425	debug	PARSING: memory_total
                                        rpi2.0
                                        2024-09-10 09:51:43.424	debug	PARSING: memory
                                        rpi2.0
                                        2024-09-10 09:51:43.424	debug	PARSING: raspberry
                                        rpi2.0
                                        2024-09-10 09:51:43.424	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:51:43.423	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.423	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.422	debug	------------- ondemand
                                        rpi2.0
                                        2024-09-10 09:51:43.413	debug	---> cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
                                        rpi2.0
                                        2024-09-10 09:51:43.413	debug	PARSING: scaling_governor
                                        rpi2.0
                                        2024-09-10 09:51:43.412	debug	NAME: load15, VALULE: 0.09
                                        rpi2.0
                                        2024-09-10 09:51:43.412	debug	MATCHING: 0.09
                                        rpi2.0
                                        2024-09-10 09:51:43.412	debug	NAME: load5, VALULE: 0.23
                                        rpi2.0
                                        2024-09-10 09:51:43.411	debug	MATCHING: 0.23
                                        rpi2.0
                                        2024-09-10 09:51:43.411	debug	NAME: load1, VALULE: 0.45
                                        rpi2.0
                                        2024-09-10 09:51:43.411	debug	MATCHING: 0.45
                                        rpi2.0
                                        2024-09-10 09:51:43.410	debug	GROUPS: 4
                                        rpi2.0
                                        2024-09-10 09:51:43.410	debug	---> REGEXP: /^(\S+)\s(\S+)\s(\S+)/
                                        rpi2.0
                                        2024-09-10 09:51:43.409	debug	------------- 0.45 0.23 0.09 1/270 523196
                                        rpi2.0
                                        2024-09-10 09:51:43.400	debug	---> cat /proc/loadavg
                                        rpi2.0
                                        2024-09-10 09:51:43.400	debug	PARSING: load1,load5,load15
                                        rpi2.0
                                        2024-09-10 09:51:43.399	debug	---> POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:51:43.399	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:51:43.398	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:51:43.398	debug	------------- 1000000
                                        rpi2.0
                                        2024-09-10 09:51:43.389	debug	---> test -r /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/cpuinfo_cur_freq || test -r /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq && cat /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq || echo -1000
                                        rpi2.0
                                        2024-09-10 09:51:43.388	debug	PARSING: cpu_frequency
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:51:43.386	debug	start parsing
                                        rpi2.0
                                        2024-09-10 09:50:45.318	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
                                        rpi2.0
                                        2024-09-10 09:50:45.318	debug	Port 23 direction: out
                                        rpi2.0
                                        2024-09-10 09:50:45.317	debug	GPIO chip undefined initialized
                                        rpi2.0
                                        2024-09-10 09:50:45.317	debug	Got chip: undefined
                                        rpi2.0
                                        2024-09-10 09:50:45.317	debug	Buttons are pull down.
                                        rpi2.0
                                        2024-09-10 09:50:45.317	debug	Inputs are pull down.
                                        rpi2.0
                                        2024-09-10 09:50:45.317	debug	Got 4 from Raspberry Pi 4 Model B Rev 1.4.
