  4. js-controller 5.0.x jetzt für alle User im STABLE!
    6.1k
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 173.7k Aufrufe 65 Beobachtet
  • A Architect0711
    @foxriver76 @Thomas-Braun Bei mir startet der admin adapter nicht mehr seit dem Update. Unten ist der output von "iob diag". Ganz unten steht ja Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually., aber das hat leider keine Abhilfe gebracht.
    pi@raspberrypi:/opt/iobroker/node_modules/iobroker.admin $ npm install --production
    npm WARN config production Use `--omit=dev` instead.
    up to date, audited 141 packages in 5s
    13 packages are looking for funding
      run `npm fund` for details
    4 moderate severity vulnerabilities
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     17:27:27 up  1:07,  2 users,  load average: 1.61, 1.93, 1.26
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2023-12-23 17:27:27 CET
               Universal time: Sat 2023-12-23 16:27:27 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	true
    Desktop: 	LXDE-pi
    Terminal: 	x11
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:           3.8G        705M        2.2G         21M        968M        3.0G
    Swap:           99M          0B         99M
    Total:         3.9G        705M        2.3G
             3838 M total memory
              705 M used memory
              417 M active memory
             1076 M inactive memory
             2164 M free memory
              128 M buffer memory
              839 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** FILESYSTEM ***
    /dev/root      ext4       59G  5.0G   51G   9% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M   12K  384M   1% /run/user/1000
    [Sat Dec 23 16:20:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:60:A4:C4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=676d1976-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Dec 23 16:20:11 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Dec 23 16:20:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Dec 23 16:20:13 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems \(real ones only\):
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G	/var/
    644M	/var/lib
    521M	/var/cache
    515M	/var/lib/piVCCU3
    509M	/var/cache/apt
    Archived and active journals take up 16.0M in the file system.
    /opt/iobroker/backups:
    du: cannot access '/opt/iobroker/backups/': No such file or directory
    /opt/iobroker/iobroker-data:
    157M	/opt/iobroker/iobroker-data/
    53M	/opt/iobroker/iobroker-data/node-red
    52M	/opt/iobroker/iobroker-data/node-red/node_modules
    46M	/opt/iobroker/iobroker-data/files
    41M	/opt/iobroker/iobroker-data/backup-objects
    21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
    5.6M	/opt/iobroker/iobroker-data/objects.jsonl
    5.4M	/opt/iobroker/iobroker-data/objects.json.migrated
    5.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    USB-Devices by-id:
    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.16.1
    /usr/bin/node 		v18.16.1
    /usr/bin/npm 		9.5.1
    /usr/bin/npx 		9.5.1
    /usr/bin/corepack 	0.17.0
    nodejs:
      Installed: 18.16.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
         18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
     *** 18.16.1-deb-1nodesource1 100
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.17
    admin: 		5.1.28
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
    + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.20.100
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 5.1.28 [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
    Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.18 [Updatable]
    Adapter    "hs100"        : 2.2.0    , installed 2.1.2  [Updatable]
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "node-red"     : 4.0.3    , installed 3.3.1  [Updatable]
    Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
    Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects: 	2298
    States: 	860
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
    Hit:4 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 155
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17270      582/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18683      420/cupsd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       61793      7787/node-red
    tcp        0      0 192.168.20.100:1882     0.0.0.0:*               LISTEN      1001       64971      8166/io.shelly.0
    tcp        0      0 192.168.20.100:2010     0.0.0.0:*               LISTEN      1001       63568      7826/io.hm-rpc.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          15251      558/mosquitto
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       61619      7722/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61612      7722/iobroker.js-co
    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15349      577/vncserver-x11-c
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62790      8041/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17272      582/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18682      420/cupsd
    tcp6       0      0 :::1883                 :::*                    LISTEN      0          15252      558/mosquitto
    tcp6       0      0 :::5900                 :::*                    LISTEN      0          15348      577/vncserver-x11-c
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20657      545/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16086      402/avahi-daemon: r
    udp        0      0 0.0.0.0:35206           0.0.0.0:*                           108        16088      402/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        16087      402/avahi-daemon: r
    udp6       0      0 :::50048                :::*                                108        16089      402/avahi-daemon: r
    2023-12-23 17:26:35.046  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
    2023-12-23 17:26:36.060  - info: host.raspberrypi iobroker npm-rebuild: exit 0
    2023-12-23 17:26:36.236  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9252
    2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
    2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]:   throw err;
    2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]:   ^
    2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
    2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: Require stack:
    2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
    2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
    2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
    2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
    2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
    2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
    2023-12-23 17:26:38.173  - error: host.raspberrypi Caught by controller[0]: }
    2023-12-23 17:26:38.173  - error: host.raspberrypi Caught by controller[0]: Node.js v18.16.1
    2023-12-23 17:26:38.173  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-12-23 17:26:38.173  - info: host.raspberrypi Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    #461
    @architect0711
    Installier da NEU! Raspberry OS 12 Bookworm. Und zwar in der Lite-Version für 64Bit. Dann dein
    iob-Backup einspielen. Zuvor den ganzen Sums auf Stand bringen.
