  4. Alpha Test js-controller Kiera (v6.0)
alphajs-controllerkieratest
234 Beiträge 20 Kommentatoren 65.7k Aufrufe 25 Beobachtet
  • S Shadowhunter23
    @foxriver76 ich hab den Adapter jetzt gelöscht und neu installiert. Fehlermeldungen sind anders:
    device-watcher.0
    2024-05-30 11:17:00.550	info	Found instances items on blacklist for notifications: lg-thinq.0,discovery.0,octoprint.1,octoprint.2
    device-watcher.0
    2024-05-30 11:17:00.550	info	Found instances items on blacklist for lists: lg-thinq.0,discovery.0,octoprint.1,octoprint.2
    device-watcher.0
    2024-05-30 11:17:00.550	info	Number of selected adapters to monitor devices: 4. Loading data from: Fritzdect, FullybrowserV3, Shelly, Zigbee ...
    device-watcher.0
    2024-05-30 11:17:00.542	info	starting. Version 2.12.1 in /opt/iobroker/node_modules/iobroker.device-watcher, node: v20.14.0, js-controller: 6.0.1-alpha.0-20240529-9dbeeb628
    host.iobroker
    2024-05-30 11:16:59.686	info	instance system.adapter.device-watcher.0 started with pid 2941
    host.iobroker
    2024-05-30 11:16:56.548	info	instance system.adapter.device-watcher.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    device-watcher.0
    2024-05-30 11:16:56.504	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.504	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.504	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.501	error	[getInstanceData] - TypeError: Cannot read properties of null (reading 'val')
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.500	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.500	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.500	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.499	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.499	error	uncaught exception: Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.499	error	Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.498	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.498	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.498	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.497	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.497	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.497	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.496	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.496	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.496	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.495	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.495	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.495	error	uncaught exception: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.494	error	uncaught exception: Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.489	error	Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.489	error	Error: Connection is closed. at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:634:26) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at TCP.<anonymous> (node:net:338:12)
    device-watcher.0
    2024-05-30 11:16:56.489	error	uncaught exception: Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.487	error	Cannot parse JSON cfg.o.admin.0.info.updatesJson: undefined
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.486	error	Cannot parse JSON cfg.o.admin.0.info.updatesJson: undefined
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.485	error	Cannot parse JSON cfg.o.admin.0.info.updatesJson: undefined
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.484	warn	redis mget of 1 keys, err: Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.483	warn	redis mget of 1 keys, err: Connection is closed.
    device-watcher.0
    2024-05-30 11:16:56.367	error	[getInstanceData] - TypeError: Cannot read properties of null (reading 'val')
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.366	error	[getInstanceData] - TypeError: Cannot read properties of null (reading 'val')
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.365	error	[getInstanceData] - TypeError: Cannot read properties of null (reading 'val')
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.364	warn	redis mget of 1 keys, err: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.363	warn	redis mget of 1 keys, err: Connection is closed.
    device-watcher.0
    device-watcher.0
    device-watcher.0
    device-watcher.0
    2024-05-30 11:16:56.277	info	terminating
    device-watcher.0
    2024-05-30 11:16:55.777	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    device-watcher.0
    2024-05-30 11:16:55.776	info	terminating
    device-watcher.0
    2024-05-30 11:16:55.776	info	cleaned everything up...
    host.iobroker
    2024-05-30 11:16:55.776	info	stopInstance system.adapter.device-watcher.0 send kill signal
    device-watcher.0
    2024-05-30 11:16:55.775	info	Got terminate signal TERMINATE_YOURSELF
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #221
    @shadowhunter23 Bitte issue im Adapter
    Videotutorials & mehr
    • foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #222
      Hat mit der neusten Version noch jemand das Problem mit Cannot find letsencrypt? Insbesondere @Feuersturm kann es noch auf dem Slave testen. Ich hoffe es ist gefixt und dann wäre aktuell erst mal nichts mehr bekannt was nicht geht, außer einzelne Adapter in die ich dann noch reinschauen kann ob Controller oder Adapter was benötigt.
