  4. ioBroker startet nicht nach Neuinstallation
67 Beiträge 7 Kommentatoren 9.2k Aufrufe 5 Beobachtet
  • W Willi-Wunder
    Okay, gerade nochmal alles neu gemacht, Image Lite ohne Desktop ausgewählt, nach Anleitung @Thomas-Braun
    ausgeführt, gleicher Fehler, siehe Log. Ab dem Punkt Installation 3/4 Iobroker hat es ca. 25 min. gedauert, dann kommt zwar ioBroker was installed successfully, kann diesen aber nicht über die Adresse aufrufen.
    pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installer!
        Installer version: 2023-10-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists... Done
        Node.js not found. Installing...
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Building dependency tree... Done
    ca-certificates is already the newest version (20230311).
    curl is already the newest version (7.88.1-10+deb12u4).
    gnupg is already the newest version (2.2.40-1.1).
    gnupg set to manually installed.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
     Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
    Installed nodejs
    Node.js Installed successfully!
    Changing npm registry to https://registry.npmjs.org
     Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
    Installed acl
     Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
    Installed libavahi-compat-libdnssd-dev
     Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
    Installed libudev-dev
     Processing triggers for man-db (2.11.2-2) ...eb12u1) ...1_arm64.deb ...
    Installed libpam0g-dev
     Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
    Installed git
    Extracting templates from packages: 100%
     Preparing to unpack .../10-libcairo-script-interpreter2_1.16.0-7+rpt1_arm64.deb        Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........
    Installed libcairo2-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
    Installed libpango1.0-dev
     Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
    Installed libjpeg-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
    Installed libgif-dev
     Preparing to unpack .../16-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-1+b1_arm64.deb ..        Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ........
    Installed librsvg2-dev
     Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
    Installed cmake
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Created /etc/sudoers.d/iobroker
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! code ECONNRESET
    npm ERR! network aborted
    npm ERR! network This is a problem related to network connectivity.
    npm ERR! network In most cases you are behind a proxy or have bad network settin        gs.
    npm ERR! network
    npm ERR! network If you are behind a proxy, please make sure that the
    npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12        -22T16_47_20_580Z-debug-0.log
        Finalizing installation (4/4)
    Enabling autostart...
    Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /        lib/systemd/system/iobroker.service.
    Autostart enabled!
        Open http://192.168.2.230:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    Und jetzt? 😕
    Iobroker Status
     pi@iobroker:~ $ iobroker status
    Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
        at Object.openSync (node:fs:596:3)
        at Object.readFileSync (node:fs:464:35)
        at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:50:22)
        at dbConnect (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:63:39)
        at CLIProcess.status (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/cli/cliProcess.js:194:9)
        at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:483:25)
        at Object.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:2705:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:40)
        at Module._compile (node:internal/modules/cjs/loader:1356:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
    der mag nicht ins Internet
    ? 1 Antwort Letzte Antwort
      @homoran sagte in ioBroker startet nicht nach Neuinstallation:
      Moin,
      doch, denn Punkt 1, die prerequisites kann er ja holen!
      VG
      Bernd
      P.S.: aktuell ist die Verbindung von hier zum iobroker.net ok, wie es vom TE aus sieht
      ❯ ping iobroker.net
      PING iobroker.net (82.165.135.239) 56(84) Bytes an Daten.
