  4. Alpha Test js-controller Kiera (v6.0)
alphajs-controllerkieratest
234 Beiträge 20 Kommentatoren 65.5k Aufrufe 25 Beobachtet
    TT-Tom
    #101
    auf meinem Testsystem läuft jetzt auch der neue Controller. Im Testsystem laufen alle Adapter mit dem Beta-Repro und sind auf dem letzten Stand.
    Der Fahrplan Adapter 1.2.3 startet nicht und bringt folgende Meldungen. läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:16:00.146	info	instance system.adapter.fahrplan.0 started with pid 218788
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: ^
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
    host.iobtest
    2024-05-24 11:16:01.252	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.iobtest
    2024-05-24 11:16:01.253	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fahrplan/node_modules/@iobroker/adapter-core/build/index.js:19:27)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.iobtest
    2024-05-24 11:16:01.254	error	Caught by controller[0]: Node.js v18.20.2
    host.iobtest
    2024-05-24 11:16:01.254	error	instance system.adapter.fahrplan.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobtest
    2024-05-24 11:16:01.254	info	Restart adapter system.adapter.fahrplan.0 because enabled
    Bei dem Javascript Adapter 8.3.1 ist mir folgendes aufgefallen, dass die Module nicht mehr einzeln in der Config stehen.
    habe sie jetzt neu eingetragen, sie werden aber laut Log-Ausgabe nicht geladen / installiert, was mir diese Fehlermeldung bestätigt.
    javascript.0
    2024-05-24 11:37:12.904	info	Compiling TypeScript source script.js.common.NSPanel4400
    javascript.0
    2024-05-24 11:37:15.383	info	script.js.common.NSPanel4400: source code did not change, using cached compilation result...
    javascript.0
    2024-05-24 11:37:15.728	warn	script.js.common.NSPanel4400: error at function init_dayjs: dayjs_1.locale is not a function
    javascript.0
    2024-05-24 11:37:15.747	info	script.js.common.NSPanel4400: setObjects enabled - create Alias Channels possible
    javascript.0
    2024-05-24 11:37:15.772	info	script.js.common.NSPanel4400: weather alias for accuweather.0. already exists
    javascript.0
    2024-05-24 11:37:15.897	info	script.js.common.NSPanel4400: registered 33 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-05-24 11:37:16.379	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:16.381	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:16.824	info	script.js.common.NSPanel4400: Debug mode disabled
    javascript.0
    2024-05-24 11:37:17.243	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.244	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.799	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.800	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:17.910	info	script.js.common.NSPanel4400: Desired TFT Firmware: 54 / v4.4.0
    javascript.0
    2024-05-24 11:37:17.911	info	script.js.common.NSPanel4400: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-24 11:37:29.303	warn	script.js.common.NSPanel4400: error at function HandleScreensaverUpdate: parseFormat is not a function
    javascript.0
    2024-05-24 11:37:53.476	info	Stopping script script.js.common.NSPanel4400
    der netamo-crawler Adapter 0.8.1 läuft auch nicht mehr , selbst im Debug modus der Instanz kommen nicht mehr Daten. Läuft jetzt nach npm update
    host.iobtest
    2024-05-24 11:46:00.632	info	instance scheduled system.adapter.netatmo-crawler.0 */5 * * * *
    host.iobtest
    2024-05-24 11:46:00.644	info	instance system.adapter.netatmo-crawler.0 started with pid 219300
    host.iobtest
    2024-05-24 11:46:01.782	error	instance system.adapter.netatmo-crawler.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    das waren die ersten Sachen die ich gefunden habe bei mir.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    mcm1957M haus-automatisierungH 2 Antworten Letzte Antwort
    • T TT-Tom
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      host.iobtest
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      host.iobtest
      host.iobtest
      host.iobtest
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #102
      @tt-tom said in Alpha Test js-controller Kiera (v6.0):
      zipFiles.js
      Dazu gabs weiter oben schon einen Beitrag. Ich glaub ein npm upgrade oder so hat das was gefixed. Ist - wenn ichs richtig im Kopf hab - ein offenes Problem. Schau mal frühere Beoiträge durch.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • sigi234S sigi234
        @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
        Und genau diese 3 Adapter haben beim Start ab 11:37 einen already running error gemeldet.
