  4. Fehlermeldungen beim Biobroker Update
37 Beiträge 4 Kommentatoren 4.0k Aufrufe 3 Beobachtet
  • V Offline
    V Offline
    Volleyhomer
    schrieb am zuletzt editiert von Volleyhomer
    mir wurde in der Facebook "iobroker SmartHome und IoT" Gruppe schon ein wenig geholfen und ich wurde darum geben hier mein Diagnose Log rein zu stellen.
    Vielen Dank schon mal dafür. Ich hoffe das funktioniert mit dem angehängten log File.
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    ======== Start marking the full check here =========
    Skript v.2023-10-25
    *** BASE SYSTEM ***
       Static hostname: rock64
             Icon name: computer
      Operating System: Debian GNU/Linux 9 (stretch)
                Kernel: Linux 4.4.192-rockchip64
          Architecture: arm64
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     11:59:39 up 20:43,  1 user,  load average: 1.35, 1.38, 0.98
    CPU threads: 4
    *** Time and Time Zones ***
          Local time: Sat 2024-01-20 11:59:39 CET
      Universal time: Sat 2024-01-20 10:59:39 UTC
            RTC time: Sat 2024-01-20 10:59:39
     Network time on: yes
    NTP synchronized: yes
     RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal:
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           4.1G        1.4G        2.1G        9.2M        651M        2.6G
    Swap:          1.0G          0B        1.0G
    Total:         5.1G        1.4G        3.1G
             3988 M total memory
             1347 M used memory
             1556 M active memory
              280 M inactive memory
             2004 M free memory
               77 M buffer memory
              559 M swap cache
             1023 M total swap
                0 M used swap
             1023 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     399M  5.4M  394M   2% /run
    /dev/mmcblk0p1 ext4       15G  4.8G  9.2G  34% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    tmpfs          tmpfs     2.0G  636K  2.0G   1% /tmp
    /dev/zram0     ext4       49M  3.9M   42M   9% /var/log
    tmpfs          tmpfs     399M     0  399M   0% /run/user/1000
    [Fri Jan 19 15:16:20 2024] Kernel command line: earlycon=uart8250,mmio32,0xff130000 swiotlb=1 kpti=0 no_console_suspend=1 usbcore.autosuspend=-1 root=UUID=aadb45fc-8b8b-4b5b-ad50-7e6416a4e1c5 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=9dd9d2a5-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    [Fri Jan 19 15:16:30 2024] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
    [Fri Jan 19 15:16:30 2024] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
    [Fri Jan 19 15:16:31 2024] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
    [Sat Jan 20 11:55:20 2024] EXT4-fs warning (device zram0): ext4_dirent_csum_verify:353: inode #11: comm du: No space for directory leaf checksum. Please run e2fsck -D.
    [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 4096
    [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 8192
    [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 12288
    Show mounted filesystems:
    TARGET                                SOURCE                   FSTYPE     OPTIONS
    /                                     /dev/mmcblk0p1           ext4       rw,noatime,nodiratime,errors=remount-ro,commit=600
    |-/sys                                sysfs                    sysfs      rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/security              securityfs               securityfs rw,nosuid,nodev,noexec,relatime
    | |-/sys/fs/cgroup                    tmpfs                    tmpfs      ro,nosuid,nodev,noexec,mode=755
    | | |-/sys/fs/cgroup/systemd          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd
    | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
    | | |-/sys/fs/cgroup/memory           cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,memory
    | | |-/sys/fs/cgroup/blkio            cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,blkio
    | | |-/sys/fs/cgroup/freezer          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,freezer
    | | |-/sys/fs/cgroup/hugetlb          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,hugetlb
    | | |-/sys/fs/cgroup/pids             cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,pids
    | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
    | | |-/sys/fs/cgroup/perf_event       cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
    | | |-/sys/fs/cgroup/devices          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,devices
    | | `-/sys/fs/cgroup/cpuset           cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
    | |-/sys/fs/pstore                    pstore                   pstore     rw,nosuid,nodev,noexec,relatime
