  4. Test Adapter rpi2 2.x
519 Beiträge 29 Kommentatoren 215.1k Aufrufe 20 Beobachtet
  • T
    T
    Tiedi
    #93
    sudo apt-get install -y libgpiod-dev
    Reading package lists... Done
    libgpiod-dev is already the newest version (1.6.3-1+b3).
    0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
    $ iobroker del rpi2
    Delete adapter "rpi2"
    host.iobroker15 Counted 1 instances of rpi2
    host.iobroker15 Counted 1 meta of rpi2
    host.iobroker15 Counted 1 devices of rpi2
    host.iobroker15 Counted 3 channels of rpi2
    host.iobroker15 Counted 11 states of rpi2
    host.iobroker15 Counted 14 states of system.adapter.rpi2
    host.iobroker15 Counted 8 states (io.rpi2.*) from states
    host.iobroker15 Counted 16 states (system.adapter.rpi2.*) from states
    host.iobroker15 file rpi2.admin deleted
    host.iobroker15 object rpi2 deleted
    host.iobroker15 object rpi2.admin deleted
    host.iobroker15 Deleting 33 object(s).
    host.iobroker15 Deleting 24 state(s).
    153 packages are looking for funding run `npm fund` for details
    Process exited with code 0
    sudo reboot
    iob upgrade rpi2@2.0.0
    Leider nein. Da kommen keine Werte an den GPIO.
    L 1 Antwort Letzte Antwort
    • T Tiedi
      $ iobroker del rpi2
      sudo reboot
      L
      L
      Laser
      #94
      Installation: ich stelle "reposteries" auf Beta um, installiere den Adapter/Instanz über die "normale" Oberfläche. Ist das richtig?
      Bei mir funktionieren weder Eingang noch Ausgang.
      rpi2.0
      2024-09-03 10:04:16.822	warn	Port 24 is configured as input and not writable
      rpi2.0
      2024-09-03 10:04:15.821	warn	Port 24 is configured as input and not writable
      rpi2.0
      2024-09-03 10:04:15.075	warn	Port 24 is configured as input and not writable
      rpi2.0
      2024-09-03 10:04:14.077	warn	Port 24 is configured as input and not writable
      rpi2.0
      2024-09-03 10:04:12.488	error	GPIO is not initialized!
      rpi2.0
      2024-09-03 10:04:11.313	error	GPIO is not initialized!
      rpi2.0
      2024-09-03 10:02:50.435	warn	Port 24 is configured as input and not writable
      rpi2.0
      2024-09-03 10:02:49.551	error	GPIO is not initialized!
      rpi2.0
      2024-09-03 10:02:47.057	error	GPIO is not initialized!
      • GarfonsoG Garfonso
        @tiedi
        Ist libgiod-dev installiert? Falls nicht / unsicher, einfach mal sudo apt-get install -y libgpiod-dev auf dem System ausführen und dann den Adapter nochmal neu installieren und gucken, ob sich was ändert, bitte.
        Das bitte bei allen, wo was von "undefined" im Log steht. Ich habe die Fehlermeldungen jetzt mal angepasst, dass die was klarer sind und da war noch ein Fehler, wo das durchrutschen konnte.
        J
        J
        JanGa
        #95
        @garfonso ich habe jetzt erst gesehen, dass die Hauptdiskussion hier stattfindet und nicht bei Github. Lass mich wissen, falls du bezüglich meines Pull Requests für Kompatibilität Raspberry Pi Zero 2 noch irgendwelche Infos brauchst. Ich kann auch gerne kurzfristig testen auf meinen Geräten. Die machen im Moment nichts wichtiges und es ist nicht schlimm, wenn es Ausfälle gibt.
          @searcher57
          danke für das Log. Könntest du den rpi2 adapter auf debug umstellen und mir dann nochmal ein log vom neustart geben? (der sollte beim umstellen direkt neugestartet werden, sonst bitte von Hand).
          Irgendwie ist mir noch nicht klar, warum das GPIO Objekt da undefined ist.