        Bei mir sind es einige mehr. War aber immer schon so. Beruhigt sich nach einiger Zeit wieder. Bis zum Neustart eben.
        host.SmartHome
        2024-05-24 11:58:49.508	error	instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:41.067	error	instance system.adapter.vis-inventwo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:37.231	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:25.628	error	instance system.adapter.ecovacs-deebot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:22.100	error	instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:16.992	error	instance system.adapter.parser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:13.106	error	instance system.adapter.tapo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:09.359	error	instance system.adapter.pollenflug.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:05.571	error	instance system.adapter.musiccast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:58:01.679	error	instance system.adapter.web.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:57.194	error	instance system.adapter.iot.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:53.440	error	instance system.adapter.jarvis.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:49.746	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:45.893	error	instance system.adapter.weather-warnings.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:42.774	error	instance system.adapter.alarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:32.892	error	instance system.adapter.socketio.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:29.354	error	instance system.adapter.ws.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:24.995	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:17.208	error	instance system.adapter.snmp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:12.895	error	instance system.adapter.lgtv.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:57:05.988	error	instance system.adapter.meross.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:57.522	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:50.507	error	instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:45.626	error	instance system.adapter.yamaha.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:42.406	error	instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:37.747	error	instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:32.874	error	instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:28.974	error	instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:24.950	error	instance system.adapter.hue.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:20.873	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:16.888	error	instance system.adapter.email.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:13.251	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:09.200	error	instance system.adapter.history.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:56:05.239	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.SmartHome
        2024-05-24 11:55:52.252	error	instance system.adapter.vis-inventwo.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:52.143	error	instance system.adapter.sayit.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:52.042	error	instance system.adapter.ecovacs-deebot.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.928	error	instance system.adapter.vis-2.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.827	error	instance system.adapter.parser.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.724	error	instance system.adapter.tapo.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.540	error	instance system.adapter.pollenflug.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.400	error	instance system.adapter.musiccast.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.300	error	instance system.adapter.web.1 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.182	error	instance system.adapter.iot.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:51.081	error	instance system.adapter.jarvis.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.961	error	instance system.adapter.fb-checkpresence.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.853	error	instance system.adapter.weather-warnings.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.752	error	instance system.adapter.alarm.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.652	error	instance system.adapter.socketio.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.553	error	instance system.adapter.ws.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.447	error	instance system.adapter.web.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.347	error	instance system.adapter.snmp.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.250	error	instance system.adapter.lgtv.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.149	error	instance system.adapter.meross.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:50.050	error	instance system.adapter.cloud.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.944	error	instance system.adapter.alexa2.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.825	error	instance system.adapter.yamaha.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.697	error	instance system.adapter.tr-064.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.576	error	instance system.adapter.hm-rpc.1 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.471	error	instance system.adapter.hm-rega.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.363	error	instance system.adapter.hm-rpc.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.226	error	instance system.adapter.hue.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:49.091	error	instance system.adapter.backitup.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:48.983	error	instance system.adapter.email.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:48.883	error	instance system.adapter.javascript.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:48.747	error	instance system.adapter.history.0 terminated with code 4294967295 ()
        host.SmartHome
        2024-05-24 11:55:48.583	error	instance system.adapter.admin.0 terminated with code 4294967295 ()
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #103
        @sigi234
        OK, aber auch diese haben einen "ungewöhnlichen" Existstatus beim Beenden.
        • mcm1957M mcm1957
          zipFiles.js
          TT-Tom
          #104
          @mcm1957 danke für die Info, läuft jetzt soweit bis auf die Sache mit dem Javascript Adapter.
          Gruß Tom
          Public Transport
          • T TT-Tom
            mcm1957M Online
            mcm1957M Online
            mcm1957
            #105
            @haus-automatisierung
            Soweit ich weiß hat sich mit js-controller 6 und / oder (?) Javascript 8.x.x was mit der Installation der zusätzlichen npm Module geändert. Wahrscheinlich kann da haus-automatisierung am besten helfen um festzustellen ob da ein Problem vorliegt oder "nur" eine Anpassung durch dich notwendig ist.
            Ref zu deinem ersten Fehlerbericht https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/106
            • T TT-Tom
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              host.iobtest
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              host.iobtest
              host.iobtest
              host.iobtest
              haus-automatisierungH Offline
              #106
              @tt-tom sagte in Alpha Test js-controller Kiera (v6.0):
              Von welcher Version bist Du denn vorher gekommen? Denke mal das hängt mit dem Wechsel auf jsonConfig zusammen und dass der alte Wert ggf. nicht richtig migriert wird.
              📚 Meine Dokumentation
                FeuersturmF Offline
                FeuersturmF Offline
                Feuersturm
                #107
                @haus-automatisierung Das Verhalten sehe ich bei mir auch.
                In der Javascript Instanz v8.0.3 auf meinem Produktivsystem werden die npm Module korrekt einzeln dargestellt.
