  3. Off Topic
  4. InfluxDB
  5. Keinen zugriff auf Influx DB
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
33 Beiträge 4 Kommentatoren 4.4k Aufrufe 4 Beobachtet
    @herrx
    systemctl status grafana
    Herrx
    schrieb am zuletzt editiert von Herrx
    @thomas-braun said in Keinen zugriff auf Influx DB:
    pi@raspberrypi:~ $ systemctl status grafana
    Unit grafana.service could not be found.
    pi@raspberrypi:~ $
    ?? Aber die Installation war doch ohne Probleme ?
    • H Herrx
      pi@raspberrypi:~ $
      @herrx
      systemctl status grafana*
      H 1 Antwort Letzte Antwort
        @herrx
        Herrx
        pi@raspberrypi:~ $ systemctl status grafana*
        pi@raspberrypi:~ $
        • H Herrx
          pi@raspberrypi:~ $
          @herrx
          sudo apt update
          apt policy grafana*
          • H Herrx
            pi@raspberrypi:~ $
            @herrx
            Bzw:
            sudo systemctl daemon-reload
            sudo systemctl start grafana-server
            sudo systemctl status grafana-server
              @herrx
              Bzw:
              Herrx
              ● grafana-server.service - Grafana instance
                   Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                   Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                     Docs: http://docs.grafana.org
                 Main PID: 19823 (grafana)
                    Tasks: 15 (limit: 457)
                      CPU: 9.853s
                   CGroup: /system.slice/grafana-server.service
                           └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
              Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
              Sehr cool danke. Jetzt geht es.
              • Thomas BraunT Online
                @herrx
                Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                  @herrx
                  Herrx
                  @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                  • H Herrx
                    @herrx
                    sudo systemctl enable grafana-server.service
                    sudo systemctl start grafana-server.service
                      @herrx
                      Herrx
                      @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                      jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                      • H Herrx
                        @herrx sagte in Keinen zugriff auf Influx DB:
                        Nein, der Service sollte nun beim booten gestartet werden.
