  4. Test Adapter Weather-Warnings
1.1k Beiträge 36 Kommentatoren 496.5k Aufrufe 41 Beobachtet
  • ArmilarA Armilar
    @ticaki
    habe folgende Fehler:
    weather-warnings.0
    2023-11-09 18:04:19.343	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    weather-warnings.0
    2023-11-09 18:04:18.785	error	Cannot read properties of undefined (reading 'join')
    weather-warnings.0
    2023-11-09 18:04:18.784	error	TypeError: Cannot read properties of undefined (reading 'join') at new BaseProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:49:104) at new UWZProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:458:9) at ProviderController.createProviderIfNotExist (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:784:25) at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:508:49 at processTicksAndRejections (node:internal/process/task_queues:95:5)
    weather-warnings.0
    2023-11-09 18:04:18.639	error	unhandled promise rejection: Cannot read properties of undefined (reading 'join')
    weather-warnings.0
    2023-11-09 18:04:18.639	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    weather-warnings.0
    2023-11-09 18:03:40.466	error	DB closed
    weather-warnings.0
    2023-11-09 18:03:40.466	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at TCP.<anonymous> (node:net:350:12)
    weather-warnings.0
    2023-11-09 18:03:40.464	error	unhandled promise rejection: DB closed
    weather-warnings.0
    2023-11-09 18:03:40.464	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    weather-warnings.0
    2023-11-09 18:03:39.939	error	Cannot read properties of undefined (reading 'join')
    weather-warnings.0
    2023-11-09 18:03:39.939	error	TypeError: Cannot read properties of undefined (reading 'join') at new BaseProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:49:104) at new UWZProvider (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:458:9) at ProviderController.createProviderIfNotExist (/opt/iobroker/node_modules/iobroker.weather-warnings/src/lib/provider.ts:784:25) at /opt/iobroker/node_modules/iobroker.weather-warnings/src/main.ts:508:49 at processTicksAndRejections (node:internal/process/task_queues:95:5)
    weather-warnings.0
    2023-11-09 18:03:39.834	error	unhandled promise rejection: Cannot read properties of undefined (reading 'join')
    weather-warnings.0
    2023-11-09 18:03:39.833	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    T Nicht stören
    T Nicht stören
    ticaki
    #821
    @armilar
    Version?
    Spenden
    LatziL 1 Antwort Letzte Antwort
    • T ticaki
      @armilar
      Version?
      LatziL Online
      LatziL Online
      Latzi
      #822
      @ticaki
      laut Screenshot 0.5.3 ;-)
      • LatziL Latzi
        @ticaki
        T Nicht stören
        T Nicht stören
        ticaki
        #823
        @latzi
        Ich gucke mir Bilder i.d.R. nicht direkt an, deshalb danke :)
        @Armilar
        Bitte ein Screenshot der UWZ Konfiguration. Ich schätze mal das es für die eingegebenen Koordinaten keine Warnzelle gibt. Das hab ich nicht überprüft und würde zu diesem Fehler führen. Wird in 0.5.4 behoben werden.
        EDIT: Der Screenshot würde mich doch interessieren, ob ich mit meiner Annahme recht habe. Oder die Koordinaten.
        EDIT: falsche Koordinaten war es schon mal nicht. Das gab zwar auch einen Fehler, aber nicht diesen.
        Spenden
        • T ticaki
          @latzi
          @Armilar
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #824
          @ticaki
          klar - alles was du brauchst
          Wenn du noch mehr brauchst, dann bescheid geben
          • ArmilarA Armilar
            @ticaki
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #825
            @armilar
            Es waren natürlich die Koordinaten... Hätte jetzt ehrlich gesagt gedacht, dass er sich die Geodaten aus dem ioBroker zieht...
            Habe auf den Pin gedrückt, die Koordinaten kamen und ...
            Keine Ahnung warum da DE12345 drin stand
            • ArmilarA Armilar
              @armilar
              T Nicht stören
              T Nicht stören
              ticaki
              #826
              @armilar
              Die DE12345 waren mal ganz zu anfang ein Beispiel, Hab die Konfiguration da stark verändert. Wird wohl ein Rest gewesen sein. Jetzt muß ich nur gucken wie es ein DE12345 durch die Checks geschafft hat. Danke.
