  4. ioBroker startet nicht nach Neuinstallation
67 Beiträge 7 Kommentatoren 9.2k Aufrufe 5 Beobachtet
  • W Willi-Wunder
    Nein, bin mir aber nicht sicher. Wie kann ich das prüfen? Der andere Rasp läuft ja auch.......
    Marc BergM Online
    Marc BergM Online
    Marc Berg
    @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
    ping registry.npmjs.org
    vom Raspi aus.
    • W Offline
      W Offline
      Willi-Wunder
      @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
      pi@iobroker:~ $ ping registry.npmjs.org
      PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=1 ttl=57 time=210 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=3 ttl=57 time=202 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=4 ttl=57 time=225 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=5 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=8 ttl=57 time=209 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=9 ttl=57 time=175 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=10 ttl=57 time=181 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=11 ttl=57 time=221 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=12 ttl=57 time=218 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=13 ttl=57 time=213 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=14 ttl=57 time=208 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=15 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=16 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=17 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=18 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=19 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=20 ttl=57 time=220 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=21 ttl=57 time=219 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=22 ttl=57 time=219 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=23 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=24 ttl=57 time=213 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=25 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=26 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=27 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=28 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=29 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=31 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=33 ttl=57 time=228 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=36 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=37 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=39 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=40 ttl=57 time=220 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=41 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=42 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=43 ttl=57 time=220 ms
      Ist das jetzt gut oder schlecht?
      • W Willi-Wunder
        Marc BergM Online
        Marc BergM Online
        Marc Berg
        Das heißt zumindest, dass IPv6 eingerichtet ist und funktioniert. Gut, dass es funktioniert. Schlecht, dass die Ursache weiter unklar bleibt.
        W 1 Antwort Letzte Antwort
        • Marc BergM Marc Berg
          W Offline
          W Offline
          Willi-Wunder
          @marc-berg
          Das sudo apt update && sudo apt full-upgrade hat er doch auch ausgeführt, daher gehe ich davon aus, dass die Internetverbindung eigentlich paßt.
          W HomoranH 2 Antworten Letzte Antwort
          • W Willi-Wunder
            @marc-berg
            W Offline
            W Offline
            Willi-Wunder
            Hab jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, log ist
                Installing ioBroker (3/4)
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/iobroker.admin
            npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T19_13_30_176Z-debug-0.log
                Finalizing installation (4/4)
            Enabling autostart...
            Autostart enabled!
                ioBroker was installed successfully
                Open http://192.168.2.230:8081 in a browser and start configuring!
            • W Willi-Wunder
              @marc-berg
              @marc-berg
              das geht zum linux Repo. das sind andere Server
              Der Fehler bei dir trat auf, als das InstallTionsskript auf den npm-server zugreifen wollte
                @homoran sagte in ioBroker startet nicht nach Neuinstallation:
                der mag nicht ins Internet
                Moin,
                doch, denn Punkt 1, die prerequisites kann er ja holen!
                    Installing prerequisites (1/4)
                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                Reading package lists... Done
                Bernd
                P.S.: aktuell ist die Verbindung von hier zum iobroker.net ok, wie es vom TE aus sieht
                ❯ ping iobroker.net
                PING iobroker.net (82.165.135.239) 56(84) Bytes an Daten.
                64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 Zeit=13.5 ms
                64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 Zeit=13.0 ms
                64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=56 Zeit=12.9 ms
                64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=56 Zeit=12.9 ms
                64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=5 ttl=56 Zeit=12.6 ms
                ^C
                --- iobroker.net ping-Statistik ---
                5 Pakete übertragen, 5 empfangen, 0% packet loss, time 4006ms
                rtt min/avg/max/mdev = 12.584/12.970/13.529/0.307 ms
                ❯ traceroute iobroker.net
                traceroute to iobroker.net (82.165.135.239), 30 hops max, 60 byte packets
                 1  _gateway (192.168.178.1)  0.317 ms  0.501 ms  0.582 ms
                 2  lo0.irai0010.as9136.net (62.176.224.222)  4.709 ms  4.797 ms  4.769 ms
                 3  ae0-181.irci0006.as9136.net (62.176.238.143)  4.794 ms  4.767 ms  4.733 ms
                 4  et-0-0-0-0.cfrc2101.as9136.net (62.176.251.11)  11.192 ms  11.251 ms  11.224 ms
                 5  decix.bb-a.fra3.fra.de.net.ionos.com (80.81.192.123)  11.437 ms  11.444 ms  11.670 ms
                 6  lo-0-0.rc-a.bap.rhr.de.net.ionos.com (212.227.117.208)  17.202 ms  18.543 ms  18.463 ms
                 7  port-channel-2.gw-distdh-a.kw.nbz.fr.net.ionos.com (195.20.243.9)  16.602 ms  13.515 ms  14.033 ms
                 8  ae-1.gw-prtr-a0110-a.kw.nbz.fr.net.ionos.com (195.20.243.81)  19.131 ms * *
                 9  s21181212.onlinehome-server.info (82.165.135.239)  19.532 ms  15.488 ms  14.474 ms
                W Offline
                W Offline
                Willi-Wunder
                @dp20eic sagte in ioBroker startet nicht nach Neuinstallation:
                ping iobroker.net
                Sieht bei mir auch gut aus, hmm
                pi@iobroker:~ $ ping iobroker.net
                PING iobroker.net (82.165.135.239) 56(84) bytes of data.