      64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 Zeit=13.5 ms
      64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 Zeit=13.0 ms
      64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=56 Zeit=12.9 ms
      64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=56 Zeit=12.9 ms
      64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=5 ttl=56 Zeit=12.6 ms
      ^C
      --- iobroker.net ping-Statistik ---
      5 Pakete übertragen, 5 empfangen, 0% packet loss, time 4006ms
      rtt min/avg/max/mdev = 12.584/12.970/13.529/0.307 ms
      ❯ traceroute iobroker.net
      traceroute to iobroker.net (82.165.135.239), 30 hops max, 60 byte packets
       1  _gateway (192.168.178.1)  0.317 ms  0.501 ms  0.582 ms
       2  lo0.irai0010.as9136.net (62.176.224.222)  4.709 ms  4.797 ms  4.769 ms
       3  ae0-181.irci0006.as9136.net (62.176.238.143)  4.794 ms  4.767 ms  4.733 ms
       4  et-0-0-0-0.cfrc2101.as9136.net (62.176.251.11)  11.192 ms  11.251 ms  11.224 ms
       5  decix.bb-a.fra3.fra.de.net.ionos.com (80.81.192.123)  11.437 ms  11.444 ms  11.670 ms
       6  lo-0-0.rc-a.bap.rhr.de.net.ionos.com (212.227.117.208)  17.202 ms  18.543 ms  18.463 ms
       7  port-channel-2.gw-distdh-a.kw.nbz.fr.net.ionos.com (195.20.243.9)  16.602 ms  13.515 ms  14.033 ms
       8  ae-1.gw-prtr-a0110-a.kw.nbz.fr.net.ionos.com (195.20.243.81)  19.131 ms * *
       9  s21181212.onlinehome-server.info (82.165.135.239)  19.532 ms  15.488 ms  14.474 ms
      W 1 Antwort Letzte Antwort
        Und jetzt?
        Moin,
        kann es sein, dass Deine Netzwerkanbindung nicht gut ist?
        Denn da steht ja,
        npm ERR! network
        Es kann auch mal wieder sein, dass der Server ausgelastet ist, vielleicht später noch einmal mit dem Befehl versuchen,, das Skript sollte dann ja 1 und 2 überspringen.
        VG
        Bernd
        W Offline
        W Offline
        Willi-Wunder
        @dp20eic sagte in ioBroker startet nicht nach Neuinstallation:
        Moin,
        Wäre mir nicht bekannt, läuft hier alles. Mein System Rasp scheint ja auch keine Probleme zu haben, der hat aber eine Fest IP. Mal die Netzwerk Einstellung in den anderen kopieren? Wo steht das genau drin? Hab mittlerweile einen zweiten Rasp bekommen, somit kann ich auf beide zugreifen.......
        Thomas BraunT ? 2 Antworten Letzte Antwort
        • W Willi-Wunder
          Moin,
          @willi-wunder
          IPv6 aktiv?
          • W Willi-Wunder
            Moin,
            Moin,
            damit ist ja auch nicht nur Dein Netzwerk gemeint, es kann ja sein, dass jemand zum iobroker.net auf der Leitung steht, dass Du vielleicht bis zu Deinem Provider eine stabile Leitung hast ist ja nur die halbe Miete.
            VG
            Bernd
              @willi-wunder
              IPv6 aktiv?
              W Offline
              W Offline
              Willi-Wunder
              Nein, bin mir aber nicht sicher. Wie kann ich das prüfen? Der andere Rasp läuft ja auch.......
              • W Willi-Wunder
                Marc BergM Online
                Marc BergM Online
                Marc Berg
                ping registry.npmjs.org
                vom Raspi aus.
                • W Offline
                  W Offline
                  Willi-Wunder
                  @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
                  pi@iobroker:~ $ ping registry.npmjs.org
                  PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=1 ttl=57 time=210 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=3 ttl=57 time=202 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=4 ttl=57 time=225 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=5 ttl=57 time=217 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=8 ttl=57 time=209 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=9 ttl=57 time=175 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=10 ttl=57 time=181 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=11 ttl=57 time=221 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=12 ttl=57 time=218 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=13 ttl=57 time=213 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=14 ttl=57 time=208 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=15 ttl=57 time=214 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=16 ttl=57 time=216 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=17 ttl=57 time=217 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=18 ttl=57 time=215 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=19 ttl=57 time=222 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=20 ttl=57 time=220 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=21 ttl=57 time=219 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=22 ttl=57 time=219 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=23 ttl=57 time=214 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=24 ttl=57 time=213 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=25 ttl=57 time=217 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=26 ttl=57 time=215 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=27 ttl=57 time=214 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=28 ttl=57 time=216 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=29 ttl=57 time=222 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=31 ttl=57 time=222 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=33 ttl=57 time=228 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=36 ttl=57 time=216 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=37 ttl=57 time=217 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=39 ttl=57 time=217 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=40 ttl=57 time=220 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=41 ttl=57 time=215 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=42 ttl=57 time=216 ms
                  64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=43 ttl=57 time=220 ms
                  Ist das jetzt gut oder schlecht?
