  3. Einsteigerfragen
  4. Installation
  5. [gelöst] Update von Debian 10 auf 11?
Geplant Angeheftet Gesperrt Verschoben Installation
90 Beiträge 4 Kommentatoren 6.5k Aufrufe 3 Beobachtet
    @alero
    und?....
    @homoran sagte in Update von Debian 10 auf 11?:
    @alero hast du gefixt?
    wenn dann immer noch Probleme sind, bitte backitup Instanz auf Logstufe debug stellen und nochmal versuchen.
    Dann das debug-log posten
    Alero
    #81
    hier mehr infos:
    backitup.0
    2023-09-26 08:39:42.995	debug	No backup file was found
    backitup.0
    2023-09-26 08:39:40.994	error	Error: Command failed: sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    backitup.0
    2023-09-26 08:39:40.974	debug	cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backups"
    backitup.0
    2023-09-26 08:39:40.974	debug	first mount attempt with smb option failed. try next mount attempt without smb option ...
    backitup.0
    2023-09-26 08:39:40.725	debug	cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backups"
    backitup.0
    2023-09-26 08:39:40.725	debug	noserverino option: false
    backitup.0
    2023-09-26 08:39:40.721	debug	[ccu] 10 30 01 */1 * *
    backitup.0
    2023-09-26 08:39:40.717	info	[ccu] backup will be activated at 01:30 every 1 day(s)
    backitup.0
    2023-09-26 08:39:40.716	debug	[iobroker] 10 00 03 */1 * *
    backitup.0
    2023-09-26 08:39:40.692	info	[iobroker] backup will be activated at 03:00 every 1 day(s)
    backitup.0
    2023-09-26 08:39:40.685	debug	Backitup has recognized a linux system
    backitup.0
    2023-09-26 08:39:40.665	info	starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.0, js-controller: 5.0.12
    backitup.0
    2023-09-26 08:39:40.532	debug	Plugin sentry Initialize Plugin (enabled=true)
    backitup.0
    2023-09-26 08:39:40.522	debug	States connected to redis: 127.0.0.1:9000
    backitup.0
    2023-09-26 08:39:40.519	debug	States create User PubSub Client
    backitup.0
    2023-09-26 08:39:40.519	debug	States create System PubSub Client
    backitup.0
    2023-09-26 08:39:40.517	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    backitup.0
    2023-09-26 08:39:40.511	debug	Objects connected to redis: 127.0.0.1:9001
    backitup.0
    2023-09-26 08:39:40.508	debug	Objects client initialize lua scripts
    backitup.0
    2023-09-26 08:39:40.502	debug	Objects create User PubSub Client
    backitup.0
    2023-09-26 08:39:40.501	debug	Objects create System PubSub Client
    backitup.0
    2023-09-26 08:39:40.500	debug	Objects client ready ... initialize now
    backitup.0
    2023-09-26 08:39:40.488	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    backitup.0
    2023-09-26 08:39:25.344	info	terminating
    backitup.0
    2023-09-26 08:39:24.893	info	Terminated (NO_ERROR): Without reason
    backitup.0
    2023-09-26 08:39:24.893	debug	Plugin sentry destroyed
    backitup.0
    2023-09-26 08:39:24.893	info	terminating
    backitup.0
    2023-09-26 08:39:24.847	info	Got terminate signal TERMINATE_YOURSELF
    backitup.0
    2023-09-26 08:39:24.842	info	cleaned everything up...
    backitup.0
    2023-09-26 08:39:13.359	debug	No backup file was found
    A 1 Antwort Letzte Antwort
    • A Alero
      hier mehr infos:
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      Alero
      #82
      hi,
      komisch ist auch das ich wenn ich den restore auslöse zeigt er mit die backup Dateien vom lokalen server.
      • A Alero
        hi,
        Alero
        schrieb am zuletzt editiert von Alero
        #83
        hi,
        vielleicht liegt es doch am container. ich habe mal geschaut. der prod server ist Privileged und der neue eben nicht.
        • A Alero
          hi,
          crunchipC Offline
          crunchipC Offline
          #84
          @alero sag ich doch😉
            Alero
            #85
            @crunchip
            hi,
            es war der previligierte Container. Habe die Kiste neu aufgesetzt und beim Aufsetzen gesagt "previligiert" jetzt sehe ich die Backups vom nas.
            Werde jetzt mal einen restore anstoßen und schauen ob es läuft
            A crunchipC 2 Antworten Letzte Antwort
            • A Alero
              @crunchip
              hi,
              Alero
              #86
              kann ich nach dem restore schauen was schief gegeangen ist?
              • A Alero
                Alero
                #87
                so ,
                habe umgeschaltet . habe nichts im log gefunden außer vis-materialdesig nicht gefunden. habe es nachinstalliert.
                Vielen dank an Euch alle die geholfen haben und nicht die Hoffung verloren haben das ich es schaffe ;-)
                Habe wieder viel gelernt.
                Vielleicht wird ja mal ein richtiger Linux freak aus mir. lol
                • A Alero
                  @crunchip
                  hi,
                  crunchipC Offline
                  crunchipC Offline
                  #88
                  @alero hättest nich neu aufsetzen müssen.
                  Man kann auch ein backup machen, dann den Lxc löschen, anschliessend backup wiederherstellen.
                  Dabei kann ausgewählt werden un/previligiert
                  • A Alero
                    Debug stand auf ein.
                    Log-Größe: 64.6 KB
                    backitup.0
                    Zeit
                    debug
                    Nachricht
                    backitup.0
                    2023-09-26 06:13:25.596	error	Error: Command failed: sudo mount -t cifs -o username=backup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                    backitup.0
                    2023-09-26 06:13:25.316	info	[iobroker] backup will be activated at 02:40 every 1 day(s)
                    backitup.0
                    2023-09-26 06:13:25.287	info	starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.0, js-controller: 5.0.12
                    backitup.0
                    2023-09-26 06:11:53.945	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    backitup.0
                    2023-09-26 06:11:53.893	info	Got terminate signal TERMINATE_YOURSELF
                    backitup.0
                    2023-09-26 06:11:53.890	info	cleaned everything up..
                    EDIT: komisch ist das die gleichen Einstellungen beim Prodsystem laufen.
                    #89
                    @alero sagte in [gelöst] Update von Debian 10 auf 11?:
                    nein!
                    nicht in der Instanz, möglicherweise der Filter
                    • A Alero
                      so ,
                      #90
                      Natürlich!
                      ist ja kein Hexenwerk