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 time=16.8 ms
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 time=14.8 ms
                ^C
                --- iobroker.net ping statistics ---
                60 packets transmitted, 60 received, 0% packet loss, time 59091ms
                rtt min/avg/max/mdev = 14.449/15.131/17.219/0.487 ms
                • W Willi-Wunder
                  ping iobroker.net
                  ^C
                  Marc BergM Online
                  Marc BergM Online
                  Marc Berg
                  @willi-wunder
                  was sagt eigentlich das besagte Log:
                    @willi-wunder
                    W Offline
                    W Offline
                    Willi-Wunder
                    @marc-berg
                    Das Verzeichnis scheint es nicht zu geben......
                    • W Willi-Wunder
                      @marc-berg
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      @marc-berg
                      Das ist ein verstecktes. Du musst das Anzeigen aktivieren. Womit guckst du da?
                        @marc-berg
                        W Offline
                        W Offline
                        Willi-Wunder
                        @marc-berg
                        Mit WinSCP .......war aber gerade auf dem aktiven System, sorry. Auf den neuen kann ich mich gerade nicht einloggen mit root......
                        Marc BergM Thomas BraunT 3 Antworten Letzte Antwort
                        • W Willi-Wunder
                          @marc-berg
                          Marc BergM Online
                          Marc BergM Online
                          Marc Berg
                          Aber doch mit "pi"?
                          Und dann Strg+Alt+H, um versteckte Dateien anzuzeigen.
                            Aber doch mit "pi"?
                            W Offline
                            W Offline
                            Willi-Wunder
                            @marc-berg
                            Super, danke, jetzt aber......
                            • W Willi-Wunder
                              @marc-berg
                              Marc BergM Online
                              Marc BergM Online
                              Marc Berg
                              Aber den Ping vorhin hast du auf dem richtigen gemacht!?
                              • W Willi-Wunder
                                @marc-berg
                                Macht man ohnehin NIE.
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  @marc-berg
                                  Ja, in Putty ist das Fenster ja noch aktiv wo ich installiere...... 😳
                                  • W Willi-Wunder
                                    @marc-berg
                                    Marc BergM Online
                                    Marc BergM Online
                                    Marc Berg
                                    Irgendwie passt das Log inhaltlich nicht zu den Connection-Problemen, die oben angezeigt wurden. Hab' erstmal keine Idee mehr.
                                      W Offline
                                      W Offline
                                      Willi-Wunder
                                      @marc-berg
                                      Gib mehrere Logs......denke die große Datei war vom ersten Versuch mit dem Netzwerkproblemen, danach kamen die weiteren Versuche.....
                                      2023-12-22T16_47_20_580Z-debug-0.log
                                      • W Willi-Wunder
                                        @marc-berg
                                        Marc BergM Online
                                        Marc BergM Online
                                        Marc Berg
                                        Zeig mal noch die beiden kleinen davor.
                                          W Offline
                                          W Offline
                                          Willi-Wunder
                                          @marc-berg
                                          Leider zu spät, SD Karte gerade platt gemacht, probiere jetzt die V11 aus, ist zwar nicht Sinn und Zweck der Geschichte, aber ein Freund hatte damit nie Probleme gehabt. Mal schauen was dann hier im Log steht. Sollte eigentlich eine simple Geschichte sein, scheinbar aber gerade nicht. 🤕
                                          Danke für deine Unterstützung.
                                          Ro75R 1 Antwort Letzte Antwort