                  • W Willi-Wunder
                    Marc BergM Online
                    Marc BergM Online
                    Marc Berg
                    Das heißt zumindest, dass IPv6 eingerichtet ist und funktioniert. Gut, dass es funktioniert. Schlecht, dass die Ursache weiter unklar bleibt.
                    • Marc BergM Marc Berg
                      W Offline
                      W Offline
                      Willi-Wunder
                      @marc-berg
                      Das sudo apt update && sudo apt full-upgrade hat er doch auch ausgeführt, daher gehe ich davon aus, dass die Internetverbindung eigentlich paßt.
                      W HomoranH 2 Antworten Letzte Antwort
                      • W Willi-Wunder
                        @marc-berg
                        W Offline
                        W Offline
                        Willi-Wunder
                        Hab jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, log ist
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/iobroker.admin
                        npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T19_13_30_176Z-debug-0.log
                        Autostart enabled!
                        • W Willi-Wunder
                          @marc-berg
                          @marc-berg
                          das geht zum linux Repo. das sind andere Server
                          Der Fehler bei dir trat auf, als das InstallTionsskript auf den npm-server zugreifen wollte
                            Moin,
                            VG
                            Bernd
                            ❯ ping iobroker.net
                            ^C
                            W Offline
                            W Offline
                            Willi-Wunder
                            ping iobroker.net
                            Sieht bei mir auch gut aus, hmm
                            pi@iobroker:~ $ ping iobroker.net
                            PING iobroker.net (82.165.135.239) 56(84) bytes of data.
                            64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 time=16.8 ms
                            64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 time=14.8 ms
                            ^C
                            --- iobroker.net ping statistics ---
                            60 packets transmitted, 60 received, 0% packet loss, time 59091ms
                            rtt min/avg/max/mdev = 14.449/15.131/17.219/0.487 ms
                            • W Willi-Wunder
                              ping iobroker.net
                              ^C
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              @willi-wunder
                              was sagt eigentlich das besagte Log:
                                @willi-wunder
                                W Offline
                                W Offline
                                Willi-Wunder
                                @marc-berg
                                Das Verzeichnis scheint es nicht zu geben......
                                • W Willi-Wunder
                                  @marc-berg
                                  Marc BergM Online
                                  Marc BergM Online
                                  Marc Berg
                                  @marc-berg
                                  Das ist ein verstecktes. Du musst das Anzeigen aktivieren. Womit guckst du da?
                                    @marc-berg
                                    W Offline
                                    W Offline
                                    Willi-Wunder
                                    @marc-berg
                                    Mit WinSCP .......war aber gerade auf dem aktiven System, sorry. Auf den neuen kann ich mich gerade nicht einloggen mit root......
                                    Marc BergM Thomas BraunT 3 Antworten Letzte Antwort
                                    • W Willi-Wunder
                                      @marc-berg
                                      Marc BergM Online
                                      Marc BergM Online
                                      Marc Berg
                                      Aber doch mit "pi"?
                                      Und dann Strg+Alt+H, um versteckte Dateien anzuzeigen.
                                        Aber doch mit "pi"?
                                        W Offline
                                        W Offline
                                        Willi-Wunder
                                        @marc-berg
                                        Super, danke, jetzt aber......
                                        • W Willi-Wunder
                                          @marc-berg
                                          Marc BergM Online
                                          Marc BergM Online
                                          Marc Berg
                                          Aber den Ping vorhin hast du auf dem richtigen gemacht!?
