  4. Fehlermeldungen beim Biobroker Update
37 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
  • V Volleyhomer
    @volleyhomer said in Fehlermeldungen beim Biobroker Update:
    @thomas-braun said in Fehlermeldungen beim Biobroker Update:
    NODE_MAJOR=16
    Hagelt Fehlermeldungen. Ich glaube ich muss mir dann mal ein Wochenende frei nehmen, die Kinder ausquartieren und in Ruhe mich einlesen und alles neu aufsetzen.
    NodeJS Update scheint aber geklappt zu haben.
    pi@rock64:~$ NODE_MAJOR=16
    pi@rock64:~$ sudo apt update
    [sudo] password for pi:
    Ign:1 http://httpredir.debian.org/debian stretch InRelease
    Ign:2 http://security.debian.org stretch/updates InRelease
    Err:3 http://security.debian.org stretch/updates Release
      404  Not Found [IP: 146.75.122.132 80]
    Ign:4 http://httpredir.debian.org/debian stretch-updates InRelease
    Ign:5 http://httpredir.debian.org/debian stretch-backports InRelease
    Err:6 http://httpredir.debian.org/debian stretch Release
    Err:7 http://httpredir.debian.org/debian stretch-updates Release
    Err:8 http://httpredir.debian.org/debian stretch-backports Release
    Hit:10 https://deb.nodesource.com/node_14.x stretch InRelease
    Hit:9 http://mirrors.dotsrc.org/armbian-apt stretch InRelease
    Reading package lists... Done
    E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    E: The repository 'http://httpredir.debian.org/debian stretch Release' does no longer have a Release file.
    E: The repository 'http://httpredir.debian.org/debian stretch-updates Release' does no longer have a Release file.
    E: The repository 'http://httpredir.debian.org/debian stretch-backports Release' does no longer have a Release file.
    pi@rock64:~$ sudo apt install -y ca-certificates curl gnupg
    Building dependency tree
    gnupg is already the newest version (2.1.18-8~deb9u4).
    The following packages will be upgraded:
      ca-certificates curl libcurl3
    3 upgraded, 0 newly installed, 0 to remove and 132 not upgraded.
    Need to get 652 kB of archives.
    After this operation, 35.8 kB of additional disk space will be used.
    Ign:1 http://security.debian.org stretch/updates/main arm64 ca-certificates all 20200601~deb9u2
    Err:2 http://security.debian.org stretch/updates/main arm64 curl arm64 7.52.1-5+deb9u16
    Err:3 http://security.debian.org stretch/updates/main arm64 libcurl3 arm64 7.52.1-5+deb9u16
    Err:1 http://security.debian.org stretch/updates/main armhf ca-certificates all 20200601~deb9u2
    E: Failed to fetch http://security.debian.org/pool/updates/main/c/ca-certificates/ca-certificates_20200601~deb9u2_all.deb  404  Not Found [IP: 146.75.122.132 80]
    E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/curl_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
    E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/libcurl3_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    pi@rock64:~$ sudo mkdir -p /etc/apt/keyrings
    pi@rock64:~$
    pi@rock64:~$ curl -kL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100  1684  100  1684    0     0   7395      0 --:--:-- --:--:-- --:--:--  7385
    pi@rock64:~$ echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x nodistro main
    pi@rock64:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
    Package: nodejs
    Pin-Priority: 1001
    Ign:1 http://security.debian.org stretch/updates InRelease
    Ign:2 http://httpredir.debian.org/debian stretch InRelease
    Ign:3 http://httpredir.debian.org/debian stretch-updates InRelease
    Err:4 http://security.debian.org stretch/updates Release
    Get:10 https://deb.nodesource.com/node_16.x nodistro InRelease [12.1 kB]
    Get:11 https://deb.nodesource.com/node_16.x nodistro/main armhf Packages [7469 B]
    Get:12 https://deb.nodesource.com/node_16.x nodistro/main arm64 Packages [7485 B]
    Get:13 https://deb.nodesource.com/node_16.x nodistro/main arm64 Contents (deb) [19.5 kB]
    Get:14 https://deb.nodesource.com/node_16.x nodistro/main armhf Contents (deb) [19.5 kB]
    pi@rock64:~$ sudo apt install nodejs
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 135 not upgraded.
    Need to get 27.2 MB of archives.
    After this operation, 7285 kB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x nodistro/main arm64 nodejs arm64 16.20.2-1nodesource1 [27.2 MB]
    Fetched 27.2 MB in 6s (3939 kB/s)
    (Reading database ... 38255 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.20.2-1nodesource1_arm64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (16.20.2-1nodesource1) over (14.21.3-1nodesource1) ...
    Setting up nodejs (16.20.2-1nodesource1) ...