                                        rpi2.0
                                        2024-09-10 09:50:45.316	debug	STDERR:
                                        rpi2.0
                                        2024-09-10 09:50:45.315	debug	CPU Info: Raspberry Pi 4 Model B Rev 1.4
                                        rpi2.0
                                        2024-09-10 09:50:45.307	debug	undefined
                                        rpi2.0
                                        2024-09-10 09:50:45.113	debug	Creating gpio.24.isInput
                                        rpi2.0
                                        2024-09-10 09:50:45.080	debug	Creating gpio.23.isInput
                                        rpi2.0
                                        2024-09-10 09:50:44.733	debug	SETSTATE FOR rpi2.0.wlan.wifi_send VALUE = 0
                                        rpi2.0
                                        2024-09-10 09:50:44.733	debug	---> POST: for wifi_send in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.684	debug	SETSTATE FOR rpi2.0.wlan.wifi_received VALUE = 0
                                        rpi2.0
                                        2024-09-10 09:50:44.683	debug	VALUE: 0 POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:50:44.683	debug	---> POST: $1*-1 for wifi_received in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.674	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.673	debug	CURRENT = wlan true
                                        rpi2.0
                                        2024-09-10 09:50:44.623	debug	SETSTATE FOR rpi2.0.uptime.uptime VALUE = 425871.62
                                        rpi2.0
                                        2024-09-10 09:50:44.622	debug	---> POST: for uptime in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.614	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.614	debug	CURRENT = uptime true
                                        rpi2.0
                                        2024-09-10 09:50:44.561	debug	SETSTATE FOR rpi2.0.temperature.soc_temp VALUE = 46.74
                                        rpi2.0
                                        2024-09-10 09:50:44.561	debug	VALUE: 46738 POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:50:44.560	debug	---> POST: $1/1000 for soc_temp in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.553	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.553	debug	CURRENT = temperature true
                                        rpi2.0
                                        2024-09-10 09:50:44.503	debug	SETSTATE FOR rpi2.0.swap.swap_used VALUE = 193.65
                                        rpi2.0
                                        2024-09-10 09:50:44.502	debug	VALUE: 6500 POST: (rpi.swap_total - $1)/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.502	debug	---> POST: (rpi.swap_total - $1)/1024 for swap_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.451	debug	SETSTATE FOR rpi2.0.swap.swap_total VALUE = 200
                                        rpi2.0
                                        2024-09-10 09:50:44.450	debug	VALUE: 204796 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.450	debug	---> POST: $1/1024 for swap_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.441	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.441	debug	CURRENT = swap true
                                        rpi2.0
                                        2024-09-10 09:50:44.390	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_boot_used VALUE = 63.14
                                        rpi2.0
                                        2024-09-10 09:50:44.389	debug	VALUE: 64654 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.389	debug	---> POST: $1/1024 for sdcard_boot_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.338	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_root_used VALUE = 5695.12
                                        rpi2.0
                                        2024-09-10 09:50:44.337	debug	VALUE: 5831804 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.337	debug	---> POST: $1/1024 for sdcard_root_used in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.287	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_boot_total VALUE = 509.99
                                        rpi2.0
                                        2024-09-10 09:50:44.287	debug	VALUE: 522230 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.286	debug	---> POST: $1/1024 for sdcard_boot_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.234	debug	SETSTATE FOR rpi2.0.sdcard.sdcard_root_total VALUE = 29433.42
                                        rpi2.0
                                        2024-09-10 09:50:44.233	debug	VALUE: 30139824 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.233	debug	---> POST: $1/1024 for sdcard_root_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.225	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.225	debug	CURRENT = sdcard true
                                        rpi2.0
                                        2024-09-10 09:50:44.174	debug	SETSTATE FOR rpi2.0.network.net_send VALUE = 162783739
                                        rpi2.0
                                        2024-09-10 09:50:44.173	debug	---> POST: for net_send in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.118	debug	SETSTATE FOR rpi2.0.network.net_received VALUE = -148333177
                                        rpi2.0
                                        2024-09-10 09:50:44.117	debug	VALUE: 148333177 POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:50:44.117	debug	---> POST: $1*-1 for net_received in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.109	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:44.109	debug	CURRENT = network true
                                        rpi2.0
                                        2024-09-10 09:50:44.058	debug	SETSTATE FOR rpi2.0.memory.memory_available VALUE = 1048.1
                                        rpi2.0
                                        2024-09-10 09:50:44.058	debug	VALUE: 1073256 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.057	debug	---> POST: $1/1024 for memory_available in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:44.006	debug	SETSTATE FOR rpi2.0.memory.memory_free VALUE = 506.56
                                        rpi2.0
                                        2024-09-10 09:50:44.006	debug	VALUE: 518716 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:44.005	debug	---> POST: $1/1024 for memory_free in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:43.953	debug	SETSTATE FOR rpi2.0.memory.memory_total VALUE = 1846.94
                                        rpi2.0
                                        2024-09-10 09:50:43.952	debug	VALUE: 1891264 POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.951	debug	---> POST: $1/1024 for memory_total in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:43.942	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:43.942	debug	CURRENT = memory true
                                        rpi2.0
                                        2024-09-10 09:50:43.942	debug	raspberry disabled -> clean up.
