  4. Influx DB Daten löschen? Wie? Kein zugriff auf den ioBroker
    5.1k
126 Beiträge 9 Kommentatoren 14.5k Aufrufe 9 Beobachtet
    @holla16
    Bitte kopiere die Kommandos. Das ist ein l, keine 1
    holla16
    Ok Sorry, dann kommt das
    pi@raspberrypi:/opt/iobroker $ ls -pi@raspberrypi:/opt/iobroker $ ls -1Ah /opt/iobroker/backups/
    ls: invalid option -- '@'
    Try 'ls --help' for more information.
    pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_25-02_40_10_backupiobroker.tar.gz
    iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz
    iobroker_2023_12_31-02_-bash: iobroker_2023_12_25-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_26-02_40_10_backupiobroker.tar.gz
    iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
    iobroker-bash: iobroker_2023_12_26-02_40_10_backupiobroker.tar.gz: command not found
    _2024_01_02-02_40_10_backupiobrokepi@raspberrypi:/opt/iobroker $ iobroker_2023_12_27-02_40_10_backupiobroker.tar.gz
    r_2024_01_03-02_40_13_backupiobroker.tar.gz
    pi@raspberrypi:/opt/iobro-bash: iobroker_2023_12_27-02_40_10_backupiobroker.tar.gz: command not found
    ker $pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_28-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2023_12_28-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_29-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2023_12_29-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2023_12_30-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2023_12_31-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2023_12_31-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
    -bash: iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz: command not found
    pi@raspberrypi:/opt/iobroker $ iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
    -bash: iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz: command not found
    • H holla16
      @holla16
      Das ist auch nicht das was ich geschrieben habe. Das ist 'irgendwas' in die Konsole gekippt und die kann dann mit dem wirren Zeug nix anfangen.
        @holla16 sagte in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
        rm /opt/iobroker/backups/iobroker_2023_12*
        df -h
        holla16
        pi@raspberrypi:/opt/iobroker $ pi@raspberrypi:/opt/iobroker $rm /opt/iobroker/backups/iobroker_2023_12*
        -bash: pi@raspberrypi:/opt/iobroker: No such file or directory
        pi@raspberrypi:/opt/iobroker $ df -h
        Filesystem      Size  Used Avail Use% Mounted on
        /dev/root        59G   59G     0 100% /
        devtmpfs        3.7G     0  3.7G   0% /dev
        tmpfs           3.9G     0  3.9G   0% /dev/shm
        tmpfs           1.6G  9.1M  1.6G   1% /run
        tmpfs           5.0M  4.0K  5.0M   1% /run/lock
        /dev/mmcblk0p1  255M   31M  225M  12% /boot
        tmpfs           782M     0  782M   0% /run/user/1000
        • H holla16
          @holla16
          NICHT
          in die Konsole knallen.
          H 1 Antwort Letzte Antwort
            @holla16
            NICHT
            holla16
            schrieb am zuletzt editiert von holla16
            @thomas-braun said in Keine Lan Verbundung zum Raspi / per SSH aber möglich:
            Ok dann kommt das
            pi@raspberrypi:/opt/iobroker $ rm /opt/iobroker/backups/iobroker_2023_12*
            rm: cannot remove '/opt/iobroker/backups/iobroker_2023_12*': No such file or directory
            /dev/root        59G   58G     0 100% /
            • H holla16
              Ok dann kommt das
              @holla16
              ls -lAh /opt/iobroker/backups/
                @holla16
                holla16
                pi@raspberrypi:/opt/iobroker $ ls -lAh /opt/iobroker/backups/
                total 27M
                -rw-rwxr--+ 1 iobroker iobroker  15M Jan  1  2024 iobroker_2024_01_01-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 4.2M Jan  2  2024 iobroker_2024_01_02-02_40_10_backupiobroker.tar.gz
                -rw-rwxr--+ 1 iobroker iobroker 8.2M Jan  3  2024 iobroker_2024_01_03-02_40_13_backupiobroker.tar.gz
                • H holla16
                  total 27M
                  @holla16
                  iob stop
                  iob fix
                  iob start
                  iob diag
                    @holla16
                    iob stop
                    iob fix
                    iob start
                    iob diag
                    holla16
                    pi@raspberrypi:/opt/iobroker $ iob stop
                    pi@raspberrypi:/opt/iobroker $ iob fix
                    pi@raspberrypi:/opt/iobroker $ iob start
                    pi@raspberrypi:/opt/iobroker $ iob diag
                    • H holla16
                      @holla16
                      curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                      • H Offline
                        holla16
                        pi@raspberrypi:/opt/iobroker $ curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                         Dload  Upload   Total   Spent    Left  Speed
                          0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                        curl: (60) SSL certificate problem: certificate is not yet valid
                        More details here: https://curl.se/docs/sslcerts.html
                        curl failed to verify the legitimacy of the server and therefore could not
                        establish a secure connection to it. To learn more about this situation and
                        how to fix it, please visit the web page mentioned above.
                        • H holla16
                          @holla16
                          curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                            @holla16
                            holla16
                            pi@raspberrypi:/opt/iobroker $ curl -kL -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
                            100   185  100   185    0     0   1258      0 --:--:-- --:--:-- --:--:--  1267
                             87 18519   87 16127    0     0  60627      0 --:--:-- --:--:-- --:--:-- 60627
                            curl: (23) Failure writing output to destination
                            • H holla16
                              @holla16
                              Wohl immer noch kein Platz auf der Kiste.
                              sudo du -a / | sort -n -r | head -n 20
                                @holla16
                                holla16
                                da kommt das
                                pi@raspberrypi:/opt/iobroker $ sudo du -a / | sort -n -r | head -n 20
                                sort: write failed: /tmp/sortm0nSnH: No space left on device
                                ne da ist alles zu 100% voll. Wir haben eben gesehen, dass dort einige Backups drin waren. Können wir da nicht was löschen?
                                • H holla16
                                  da kommt das
                                  Haben wir schon.
                                  df -h
                                    Haben wir schon.
                                    df -h
                                    holla16
                                    • H holla16
                                      @holla16
                                      cd /opt/iobroker
                                      du -cks * | sort -rn | head
                                        @holla16
                                        cd /opt/iobroker
                                        holla16
                                        pi@raspberrypi:/opt/iobroker $ cd /opt/iobroker
                                        pi@raspberrypi:/opt/iobroker $ du -cks * | sort -rn | head
                                        1456376 total
                                        1014316 node_modules
                                        371380  iobroker-data
                                        42608   log
                                        27060   backups
                                        1004    package-lock.json
                                        4       package.json
                                        4       INSTALLER_INFO.txt
                                        0       iobroker
                                        0       iob
                                        • H holla16
                                          1456376 total
                                          42608   log
                                          27060   backups
                                          4       package.json
                                          0       iobroker
                                          0       iob
                                          @holla16
                                          sudo journalctl --vacuum-time=1d
