  3. Entwicklung
  4. Anker Adapter
Anker Adapter
437 Beiträge 63 Kommentatoren 160.0k Aufrufe 60 Beobachtet
  • E erazorlee
    @ronny130286
    Sieht so aus. Bei der Bank mit Smartmeter bekomme ich die Meldung nicht, bei der ohne schon.
    ronny130286
    #219
    @erazorlee
    Wäre es möglich, das du mirdas RAW_JSON von der Solarbank wo es nicht geht zur Verfügung stellen könntest?
    Thomas BraunT E 2 Antworten Letzte Antwort
    • R ronny130286
      @erazorlee
      Thomas BraunT Offline
      #220
      @ronny130286
      Ich bin zwar nicht angesprochen, habe die Meldungen aber auch.
      RAW_JSON:
      {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"563.31","unit":"kwh"},{"type":"2","total":"561.62","unit":"kg"},{"type":"3","total":"225.33","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZV6Y60D12345678","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"100","bind_site_status":"","charging_power":"185","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"185","output_power":"185","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"1.00","updated_time":"2025-05-15 18:04:14","total_photovoltaic_power":"185","total_output_power":"185.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"185","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0},"use_time_excute_info":{"current_band":"0"}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"asdec432-abc6-45c0-bb93-cb80eb3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1,"user_scene_mode":0,"is_dynamic_price_down_grade":false,"aiems_profit":null,"switch_0w":0}
      R 1 Antwort Letzte Antwort
        @ronny130286
        RAW_JSON:
        ronny130286
        schrieb am zuletzt editiert von ronny130286
        #221
        Danke dir :)
        Lösch es mal bitte wieder, weil deine SN sichtbar ist ;) man weis ja nie
        Ich gucke durch und patche es:)
        • R ronny130286
          Danke dir :)
          #222
          @ronny130286 sagte in Anker Adapter:
          Die hab ich verändert. Ist die S/N von wem anders dann... :-)
          Und die site_id ist auch gefälscht.
            ronny130286
            #223
            Sehr gut :D
            • R ronny130286
              Sehr gut :D
              #224
              @ronny130286
              Patch funktioniert, die Meldungen zum grid sind weg.
              Jetzt ist mein LogFile auch wieder übersichtlich!
              Danke schön!
                @ronny130286
                Danke schön!
                ronny130286
                #225
                Danke für das Feedback, ich lasse es mal noch bis nächste Woche im Beta Repo und mache dann eine Stable drauß (wenn es keine weitern Probleme gibt)
                E 1 Antwort Letzte Antwort
                • R ronny130286
                  @erazorlee
                  erazorlee
                  #226
                  @ronny130286
                  sorry, war "urlaubusbedingt" nicht online.
                  Das Thema hat sich ja erledigt.
                  Danke für deinen Einsatz.
                    Tony H.
                    #227
                    Gude,
                    Ich habe die Solix 3 pro in Betrieb, einmal kamen Daten rein aber es wird nichts so richtig aktualisiert. Hat einer ein Trick 17?
                    Thomas BraunT R 2 Antworten Letzte Antwort
                    • T Tony H.
                      Gude,
                      #228
                      @tony-h sagte in Anker Adapter:
                      Trick 16: Schau ins Log, vielleicht steht da was zu Trick 17 drin.
                      • T Tony H.
                        Gude,
                        ronny130286
                        #229
                        @tony-h
                        Ein Trick gibt es da leider nicht, ich kann dir nur soviel sagen, dass nicht immer alle Daten aktualisiert werden, weil in der Anker Cloud auch keine neuen Daten zur Verfügung stehen.
                        Die Datenpunkten werden nur geändert, wenn es eine Aktualisierung gegeben hat.
                        Bspw. wird bei mir immer zuverlässig der Wert ankersolix2.0.xxxxxxxxxxxxxxx.home_load_power aktualisiert
                        Wenn man jedoch in der Anker App selbst guckt (zumindest ist es bei mir so) dann sieht man auch, dass das Diagramm nur alle 20min einen Wert bekommt.
                        • G Offline
                          gluecksmann
                          #230
                          Hat jemand mal ein schönes Beispiel wie man das mit dem Energiefluss 2 Adapter visualisiert?
                          UweRLPU 1 Antwort Letzte Antwort
                          • R ronny130286
                            erazorlee
                            #231
                            @ronny130286
                            Was denkst du, wann du das stable fertig hast?
                            • R Offline
                              ronny130286
                              #232
                              @erazorlee
                              Ich spiele heute nochmal einen kleinen Patch ein, weil die Solix 3 einen neuen Wert liefert, der als String erkannt wird, allerdings ein bool ist.
                              Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;)
                              • R ronny130286
                                @erazorlee
                                #233
                                @ronny130286
                                Mir scheint das in ein Install-Loop zu laufen:
                                Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.1  [Updatable]
                                Wird jedenfalls nach erfolgreichem Update wieder zum Update vorgeschlagen.
                                Hatten wir neulich bei anderen Adaptern schon mal.
                                  @ronny130286
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #234
                                  2.1.2 ist auf npm verfügbar. Die Version stimmt.
                                  Warum das nicht sauber installiert wird kann ich nicht sagen. Mit den Problemen vor ca 1 bis 2 Woichen ("Fantasieversionen") hat das definitiv nichts zu tun.
                                  Ev. mach ein Issue beim js-controller auf. Nehme an du installierst auf der commandline ( :-) ) - also kann da admin nicht mitspielen. Ev. schau was nun wirklich installiuert ist (npm paket / io-package.json Inhalt)
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  • mcm1957M mcm1957
                                    #235
                                    @mcm1957
                                    Alles i.O.! Das war auf meinem Test-System (mit nodejs@22 und installiertem yahka).
                                    Und da klemmt es ja zur Zeit...
                                    yahka rausgekickt und das Update ging dann auch tatsächlich durch.
                                      @mcm1957
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #236
                                      OK - bei YAHKA und node 22 kriegst nen npm Fehler :-)
                                      Und wie im anderen Posting geschrieben an unerwarteten Stellen :-) :-) :-)
                                      • mcm1957M mcm1957
                                        #237
                                        @mcm1957 sagte in Anker Adapter:
                                        Aber nicht, wenn du andere Adapter installierst oder updatest. Das ist aber gemein! :-)
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #238
                                          hmm
                                          Beim Update von backitup kam ein Fehler (lt. Diskussion in Telegram oder so - habs nicht mehr im Kopf).
                                          Ist aber jedenfalls hier OT.