    Processing triggers for man-db (2.7.6.1-2) ...
    pi@rock64:~$
    Obwohl...
    pi@rock64:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v16.20.2
    v16.20.2
    8.19.4
    8.19.4
    pi@rock64:~$
    @volleyhomer sagte in Fehlermeldungen beim Biobroker Update:
    Obwohl
    dann besteht Hoffnung die wichtigsten Komponenten von iobroker relativ aktuell zu bekommen.
    dann backup
    Neuinstallation
    Restore
    am besten jetzt das erste backup starten und an sicherer Stelle extern speichern
    geht denn jetzt iob diag?
    V 1 Antwort Letzte Antwort
    • V Volleyhomer
      NODE_MAJOR=16
      pi@rock64:~$
      Package: nodejs
      Pin-Priority: 1001
        nodejs
      pi@rock64:~$
      Obwohl...
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v16.20.2
      v16.20.2
      8.19.4
      8.19.4
      pi@rock64:~$
      @volleyhomer
      Natürlich...
      Aber nodejs@16 ist jetzt drauf, das ist die höchste Version die du da drauf bekommst. Alles andere braucht auch ein aktuelleres Betriebssystem.
      iob stop
      iob update
      iob upgrade self
        Obwohl
        dann backup
        Neuinstallation
        Restore
        V Offline
        V Offline
        Volleyhomer
        @homoran said in Fehlermeldungen beim Biobroker Update:
        Obwohl
        dann backup
        Neuinstallation
        Restore
        Nein, geht nicht.
        pi@rock64:~$ iob diag
        pi@rock64:~$
        Backups kopiere ich nach dem erstellen immer direkt via filezilla in die icloud. Normalerweise via backitup auch auf das NAS.
          @volleyhomer
          Natürlich...
          iob stop
          iob update
          iob upgrade self
          V Offline
          V Offline
          Volleyhomer
          @volleyhomer
          Natürlich...
          iob stop
          iob update
          iob upgrade self
          Ich hab gerade kurz bzgl. debian Update gegoogelt. Habe ich keine Ahnung von, scheint ja aber nicht wild zu sein. Geht sowas "am offenen Herzen"? Ich bekomme nächste Woche eine neue eMMC für den ROCK64 und werde damit dann alles nochmal neu aufsetzen.
          • V Volleyhomer
            @volleyhomer
            Natürlich...
            iob stop
            iob update
            iob upgrade self
            Aber nicht über drei Releases aus einer Ruine heraus.
            Bring den iobroker jetzt auf den höchstmöglichen Stand, zieh ein Backup und dann spielst du das sauber in ein frisch installiertes Debian 12 'Bookworm' wieder ein.
              V Offline
              V Offline
              Volleyhomer
              Okay. Das werde ich dann irgendwann die nächsten Tage angehen. Vielen Dank für deine Mühe, Zeit und Hilfe!
              • V Offline
                V Offline
                Volleyhomer
                schrieb am zuletzt editiert von Volleyhomer
                @Thomas-Braun :
                Ein Problem habe ich jetzt noch. Wenn ich Adapter updaten will (u.a. auch Admin) dann wird mir in der iobroker UI folgendes angezeigt.
                Dependencies
                js-controller (>=3.3.0): 4.0.24
                admin (>=5.1.28): 6.3.5
                node (>=16): 14.21.3
                angezeigt. Version ist laut Kommando Zeile aber:
                pi@rock64:~$ node -v
                v16.20.2
                pi@rock64:~$
                Muss man da noch irgendwas reseten? Neu starten? Oder ähnliches?
                • V Volleyhomer
                  @Thomas-Braun :
                  Dependencies
                  v16.20.2
                  pi@rock64:~$
                  Neu starten?
                  Würde ich machen.
                  Und dann nochmal
                  iob diag
                    Neu starten?
                    Würde ich machen.
                    Und dann nochmal
                    iob diag
                    V Offline
                    V Offline
                    Volleyhomer
                    Neu starten?
                    Würde ich machen.
                    Und dann nochmal
                    iob diag
                    Okay, nochmals danke dir.
                    Ein harter Reboot hat geholfen. Jetzt wird im UI auch die korrekten Versionen erkannt.
                    Dann hoffe ich, dass ich beim neuen Aufsetzen so klar komme; Sonst melde ich mich wieder :-)
                    Schönen Sonntagabend noch!
                    W 1 Antwort Letzte Antwort
                    • V Volleyhomer
                      Neu starten?
                      Würde ich machen.
                      Und dann nochmal
                      iob diag
                      W Online
                      W Online
                      Wildbill
                      schrieb am zuletzt editiert von Wildbill
                      Was ist ein „harter“ Reboot? Strom weg und gut? Das solltest Du tunlichst vermeiden. Die Chancen stehen gut, Dir dabei mindestens das Dateisystem zu zerstören (geöffnete Dateien und welche, die gerade beschrieben werden sind danach in unbrauchbarem Zustand), beim Raspi kannst Du so auch relativ einfach die SD-Karte zerstören, so dass Du eine neue kaufen musst.
                      Reboot immer sauber mittels
                      sudo reboot
                      oder zum Abschalten
                      sudo shutdown -h now
                      Gruss, Jürgen