    | |-/sys/kernel/debug                 debugfs                  debugfs    rw,relatime
    | | `-/sys/kernel/debug/tracing       tracefs                  tracefs    rw,relatime
    | |-/sys/kernel/config                configfs                 configfs   rw,relatime
    | `-/sys/fs/fuse/connections          fusectl                  fusectl    rw,relatime
    |-/proc                               proc                     proc       rw,nosuid,nodev,noexec,relatime
    | `-/proc/sys/fs/binfmt_misc          systemd-1                autofs     rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
    |-/dev                                udev                     devtmpfs   rw,nosuid,relatime,size=2039432k,nr_inodes=509858,mode=755
    | |-/dev/pts                          devpts                   devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
    | |-/dev/shm                          tmpfs                    tmpfs      rw,nosuid,nodev
    | |-/dev/mqueue                       mqueue                   mqueue     rw,relatime
    | `-/dev/hugepages                    hugetlbfs                hugetlbfs  rw,relatime
    |-/run                                tmpfs                    tmpfs      rw,nosuid,noexec,relatime,size=408448k,mode=755
    | |-/run/lock                         tmpfs                    tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
    | |-/run/rpc_pipefs                   sunrpc                   rpc_pipefs rw,relatime
    | `-/run/user/1000                    tmpfs                    tmpfs      rw,nosuid,nodev,relatime,size=408444k,mode=700,uid=1000,gid=1000
    |-/tmp                                tmpfs                    tmpfs      rw,nosuid,relatime
    |-/var/log.hdd                        /dev/mmcblk0p1[/var/log] ext4       rw,noatime,nodiratime,errors=remount-ro,commit=600
    `-/var/log                            /dev/zram0               ext4       rw,relatime,discard
    /var:
    569M	/var/
    286M	/var/lib
    274M	/var/cache
    269M	/var/cache/apt
    266M	/var/lib/apt/lists
    Archived and active journals take up 4.9M in the file system.
    /opt/iobroker/backups:
    71M	/opt/iobroker/backups/
    43M	/opt/iobroker/backups/Alt
    /opt/iobroker/iobroker-data:
    357M	/opt/iobroker/iobroker-data/
    234M	/opt/iobroker/iobroker-data/files
    83M	/opt/iobroker/iobroker-data/backup-objects
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    51M	/opt/iobroker/iobroker-data/files/javascript.admin
    23M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.2M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v14.21.3
    /usr/bin/node 		v14.21.3
    /usr/bin/npm 		6.14.18
    /usr/bin/npx 		6.14.18
    /usr/bin/corepack 	0.15.1
    nodejs:
      Installed: 14.21.3-1nodesource1
      Candidate: 14.21.3-1nodesource1
      Version table:
     *** 14.21.3-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x stretch/main arm64 Packages
            100 /var/lib/dpkg/status
         8.11.1~dfsg-2~bpo9+1 100
            100 http://httpredir.debian.org/debian stretch-backports/main arm64 Packages
         4.8.2~dfsg-1 500
            500 http://httpredir.debian.org/debian stretch/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	6.1.4
    Adapters from github: 	3
    Adapter State
    + system.adapter.admin.0                  : admin                 : rock64                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : rock64                                   - disabled
    + system.adapter.bluelink.0               : bluelink              : rock64                                   -  enabled
    + system.adapter.discovery.0              : discovery             : rock64                                   -  enabled
      system.adapter.fronius.0                : fronius               : rock64                                   - disabled
    + system.adapter.fronius.1                : fronius               : rock64                                   -  enabled
    + system.adapter.history.0                : history               : rock64                                   -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : rock64                                   -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : rock64                                   -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : rock64                                   -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : rock64                                   -  enabled, port: 443
    + system.adapter.info.0                   : info                  : rock64                                   -  enabled
    + system.adapter.iot.0                    : iot                   : rock64                                   -  enabled
