  3. Off Topic
  4. InfluxDB
  5. Keinen zugriff auf Influx DB
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
33 Beiträge 4 Kommentatoren 4.4k Aufrufe 4 Beobachtet
    @herrx
    Grafana:
    sudo apt-get install -y apt-transport-https
    sudo apt-get install -y software-properties-common wget
    sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
    echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
    sudo apt update
    sudo apt install grafana
    Herrx
    @thomas-braun said in Keinen zugriff auf Influx DB:
        sudo apt update        sudo apt install grafana
    pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
    Reading package lists... Done
    Building dependency tree... Done
    apt-transport-https is already the newest version (2.6.1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    software-properties-common is already the newest version (0.99.30-4).
    wget is already the newest version (1.21.3-1+b1).
    pi@raspberrypi:~ $ sudo apt update
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    All packages are up to date.
    grafana is already the newest version (10.2.3).
    Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
    • H Herrx
      @herrx
      systemctl status grafana
      H 1 Antwort Letzte Antwort
        @herrx
        Herrx
        schrieb am zuletzt editiert von Herrx
        pi@raspberrypi:~ $ systemctl status grafana
        Unit grafana.service could not be found.
        pi@raspberrypi:~ $
        ?? Aber die Installation war doch ohne Probleme ?
        • H Herrx
          pi@raspberrypi:~ $
          @herrx
          systemctl status grafana*
            @herrx
            Herrx
            pi@raspberrypi:~ $ systemctl status grafana*
            pi@raspberrypi:~ $
            • H Herrx
              pi@raspberrypi:~ $
              @herrx
              sudo apt update
              apt policy grafana*
              • H Herrx
                pi@raspberrypi:~ $
                @herrx
                Bzw:
                sudo systemctl daemon-reload
                sudo systemctl start grafana-server
                sudo systemctl status grafana-server
                  @herrx
                  Bzw:
                  Herrx
                  ● grafana-server.service - Grafana instance
                       Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                       Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                         Docs: http://docs.grafana.org
                     Main PID: 19823 (grafana)
                        Tasks: 15 (limit: 457)
                          CPU: 9.853s
                       CGroup: /system.slice/grafana-server.service
                               └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                  Sehr cool danke. Jetzt geht es.
                  • Thomas BraunT Online
                    @herrx
                    Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                      @herrx
                      Herrx
                      @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                      • H Herrx
                        @herrx
                        sudo systemctl enable grafana-server.service
                        sudo systemctl start grafana-server.service
                          @herrx
                          Herrx
                          @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                          jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                          • H Herrx
                            @herrx sagte in Keinen zugriff auf Influx DB:
                            Nein, der Service sollte nun beim booten gestartet werden.