                                        rpi2.0
                                        2024-09-10 09:50:43.941	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:43.941	debug	CURRENT = raspberry false
                                        rpi2.0
                                        2024-09-10 09:50:43.890	debug	SETSTATE FOR rpi2.0.cpu.scaling_governor VALUE = ondemand
                                        rpi2.0
                                        2024-09-10 09:50:43.889	debug	---> POST: for scaling_governor in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:43.838	debug	SETSTATE FOR rpi2.0.cpu.load15 VALUE = 0.07
                                        rpi2.0
                                        2024-09-10 09:50:43.837	debug	NAME: load15 VALUE: 0.07
                                        rpi2.0
                                        2024-09-10 09:50:43.837	debug	MATCHING: 0.07
                                        rpi2.0
                                        2024-09-10 09:50:43.786	debug	SETSTATE FOR rpi2.0.cpu.load5 VALUE = 0.16
                                        rpi2.0
                                        2024-09-10 09:50:43.786	debug	NAME: load5 VALUE: 0.16
                                        rpi2.0
                                        2024-09-10 09:50:43.785	debug	MATCHING: 0.16
                                        rpi2.0
                                        2024-09-10 09:50:43.736	debug	SETSTATE FOR rpi2.0.cpu.load1 VALUE = 0.32
                                        rpi2.0
                                        2024-09-10 09:50:43.735	debug	NAME: load1 VALUE: 0.32
                                        rpi2.0
                                        2024-09-10 09:50:43.735	debug	MATCHING: 0.32
                                        rpi2.0
                                        2024-09-10 09:50:43.734	debug	---> POST: for load1,load5,load15 in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:43.679	debug	SETSTATE FOR rpi2.0.cpu.cpu_frequency VALUE = 1800
                                        rpi2.0
                                        2024-09-10 09:50:43.679	debug	VALUE: 1800000 POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:50:43.678	debug	---> POST: $1/1000 for cpu_frequency in [object Object]
                                        rpi2.0
                                        2024-09-10 09:50:43.547	debug	-1
                                        rpi2.0
                                        2024-09-10 09:50:43.546	debug	CURRENT = cpu true
                                        rpi2.0
                                        2024-09-10 09:50:43.543	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:50:43.542	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.542	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:50:43.541	debug	------------- 0
                                        rpi2.0
                                        2024-09-10 09:50:43.535	debug	---> cat /sys/class/net/wl*/statistics/tx_bytes
                                        rpi2.0
                                        2024-09-10 09:50:43.534	debug	PARSING: wifi_send
                                        rpi2.0
                                        2024-09-10 09:50:43.534	debug	---> POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:50:43.534	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.534	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:50:43.533	debug	------------- 0
                                        rpi2.0
                                        2024-09-10 09:50:43.527	debug	---> cat /sys/class/net/wl*/statistics/rx_bytes
                                        rpi2.0
                                        2024-09-10 09:50:43.527	debug	PARSING: wifi_received
                                        rpi2.0
                                        2024-09-10 09:50:43.527	debug	PARSING: wlan
                                        rpi2.0
                                        2024-09-10 09:50:43.527	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:50:43.527	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.526	debug	---> REGEXP: /(^\S+)/
                                        rpi2.0
                                        2024-09-10 09:50:43.526	debug	------------- 425871.62 1682115.42
                                        rpi2.0
                                        2024-09-10 09:50:43.520	debug	---> cat /proc/uptime
                                        rpi2.0
                                        2024-09-10 09:50:43.520	debug	PARSING: uptime
                                        rpi2.0
                                        2024-09-10 09:50:43.519	debug	PARSING: uptime
                                        rpi2.0
                                        2024-09-10 09:50:43.519	debug	---> POST: $1/1000
                                        rpi2.0
                                        2024-09-10 09:50:43.519	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.519	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:50:43.518	debug	------------- 46738