    + system.adapter.javascript.0             : javascript            : rock64                                   -  enabled
      system.adapter.midea.0                  : midea                 : rock64                                   - disabled
    + system.adapter.mihome.0                 : mihome                : rock64                                   -  enabled, port: 9898, bind: 192.168.0.176
    + system.adapter.pushover.0               : pushover              : rock64                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : rock64                                   -  enabled, port: 1882, bind: 192.168.0.176
    + system.adapter.telegram.0               : telegram              : rock64                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : rock64                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : rock64                                   -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rock64                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rock64                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : rock64                                   -  enabled
      system.adapter.vis.0                    : vis                   : rock64                                   -  enabled
    + system.adapter.web.0                    : web                   : rock64                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : rock64                                   -  enabled
    + system.adapter.yahka.1                  : yahka                 : rock64                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 2.9.8    , installed 2.8.1  [Updatable]
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.2  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
    Adapter    "hue"          : 3.10.1   , installed 3.7.1  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
    Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
    Adapter    "telegram"     : 3.0.1    , installed 1.15.6 [Updatable]
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
    Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
    Adapter    "worx"         : 2.3.4    , installed 2.3.2  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Objects and States
    Objects: 	5463
    States: 	3094
    Pending Updates: 136
    *** Listening Ports ***
    Netid  State      Recv-Q Send-Q Local Address:Port               Peer Address:Port
    udp    UNCONN     0      0         *:9898                  *:*                   users:(("io.mihome.0",pid=1750,fd=27))
    udp    UNCONN     0      0         *:68                    *:*                   users:(("dhclient",pid=906,fd=6))
    udp    UNCONN     0      0         *:111                   *:*                   users:(("rpcbind",pid=443,fd=6))
    udp    UNCONN     0      0      192.168.0.176:123                   *:*                   users:(("ntpd",pid=1481,fd=19))
    udp    UNCONN     0      0      127.0.0.1:123                   *:*                   users:(("ntpd",pid=1481,fd=18))
    udp    UNCONN     0      0         *:123                   *:*                   users:(("ntpd",pid=1481,fd=17))
    udp    UNCONN     0      0         *:619                   *:*                   users:(("rpcbind",pid=443,fd=7))
    udp    UNCONN     0      0         *:5353                  *:*                   users:(("io.yahka.1",pid=2294,fd=27))
    udp    UNCONN     0      0        :::111                  :::*                   users:(("rpcbind",pid=443,fd=9))
    udp    UNCONN     0      0       fdad:a636:5c1e:ff4d:8907:c27d:dc5a:3529:123                  :::*                   users:(("ntpd",pid=1481,fd=25))
    udp    UNCONN     0      0      fe80::f777:1c02:d801:d955%eth0:123                  :::*                   users:(("ntpd",pid=1481,fd=21))
    udp    UNCONN     0      0       ::1:123                  :::*                   users:(("ntpd",pid=1481,fd=20))
    udp    UNCONN     0      0        :::123                  :::*                   users:(("ntpd",pid=1481,fd=16))
    udp    UNCONN     0      0        :::619                  :::*                   users:(("rpcbind",pid=443,fd=10))
    tcp    LISTEN     0      128    127.0.0.1:9000                  *:*                   users:(("iobroker.js-con",pid=838,fd=26))
    tcp    LISTEN     0      128    127.0.0.1:9001                  *:*                   users:(("iobroker.js-con",pid=838,fd=20))
    tcp    LISTEN     0      128       *:111                   *:*                   users:(("rpcbind",pid=443,fd=8))
    tcp    LISTEN     0      128    192.168.0.176:2001                  *:*                   users:(("io.hm-rpc.0",pid=1684,fd=27))
