  4. Fehlermeldungen beim Biobroker Update
37 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
    @volleyhomer sagte in Fehlermeldungen beim Biobroker Update:
    curl -kL https://iobroker.net/fix.sh | bash -
    V Offline
    V Offline
    Volleyhomer
    @thomas-braun said in Fehlermeldungen beim Biobroker Update:
    Das lief scheinbar durch.
    pi@rock64:~$ curl -kL https://iobroker.net/fix.sh | bash -
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100   185  100   185    0     0    916      0 --:--:-- --:--:-- --:--:--   915
    100 39849  100 39849    0     0  59580      0 --:--:-- --:--:-- --:--:-- 59580
    library: loaded
    Library version=2024-01-04
        Welcome to the ioBroker installation fixer!
        Script version: 2024-01-04
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Ign:1 http://security.debian.org stretch/updates InRelease
    Ign:2 http://httpredir.debian.org/debian stretch InRelease
    Err:3 http://security.debian.org stretch/updates Release
      404  Not Found [IP: 146.75.122.132 80]
    Ign:4 http://httpredir.debian.org/debian stretch-updates InRelease
    Ign:5 http://httpredir.debian.org/debian stretch-backports InRelease
    Err:6 http://httpredir.debian.org/debian stretch Release
    Err:7 http://httpredir.debian.org/debian stretch-updates Release
    Err:8 http://httpredir.debian.org/debian stretch-backports Release
    Hit:10 https://deb.nodesource.com/node_14.x stretch InRelease
    Hit:9 http://fi.mirror.armbian.de/apt stretch InRelease
    Reading package lists... Done
    E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: The repository 'http://httpredir.debian.org/debian stretch Release' does no longer have a Release file.
    E: The repository 'http://httpredir.debian.org/debian stretch-updates Release' does no longer have a Release file.
    E: The repository 'http://httpredir.debian.org/debian stretch-backports Release' does no longer have a Release file.
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed libpixman-1-dev
    Installed cmake
        Checking ioBroker user and directory permissions (2/5)
    Created /etc/sudoers.d/iobroker
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npx: installed 12 in 14.437s
    No path given, using /opt/iobroker/iobroker-data
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
    • V Volleyhomer
      library: loaded
      Installed cmake
      Done.
      Autostart enabled!
      @volleyhomer
      Die ganzen Stretch-Quellen sind natürlich vor geraumer Zeit trockengelegt worden... Never change a running system, was?
      Funktioniert
      iob nodejs-update 16
      denn nun?
      V 1 Antwort Letzte Antwort
        @volleyhomer
        Funktioniert
        denn nun?
        V Offline
        V Offline
        Volleyhomer
        schrieb am zuletzt editiert von Volleyhomer
        @volleyhomer
        Funktioniert
        denn nun?
        Es gibt keine Fehlermeldung mehr. Muss iobroker dafür laufen? Is ja aktuell noch gestoppt.
        pi@rock64:~$ iob nodejs-update 16
        pi@rock64:~$
        Ist das Problem denn jetzt die alte debian oder die alte npm, node, etc. Version?
        • V Volleyhomer
          @volleyhomer
          Funktioniert
          denn nun?
          pi@rock64:~$
          Alles zusammen. Da ist ja gar nix aktuell bei dir.
          • V Volleyhomer
            @volleyhomer
            Funktioniert
            denn nun?
            pi@rock64:~$
            @volleyhomer
            Versuch:
            NODE_MAJOR=16
            sudo apt update
            sudo apt install -y ca-certificates curl gnupg
            sudo mkdir -p /etc/apt/keyrings
            curl -kL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
            echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
            echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
            sudo apt update
            sudo apt install nodejs
              @volleyhomer
              Versuch:
              NODE_MAJOR=16
              sudo apt update
              sudo apt update
              V Offline
              V Offline
              Volleyhomer
              NODE_MAJOR=16
              Hagelt Fehlermeldungen. Ich glaube ich muss mir dann mal ein Wochenende frei nehmen, die Kinder ausquartieren und in Ruhe mich einlesen und alles neu aufsetzen.
              NodeJS Update scheint aber geklappt zu haben.
              pi@rock64:~$ NODE_MAJOR=16
              pi@rock64:~$ sudo apt update
              [sudo] password for pi:
              Ign:1 http://httpredir.debian.org/debian stretch InRelease
              Ign:2 http://security.debian.org stretch/updates InRelease
              Hit:9 http://mirrors.dotsrc.org/armbian-apt stretch InRelease
              pi@rock64:~$ sudo apt install -y ca-certificates curl gnupg
              Building dependency tree
              gnupg is already the newest version (2.1.18-8~deb9u4).
