  4. ioBroker startet nicht nach Neuinstallation
67 Beiträge 7 Kommentatoren 9.2k Aufrufe 5 Beobachtet
  • W Willi-Wunder
    @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
    ping registry.npmjs.org
    pi@iobroker:~ $ ping registry.npmjs.org
    PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=1 ttl=57 time=210 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=3 ttl=57 time=202 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=4 ttl=57 time=225 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=5 ttl=57 time=217 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=8 ttl=57 time=209 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=9 ttl=57 time=175 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=10 ttl=57 time=181 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=11 ttl=57 time=221 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=12 ttl=57 time=218 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=13 ttl=57 time=213 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=14 ttl=57 time=208 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=15 ttl=57 time=214 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=16 ttl=57 time=216 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=17 ttl=57 time=217 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=18 ttl=57 time=215 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=19 ttl=57 time=222 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=20 ttl=57 time=220 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=21 ttl=57 time=219 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=22 ttl=57 time=219 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=23 ttl=57 time=214 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=24 ttl=57 time=213 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=25 ttl=57 time=217 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=26 ttl=57 time=215 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=27 ttl=57 time=214 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=28 ttl=57 time=216 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=29 ttl=57 time=222 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=31 ttl=57 time=222 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=33 ttl=57 time=228 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=36 ttl=57 time=216 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=37 ttl=57 time=217 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=39 ttl=57 time=217 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=40 ttl=57 time=220 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=41 ttl=57 time=215 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=42 ttl=57 time=216 ms
    64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=43 ttl=57 time=220 ms
    Ist das jetzt gut oder schlecht?
    Marc BergM Online
    Marc BergM Online
    Marc Berg
    @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
    Das heißt zumindest, dass IPv6 eingerichtet ist und funktioniert. Gut, dass es funktioniert. Schlecht, dass die Ursache weiter unklar bleibt.
    W 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      W Offline
      W Offline
      Willi-Wunder
      @marc-berg
      Das sudo apt update && sudo apt full-upgrade hat er doch auch ausgeführt, daher gehe ich davon aus, dass die Internetverbindung eigentlich paßt.
      W HomoranH 2 Antworten Letzte Antwort
      • W Willi-Wunder
        @marc-berg
        W Offline
        W Offline
        Willi-Wunder
        Hab jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, log ist
            Installing ioBroker (3/4)
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/iobroker.admin
        npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T19_13_30_176Z-debug-0.log
            Finalizing installation (4/4)
        Enabling autostart...
        Autostart enabled!
            ioBroker was installed successfully
            Open http://192.168.2.230:8081 in a browser and start configuring!
        • W Willi-Wunder
          @marc-berg
          @marc-berg
          das geht zum linux Repo. das sind andere Server
          Der Fehler bei dir trat auf, als das InstallTionsskript auf den npm-server zugreifen wollte
            @homoran sagte in ioBroker startet nicht nach Neuinstallation:
            der mag nicht ins Internet
            Moin,
            doch, denn Punkt 1, die prerequisites kann er ja holen!
                Installing prerequisites (1/4)
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
            Reading package lists... Done
            Bernd
            P.S.: aktuell ist die Verbindung von hier zum iobroker.net ok, wie es vom TE aus sieht
            ❯ ping iobroker.net
            PING iobroker.net (82.165.135.239) 56(84) Bytes an Daten.
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 Zeit=13.5 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 Zeit=13.0 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=56 Zeit=12.9 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=56 Zeit=12.9 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=5 ttl=56 Zeit=12.6 ms
            ^C
            --- iobroker.net ping-Statistik ---
            5 Pakete übertragen, 5 empfangen, 0% packet loss, time 4006ms
            rtt min/avg/max/mdev = 12.584/12.970/13.529/0.307 ms
            ❯ traceroute iobroker.net
            traceroute to iobroker.net (82.165.135.239), 30 hops max, 60 byte packets
             1  _gateway (192.168.178.1)  0.317 ms  0.501 ms  0.582 ms
             2  lo0.irai0010.as9136.net (62.176.224.222)  4.709 ms  4.797 ms  4.769 ms
             3  ae0-181.irci0006.as9136.net (62.176.238.143)  4.794 ms  4.767 ms  4.733 ms
             4  et-0-0-0-0.cfrc2101.as9136.net (62.176.251.11)  11.192 ms  11.251 ms  11.224 ms
             5  decix.bb-a.fra3.fra.de.net.ionos.com (80.81.192.123)  11.437 ms  11.444 ms  11.670 ms
             6  lo-0-0.rc-a.bap.rhr.de.net.ionos.com (212.227.117.208)  17.202 ms  18.543 ms  18.463 ms
             7  port-channel-2.gw-distdh-a.kw.nbz.fr.net.ionos.com (195.20.243.9)  16.602 ms  13.515 ms  14.033 ms
             8  ae-1.gw-prtr-a0110-a.kw.nbz.fr.net.ionos.com (195.20.243.81)  19.131 ms * *
             9  s21181212.onlinehome-server.info (82.165.135.239)  19.532 ms  15.488 ms  14.474 ms
            W Offline
            W Offline
            Willi-Wunder
            @dp20eic sagte in ioBroker startet nicht nach Neuinstallation:
            ping iobroker.net
            Sieht bei mir auch gut aus, hmm
            pi@iobroker:~ $ ping iobroker.net
            PING iobroker.net (82.165.135.239) 56(84) bytes of data.
