  3. Off Topic
  4. InfluxDB
  5. Keinen zugriff auf Influx DB
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
33 Beiträge 4 Kommentatoren 4.4k Aufrufe 4 Beobachtet
  • H Herrx
    @thomas-braun said in Keinen zugriff auf Influx DB:
    systemctl status grafana
    pi@raspberrypi:~ $ systemctl status grafana
    Unit grafana.service could not be found.
    pi@raspberrypi:~ $
    ?? Aber die Installation war doch ohne Probleme ?
    @herrx
    systemctl status grafana*
    H 1 Antwort Letzte Antwort
      @herrx
      Herrx
      pi@raspberrypi:~ $ systemctl status grafana*
      pi@raspberrypi:~ $
      • H Herrx
        pi@raspberrypi:~ $
        @herrx
        sudo apt update
        apt policy grafana*
        • H Herrx
          pi@raspberrypi:~ $
          @herrx
          Bzw:
          sudo systemctl daemon-reload
          sudo systemctl start grafana-server
          sudo systemctl status grafana-server
            @herrx
            Bzw:
            Herrx
            schrieb am zuletzt editiert von Herrx
            ● grafana-server.service - Grafana instance
                 Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                 Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                   Docs: http://docs.grafana.org
               Main PID: 19823 (grafana)
                  Tasks: 15 (limit: 457)
                    CPU: 9.853s
                 CGroup: /system.slice/grafana-server.service
                         └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
            Sehr cool danke. Jetzt geht es.
            • Thomas BraunT Online
              @herrx
              Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                @herrx
                Herrx
                @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                • H Herrx
                  @herrx
                  sudo systemctl enable grafana-server.service
                  sudo systemctl start grafana-server.service
                    @herrx
                    Herrx
                    @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                    jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                    • H Herrx
                      @herrx sagte in Keinen zugriff auf Influx DB:
                      Nein, der Service sollte nun beim booten gestartet werden.