              The following packages will be upgraded:
                ca-certificates curl libcurl3
              3 upgraded, 0 newly installed, 0 to remove and 132 not upgraded.
              Need to get 652 kB of archives.
              After this operation, 35.8 kB of additional disk space will be used.
              Ign:1 http://security.debian.org stretch/updates/main arm64 ca-certificates all 20200601~deb9u2
              Err:2 http://security.debian.org stretch/updates/main arm64 curl arm64 7.52.1-5+deb9u16
              Err:3 http://security.debian.org stretch/updates/main arm64 libcurl3 arm64 7.52.1-5+deb9u16
              Err:1 http://security.debian.org stretch/updates/main armhf ca-certificates all 20200601~deb9u2
              E: Failed to fetch http://security.debian.org/pool/updates/main/c/ca-certificates/ca-certificates_20200601~deb9u2_all.deb  404  Not Found [IP: 146.75.122.132 80]
              E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/curl_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
              E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/libcurl3_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
              E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
              pi@rock64:~$ sudo mkdir -p /etc/apt/keyrings
              pi@rock64:~$
              pi@rock64:~$ curl -kL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
              100  1684  100  1684    0     0   7395      0 --:--:-- --:--:-- --:--:--  7385
              pi@rock64:~$ echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x nodistro main
              pi@rock64:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
              Package: nodejs
              Pin-Priority: 1001
              Ign:3 http://httpredir.debian.org/debian stretch-updates InRelease
              Err:4 http://security.debian.org stretch/updates Release
              Get:10 https://deb.nodesource.com/node_16.x nodistro InRelease [12.1 kB]
              Get:11 https://deb.nodesource.com/node_16.x nodistro/main armhf Packages [7469 B]
              Get:12 https://deb.nodesource.com/node_16.x nodistro/main arm64 Packages [7485 B]
              Get:13 https://deb.nodesource.com/node_16.x nodistro/main arm64 Contents (deb) [19.5 kB]
              Get:14 https://deb.nodesource.com/node_16.x nodistro/main armhf Contents (deb) [19.5 kB]
              pi@rock64:~$ sudo apt install nodejs
                nodejs
              1 upgraded, 0 newly installed, 0 to remove and 135 not upgraded.
              Need to get 27.2 MB of archives.
              After this operation, 7285 kB of additional disk space will be used.
              Get:1 https://deb.nodesource.com/node_16.x nodistro/main arm64 nodejs arm64 16.20.2-1nodesource1 [27.2 MB]
              Fetched 27.2 MB in 6s (3939 kB/s)
              (Reading database ... 38255 files and directories currently installed.)
              Preparing to unpack .../nodejs_16.20.2-1nodesource1_arm64.deb ...
              Detected old npm client, removing...
              Unpacking nodejs (16.20.2-1nodesource1) over (14.21.3-1nodesource1) ...
              Setting up nodejs (16.20.2-1nodesource1) ...
              Processing triggers for man-db (2.7.6.1-2) ...
              pi@rock64:~$
              • V Volleyhomer
                NODE_MAJOR=16
                pi@rock64:~$
                Package: nodejs
                Pin-Priority: 1001
                  nodejs
                pi@rock64:~$
                V Offline
                V Offline
                Volleyhomer
                @volleyhomer said in Fehlermeldungen beim Biobroker Update:
                NODE_MAJOR=16
                pi@rock64:~$
                Package: nodejs
                Pin-Priority: 1001
                  nodejs
                pi@rock64:~$
                Obwohl...
                pi@rock64:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v16.20.2
                v16.20.2
                8.19.4
                8.19.4
                pi@rock64:~$
                • V Volleyhomer
                  NODE_MAJOR=16
                  pi@rock64:~$
                  Package: nodejs
                  Pin-Priority: 1001
                    nodejs
                  pi@rock64:~$
                  Obwohl...
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v16.20.2
                  v16.20.2
                  8.19.4
                  8.19.4
                  pi@rock64:~$
                  Obwohl
                  dann besteht Hoffnung die wichtigsten Komponenten von iobroker relativ aktuell zu bekommen.
                  dann backup
                  Neuinstallation
                  Restore
                  am besten jetzt das erste backup starten und an sicherer Stelle extern speichern
                  geht denn jetzt iob diag?
                  • V Volleyhomer
                    NODE_MAJOR=16
                    pi@rock64:~$
                    Package: nodejs
                    Pin-Priority: 1001
                      nodejs
                    pi@rock64:~$
                    Obwohl...