              Spenden
              • T Nicht stören
                T Nicht stören
                ticaki
                #827
                Gleich geht ne neue Version auf den Weg:
                v0.5.4
                • Hinzugefügt: Anzahl der maximalen Warnungen pro Provider einstellbar (Default 5)
                • Behoben: Zufälliger Fehler in den ersten ca 6-15 Sekunden nach Start des Adapters. Die Auswirkungen habe ich wohl schon größten Teils behoben gehabt, jetzt hab ich aber den Grund gefunden. :)
                • Behoben: kleine Sache in den Ruhezeiten
                • UWZ Warnzellenüberprüfung verbessert.
                Edit: ist das eigentlich ok das ich unter .warning. keine leeren Standardordner erzeuge, sondern nur wenn auch einen Warnung da ist, bis zur maximalen Anzahl, die man jetzt konfigurieren kann?!
                Spenden
                • sigi234S sigi234
                  @ticaki
                  kann man warntypename in einen extra DP zusammenfassen?
                  weather-warnings.0.provider.zamg.xxxxxxxxx-xxxxxxxxxxx.formatedKeys.00.warntypename
                  Also , es gibt bei den Ort mehrere Warnungen mit: ............formatedKeys.00 , 01 , 02 usw
                  Für Vis müsste ich bei jeder Warnung einen eigenen Button erstellen.
                  Kurz um, welche warntypename gibt es Alle im Ort.
                  Hier sollte dann Gewitter, Glatteis stehen.
                  T Nicht stören
                  T Nicht stören
                  ticaki
                  #828
                  @sigi234 sagte in Test Adapter Weather-Warnings:
                  @ticaki
                  Deshalb github request. Ich kann mich nichtmal errinnern dass du danach gefragt hast. :D
                  Sollte jetzt unter .alerts. zu finden sein... Oder hatte ich das schon eingebaut und kann mich auch daran nicht errinnern... Alt werden ist doof, kann ich nicht empfehlen.
                  Spenden
                    mp24
                    schrieb am zuletzt editiert von mp24
                    #829
                    @ticaki
                    Ich habe 2 Warnungen gefunden:
                    und
                    Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:726:40) at WeatherWarnings._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7711:34)
                    und noch: cannot get Warncellid.
                    Ich hatte die Koordinaten eingegeben.
                    • M mp24
                      @ticaki
                      und
                      T Nicht stören
                      T Nicht stören
                      ticaki
                      #830
                      @mp24
                      Bitte gib mir das ganze Log um die Fehler herum. Mit den Fehlermeldungen kann ich leider nichts anfangen
                      Spenden
                        mp24
                        #831
                        Ich werde später den Adapter noch einmal installieren und dann mitloggen.
                        Der Admin - Adapter hat gerade diese Fehlermeldung abgegeben:
                        	weather-warnings has an invalid jsonConfig: [{"instancePath":"/items/_basicconfig/items/allowedDirs/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["alive","autocomplete","cron","text","textSendTo","number","port","color","checkbox","chips","header","slider","ip","user","room","func","select","icon","image","panel","password","file","sendTo","staticText","custom","pattern","table","instance","language","setState","certificate","certificates","staticImage","staticLink","divider","objectId","selectSendTo","autocompleteSendTo","checkLicense","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/_basicconfig","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                        • M mp24
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          #832
                          @mp24
                          Der Admin Adapter hat dir einen fehlerhafte Warnmeldung ins Log geschrieben. Das ist ein Adminproblem und kann ich nicht beheben. Eine Option die ich in der Konfiguration benutze und die funktioniert, wird vom Admin fälschlicherweise als Invalid angesehen.
                          Spenden
                          • rtwlR Offline
                            rtwlR Offline
                            rtwl
                            #833
                            Falls mehrere Warnungen vorhanden sind (ZAMG). Wie werden denn die Ordner 00-04 in formatedKeys sortiert?
                            -Peter
                            • rtwlR rtwl
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              #834
                              @rtwl
                              Nach startzeit - außer du änderst die Systemsprache, dann ist die Reihenfolge, wohl auch nach startzeit, aber wird nicht extra kontrolliert.
