  3. Entwicklung
  4. Anker Adapter
    1.9k
    1.5k
Anker Adapter
437 Beiträge 63 Kommentatoren 174.8k Aufrufe 60 Beobachtet
    @ronny130286
    Ich bin zwar nicht angesprochen, habe die Meldungen aber auch.
    RAW_JSON:
    {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"563.31","unit":"kwh"},{"type":"2","total":"561.62","unit":"kg"},{"type":"3","total":"225.33","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZV6Y60D12345678","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"100","bind_site_status":"","charging_power":"185","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"185","output_power":"185","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"1.00","updated_time":"2025-05-15 18:04:14","total_photovoltaic_power":"185","total_output_power":"185.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"185","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0},"use_time_excute_info":{"current_band":"0"}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"asdec432-abc6-45c0-bb93-cb80eb3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1,"user_scene_mode":0,"is_dynamic_price_down_grade":false,"aiems_profit":null,"switch_0w":0}
    R
    R
    ronny130286
    schrieb am zuletzt editiert von ronny130286
    #221
    Danke dir :)
    Lösch es mal bitte wieder, weil deine SN sichtbar ist ;) man weis ja nie
    Ich gucke durch und patche es:)
    • R ronny130286
      Danke dir :)
      Thomas BraunT
      Thomas BraunT
      #222
      @ronny130286 sagte in Anker Adapter:
      Die hab ich verändert. Ist die S/N von wem anders dann... :-)
      Und die site_id ist auch gefälscht.
      R 1 Antwort Letzte Antwort
        R
        R
        ronny130286
        #223
        Sehr gut :D
        • R ronny130286
          Sehr gut :D
          Thomas BraunT
          Thomas BraunT
          #224
          @ronny130286
          Patch funktioniert, die Meldungen zum grid sind weg.
          Jetzt ist mein LogFile auch wieder übersichtlich!
          Danke schön!
            @ronny130286
            Danke schön!
            R
            R
            ronny130286
            #225
            Danke für das Feedback, ich lasse es mal noch bis nächste Woche im Beta Repo und mache dann eine Stable drauß (wenn es keine weitern Probleme gibt)
            E 1 Antwort Letzte Antwort
            • R ronny130286
              @erazorlee
              Wäre es möglich, das du mirdas RAW_JSON von der Solarbank wo es nicht geht zur Verfügung stellen könntest?
              E
              E
              erazorlee
              #226
              @ronny130286
              sorry, war "urlaubusbedingt" nicht online.
              Das Thema hat sich ja erledigt.
              Danke für deinen Einsatz.
              • T
                T
                Tony H.
                #227
                Gude,
                Ich habe die Solix 3 pro in Betrieb, einmal kamen Daten rein aber es wird nichts so richtig aktualisiert. Hat einer ein Trick 17?
                Thomas BraunT R 2 Antworten Letzte Antwort
                • T Tony H.
                  Gude,
                  Thomas BraunT
                  Thomas BraunT
                  #228
                  @tony-h sagte in Anker Adapter:
                  Trick 16: Schau ins Log, vielleicht steht da was zu Trick 17 drin.
                  • T Tony H.
                    Gude,
                    R
                    R
                    ronny130286
                    #229
                    @tony-h
                    Ein Trick gibt es da leider nicht, ich kann dir nur soviel sagen, dass nicht immer alle Daten aktualisiert werden, weil in der Anker Cloud auch keine neuen Daten zur Verfügung stehen.
                    Die Datenpunkten werden nur geändert, wenn es eine Aktualisierung gegeben hat.
                    Bspw. wird bei mir immer zuverlässig der Wert ankersolix2.0.xxxxxxxxxxxxxxx.home_load_power aktualisiert
                    Wenn man jedoch in der Anker App selbst guckt (zumindest ist es bei mir so) dann sieht man auch, dass das Diagramm nur alle 20min einen Wert bekommt.
                    • G
                      G
                      gluecksmann
                      #230
                      Hat jemand mal ein schönes Beispiel wie man das mit dem Energiefluss 2 Adapter visualisiert?
