  4. Modbus Fehler bei Anbindung meines Wechselrichters von Renac
23 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
    Miokoeln
    Hallo Zusammen, ich bekomme immer einen Fehler im IoBroker mit dem Adapter Modbus.
    Hoffe es kann mir einer helfen diesen zu lösen.
    modbus.0
    2024-02-25 18:54:38.602	info	Disconnected from slave 192.168.178.175
    modbus.0
    2024-02-25 18:54:37.602	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
    modbus.0
    2024-02-25 18:54:37.601	error	Client in error state.
    modbus.0
    2024-02-25 18:54:37.601	error	Request timed out.
    modbus.0
    2024-02-25 18:54:37.601	warn	Error: undefined
    modbus.0
    2024-02-25 18:54:32.810	error	unknown function code: 0x35, 0x37
    modbus.0
    2024-02-25 18:54:32.780	error	unknown function code: 0x0, 0x0
    modbus.0
    2024-02-25 18:54:32.730	error	unknown function code: 0x0, 0x0
    modbus.0
    2024-02-25 18:54:32.680	error	Wrong CRC for frame: 1,3,32,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,3
    modbus.0
    2024-02-25 18:54:32.598	info	Connected to slave
    modbus.0
    2024-02-25 18:54:30.593	info	Disconnected from slave 192.168.178.175
    modbus.0
    2024-02-25 18:54:29.592	error	Client in error state.
    modbus.0
    2024-02-25 18:54:29.592	error	Request timed out.
    modbus.0
    2024-02-25 18:54:29.591	warn	Error: undefined
    modbus.0
    2024-02-25 18:54:28.575	warn	Poll error count: 1 code: "App Timeout"
    modbus.0
    2024-02-25 18:53:39.517	info	Connected to slave
    modbus.0
    2024-02-25 18:53:37.510	info	Disconnected from slave 192.168.178.175
    modbus.0
    2024-02-25 18:53:36.510	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
    modbus.0
    2024-02-25 18:53:36.509	error	Client in error state.
    modbus.0
    2024-02-25 18:53:36.509	error	Request timed out.
    modbus.0
    2024-02-25 18:53:36.508	warn	Error: undefined
    modbus.0
    2024-02-25 18:53:31.708	error	unknown function code: 0x32, 0x36
    modbus.0
    2024-02-25 18:53:31.648	error	Wrong CRC for frame: 1,3,128,56,53,49,48,48,49,48,48,50,50,51,57,48,52,53,53,248,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,133,61,1,3,128,78,51,45,72,86,45,49,48,46,48,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,56,51,48,49,48,51,49,50,51,48,55,51,53
    modbus.0
    2024-02-25 18:53:31.505	info	Connected to slave
    modbus.0
    2024-02-25 18:53:29.501	info	Disconnected from slave 192.168.178.175
    modbus.0
    2024-02-25 18:53:28.501	error	Client in error state.
    modbus.0
    2024-02-25 18:53:28.500	error	Request timed out.
    modbus.0
    2024-02-25 18:53:28.500	warn	Error: undefined
    modbus.0
    2024-02-25 18:53:28.298	warn	Poll error count: 1 code: "App Timeout"
    modbus.0
    2024-02-25 18:50:32.027	info	Connected to slave
    modbus.0
    2024-02-25 18:50:30.021	info	Disconnected from
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      Pauschal mit den wenigen Informationen würde ich sagen Register falsch bzw. Falsch eingetragen
      Dazu wäre ein logfile im Debug mode sowie die Instanz, Register Einstellungen sowie mehr Infos zum WR hilfreich
      • wendy2702W wendy2702
        Miokoeln
        @wendy2702 Hoffe das hilft
        Bildschirmfoto 2024-02-25 um 19.27.43.png Bildschirmfoto 2024-02-25 um 19.27.28.png
        • M Miokoeln
          wendy2702W Offline
          wendy2702W Offline
          wendy2702
          @miokoeln ich glaube nicht das die Geräte ID richtig ist. So groß ist der Range nicht.
          Was hast du da eingetragen?
          Was steht dazu in der Doku zum WR?