                              Spenden
                              rtwlR 1 Antwort Letzte Antwort
                              • T ticaki
                                @rtwl
                                rtwlR Offline
                                rtwlR Offline
                                rtwl
                                #835
                                @ticaki perfekt, danke!
                                -Peter
                                • T Nicht stören
                                  T Nicht stören
                                  ticaki
                                  #836
                                  Hab noch 2 Fehler und 1 was mich nervt gefunden.
                                  1. Vorlage EmailMessage - da fehlt ein Leerzeichen
                                  2. ${status} zeigt noch immer den falschen Wert an bei keiner Warnung
                                  3. Das die Testingoptionen über 2 tabs gehen ist mist - kommt wieder auf die erste Seite.
                                  Wird in der kommenden Version behoben werden. Wahrscheinliche heute abend - für das fehlende Leerzeichen muß ich auf weblate warten.
                                  Ach und Ist schon gefixt oder mit der nächsten Admin version:
                                  • expert kann dann nicht mehr deaktiviert werden
                                  • dwd man kann eigene aber falsche Ortsnamen nicht mehr auswählen.
                                  Spenden
                                  • sigi234S sigi234
                                    @ticaki
                                    Hallo, ich möchte wenn keine Warnung ist das Alexa mir das ansagt aber nur bei manuellen auslösen.
                                    Wie mache ich das?
                                    Edit:
                                    Des Weiteren wäre noch ein DP mit true/false interessant ob eine Warnung vorliegt für die Weiterverarbeitung in ein Blockly. Beispiel: Frage an Alexa: Gibt es eine Warnung?
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    #837
                                    @ticaki
                                    Wie mache ich das?
                                    Edit:
                                    Brauchst du Punkt 1 noch? Das geht bis her nicht.
                                    Punkt 2. sollte mit alerts bzw. dem Zähler für aktive Warnungen ja abgedeckt sein.
                                    update v0.5.5 auf dem weg ins latest, auf npm verfügbar.
                                    update v0.5.6
                                    • die Vorlage für keine Warnung bei manueller Auslösung ist konfigurierbar also auch keine.
                                    • Vorlagenschlüssel die nicht existieren werden rot markiert
                                    Info zu Admin >= v6.12.3
                                    • DWD Auswahl funktioniert wie von mir vorgesehen
                                    Spenden
                                    • T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #838
                                      v0.6.0
                                      • Hinzugefügt: globale Alarme, in diesen gibt es zusätzlich das Feld Provider.
                                      • Geändert: Token **adverb - wenn kein Adverb vorhanden ist, wird der Tag der Woche verwendet. Entweder ist es gestern, heute, morgen, übermorgen oder Wochentag.
                                      Jetzt ist der nächste halt stable, bin aber Nina langsam am integieren.
                                      Wäre nett wenn ihr in den nächsten 7 Tagen mal bescheid sagt, dass alles geht wie gewünscht.
                                      v0.6.1
                                      • Deutsch nochmal etwas verbessert
                                      • Adminkonfiguration verbessert
                                      • DWD Ortsnamen verbessert
                                      Spenden
                                      • T ticaki
                                        v0.6.0
                                        v0.6.1
                                        MartyBr
                                        #839
                                        @ticaki hallo @ticaki , ich hatte deinen Adapter bisher auf einen Slave laufen. Dort ist ja kein Admin installiert. Nun habe ich versucht, ein Update durchzuführen, was aber schiefging. Ursache ist der fehlende Admin auf dem Slave.
                                        Ich konnte weather-Warnings ohne Probleme auf dem Master installieren.
                                        Könntest du die Prüfung auf den Admin-Prozess entfernen oder gibt es eine Möglichkeit, den Adapter trotz nicht installiertem Admin auf einen Slave Rechner zu installieren?
                                        Martin
                                        Intel NUCs mit Proxmox / Iobroker als VM unter Debian
                                        Raspeberry mit USB Leseköpfen für Smartmeter
                                        Homematic und Homematic IP
                                        • M MartyBr
                                          T Nicht stören
                                          T Nicht stören
                                          ticaki
                                          #840
                                          @martybr
                                          Das ist nicht mit Absicht so. Hast du einen Fehlermeldung für mich? Von welcher Version zu welcher Version wolltest du updaten?
                                          Spenden