    tcp    LISTEN     0      128    127.0.0.1:42836                 *:*                   users:(("io.yahka.1",pid=2294,fd=30))
    tcp    LISTEN     0      128       *:22                    *:*                   users:(("sshd",pid=857,fd=3))
    tcp    LISTEN     0      128    192.168.0.176:1882                  *:*                   users:(("io.shelly.0",pid=1781,fd=27))
    tcp    LISTEN     0      128    192.168.0.176:2010                  *:*                   users:(("io.hm-rpc.1",pid=1712,fd=27))
    tcp    LISTEN     0      128      :::40972                :::*                   users:(("io.yahka.1",pid=2294,fd=26))
    tcp    LISTEN     0      128      :::111                  :::*                   users:(("rpcbind",pid=443,fd=11))
    tcp    LISTEN     0      128      :::8081                 :::*                   users:(("io.admin.0",pid=1489,fd=27))
    tcp    LISTEN     0      128      :::8082                 :::*                   users:(("io.web.0",pid=1856,fd=27))
    tcp    LISTEN     0      128      :::22                   :::*                   users:(("sshd",pid=857,fd=4))
    2024-01-20 12:00:44.991  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.58" greater than max "100"
    2024-01-20 12:00:47.513  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:00:47.845  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:00:51.499  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:00:57.801  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:00:58.422  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:02.168  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:08.258  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:08.972  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:13.540  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:14.954  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.47" greater than max "100"
    2024-01-20 12:01:18.555  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:19.303  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:20.258  - info: admin.0 (1489) <== Disconnect system.user.admin from ::ffff:192.168.0.100 admin
    2024-01-20 12:01:25.247  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:29.139  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:29.794  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:35.888  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:38.567  - error: shelly.0 (1781) [MQTT] (Shelly?) device unknown, configuration for client with id "shellypmmini-543204a97f50" does not exist!
    2024-01-20 12:01:38.568  - error: shelly.0 (1781) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
    2024-01-20 12:01:38.605  - info: shelly.0 (1781) [MQTT] Client Close:  (shellypmmini / shellypmmini-543204a97f50 / undefined) (false)
    2024-01-20 12:01:39.697  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:40.202  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
    2024-01-20 12:01:44.922  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.12" greater than max "100"
    2024-01-20 12:01:46.455  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    			v.2023-10-25
             Icon name: computer
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		arm64
    Timezone: 		rlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		false
    Pending OS-Updates: 	136
    Pending iob updates: 	20
    Nodejs-Installation: 	/usr/bin/nodejs 	v14.21.3
    Recommended versions are nodejs 16.20.2 and npm 8.19.4
    MEMORY:
    Mem:           4.1G        1.4G        2.1G        9.2M        653M        2.6G
    Swap:          1.0G          0B        1.0G
    Active iob-Instances: 	22
    ioBroker Core: 		js-controller 		4.0.24
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		5463
    States: 		3094
    Size of iob-Database:
    6.3M	/opt/iobroker/iobroker-data/objects.json.migrated
    6.3M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    3.8M	/opt/iobroker/iobroker-data/states.jsonl
    1000K	/opt/iobroker/iobroker-data/states.json.migrated
    1000K	/opt/iobroker/iobroker-data/states.json.bak.migrated
    === Mark text until here for copying ===
    Mein Versionen:
    pi@rock64:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v14.21.3
    v14.21.3
    6.14.18
    6.14.18
    Mein iobroker läuft sehr gut und stabil (backitup Adapter ausgenommen) ich kann nur einige wichtige Adapter nicht mehr updaten (u.a. Shelly) weil meine Versionen zu alt sind. Beim Updaten kommen dann diverse npm Fehlermeldungen.
    Meine Idee war jetzt erstmal ein backup zu ziehen, ein neues System auf dem neuesten Stand aufzusetzen und das Backup wieder einzuspielen.
    Achso, das ganze läuft auf einem ROCK64.
    Danke an Thomas Braun. Das Diagnose Tool ist mega gut!!