            64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 time=16.8 ms
            64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 time=14.8 ms
            ^C
            --- iobroker.net ping statistics ---
            60 packets transmitted, 60 received, 0% packet loss, time 59091ms
            rtt min/avg/max/mdev = 14.449/15.131/17.219/0.487 ms
            • W Willi-Wunder
              ping iobroker.net
              ^C
              Marc BergM Online
              Marc BergM Online
              Marc Berg
              @willi-wunder
              was sagt eigentlich das besagte Log:
                @willi-wunder
                W Offline
                W Offline
                Willi-Wunder
                @marc-berg
                Das Verzeichnis scheint es nicht zu geben......
                • W Willi-Wunder
                  @marc-berg
                  Marc BergM Online
                  Marc BergM Online
                  Marc Berg
                  @marc-berg
                  Das ist ein verstecktes. Du musst das Anzeigen aktivieren. Womit guckst du da?
                    @marc-berg
                    W Offline
                    W Offline
                    Willi-Wunder
                    @marc-berg
                    Mit WinSCP .......war aber gerade auf dem aktiven System, sorry. Auf den neuen kann ich mich gerade nicht einloggen mit root......
                    Marc BergM Thomas BraunT 3 Antworten Letzte Antwort
                    • W Willi-Wunder
                      @marc-berg
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      Aber doch mit "pi"?
                      Und dann Strg+Alt+H, um versteckte Dateien anzuzeigen.
                        Aber doch mit "pi"?
                        W Offline
                        W Offline
                        Willi-Wunder
                        @marc-berg
                        Super, danke, jetzt aber......
                        • W Willi-Wunder
                          @marc-berg
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          Aber den Ping vorhin hast du auf dem richtigen gemacht!?
                          • W Willi-Wunder
                            @marc-berg
                            Macht man ohnehin NIE.
                              W Offline
                              W Offline
                              Willi-Wunder
                              @marc-berg
                              Ja, in Putty ist das Fenster ja noch aktiv wo ich installiere...... 😳
                              • W Willi-Wunder
                                @marc-berg
                                Marc BergM Online
                                Marc BergM Online
                                Marc Berg
                                Irgendwie passt das Log inhaltlich nicht zu den Connection-Problemen, die oben angezeigt wurden. Hab' erstmal keine Idee mehr.
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  @marc-berg
                                  Gib mehrere Logs......denke die große Datei war vom ersten Versuch mit dem Netzwerkproblemen, danach kamen die weiteren Versuche.....
                                  2023-12-22T16_47_20_580Z-debug-0.log
                                  • W Willi-Wunder
                                    @marc-berg
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    Zeig mal noch die beiden kleinen davor.
                                      W Offline
                                      W Offline
                                      Willi-Wunder
                                      @marc-berg
                                      Leider zu spät, SD Karte gerade platt gemacht, probiere jetzt die V11 aus, ist zwar nicht Sinn und Zweck der Geschichte, aber ein Freund hatte damit nie Probleme gehabt. Mal schauen was dann hier im Log steht. Sollte eigentlich eine simple Geschichte sein, scheinbar aber gerade nicht. 🤕
                                      Danke für deine Unterstützung.
                                      Ro75R 1 Antwort Letzte Antwort
                                      • W Willi-Wunder
                                        @marc-berg
                                        Ro75R Online
                                        Ro75R Online
                                        Ro75
                                        @willi-wunder schon mal eine "frische" SD-Card benutzt?
                                        Ro75.
                                        • Ro75R Ro75
                                          Ro75.
                                          W Offline
                                          W Offline
                                          Willi-Wunder
                                          @ro75
                                          Die war Original verpackt, gestern.......ScanDisk High Endurance 32 GB