                                        rpi2.0
                                        2024-09-10 09:50:43.512	debug	---> cat /sys/devices/virtual/thermal/thermal_zone0/temp
                                        rpi2.0
                                        2024-09-10 09:50:43.512	debug	PARSING: soc_temp
                                        rpi2.0
                                        2024-09-10 09:50:43.511	debug	PARSING: temperature
                                        rpi2.0
                                        2024-09-10 09:50:43.511	debug	---> POST: (rpi.swap_total - $1)/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.511	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.511	debug	---> REGEXP: /SwapFree:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:50:43.510	debug	------------- MemTotal: 1891264 kB MemFree: 518516 kB MemAvailable: 1073008 kB Buffers: 81276 kB Cached: 503240 kB SwapCached: 1752 kB Active: 534156 kB Inactive: 732040 kB Active(anon): 479580 kB Inactive(anon): 202124 kB Active(file): 54576 kB Inactive(file): 529916 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6500 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 104 kB Writeback: 0 kB AnonPages: 679896 kB Mapped: 86588 kB Shmem: 24 kB KReclaimable: 38188 kB Slab: 62956 kB SReclaimable: 38188 kB SUnreclaim: 24768 kB KernelStack: 4324 kB PageTables: 6576 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553012 kB VmallocTotal: 257687552 kB VmallocUsed: 11984 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:50:43.504	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:50:43.504	debug	PARSING: swap_used
                                        rpi2.0
                                        2024-09-10 09:50:43.504	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.503	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.503	debug	---> REGEXP: /SwapTotal:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:50:43.502	debug	------------- MemTotal: 1891264 kB MemFree: 518216 kB MemAvailable: 1072708 kB Buffers: 81276 kB Cached: 503240 kB SwapCached: 1752 kB Active: 534156 kB Inactive: 732040 kB Active(anon): 479580 kB Inactive(anon): 202124 kB Active(file): 54576 kB Inactive(file): 529916 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6500 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 104 kB Writeback: 0 kB AnonPages: 679896 kB Mapped: 86688 kB Shmem: 24 kB KReclaimable: 38188 kB Slab: 62956 kB SReclaimable: 38188 kB SUnreclaim: 24768 kB KernelStack: 4352 kB PageTables: 6576 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553012 kB VmallocTotal: 257687552 kB VmallocUsed: 11984 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        rpi2.0
                                        2024-09-10 09:50:43.496	debug	---> cat /proc/meminfo
                                        rpi2.0
                                        2024-09-10 09:50:43.496	debug	PARSING: swap_total
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:50:43.496	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.495	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.495	debug	---> REGEXP: /\S+\s+\d+\s+(\d+).*\/boot/m
                                        rpi2.0
                                        2024-09-10 09:50:43.493	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% /
                                        rpi2.0
                                        2024-09-10 09:50:43.485	debug	---> df /boot/*
                                        rpi2.0
                                        2024-09-10 09:50:43.484	debug	PARSING: sdcard_boot_used
                                        rpi2.0
                                        2024-09-10 09:50:43.484	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.483	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.483	debug	---> REGEXP: /\S+\s+\d+\s+(\d+).*\/$/m
                                        rpi2.0
                                        2024-09-10 09:50:43.482	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831804 22757492 21% /
                                        rpi2.0
                                        2024-09-10 09:50:43.473	debug	---> df /
                                        rpi2.0
                                        2024-09-10 09:50:43.473	debug	PARSING: sdcard_root_used
                                        rpi2.0
                                        2024-09-10 09:50:43.472	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.472	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.472	debug	---> REGEXP: /\S+\s+(\d+).*\/boot/m
                                        rpi2.0
                                        2024-09-10 09:50:43.470	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p1 522230 64654 457576 13% /boot/firmware /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% / /dev/mmcblk0p2 30139824 5831804 22757492 21% /
                                        rpi2.0
