Anker Adapter
Ich bin zwar nicht angesprochen, habe die Meldungen aber auch.
RAW_JSON:{"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"563.31","unit":"kwh"},{"type":"2","total":"561.62","unit":"kg"},{"type":"3","total":"225.33","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZV6Y60D12345678","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"100","bind_site_status":"","charging_power":"185","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"185","output_power":"185","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"1.00","updated_time":"2025-05-15 18:04:14","total_photovoltaic_power":"185","total_output_power":"185.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"185","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0},"use_time_excute_info":{"current_band":"0"}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"asdec432-abc6-45c0-bb93-cb80eb3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1,"user_scene_mode":0,"is_dynamic_price_down_grade":false,"aiems_profit":null,"switch_0w":0}Danke dir :)
Lösch es mal bitte wieder, weil deine SN sichtbar ist ;) man weis ja nie
Ich gucke durch und patche es:)
Danke dir :)
@ronny130286 sagte in Anker Adapter:
Die hab ich verändert. Ist die S/N von wem anders dann... :-)
Und die site_id ist auch gefälscht. -
Und die site_id ist auch gefälscht.Sehr gut :D
Sehr gut :D
Patch funktioniert, die Meldungen zum grid sind weg.
Jetzt ist mein LogFile auch wieder übersichtlich!Danke schön!
Danke für das Feedback, ich lasse es mal noch bis nächste Woche im Beta Repo und mache dann eine Stable drauß (wenn es keine weitern Probleme gibt)
Wäre es möglich, das du mirdas RAW_JSON von der Solarbank wo es nicht geht zur Verfügung stellen könntest?
sorry, war "urlaubusbedingt" nicht online.
Das Thema hat sich ja erledigt.
Danke für deinen Einsatz.
Gude,
Ich habe die Solix 3 pro in Betrieb, einmal kamen Daten rein aber es wird nichts so richtig aktualisiert. Hat einer ein Trick 17?
@tony-h sagte in Anker Adapter:
Trick 16: Schau ins Log, vielleicht steht da was zu Trick 17 drin.
Gude,
@tony-h
Ein Trick gibt es da leider nicht, ich kann dir nur soviel sagen, dass nicht immer alle Daten aktualisiert werden, weil in der Anker Cloud auch keine neuen Daten zur Verfügung stehen.
Die Datenpunkten werden nur geändert, wenn es eine Aktualisierung gegeben hat.
Bspw. wird bei mir immer zuverlässig der Wert ankersolix2.0.xxxxxxxxxxxxxxx.home_load_power aktualisiertWenn man jedoch in der Anker App selbst guckt (zumindest ist es bei mir so) dann sieht man auch, dass das Diagramm nur alle 20min einen Wert bekommt.
Hat jemand mal ein schönes Beispiel wie man das mit dem Energiefluss 2 Adapter visualisiert?
Was denkst du, wann du das stable fertig hast?
Ich spiele heute nochmal einen kleinen Patch ein, weil die Solix 3 einen neuen Wert liefert, der als String erkannt wird, allerdings ein bool ist.
Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;) -
Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;)Mir scheint das in ein Install-Loop zu laufen:
Adapter "ankersolix2" : 2.1.2 , installed 2.1.1 [Updatable]Wird jedenfalls nach erfolgreichem Update wieder zum Update vorgeschlagen.
Hatten wir neulich bei anderen Adaptern schon mal. -
Hatten wir neulich bei anderen Adaptern schon mal.2.1.2 ist auf npm verfügbar. Die Version stimmt.
Warum das nicht sauber installiert wird kann ich nicht sagen. Mit den Problemen vor ca 1 bis 2 Woichen ("Fantasieversionen") hat das definitiv nichts zu tun.Ev. mach ein Issue beim js-controller auf. Nehme an du installierst auf der commandline ( :-) ) - also kann da admin nicht mitspielen. Ev. schau was nun wirklich installiuert ist (npm paket / io-package.json Inhalt)
Alles i.O.! Das war auf meinem Test-System (mit nodejs@22 und installiertem yahka).
Und da klemmt es ja zur Zeit...
yahka rausgekickt und das Update ging dann auch tatsächlich durch. -
yahka rausgekickt und das Update ging dann auch tatsächlich durch.@thomas-braun
OK - bei YAHKA und node 22 kriegst nen npm Fehler :-)Und wie im anderen Posting geschrieben an unerwarteten Stellen :-) :-) :-)
@mcm1957 sagte in Anker Adapter:
Aber nicht, wenn du andere Adapter installierst oder updatest. Das ist aber gemein! :-)
hmm
Beim Update von backitup kam ein Fehler (lt. Diskussion in Telegram oder so - habs nicht mehr im Kopf).
Ist aber jedenfalls hier OT. -
Hallo Ronny,
vielen Dank für den Anker-Adapter. Klasse Arbeit.
Habe seit heute eine Solix 3 Pro im Einsatz und wollte einen Max-Wert für den Datenpunkt ankersolix2.0.xxxxxxx.solarbank_info.battery_discharge_power über den Statistics-Adapter einbauen. Statistics sagt bei dem Wert aber, dass es weder Boolean noch Number ist und lässt mich dann die Einstellungen für Min/Max-Werte nicht auswählen.
Bei anderen Werten funktioniert es aber. Zum Beispiel für:
statistics.0.temp.minmax.ankersolix2.0.xxxxxxxx.solarbank_info.total_charging_power.dayMax
Wäre toll, wenn du da mal schauen könntes.
Viele Grüße
Uwe -
Moin,
von mir auch ein großes Lob für den Adapter! Super Arbeit!
Ich hätte da ein Anliegen: Gibt es eine Beschreibung der Datenpunkte? Interessieren würde mich derzeit der Datenpunkt: "charging_status" Der wechselt zwischen 0 .. 6. Leider habe ich nicht herausgefunden welche Bedingungen zu 0 .. 6 führen. Kann mir da jemand weiterhelfen?
Besten Dank,
Heinz
