  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
    @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
    rm /opt/iobroker/backups/iobroker_2023_12*
    df -h
    holla16
    #41
    pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $rm /opt/iobroker/backups/iobroker_2023_12*
    -bash: pi@raspberrypi:/opt/iobroker: No such file or directory
    pi@raspberrypi:/opt/iobroker $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root        59G   59G     0 100% /
    devtmpfs        3.7G     0  3.7G   0% /dev
    tmpfs           3.9G     0  3.9G   0% /dev/shm
    tmpfs           1.6G  9.1M  1.6G   1% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1  255M   31M  225M  12% /boot
    tmpfs           782M     0  782M   0% /run/user/1000
    • H holla16
      #42
      @holla16
      NICHT
      in die Konsole knallen.
      H 1 Antwort Letzte Antwort
        @holla16
        NICHT
        holla16
        schrieb am zuletzt editiert von holla16
        #43
        @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
        Ok dann kommt das
        pi@raspberrypi:/opt/iobroker $ rm /opt/iobroker/backups/iobroker_2023_12*
        rm: cannot remove '/opt/iobroker/backups/iobroker_2023_12*': No such file or directory
        /dev/root        59G   58G     0 100% /
        • H holla16
          Ok dann kommt das
          #44
          @holla16
          ls -lAh /opt/iobroker/backups/
            @holla16
            holla16
            #45
            pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
            total 27M
            -rw-rwxr--+ 1 iobroker iobroker  15M Jan  1  2024 iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 4.2M Jan  2  2024 iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 8.2M Jan  3  2024 iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
            • H holla16
              total 27M
              #46
              @holla16
              iob stop
              iob fix
              iob start
              iob diag
                @holla16
                iob stop
                iob fix
                iob start
                iob diag
                holla16
                #47
                pi@raspberrypi:/opt/iobroker $ iob stop
                pi@raspberrypi:/opt/iobroker $ iob fix
                pi@raspberrypi:/opt/iobroker $ iob start
                pi@raspberrypi:/opt/iobroker $ iob diag
                • H holla16
                  #48
                  @holla16
                  curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                  • H Offline
                    holla16
                    #49
                    pi@raspberrypi:/opt/iobroker $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                     Dload  Upload   Total   Spent    Left  Speed
                      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                    curl: (60) SSL certificate problem: certificate is not yet valid
                    More details here: https://curl.se/docs/sslcerts.html
                    curl failed to verify the legitimacy of the server and therefore could not
                    establish a secure connection to it. To learn more about this situation and
                    how to fix it, please visit the web page mentioned above.
                    • H holla16
                      #50
                      @holla16
                      curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                        @holla16
                        holla16
                        #51
                        pi@raspberrypi:/opt/iobroker $ curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                        100   185  100   185    0     0   1258      0 --:--:-- --:--:-- --:--:--  1267
                         87 18519   87 16127    0     0  60627      0 --:--:-- --:--:-- --:--:-- 60627
                        curl: (23) Failure writing output to destination
                        • H holla16
                          #52
                          @holla16
                          Wohl immer noch kein Platz auf der Kiste.
                          sudo du -a / | sort -n -r | head -n 20
                            @holla16
                            holla16
                            #53
                            da kommt das
                            pi@raspberrypi:/opt/iobroker $ sudo du -a / | sort -n -r | head -n 20
                            sort: write failed: /tmp/sortm0nSnH: No space left on device
                            ne da ist alles zu 100% voll. Wir haben eben gesehen, dass dort einige Backups drin waren. Können wir da nicht was löschen?
                            • H holla16
                              da kommt das
                              #54
                              Haben wir schon.
                              df -h
                                Haben wir schon.
                                df -h
                                holla16
                                #55
                                • H holla16
                                  #56
                                  @holla16
                                  cd /opt/iobroker
                                  du -cks * | sort -rn | head
                                    @holla16
                                    cd /opt/iobroker
                                    holla16
                                    #57
                                    pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
                                    pi@raspberrypi:/opt/iobroker $ du -cks * | sort -rn | head
                                    1456376 total
                                    1014316 node_modules
                                    371380  iobroker-data
                                    42608   log
                                    27060   backups
                                    1004    package-lock.json
                                    4       package.json
                                    4       INSTALLER_INFO.txt
                                    0       iobroker
                                    0       iob
                                    • H holla16
                                      1456376 total
                                      42608   log
                                      27060   backups
                                      4       package.json
                                      0       iobroker
                                      0       iob
                                      #58
                                      @holla16
                                      sudo journalctl --vacuum-time=1d
                                        @holla16
                                        holla16
                                        #59
                                        pi@raspberrypi:/opt/iobroker $ sudo journalctl --vacuum-time=1d
                                        Journal file /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system.journal is truncated, ignoring file.
                                        Vacuuming done, freed 0B of archived journals from /var/log/journal.
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf4377d-29094d0e0283d9c4.journal~ (4.0K).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf60270-5ed240af70674cab.journal~ (16.0K).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/user-1001@00060e412865f478-c67b3d07a3effefe.journal~ (0B).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4311051e99-63e627a9400cfabf.journal~ (4.0K).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e4128666972-6cc52e4157cb0ff4.journal~ (6.8M).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bfd91c1-7ce41f4661306f35.journal~ (16.0K).
                                        Deleted empty archived journal /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9/system@00060e431bf47993-12a2a39f85f1a43d.journal~ (16.0K).
                                        Vacuuming done, freed 6.9M of archived journals from /var/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                                        Vacuuming done, freed 0B of archived journals from /run/log/journal/01a56749d6014a4a88a8e1ae7e3c25b9.
                                        Vacuuming done, freed 0B of archived journals from /run/log/journal.
                                        • H holla16
                                          #60
                                          freed 6.9M
                                          Das ist natürlich nix.
                                          sudo ncdu /
                                          wird vermutlich nicht funktionieren.
                                          H HomoranH 3 Antworten Letzte Antwort