                                        2024-09-10 09:50:43.463	debug	---> df /boot/*
                                        rpi2.0
                                        2024-09-10 09:50:43.463	debug	PARSING: sdcard_boot_total
                                        rpi2.0
                                        2024-09-10 09:50:43.463	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.462	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.462	debug	---> REGEXP: /\S+\s+(\d+).*\/$/m
                                        rpi2.0
                                        2024-09-10 09:50:43.461	debug	------------- Filesystem 1K-blocks Used Available Use% Mounted on /dev/mmcblk0p2 30139824 5831804 22757492 21% /
                                        rpi2.0
                                        2024-09-10 09:50:43.454	debug	---> df /
                                        rpi2.0
                                        2024-09-10 09:50:43.454	debug	PARSING: sdcard_root_total
                                        rpi2.0
                                        rpi2.0
                                        2024-09-10 09:50:43.453	debug	---> POST:
                                        rpi2.0
                                        2024-09-10 09:50:43.453	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.453	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:50:43.452	debug	------------- 162783739
                                        rpi2.0
                                        2024-09-10 09:50:43.447	debug	---> cat /sys/class/net/e*/statistics/tx_bytes
                                        rpi2.0
                                        2024-09-10 09:50:43.446	debug	PARSING: net_send
                                        rpi2.0
                                        2024-09-10 09:50:43.446	debug	---> POST: $1*-1
                                        rpi2.0
                                        2024-09-10 09:50:43.446	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.446	debug	---> REGEXP: /(.*)/
                                        rpi2.0
                                        2024-09-10 09:50:43.445	debug	------------- 148333177
                                        rpi2.0
                                        2024-09-10 09:50:43.439	debug	---> cat /sys/class/net/e*/statistics/rx_bytes
                                        rpi2.0
                                        2024-09-10 09:50:43.439	debug	PARSING: net_received
                                        rpi2.0
                                        2024-09-10 09:50:43.439	debug	PARSING: network
                                        rpi2.0
                                        2024-09-10 09:50:43.439	debug	---> POST: $1/1024
                                        rpi2.0
                                        2024-09-10 09:50:43.439	debug	GROUPS: 2
                                        rpi2.0
                                        2024-09-10 09:50:43.438	debug	---> REGEXP: /MemAvailable:\s+(\d+)/m
                                        rpi2.0
                                        2024-09-10 09:50:43.437	debug	------------- MemTotal: 1891264 kB MemFree: 518764 kB MemAvailable: 1073256 kB Buffers: 81276 kB Cached: 503240 kB SwapCached: 1752 kB Active: 533516 kB Inactive: 732040 kB Active(anon): 478940 kB Inactive(anon): 202124 kB Active(file): 54576 kB Inactive(file): 529916 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 204796 kB SwapFree: 6500 kB Zswap: 0 kB Zswapped: 0 kB Dirty: 104 kB Writeback: 0 kB AnonPages: 679248 kB Mapped: 86588 kB Shmem: 24 kB KReclaimable: 38188 kB Slab: 62956 kB SReclaimable: 38188 kB SUnreclaim: 24768 kB KernelStack: 4324 kB PageTables: 6476 kB SecPageTables: 0 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1150428 kB Committed_AS: 1553012 kB VmallocTotal: 257687552 kB VmallocUsed: 11984 kB VmallocChunk: 0 kB Percpu: 672 kB CmaTotal: 524288 kB CmaFree: 319716 kB
                                        • L Laser
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          JanGa
                                          #120
                                          @laser
                                          Das dürfte der relevante Teil sein. Das sieht eigentlich sauber aus. Für mich sieht das immer noch aus, als würde die Schnittstelle zur GPIO-Library fehlen bzw. nicht installiert sein. An der Stelle muss ich erstmal wieder gucken, weil ich noch nicht verstehe wie da das Zusammenspiel zwischen NodeJS und der auf dem System installierten Bibliothek aussieht. Da man die dev Version davon installieren muss und weil diese bei der Installation des Adapters vorhanden sein muss, vermute ich mal, dass bei der Installation noch Binärcode erzeugt wird, der dann von der JS Bibliothek im Hintergrund angesprochen wird. Eventuell fehlen da auf deinem System irgendwelche Build Tools oder so? Ich werde mich da mal reinfuchsen und dann wieder melden.
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
                                          rpi2.0