          S
          S
          searcher57
          #96
          @garfonso said in Test Adapter rpi2 2.x:
          @searcher57
          rpi2.0
          	2024-09-04 12:50:23.537	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
          rpi2.0
          	2024-09-04 12:50:22.935	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 6.0.11
          rpi2.0
          	2024-09-04 12:50:18.788	info	terminating
          rpi2.0
          	2024-09-04 12:50:18.288	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          rpi2.0
          	2024-09-04 12:50:18.288	info	terminating
          rpi2.0
          	2024-09-04 12:50:18.286	info	Got terminate signal TERMINATE_YOURSELF
          rpi2.0
          	2024-09-04 12:50:14.578	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
          rpi2.0
          	2024-09-04 12:50:13.912	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 6.0.11
          • S searcher57
            @searcher57
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            rpi2.0
            J
            J
            JanGa
            #97
            @searcher57 ist libgiod-dev auf dem System installiert? War es schon installiert, als der Adapter installiert wurde? Wenn nicht, Adapter deinstallieren, libgiod-dev installieren und Adapter wieder installieren!
            L S 2 Antworten Letzte Antwort
            • J JanGa
              L
              L
              Laser
              #98
              @janga Adapter deinstalliert, GPIO- Bibliothek installiert, Beides wieder neu installiert, die gleichen Fehlermeldungen wie oben gezeigt.
              • L Laser
                J
                J
                JanGa
                #99
                @laser wenn ich das richtig sehe, hat @Garfonso im letzten Commit die Fehlermeldung erweitert:
                 this.log.error('Cannot initialize/setMode GPIO: ' + e);
                 this.log.error('Please make sure that libgpiod-dev (on raspian/debian run sudo apt install libgpiod-dev) is installed in the system and then reinstall the adapter.');
                Wenn bei dir die Bibliothek schon installiert ist, muss es noch eine andere Ursache für das Problem geben. Du hast den Adapter aber wirklich neu installiert und nicht nur die Instanz gelöscht und wieder erstellt?
                • J JanGa
                  L
                  L
                  Laser
                  #100
                  @janga Nur die Instanz gelöscht. Werde das noch mal wiederholen.
                  • L Laser
                    J
                    J
                    JanGa
                    schrieb am zuletzt editiert von JanGa
                    #101
                    @laser Wenn du sichergehen willst, dass du den richtigen Adapter hast, dann installier den über die Shell mit
                    bzw. wenn er gerade deinstalliert ist
                    iob add rpi2@2.0.0
                    • J JanGa
                      iob add rpi2@2.0.0
                      L
                      L
                      Laser
                      #102
                      @janga Noch mal den Adapter über die Shell installiert (vorher libgiod und Adapter gelöscht, rebot).
                      rpi2.0
                      2024-09-05 11:45:59.188	error	GPIO is not initialized!
                      rpi2.0
                      2024-09-05 11:45:56.857	error	GPIO is not initialized!
                      rpi2.0
                      2024-09-05 11:45:53.430	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
                      rpi2.0
                      2024-09-05 11:45:52.715	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 5.0.19
                      rpi2.0
                      2024-09-05 11:45:49.713	info	terminating
                      rpi2.0
                      2024-09-05 11:45:49.268	info	Terminated (NO_ERROR): Without reason
                      rpi2.0
                      2024-09-05 11:45:49.266	info	terminating
                      rpi2.0
                      2024-09-05 11:45:49.213	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'output')
                      rpi2.0
                      2024-09-05 11:45:48.419	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.20.4, js-controller: 5.0.19
                      rpi2.0
                      2024-09-05 11:45:44.350	info	terminating
                      rpi2.0
                      2024-09-05 11:45:43.853	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      rpi2.0
                      2024-09-05 11:45:43.851	info	terminating
                      rpi2.0
                      2024-09-05 11:45:43.845	info	Got terminate signal TERMINATE_YOURSELF
                      rpi2.0
                      2024-09-05 11:45:02.810	warn	Port 23 is configured as input and not writable
                      rpi2.0
                      2024-09-05 11:45:01.121	warn	Port 23 is configured as input and not writable
                      rpi2.0
                      2024-09-05 11:44:59.273	warn	Port 23 is configured as input and not writable
                      rpi2.0
                      2024-09-05 11:44:58.352	error	Cannot initialize/setMode GPIO: TypeError: Cannot read properties of undefined (reading 'watch')
                      Zuerst den GPIO23 falsch eingestellt, dann korrigiert. Versucht, den Ausgang zu setzen und den Eingang abzufragen. Klappt Beides nicht.