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v16.20.2
                    v16.20.2
                    8.19.4
                    8.19.4
                    pi@rock64:~$
                    @volleyhomer
                    Natürlich...
                    Aber nodejs@16 ist jetzt drauf, das ist die höchste Version die du da drauf bekommst. Alles andere braucht auch ein aktuelleres Betriebssystem.
                    iob stop
                    iob update
                    iob upgrade self
                      Obwohl
                      dann backup
                      Neuinstallation
                      Restore
                      V Offline
                      V Offline
                      Volleyhomer
                      @homoran said in Fehlermeldungen beim Biobroker Update:
                      Obwohl
                      dann backup
                      Neuinstallation
                      Restore
                      Nein, geht nicht.
                      pi@rock64:~$ iob diag
                      pi@rock64:~$
                      Backups kopiere ich nach dem erstellen immer direkt via filezilla in die icloud. Normalerweise via backitup auch auf das NAS.
                        @volleyhomer
                        Natürlich...
                        iob stop
                        iob update
                        iob upgrade self
                        V Offline
                        V Offline
                        Volleyhomer
                        @volleyhomer
                        Natürlich...
                        iob stop
                        iob update
                        iob upgrade self
                        Ich hab gerade kurz bzgl. debian Update gegoogelt. Habe ich keine Ahnung von, scheint ja aber nicht wild zu sein. Geht sowas "am offenen Herzen"? Ich bekomme nächste Woche eine neue eMMC für den ROCK64 und werde damit dann alles nochmal neu aufsetzen.
                        • V Volleyhomer
                          @volleyhomer
                          Natürlich...
                          iob stop
                          iob update
                          iob upgrade self
                          Aber nicht über drei Releases aus einer Ruine heraus.
                          Bring den iobroker jetzt auf den höchstmöglichen Stand, zieh ein Backup und dann spielst du das sauber in ein frisch installiertes Debian 12 'Bookworm' wieder ein.
                            V Offline
                            V Offline
                            Volleyhomer
                            Okay. Das werde ich dann irgendwann die nächsten Tage angehen. Vielen Dank für deine Mühe, Zeit und Hilfe!
                            • V Offline
                              V Offline
                              Volleyhomer
                              @Thomas-Braun :
                              Ein Problem habe ich jetzt noch. Wenn ich Adapter updaten will (u.a. auch Admin) dann wird mir in der iobroker UI folgendes angezeigt.
                              Dependencies
                              js-controller (>=3.3.0): 4.0.24
                              admin (>=5.1.28): 6.3.5
                              node (>=16): 14.21.3
                              angezeigt. Version ist laut Kommando Zeile aber:
                              pi@rock64:~$ node -v
                              v16.20.2
                              pi@rock64:~$
                              Muss man da noch irgendwas reseten? Neu starten? Oder ähnliches?
                              • V Volleyhomer
                                @Thomas-Braun :
                                Dependencies
                                v16.20.2
                                pi@rock64:~$
                                Neu starten?
                                Würde ich machen.
                                Und dann nochmal
                                iob diag
                                  Neu starten?
                                  Würde ich machen.
                                  Und dann nochmal
                                  iob diag
                                  V Offline
                                  V Offline
                                  Volleyhomer
                                  Neu starten?
                                  Würde ich machen.
                                  Und dann nochmal
                                  iob diag
                                  Okay, nochmals danke dir.
                                  Ein harter Reboot hat geholfen. Jetzt wird im UI auch die korrekten Versionen erkannt.
                                  Dann hoffe ich, dass ich beim neuen Aufsetzen so klar komme; Sonst melde ich mich wieder :-)
                                  Schönen Sonntagabend noch!
                                  W 1 Antwort Letzte Antwort
                                  • V Volleyhomer
                                    Neu starten?
                                    Würde ich machen.
                                    Und dann nochmal
                                    iob diag
                                    W Online
                                    W Online
                                    Wildbill
                                    schrieb am zuletzt editiert von Wildbill
                                    Was ist ein „harter“ Reboot? Strom weg und gut? Das solltest Du tunlichst vermeiden. Die Chancen stehen gut, Dir dabei mindestens das Dateisystem zu zerstören (geöffnete Dateien und welche, die gerade beschrieben werden sind danach in unbrauchbarem Zustand), beim Raspi kannst Du so auch relativ einfach die SD-Karte zerstören, so dass Du eine neue kaufen musst.
                                    Reboot immer sauber mittels
                                    sudo reboot
                                    oder zum Abschalten
                                    sudo shutdown -h now
                                    Gruss, Jürgen