                      UweRLPU 1 Antwort Letzte Antwort
                      • R ronny130286
                        E
                        E
                        erazorlee
                        #231
                        @ronny130286
                        Was denkst du, wann du das stable fertig hast?
                        • R
                          R
                          ronny130286
                          #232
                          @erazorlee
                          Ich spiele heute nochmal einen kleinen Patch ein, weil die Solix 3 einen neuen Wert liefert, der als String erkannt wird, allerdings ein bool ist.
                          Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;)
                          • R ronny130286
                            @erazorlee
                            Thomas BraunT
                            Thomas BraunT
                            #233
                            @ronny130286
                            Mir scheint das in ein Install-Loop zu laufen:
                            Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.1  [Updatable]
                            Wird jedenfalls nach erfolgreichem Update wieder zum Update vorgeschlagen.
                            Hatten wir neulich bei anderen Adaptern schon mal.
                              @ronny130286
                              mcm1957M
                              mcm1957M
                              mcm1957
                              #234
                              2.1.2 ist auf npm verfügbar. Die Version stimmt.
                              Warum das nicht sauber installiert wird kann ich nicht sagen. Mit den Problemen vor ca 1 bis 2 Woichen ("Fantasieversionen") hat das definitiv nichts zu tun.
                              Ev. mach ein Issue beim js-controller auf. Nehme an du installierst auf der commandline ( :-) ) - also kann da admin nicht mitspielen. Ev. schau was nun wirklich installiuert ist (npm paket / io-package.json Inhalt)
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                              • mcm1957M mcm1957
                                Thomas BraunT
                                Thomas BraunT
                                #235
                                @mcm1957
                                Alles i.O.! Das war auf meinem Test-System (mit nodejs@22 und installiertem yahka).
                                Und da klemmt es ja zur Zeit...
                                yahka rausgekickt und das Update ging dann auch tatsächlich durch.
                                  @mcm1957
                                  mcm1957M
                                  mcm1957M
                                  mcm1957
                                  #236
                                  OK - bei YAHKA und node 22 kriegst nen npm Fehler :-)
                                  Und wie im anderen Posting geschrieben an unerwarteten Stellen :-) :-) :-)
                                  • mcm1957M mcm1957
                                    Thomas BraunT
                                    Thomas BraunT
                                    #237
                                    @mcm1957 sagte in Anker Adapter:
                                    Aber nicht, wenn du andere Adapter installierst oder updatest. Das ist aber gemein! :-)
                                      mcm1957M
                                      mcm1957M
                                      mcm1957
                                      #238
                                      hmm
                                      Beim Update von backitup kam ein Fehler (lt. Diskussion in Telegram oder so - habs nicht mehr im Kopf).
                                      Ist aber jedenfalls hier OT.
                                      • M
                                        M
                                        Mumpitz
                                        #239
                                        Hallo Ronny,
                                        vielen Dank für den Anker-Adapter. Klasse Arbeit.
                                        Habe seit heute eine Solix 3 Pro im Einsatz und wollte einen Max-Wert für den Datenpunkt ankersolix2.0.xxxxxxx.solarbank_info.battery_discharge_power über den Statistics-Adapter einbauen. Statistics sagt bei dem Wert aber, dass es weder Boolean noch Number ist und lässt mich dann die Einstellungen für Min/Max-Werte nicht auswählen.
                                        Bei anderen Werten funktioniert es aber. Zum Beispiel für:
                                        statistics.0.temp.minmax.ankersolix2.0.xxxxxxxx.solarbank_info.total_charging_power.dayMax
                                        Wäre toll, wenn du da mal schauen könntes.
                                        Viele Grüße
                                        Uwe
                                        • H
                                          H
                                          HeinzOs
                                          #240
                                          Moin,
                                          von mir auch ein großes Lob für den Adapter! Super Arbeit!
                                          Ich hätte da ein Anliegen: Gibt es eine Beschreibung der Datenpunkte? Interessieren würde mich derzeit der Datenpunkt: "charging_status" Der wechselt zwischen 0 .. 6. Leider habe ich nicht herausgefunden welche Bedingungen zu 0 .. 6 führen. Kann mir da jemand weiterhelfen?
                                          Besten Dank,
                                          Heinz
                                          83.8k