                      • L Laser
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        rpi2.0
                        J
                        J
                        JanGa
                        #103
                        @laser an der Stelle weiß ich jetzt leider auch nicht mehr weiter. Wir müssen da wohl eine Wortmeldung von @Garfonso warten.
                        • J JanGa
                          S
                          S
                          searcher57
                          #104
                          @janga said in Test Adapter rpi2 2.x:
                          Danke, ja das habe ich alles schon gemacht.
                          • S searcher57
                            J
                            J
                            JanGa
                            #105
                            @searcher57 Was für einen Raspberry Pi benutzt du?
                            • J JanGa
                              S
                              S
                              searcher57
                              #106
                              Ich habe einen Raspi 5 im Einsatz. Aber mein Raspi 4 verhält sich genauso. Leider funktioniert nach wenigen Monaten der Freude über eine erfolgreiche Nachbesserung von @garfonso die APP wieder nicht!
                              • S searcher57
                                L
                                L
                                Laser
                                #107
                                @searcher57 Wird schon werden! Bevor ich jetzt Klimmzüge mit Scripten auf Debian Ebene mache, warte ich ab.
                                • J
                                  J
                                  JanGa
                                  #108
                                  @laser Es gibt auch noch die Möglichkeit eines Javascripts in IOBroker. Habe die Tage irgendwo einen Eintrag gesehen von jemanden, der GPIO ohne den Adapter benutzt hat. Finde das nur leider im Moment nicht...
                                  Bei mir selbst geht der Kram im Moment auch nicht. In meinem Fall liegt es aber an der Art und Weise wie der Adapter bestimmt, welcher Raspberry Pi verwendet wird, und wie er diese Information dann so umsetzt, dass die verwendete GPIO-Bibliothek weiß, wie sie den Chip ansteuern muss. Ich habe einen Raspberry Pi Zero 2 W in einem Schalkasten im Garten und steuere damit die Beleuchtung. Leider kann man Zero 2 W nicht mit dem gleichen Regex in eine Nummer umwandeln wie Raspberry Pi 1,2,3,4 oder 5. Ich habe da auch schon eine Lösung für und habe einen Pull Request auf Github eingereicht. Ich bin nur leider zu unfähig, um meinen eigenen Fix bei mir einzuspielen ohne dass er im Repository ist. Bzw. ich hab einfach zu wenig Zeit, um mich in die IOBroker Adapterentwicklung tief genug einzuarbeiten. Stattdessen muss ich jetzt genau wie du warten, dass @Garfonso meinen oder einen anderen Fix einbaut. Schon bitter, wie hilflos man da ist. :D
                                  L mcm1957M 2 Antworten Letzte Antwort
                                  • J JanGa
                                    L
                                    L
                                    Laser
                                    #109
                                    @janga Man kann Linux Befehle vom IO Broker ausführen. Aber das tue ich nur, wenn nichts Anderes geht. Das wird schnell unübersichtlich, wenn man das System neu aufsetzen muß, grübelt man erst mal, was man Alles umgestrickt hat. Adapter sind sind die bessere Lösung. Wenn Sie funktionieren.
                                    • J JanGa
                                      mcm1957M
                                      mcm1957M
                                      mcm1957
                                      #110
                                      Ähmm
                                      Blöde Frage - aber wie hast du den PR gestestet ohne die Codeänderung zu installieren ???
                                      Installieren kannst du den von dir geänderten Adpapter jederzeit via "install from Github" von deinem geforkten Repository in dem du die Änderungen vorgenommen hast. (https://github.com/jangatzke/ioBroker.rpi2 ?)
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      HomoranH J 2 Antworten Letzte Antwort
                                      • mcm1957M mcm1957
                                        Ähmm
                                        #111
                                        @mcm1957 sagte in Test Adapter rpi2 2.x:
                                        reicht es nicht die Instanz zu stoppen, die geänderte Datei im Adapterverzeichnis zu tauschen, dann ein upload zu machen und die Instanz wieder zu starten?
                                          mcm1957M
                                          mcm1957M
                                          mcm1957
                                          #112
                                          Natürlich - nur sollte man vermeiden direkt im Codetree rumzuwerken. Via GH Installtion hat man in diesem Fall die Sicherheit dass das was man vie PR einreicht auch selbst bei einem läuft :-)
                                          83.8k
