  3. Off Topic
  4. InfluxDB
  5. Keinen zugriff auf Influx DB
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
33 Beiträge 4 Kommentatoren 4.4k Aufrufe 4 Beobachtet
  • H Herrx
    @thomas-braun said in Keinen zugriff auf Influx DB:
    sudo rm /etc/apt/sources.list.d/influx* wget -q https://repos.influxdata.com/influxdata-archive_compat.key echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list rm influxdata-archive_compat.ke*
    pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influx*
    influxdata-archive_compat.key: OK
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo apt update
    apt policy influx*
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Fetched 52.1 kB in 2s (26.4 kB/s)
    Reading package lists... Done
    All packages are up to date.
    influxdb2-cli:
      Installed: (none)
      Candidate: 2.7.3-1
      Version table:
         2.7.3-1 500
            500 https://repos.influxdata.com/debian stable/main arm64 Packages
         2.7.1-2 500
         2.6.1 500
         2.6.0 500
         2.5.0 500
         2.4.0 500
         2.3.0 500
    influxdb-client:
      Installed: (none)
      Candidate: 1.6.7~rc0-1+b13
      Version table:
         1.6.7~rc0-1+b13 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
    influxdb-dev:
      Installed: (none)
      Candidate: (none)
      Version table:
    influxdb2-client:
      Installed: (none)
      Candidate: 2.7.1-1
      Version table:
         2.7.1-1 500
    influxdb:
      Installed: 1.8.10-1
      Candidate: 1.8.10-1
      Version table:
     *** 1.8.10-1 500
         1.6.7~rc0-1+b13 500
    influxctl:
      Installed: (none)
      Candidate: 2.4.3
      Version table:
         2.4.3 500
         2.4.2 500
         2.4.1 500
         2.4.0 500
         2.3.1 500
         2.3.0 500
         2.2.0 500
         2.1.0 500
         2.0.4 500
         2.0.3 500
         2.0.2 500
         2.0.1 500
         2.0.0 500
    influxdb2:
      Installed: (none)
      Candidate: 2.7.5-1
      Version table:
         2.7.5-1 500
         2.7.4-1 500
         2.7.3-1 500
         2.7.1-1 500
         2.7.0-1 500
         2.6.1-1 500
         2.6.0-1 500
         2.5.1-1 500
         2.4.0-1 500
         2.3.0-1 500
         2.2.0 500
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list
    cat: /etc/apt/sources.list.d/influxdb.list: No such file or directory
    @herrx sagte in Keinen zugriff auf Influx DB:
    Richtig. Das heißt ja auch
    cat /etc/apt/sources.list.d/influxdata.list
    H 1 Antwort Letzte Antwort
      Herrx
      @thomas-braun Aber ich komme immer noch nicht auf das interface via http://RPI-IP:8086
      • H Herrx
        @herrx
        Wenn ich auf die Webseite gehe http://RPI-IP:8086 bekomme ich den Fehler 404 page not found.
        Kann ja auch nix kommen, die influxdb 1.8 hat auch kein WebGUI.
        Gibt es erst ab influxdb2.
          @herrx
          Herrx
          @thomas-braun Ah ok das macht Sinn. Hast du noch eine Anleitung um Grafana zu installieren =! Youtube?
          • H Herrx
            @herrx
            Grafana:
            sudo apt-get install -y apt-transport-https
            sudo apt-get install -y software-properties-common wget
            sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
            echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
            sudo apt update
            sudo apt install grafana
              @herrx
              Grafana:
              sudo apt update
              Herrx
        sudo apt update        sudo apt install grafana
              pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
              apt-transport-https is already the newest version (2.6.1).
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              software-properties-common is already the newest version (0.99.30-4).
              wget is already the newest version (1.21.3-1+b1).
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              grafana is already the newest version (10.2.3).
              Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
              • H Herrx
                @herrx
                systemctl status grafana
                  @herrx
                  Herrx
                  schrieb am zuletzt editiert von Herrx
                  pi@raspberrypi:~ $ systemctl status grafana
                  Unit grafana.service could not be found.
                  pi@raspberrypi:~ $
                  ?? Aber die Installation war doch ohne Probleme ?
                  • H Herrx
                    pi@raspberrypi:~ $
                    @herrx
                    systemctl status grafana*
                      @herrx
                      Herrx
                      pi@raspberrypi:~ $ systemctl status grafana*
                      pi@raspberrypi:~ $
                      • H Herrx
                        pi@raspberrypi:~ $
                        @herrx
                        sudo apt update
                        apt policy grafana*
                        • H Herrx
                          pi@raspberrypi:~ $
                          @herrx
                          Bzw:
                          sudo systemctl daemon-reload
                          sudo systemctl start grafana-server
                          sudo systemctl status grafana-server
                            @herrx
                            Bzw:
                            Herrx
                            ● grafana-server.service - Grafana instance
                                 Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                                 Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                                   Docs: http://docs.grafana.org
                               Main PID: 19823 (grafana)
                                  Tasks: 15 (limit: 457)
                                    CPU: 9.853s
                                 CGroup: /system.slice/grafana-server.service
                                         └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                            Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                            Sehr cool danke. Jetzt geht es.
                            • Thomas BraunT Online
                              @herrx
                              Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                                @herrx
                                Herrx
                                @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                                • H Herrx
                                  @herrx
                                  sudo systemctl enable grafana-server.service
                                  sudo systemctl start grafana-server.service
                                    @herrx
                                    Herrx
                                    @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                                    jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                                    • H Herrx
                                      Nein, der Service sollte nun beim booten gestartet werden.