      Thomas BraunT T FeuersturmF 3 Antworten Letzte Antwort
      • foxriver76F foxriver76
        #223
        @foxriver76
        Aktuellste Version startet sauber durch. Die Meldung
        2024-05-30 14:16:22.772  - warn: javascript.0 (125665) Cannot install custom npm package playactor: Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
        ignoriere ich.
          TT-Tom
          #224
          @foxriver76
          bei mir läuft auch alles aktuell, ohne Fehlermeldungen.
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #225
            @foxriver76 Update auf 6.0.1-alpha.0-20240529-9dbeeb628
            Beide Testsysteme erfolgreich aktualisiert und keine Probleme mehr beim Start. Super.
              Aktuelle Test Version 6.0.0
              Veröffentlichungsdatum 22.05.2024
              Hallo ioBroker-Community,
              Heute möchte ich Euch den js-controller 6.0 für einen ersten Alpha-test zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos.
              Node.js Versions-Anforderungen
              In diesem Release entfällt Node.js 14.x und 16.x. Die unterstützten Node.js Versionen sind: 18.x, 20.x und voraussichtlich 22.x. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 20.x angehoben.
              Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
              Informationen zur Version
              In dieser Version wurde die Umstellung des Quellcodes auf TypeScript nochmal vorangetrieben (5.X 76%, mit 6.X 90% der Codebase), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können.
              Ebenfalls läuft der Controller nun komplett als ESM Modul, was uns technisch alle Möglichkeiten offen hält und auch Adapter nun komplett als ESM Module laufen können und somit keine Einschränkungen mehr haben falls Dependencies nur für ESM verfügbar sind.
              Weiterhin sind auch einige neue Features unter anderem die Möglichkeit des automatisierten Adapter-Upgrades (Admin Funktionalität wird zeitnah implementiert), Informationen über das System Management (neue Pakete, restart nötig, ...) sowie das Management von geblockten Adapter-Versionen hinzugefügt.
              Auch wenn mit dieser Version keine neuen relevanten Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
              Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog. Ich hoffe auch diesmal auf Eure tatkräftige Unterstützung, sodass der Latest-Release dann genau so reibungslos verläuft wie bei den letzten Versionen.
              Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
              Darüber hinaus ist der js-controller 6.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der Version 5.x ist problemlos möglich.
              Ansonsten empfehlen wir ein schrittweises Update auf die 6.0 (3.3.x -> 4.0 -> 5.0).
              Installation
              VOR der Installation
              Wie bei jedem Test dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
              Eine alte 5.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Letzter Stable Stand ist die 5.0.19)
              Nötige Adapter-Aktualisierungen
              Am besten VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 5.0 oder höher hinweisen.
              Mit den stable Versionen der jeweiligen Adapter sollten keine Probleme auftreten, falls doch bitte hier melden.
              Achtung: MASTER/SLAVE-Systeme Reihenfolgen beachten!
              Bei einem Multi-Host-System, welches auf js-controller 5.0.x läuft, ist es beim Update auf Version 6.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
              Bei Updates von Master/Slave-Systemen mit js-controller 4.x oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
              Windows
              Generell muss das Update manuell via npm installiert werden. Zusätzlich muss einmalig bei bestehenden Installationen der fixer ausgeführt werden und falls noch vorhanden die iobroker.bat gelöscht werden.
              Hierzu werden folgende Befehle genutzt:
              del iobroker.bat
              iob fix
              Anschließend im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl npm i iobroker.js-controller@next --omit=dev ausführen.
              Linux
              • ioBroker stoppen (iobroker stop)
              • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
              • cd /opt/iobroker
              • Das Update erfolgt via npm i iobroker.js-controller@next --omit=dev
              • ioBroker starten (iobroker start)
              Bei Fehlern:
              Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
              Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev versuchen. Bitte berichtet solche Fälle hier im Thread.
              NACH der Installation
              Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
              Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
              Was hat sich geändert, was besonders ansehen/beachten?
              Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
              • generell siehe Changelog, speziell auch für die Features
              • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript und ESM Umstellungen haben sehr viel Code angefasst.
              Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
              Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
              6.0.1 Release Kiera
              Breaking changes
              • Support for Node.js 16 is dropped!
              • Binary states have been removed
              • Let's encrypt has been removed
              Features
              • (foxriver76) Added possibility to automatically upgrade adapters (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#automatic-adapter-upgrade)
              • (foxriver76) if updates for OS packages are available a notification is generated (Linux only)
              • (foxriver76) the controller creates a notification if free disk space is critical (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#disk-space-warnings)
              • (foxriver76) allow to ignore specific adapter versions (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#ignoring-specific-adapter-version)
              • (foxriver76) if an adapter is blocklisted and thus stopped the controller now generates a notification
              • (foxriver76) allow to configure redis tls during setup custom
              Optimizations and fixes
              • (foxriver76) we now send SIGKILL instead of SIGTERM if adapter does not stop in normal time to prevent ghost processes
              • (foxriver76) prevent crash case if an invalid pattern is scanned in the database
              • (foxriver76) we now log the pid if a adapter process is stopped
              • (foxriver76/Apollon77) fixed crash case on file rotation
              • (foxriver76) optimized error messages and help text for cli commands url and install
              • (foxriver76) if users want to install non existing adapters we now hint to the url command instead of recommending the use of npm
              • (foxriver76) when interacting with aliases we no longer check permissions of the alias and the original object, we now only check the alias
              • (foxriver76) host object is now already created during setup first run, allowing eg to disable sentry globally before first start of ioBroker
              • (foxriver76) if the user sets a custom title for instances this is now preserved during upload
              • (foxriver76) on reinstallation of adapters we uninstall the package manually first to ensure a correct reinstall
              • (foxriver76) fixed problem on multihost discover
              • (foxriver76) if getState is called on a non existing or non linked alias we return null like for all other non existing states
              • (foxriver76) optimize alias subscribe performance for non-redis dbs
              • (foxriver76/bluefox/Apollon77) updated dependencies
              • (foxriver76/bluefox/Apollon77) minor fixes and stability improvements
              Developer relevant DEPRECATIONS/WARNINGS
              • (foxriver76) adapters need to specify adapter-core version 3.1.4 or higher or allow an upgrade to this version by specifying e.g. ^3.x.x
              • (foxriver76) it is now validated that obj.native is of type Record<string, unknown>
              • (foxriver76) Let's encrypt has been removed (@iobroker/webeserver should be used instead)
              • (foxriver76) deprecated delete/createState/channel/device methods
              • (foxriver76) deprecated ioPack common.license which is replaced by the new object common.licenseInfo
              • (foxriver76) ioPack mode subscribe has been removed as you can achieve the same with mode once and setting system.adapter.xy.alive state (also removed common.wakeup and common.subscribe because of this)
              Developer relevant new features
              • (foxriver76) js-controller (and thus the whole ioBroker) is now running as an ESM module internally while staying a 100 % backward compatible to adapters written in cjs
              • (foxriver76) adapters can now be written as ESM modules having full support (including compact mode)
              • (foxriver76) we provide all exports as ESM and as CJS to allow adapter developers to choose what to use
              • (foxriver76) added convenient methods to manage node modules (see https://github.com/ioBroker/ioBroker.js-controller?tab=readme-ov-file#managing-node-modules)
              • (foxriver76) allow to specify reason and exit code on adapter.stop
              • (foxriver76) if you blocklist a version in your io-package.json the controller won't start it anymore and will generate a notification
              • (foxriver76) for adapters of type schedule and connectionType set to cloud the schedule will be automatically delayed by up to 60 seconds randomly per user if the CRON does not contain a seconds argument, this is to prevent DDoS attacks
              Developer relevant optimizations and fixes
              • (foxriver76) fixed crash case if an malformed object was defined in ioPack instanceObjects
              • (foxriver76) if getState is called on a non-existing or non-linked alias we return null like for all other non-existing states
              • (foxriver76/bluefox) multiple improvements on type level
              Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
              Wie Fehler melden?
              Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
              Bitte checkt auch die "Known issues Liste" (zweiter Post) mit den Dingen die aktuell während der Alpha bekannt sind und bis zum Releasen noch angepasst werden.
              Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
              Bitte postet auch die Ausgabe von iob diag mit rein.
              Wir wünschen allen viel Spaß beim Testen und vielen Dank für Eure Unterstützung!
              Moritz
              ag
              #226
              @foxriver76
              Testsystem aktualisiert, keine Problem oder Fehlermeldungen.
              Gute Arbeit
              Operating System: Debian GNU/Linux 12 architecture: arm64 Pi5 8GB
              /usr/bin/nodejs v20.18.0 /usr/bin/node 20.18.1 /usr/bin/npm 10.8.2
              js-controller 7.0.6 admin 7.4.10
              • D Online
                D Online
                DLehmann
                #227
                @foxriver76
                Auch hier Testsystem aktualisiert. Keine Probleme beim Start. Alle Adapter laufen ohne Fehler. Super.
                ESP8266E 1 Antwort Letzte Antwort
                • D DLehmann
                  @foxriver76
                  ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  #228
                  Ich weiß nicht ob es hier rein gehört, aber mit dem neuen Node 20.x.x laufen die Adapter Maxcul und G-Homa nicht mehr. Beide Rot. Zurück zu 18 alles läuft wieder.
                  • ESP8266E ESP8266
                    #229
                    @esp8266
                    Das hat aber ja nix mit dem Alpha-Test des js-controllers zu tun.
                    Ich würde pro Adapter einen Thread oder ein Issue eröffnen. Und dann dort Logs rein.
                      @esp8266
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      #230
                      • entfernt da Blödsinn - betrifft ja NODE nicht js-controller -
                        Und nebenbei hilft ein Blick ind ie Issues der Adapter:
                        https://github.com/ioBroker/ioBroker.maxcul/issues/64
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        #231
                        Mit dem aktuellen github-Stand js-controller@6.0.1-alpha.0-20240603-3deca26fa
                        fliegt mit das um die Ohren:
                        echad@chet:/opt/iobroker $ iob stop
                        echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                        npm warn ERESOLVE overriding peer dependency
                        npm warn While resolving: @iobroker/adapter-core@3.1.4
                        npm warn Found: @iobroker/types@6.0.0
                        npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
                        npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
                        npm warn     iobroker.admin@"6.17.14" from the root project
                        npm warn
                        npm warn Could not resolve dependency:
                        npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                        npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                        npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
                        npm warn
                        npm warn Conflicting peer dependency: @iobroker/types@5.0.19
                        npm warn node_modules/@iobroker/types
                        up to date in 8s
                        190 packages are looking for funding
                          run `npm fund` for details
                        Da ist also in den Deps der Wurm drin.
                        Edit: Mittels iob upgrade admin@6.17.14 --omit=dev bekommt man das wohl wieder in die Reihe.
                        • Rene55R Offline
                          Rene55R Offline
                          Rene55
                          #232
                          @foxriver76 Ist der js-controller 6.0.1 auch für den dev-server schon zu testen oder nur für 'normale' Installationen? Ich frage, weil mir der gerade zum Update angeboten wird.
                          Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
                          ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
                          Wetterstation: Froggit WH3000SE V1.6.6
                          • Rene55R Rene55
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            #233
                            @rene55 said in Alpha Test js-controller Kiera (v6.0):
                            js-controller 6.0.1 ist seit heute BETA / LATEST. Du kannst und sollst ihn auf allen deinen TESTsystemen testen um Fehler zu finden.
                            Ansonsten bitte um entsprchenden BETA Thread disktutieren
                            https://forum.iobroker.net/topic/75206/beta-test-js-controller-kiera-v6-0
                            @Homoran
                            @foxriver76
                            Ich rege an hier zu schließen
                            • mcm1957M mcm1957
                              @Homoran
                              @foxriver76
                              #234
                              @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
                              regen angenommen