    Gruß Andy
    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
    • V Volleyhomer
      Skript v.2023-10-25
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
       RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:          1.0G          0B        1.0G
               3988 M total memory
               1347 M used memory
               2004 M free memory
                 77 M buffer memory
                559 M swap cache
               1023 M total swap
                  0 M used swap
               1023 M free swap
      *** FILESYSTEM ***
      /var:
      569M	/var/
      286M	/var/lib
      274M	/var/cache
      269M	/var/cache/apt
      USB-Devices by-id:
      nodejs:
        Version table:
           4.8.2~dfsg-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	5463
      States: 	3094
      			v.2023-10-25
               Icon name: computer
            Architecture: arm64
      Kernel: 		aarch64
      Userland: 		arm64
      User-ID: 		1000
      X-Server: 		false
      MEMORY:
      Swap:          1.0G          0B        1.0G
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		5463
      States: 		3094
      Mein Versionen:
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v14.21.3
      v14.21.3
      6.14.18
      6.14.18
      Gruß Andy
      @volleyhomer
      Da ist aber auch alles hoffnungslos veraltet...
      Debian 9 'Stretch'...
      Mittlerweile sind wir bei 12 und 10 ist auch bereits tot, 11 ist im Auslauf...
      Versuch mal:
      iob stop
      iob fix
      iob nodejs-update 16
      V 1 Antwort Letzte Antwort
      • V Volleyhomer
        Skript v.2023-10-25
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
         RTC in local TZ: no
        pi
        /home/pi
        X-Server: 	false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:          1.0G          0B        1.0G
                 3988 M total memory
                 1347 M used memory
                 2004 M free memory
                   77 M buffer memory
                  559 M swap cache
                 1023 M total swap
                    0 M used swap
                 1023 M free swap
        *** FILESYSTEM ***
        /var:
        569M	/var/
        286M	/var/lib
        274M	/var/cache
        269M	/var/cache/apt
        USB-Devices by-id:
        nodejs:
          Version table:
             4.8.2~dfsg-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin: 		6.3.5
        javascript: 	6.1.4
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	5463
        States: 	3094
        			v.2023-10-25
                 Icon name: computer
              Architecture: arm64
        Kernel: 		aarch64
        Userland: 		arm64
        User-ID: 		1000
        X-Server: 		false
        MEMORY:
        Swap:          1.0G          0B        1.0G
        			admin 			6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects: 		5463
        States: 		3094
        Mein Versionen:
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v14.21.3
        v14.21.3
        6.14.18
        6.14.18
        Gruß Andy
        @volleyhomer
        Die Kiste über Jahre versumpfen zu lassen funktioniert nachgewiesener Maßen nicht.
        • V Volleyhomer
          Skript v.2023-10-25
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
           RTC in local TZ: no
          pi
          /home/pi
          X-Server: 	false
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:          1.0G          0B        1.0G
                   3988 M total memory
                   1347 M used memory
                   2004 M free memory
                     77 M buffer memory
                    559 M swap cache
                   1023 M total swap
                      0 M used swap
                   1023 M free swap
          *** FILESYSTEM ***
          /var:
          569M	/var/
          286M	/var/lib
          274M	/var/cache
          269M	/var/cache/apt
          USB-Devices by-id:
          nodejs:
            Version table:
               4.8.2~dfsg-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		6.3.5
          javascript: 	6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	5463
          States: 	3094
          			v.2023-10-25
                   Icon name: computer
                Architecture: arm64
          Kernel: 		aarch64
          Userland: 		arm64
          User-ID: 		1000
          X-Server: 		false
          MEMORY:
          Swap:          1.0G          0B        1.0G
          			admin 			6.3.5
          Objects type: jsonl
          States  type: jsonl
          Objects: 		5463
          States: 		3094
          Mein Versionen:
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v14.21.3
          v14.21.3
          6.14.18
          6.14.18
          Gruß Andy
          @volleyhomer sagte in Fehlermeldungen beim Biobroker Update:
          bitte als Text in code-tags posten.
            V Offline
            V Offline
            Volleyhomer
            @homoran said in Fehlermeldungen beim Biobroker Update:
            Hab ich gemacht.