          M 2 Antworten Letzte Antwort
            Miokoeln
            @wendy2702 Wo finde ich das? In der Datei zum WR Modbus Protocol steht nichts drin. In der App Steht Modbus-Adresse 1
              Miokoeln
              @wendy2702 Ich glaube das wars hab jetzt auf 1 geändert und Hacken bei mehrere Geräte rausgenommen. Hält bis jetzt schon 8 Minuten. Wie kann ich die Abfrage erhöhen das diese schneller geht?
              • M Miokoeln
                wendy2702W Offline
                wendy2702W Offline
                wendy2702
                @miokoeln was soll denn wie schnell abgefragt werden?
                Wie viele Register?
                Wenn ich das im Screenshot richtig sehe steht das Abfrage Intervall auf 5000msec, ist das zu langsam?
                  Wie viele Register?
                  Miokoeln
                  schrieb am zuletzt editiert von Miokoeln
                  @wendy2702
                  Will die alle dort einpfegen
                  N3 HV Modbus Protocol V1.00.pdf
                    Wie viele Register?
                    Miokoeln
                    @wendy2702 Ja sind ja 5 Sekunden. Wollte so auf eine Sekunde gehen
                    • M Miokoeln
                      wendy2702W Offline
                      wendy2702W Offline
                      wendy2702
                      @miokoeln eine Sekunde?
                      Wofür soll das gut sein?
                      Unabhängig davon wird das je nach Anzahl der Register eh ein Problem weil dann unter Umständen die letzten Register noch nicht beantwortet wurden während die ersten wieder abgefragt werden.
                        Miokoeln
                        @wendy2702
                        Ok verstehe, wollte den Adapter Energiefluss live haben. Aber wenn du denkst 5 Sekunden ist ok. Bin ich dabei.
                        • M Miokoeln
                          @wendy2702
                          wendy2702W Offline
                          wendy2702W Offline
                          wendy2702
                          @miokoeln den Energie Fluss nutze ich auch und funktioniert mit 5 Sekunden bei mir super
                            Miokoeln
                            @wendy2702
                            Alles klar dank dir für deine Hilfe. :-)
                              Miokoeln
                              @wendy2702 Kannst du mir noch einen Tipp geben.
                              Wie 'pflege ich das Register 11040 aus der Datei Modbus mit Bit15-Bit5:
                              Reserve; den Bits ein? Wo muss ich diese hinschreiben?
                              Bit4:
                              0 : Null;
                              1 :
                              Balance
                              charge
                              request
                              • M Miokoeln
                                Bit4:
                                0 : Null;
                                1 :
                                Balance
                                charge
                                request
                                wendy2702W Offline
                                wendy2702W Offline
                                wendy2702
                                @miokoeln hm,
                                Könnte ein Float sein 16Bit.
                                Die Bezeichnung Bitfield habe ich noch nicht gesehen bisher.
                                  @miokoeln hm,
                                  Miokoeln
                                  @wendy2702
                                  Dank dir ich versuche es. Frage mich halt wo ich die Bits hinschreibe
                                  • M Miokoeln
                                    @wendy2702
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    wendy2702
                                    @miokoeln Nix schreiben.
                                    Ist ein RO = ReadOnly
                                    Du liest den und bekommst einen Bit wert zurück und die Bits haben dann die entsprechenden Bedeutungen
                                      HomoranH Offline
                                      HomoranH Offline
                                      @wendy2702 klingt für mich wie ein dipswitch.
                                      alles zusammen ergibt eine Zahl
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        wendy2702
                                        @homoran laut Dokument Abfrage BMS status. Eher kein switch würde ich vermuten
                                          HomoranH Offline
                                          HomoranH Offline
                                          @wendy2702 sagte in Modbus Fehler bei Anbindung meines Wechselrichters von Renac:
                                          Eher kein switch
                                          nein! Wie ein Mäuseklavier.
                                          jede Position ein Bit (on/off) ergibt bei mehrerrn (8/16) Bits eine Zahl, die übertragen eird und due Stellung aller Schalter angibt
                                          Binärcodierung.