                Auf meinem Testsystem ist Javascript auf 8.3.1 und dort sieht es jetzt auch so aus, das alles in einem item steht
                • FeuersturmF Feuersturm
                  #108
                  @feuersturm sagte in Alpha Test js-controller Kiera (v6.0):
                  Dann zeig mal bitte das Native-Objekt aus dem Instanz-Objekt.
                    FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    #109
                    @haus-automatisierung Meinst du das hier?
                      #110
                      @feuersturm Genau, danke. Ist also mit Leerzeichen getrennt und kein Array. Muss ich fixen.
                      "libraries": "xml2js moment moment-timezone moment-duration-format mathjs",
                      Thomas BraunT T 2 Antworten Letzte Antwort
                        #111
                        @foxriver76
                        Gerade gecheckt: Die Anzeige von anstehenden Updates meines Debian-Systems funktioniert im Admin.
                          @foxriver76
                          FeuersturmF Offline
                          FeuersturmF Offline
                          Feuersturm
                          #112
                          @thomas-braun sagte in Alpha Test js-controller Kiera (v6.0):
                          @foxriver76
                          Bei mir werden auch mögliche Updates angezeigt
                          Wenn ich dann versuche die Pakete zu aktualisieren werden diese aber nicht aktualisiert, sondern zurückgehalten.
                          proxmox@ioBrokerTestsystem:~$ sudo apt update
                          [sudo] password for proxmox:
                          Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [119 kB]
                          Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                          Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1683 k        B]
                          Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [10        75 kB]
                          Fetched 2987 kB in 3s (892 kB/s)
                          Reading package lists... Done
                          Building dependency tree... Done
                          2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          proxmox@ioBrokerTestsystem:~$ sudo apt list --upgradable
                          Listing... Done
                          python3-update-manager/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                          update-manager-core/jammy-updates 1:22.04.20 all [upgradable from: 1:22.04.19]
                          proxmox@ioBrokerTestsystem:~$ sudo apt full-upgrade -y
                          Calculating upgrade... Done
                          The following packages have been kept back:
                            python3-update-manager update-manager-core
                          0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                          Kannst du mir sagen, was hier der Hintergrund ist? Für den Enduser ist die Meldung aus meiner Sicht verwirrend, wenn hier Updates angezeigt werden, welche aber nicht installiert werden können.
                            @foxriver76
                            Listing... Done
                            #113
                            Das hat mit dem ioBroker nix zu tun sondern ist eine der vielen Schnubbibuntu-Sonderlocken. (Weswegen ich diese Distribution auch nicht mag und auch nicht empfehlen würde).
                            Nennt sich 'Phased Updates' und sorgt dafür, dass eigentlich anstehende Updates in Wellen scharf geschaltet werden.
                              FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              #114
                              @thomas-braun Danke für die Erklärung, das heißt ich warte einfach und bis dahin muss ich mit der Meldung leben.
                              • foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #115
                                @thomas-braun https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/100 hast du gesehen?
                                Videotutorials & mehr
                                  TT-Tom
                                  #116
                                  Danke, warte jetzt auf dein Fix. Wollen wir damit in dein Test Thread wechseln??
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    #117
                                    Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
                                    • foxriver76F foxriver76
                                      #118
                                      @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                                      Ja, aber noch nicht testen können. Kein gescheites Terminal zur Hand, nur eine Android-App und mit der will ich nix aufwändigeres per SSH machen.
                                        foxriver76F Offline
                                        foxriver76
                                        #119
                                        An alle: bitte nochmal updaten
                                        A F T 3 Antworten Letzte Antwort
                                          A Online
                                          A Online
                                          ag
                                          #120
                                          @foxriver76
                                          js-controller 6.01 auf dem testsystem läuft alles wieder.
                                          Beim Start der Instamcen nach reboot oder iobroker start.
                                          2024-05-24 18:16:06.510 - info: host.RPI5Test instance system.adapter.daikin.0 started with pid 1646
                                          2024-05-24 18:16:07.191 - error: daikin.0 (1646) daikin.0 invalid instance object: {"_id":"","type":"device","common":{},"native":{}}
                                          2024-05-24 18:16:07.232 - info: daikin.0 (1646) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.daikin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240524-14a872375
                                          2024-05-24 18:16:08.169 - info: daikin.0 (1646) Daikin Device initialized successfully
                                          2024-05-24 18:16:08.170 - info: daikin.0 (1646) Set polling Intervall to 300s
                                          Adapter funktiniert aber danach
                                          Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
                                          /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
                                          js-controller 7.0.6 admin 7.4.10