              @volleyhomer
              Versuch mal:
              iob stop
              iob fix
              V Offline
              V Offline
              Volleyhomer
              @thomas-braun said in Fehlermeldungen beim Biobroker Update:
              @volleyhomer
              Versuch mal:
              iob stop
              iob fix
              Mir fehlte die Zeit und die Muße mich damit weiter zu beschäftigen. Seit dem Umstieg auf den Rock64 lief das System zu fehlerfrei... Das wird dann aber jetzt so langsam mal Zeit.
              Der Befehl "iob nodejs-update 16" brachte folgende Ausgabe:
              pi@rock64:~$ iob nodejs-update 16
              iobroker [command]
              Commands:
               iobroker setup                                               Setup ioBroker
               iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
               iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
               iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
               iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
               iobroker info                                                Shows the host info
               iobroker logs [<adapter>]                                    Monitor log
               iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
               iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
               iobroker rebuild [<module>]                                  Rebuild all native modules or path
               iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
               iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
               iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
               iobroker update [<repositoryUrl>]                            Update repository and list adapters
               iobroker upgrade                                             Upgrade management
               iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
               iobroker object                                              Object management  [aliases: o]
               iobroker state                                               State management  [aliases: s]
               iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
               iobroker list <type> [<filter>]                              List all entries, like objects
               iobroker chmod <mode> <file>                                 Change file rights
               iobroker chown <user> <group> <file>                         Change file ownership
               iobroker touch <file>                                        Touch file
               iobroker rm <file>                                           Remove file
               iobroker file                                                File management
               iobroker user                                                User commands
               iobroker group                                               group management
               iobroker host <hostname>                                     Set host to given hostname
               iobroker set <adapter>.<instance>                            Change settings of adapter config
               iobroker license <license.file or license.text>              Update license by given file
               iobroker cert                                                Certificate management
               iobroker clean <yes>                                         Clears all objects and states
               iobroker backup                                              Create backup
               iobroker restore <backup name or path>                       Restore a specified backup
               iobroker validate <backup name or path>                      Validate a specified backup
               iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
               iobroker repo [<name>]                                       Show repo information
               iobroker uuid                                                Show uuid of the installation  [aliases: id]
               iobroker unsetup                                             Reset license, installation secret and language
               iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
               iobroker multihost                                           Multihost management
               iobroker compact                                             compact group management
               iobroker plugin                                              Plugin management
               iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
              Options:
               --help  Show help  [boolean]
              Erscheint den Befehl also nicht zu kennen.
              Vielleicht ist es doch mal Zeit alles frisch und sauber aufzusetzen.
              • V Volleyhomer
                @volleyhomer
                Versuch mal:
                iob stop
                iob fix
                iobroker [command]
                Commands:
                Options:
                iob stop
                iob fix
                iob start
                ...warten...
                oder
                • V Volleyhomer
                  @volleyhomer
                  Versuch mal:
                  iob stop
                  iob fix
                  iobroker [command]
                  Commands:
                  Options:
                  Du musst auch den fix zuvor ausführen... Wie ich geschrieben hatte...
                    V Offline
                    V Offline
                    Volleyhomer
                    Habe ich exakt in der Reihenfolge gemacht. Bei dem fix kommt nach einer Sekunde der Eingabe-Prompt.
                    pi@rock64:~$ iob stop
                    pi@rock64:~$ iob fix
                    iobroker [command]
                      iob stop
                      iob fix
                      iob start
                      ...warten...
                      oder
                      V Offline
                      V Offline
                      Volleyhomer
                      iob stop
                      iob fix
                      iob start
                      ...warten...
                      oder
                      Es bleibt bei der gleichen Reaktion. iobroker listet mir möglich Optionen auf.
                      pi@rock64:~$ iob start
                      pi@rock64:~$ iobroker stop
                      iobroker [command]
                      Commands:
                      • V Volleyhomer
                        iobroker [command]
                        @volleyhomer
                        Dann anders:
                        curl -fsL https://iobroker.net/fix.sh | bash -
                          @volleyhomer
                          Dann anders:
                          V Offline
                          V Offline
                          Volleyhomer
                          Soll iobroker dabei laufen? Also mit oder ohne
                          iob stop
                          Danke nochmal!
