  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
  • H holla16
    @marc-berg
    wenn ich influx eingebe kommt das
    pi@raspberrypi:~ $ influx
    NAME:
       influx - Influx Client
    USAGE:
       influx [command]
    HINT: If you are looking for the InfluxQL shell from 1.x, run "influx v1 shell"
    COMMANDS:
       version              Print the influx CLI version
       write                Write points to InfluxDB
       bucket               Bucket management commands
       completion           Generates completion scripts
       query                Execute a Flux query
       config               Config management commands
       org, organization    Organization management commands
       delete               Delete points from InfluxDB
       user                 User management commands
       task                 Task management commands
       telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
       dashboards           List Dashboard(s).
       export               Export existing resources as a template
       secret               Secret management commands
       v1                   InfluxDB v1 management commands
       auth, authorization  Authorization management commands
       apply                Apply a template to manage resources
       stacks               List stack(s) and associated templates. Subcommands manage stacks.
       template             Summarize the provided template
       bucket-schema        Bucket schema management commands
       scripts              Scripts management commands
       ping                 Check the InfluxDB /health endpoint
       setup                Setup instance with initial user, org, bucket
       backup               Backup database
       restore              Restores a backup directory to InfluxDB
       remote               Remote connection management commands
       replication          Replication stream management commands
       server-config        Display server config
       help, h              Shows a list of commands or help for one command
    was muss ich als Name eingeben?
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    #101
    @holla16 sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
    Dann ist es keine 1.x, sondern 2.x
    Kommst Du auf die Weboberfläche der DB?
    http://<IP des RASPI>:8086
    H 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      holla16
      #102
      @marc-berg
      ne auf die Weboberfläche geht mit der Ip und dem Port nicht.
      • H holla16
        @marc-berg
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #103
        Hast du die DB noch gestoppt?
        @thomas-braun sagte in Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker:
        sudo systemctl stop influxd*
        dann wieder starten.
        sudo systemctl start influxd*
          holla16
          #104
          @marc-berg
          ist ausgeführt:
          pi@raspberrypi:~ $ sudo systemctl start influxd*
          Warning: systemctl start called with a glob pattern.
          Hint: unit globs expand to loaded units, so start will usually have no effect.
                Passing --all will also load units which are pulled in by other units.
                See systemctl(1) for more details.
          Job for influxdb.service failed because the control process exited with error code.
          See "systemctl status influxdb.service" and "journalctl -xe" for details.
          pi@raspberrypi:~ $
          auf die Weboberfläche komme ich aber noch nicht
          Marc BergM 2 Antworten Letzte Antwort
          • H holla16
            @marc-berg
            ist ausgeführt:
            pi@raspberrypi:~ $
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #105
            Ich denke, die DB kann wegen deines Speicherproblems nicht gestartet werden. Puh ...
            • H holla16
              @marc-berg
              ist ausgeführt:
              pi@raspberrypi:~ $
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              #106
              @holla16
              Ich glaube, jetzt hilft nur noch der Holzhammer. Wenn die Daten nicht zu wichtig sind, dann einfach einen Shard löschen:
              sudo rm -r /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1
              Den Raspi neu starten und schauen, ob die DB wieder hoch kommt. Dann auf die Oberfläche und die Vorhaltezeit verkürzen.
                @holla16
                holla16
                #107
                @marc-berg
                geht auch nicht
                pi@raspberrypi:~ $ sudo rm -r /var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1
                rm: cannot remove '/var/lib/influxdb/engine/data/ea8b2dc8c77648a5/autogen/1': No such file or directory
                pi@raspberrypi:~ $
                • H holla16
                  @marc-berg
                  geht auch nicht
                  pi@raspberrypi:~ $
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  #108
                  geht auch nicht
                  Hier https://forum.iobroker.net/post/1107842
                  hattest du allerdings gezeigt, dass das Verzeichnis existiert. Warum es jetzt plötzlich nicht mehr vorhanden sein soll, keine Ahnung.
                    geht auch nicht
                    holla16
                    #109
                    @marc-berg
                    sorry. Verzeichnis 1 ist raus.
                    • H holla16
                      @marc-berg
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      #110
                      Das heißt jetzt was?
                        holla16
                        #111
                        @marc-berg
                        habe das Verzeichnis 1 und 91 gelöscht. mit sudo reboot auch neu gestartet aber weder die Weboberfläche vom Influx geht noch die vom iobroker??
                        • H holla16
                          @marc-berg
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          #112
                          Ich würde sagen, nach 110 Posts in diesem Thread: Platt machen, neu installieren und Backup zurück spielen. Schade um unser aller Lebenszeit.
                            holla16
                            #113
                            @marc-berg
                            ja an dem punkt bin ich jetzt auch. Problem nur, dass die Backups auch auf der SD sind. Kann ich die irgendwie auf eine externe Festplatte kopieren? ZUmindest das letzte aus Anfang der Woche?
                            • H holla16
                              @marc-berg
                              #114
                              @holla16
                              Backups auf dem gleichen Datenträger sind keine. Sowas gehört immer nach extern. Am besten doppelt.
                                @holla16
                                holla16
                                #115
                                Da sind die Backups und die würde ich gern irgendwo anders sichern und dann die SD platt machen
                                pi@raspberrypi:~ $ ls -1Ah /opt/iobroker/backups/
                                iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
                                iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
                                iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                                pi@raspberrypi:~ $
                                • H holla16
                                  pi@raspberrypi:~ $
                                  #116
                                  Und wo darf es hingehen?
                                    holla16
                                    #117
                                    eine externe Festplatte. Oder ich habe noch eine SD Karte mit USB Kartenleser. da könnte ich was per USB anschließen
                                    Thomas BraunT Marc BergM 3 Antworten Letzte Antwort
                                    • H holla16
                                      #118
                                      @holla16
                                      cp /pfad/zur/quelle /pfad/zum/ziel
                                      • H holla16
                                        Marc BergM Offline
                                        Marc BergM Offline
                                        Marc Berg
                                        #119
                                        Falls du Putty installiert hast, sollte sich im gleichen Verzeichnis auch pscp befinden:
                                         pscp -P 22 pi@<IP des PI>:/opt/iobroker/backups/* C:\\windows\\temp
                                        EDIT: oder über die Powershell, gleicher Befehl.
                                        Pedder007P 1 Antwort Letzte Antwort
                                        • H holla16
                                          #120
                                          @holla16
                                          Bevor du komplett neuaufsetzt:
                                          iob stop influxdb
                                          sudo systemctl stop influx*
                                          sudo rm -rf /var/lib/influxdb/engine/data/*
                                          df -h