                          • V Volleyhomer
                            iob stop
                            Danke nochmal!
                            V Offline
                            V Offline
                            Volleyhomer
                            @volleyhomer said in Fehlermeldungen beim Biobroker Update:
                            iob stop
                            Danke nochmal!
                            Hab gerade getestet. Result ist so oder so gleich. Seltsam
                            • V Volleyhomer
                              iob stop
                              Danke nochmal!
                              Und wie lautet das gleiche Resultat?
                                V Offline
                                V Offline
                                Volleyhomer
                                @thomas-braun bei dem fix passiert gar nichts und der Eingabeprompt erscheint nach 1 Sekunde und wenn ich danach nodejs-16 Updaten will, listet er mir alle Optionen auf. Exakt gleich wie weiter oben beschrieben.
                                • V Volleyhomer
                                  Du sollst es auch nicht nacherzählen oder beschreiben sondern immer den Output im Terminal zeigen. Dann sehe ich was da passiert.
                                  curl -L https://iobroker.net/fix.sh | bash -
                                    V Offline
                                    V Offline
                                    Volleyhomer
                                    pi@rock64:~$ curl -L https://iobroker.net/fix.sh | bash -
                                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                                    curl: (60) SSL certificate problem: certificate has expired
                                    More details here: https://curl.haxx.se/docs/sslcerts.html
                                    curl performs SSL certificate verification by default, using a "bundle"
                                     of Certificate Authority (CA) public keys (CA certs). If the default
                                     bundle file isn't adequate, you can specify an alternate file
                                     using the --cacert option.
                                    If this HTTPS server uses a certificate signed by a CA represented in
                                     the bundle, the certificate verification probably failed due to a
                                     problem with the certificate (it might be expired, or the name might
                                     not match the domain name in the URL).
                                    If you'd like to turn off curl's verification of the certificate, use
                                     the -k (or --insecure) option.
                                    • V Volleyhomer
                                      @volleyhomer
                                      Auch das ist eine Folge von deiner Update-Faulheit...
                                      sudo apt update
                                        @volleyhomer
                                        sudo apt update
                                        V Offline
                                        V Offline
                                        Volleyhomer
                                        @volleyhomer
                                        sudo apt update
                                        pi@rock64:~$ sudo apt update
                                        [sudo] password for pi:
                                        Ign:1 http://httpredir.debian.org/debian stretch InRelease
                                        Ign:2 http://security.debian.org stretch/updates InRelease
                                        Err:3 http://security.debian.org stretch/updates Release
                                          404  Not Found [IP: 146.75.122.132 80]
                                        Ign:4 http://httpredir.debian.org/debian stretch-updates InRelease
                                        Ign:5 http://httpredir.debian.org/debian stretch-backports InRelease
                                        Err:6 http://httpredir.debian.org/debian stretch Release
                                        Err:7 http://httpredir.debian.org/debian stretch-updates Release
                                        Err:8 http://httpredir.debian.org/debian stretch-backports Release
                                        Ign:9 http://apt.armbian.com stretch InRelease
                                        Hit:10 https://deb.nodesource.com/node_14.x stretch InRelease
                                        Err:11 http://apt.armbian.com stretch Release
                                          502  Bad Gateway [IP: 130.185.239.78 80]
                                        Reading package lists... Done
                                        E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
                                        N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                        N: See apt-secure(8) manpage for repository creation and user configuration details.
                                        E: The repository 'http://httpredir.debian.org/debian stretch Release' does no longer have a Release file.
                                        E: The repository 'http://httpredir.debian.org/debian stretch-updates Release' does no longer have a Release file.
                                        E: The repository 'http://httpredir.debian.org/debian stretch-backports Release' does no longer have a Release file.
                                        E: The repository 'http://apt.armbian.com stretch Release' does no longer have a Release file.
                                        • V Volleyhomer
                                          curl -kL https://iobroker.net/fix.sh | bash -