    Künftig REGELMÄSSIG Systempflege betreiben.
    • A Architect0711
        npm audit fix
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Swap:           99M          0B         99M
               3838 M total memory
                705 M used memory
                417 M active memory
               2164 M free memory
                128 M buffer memory
                839 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.3G	/var/
      644M	/var/lib
      521M	/var/cache
      509M	/var/cache/apt
      USB-Devices by-id:
      /usr/bin/npm 		9.5.1
      /usr/bin/npx 		9.5.1
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin: 		5.1.28
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	2298
      States: 	860
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      #462
      @architect0711
      ist das richtig ... das du kein backitup Adapter hast !?
      Wo sind deine Backups !?
      A 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @architect0711
        Architect0711
        #463
        ich habe neben dem iobroker noch andere sachen auf dem raspi, deshalb mache ich immer sd card images als backup.
        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
        • A Architect0711
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          #464
          @architect0711
          Keine gute Lösung !
          • A Architect0711
            #465
            @architect0711
            Dann ist dein 'Backup-Konzept' genau jetzt an seine Grenzen gestoßen...
            • mcm1957M mcm1957
              @architect0711
              Wie im Einleitungsposting steht brauchen einige Adapter ein Update. Dein admin (5.X.X) Ist zu alt.
              Ambesten lies das ETSTE Posting nochmal durch.
              Architect0711
              #466
              @mcm57 danke, habe die Liste mit den Adaptern gefunden :) nach dem Upgrade vom Admin und vom Node Red Adapter hat wieder alles funktioniert wie gehabt :)
                torti0111
                schrieb am zuletzt editiert von torti0111
                #467
                Hi Zusammen,
                Ich habe heute morgen auf 5.0.17 geupdated…
                Habe 2 Shelly Adapter laufen. Einer für die ältere Generation, eine für die neuen über mqtt.
                Nach dem Update auf den 5.0.17 sind mir die „alten“ Shelly’s via coap eingefroren.
                Sie zeigen grün, sieht alles gut aus, aber sie machen nichts. Weder die schaltenden, noch die messenden.
                Hab die Testweise via mqtt angebunden, dann geht alles. Sobald sie via coap verbunden sind, keine Reaktion.
                Ich sehe keine Fehlermeldungen nichts im log.
                Hat jemand die gleichen Probleme?
                Edit: coap ist bei den alten wichtig, damit ich sie weiter über die cloud steuern kann.
                P 1 Antwort Letzte Antwort
                • T torti0111
                  Hi Zusammen,
                  pfahlenbauer
                  schrieb am zuletzt editiert von pfahlenbauer
                  #468
                  @torti0111
                  Ist das ein generelles Problem und konnte es gelöst werden? Ich habe meine Shelly's auch über COAP laufen und würde sonst mit dem Update noch warten.
                  Dr. BakteriusD 1 Antwort Letzte Antwort
                  • P pfahlenbauer
                    @torti0111
                    Dr. BakteriusD Online
                    Dr. Bakterius
                    schrieb am zuletzt editiert von Dr. Bakterius
                    #469
                    @pfahlenbauer sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                    Also ich habe mit meinen Shelly 1 die alle mit COAP unter dem js-controller v5.0.17 laufen keine Probleme. Funktioniert alles wie immer. Allerdings verwende ich die Cloud nicht.
                    • foxriver76F Offline
                      foxriver76F Offline
                      foxriver76
                      schrieb am zuletzt editiert von foxriver76
                      #470
                      js-controller 5.0.18 ab heute im Latest:
                      • Das Problem, dass vis States am Anfang nicht aktualisiert wurden wenn ein OBjekt null auf top level existiert wurde gefixt
                      • Wir haben versucht den hohen RAM Verbrauch zu fixen der bei manchen Adapters unter Proxmox bei Uploads auftritt
                      • CPU Verbrauch von JSONL optimiert
                      • Problem behoben dass multihost enable/disable nie "fertig" wird
                      Videotutorials & mehr
                      G FeuersturmF 2 Antworten Letzte Antwort
                      • ? Offline
                        #471
                        @foxriver76 5.0.18 laeuft hier unter Docker als Multihost Master mit buanet V9.0.1 und gleiches als Slave ohne Auffaelligkeiten ( Node 18.19.0, NPM 10.2.3)
                        Dazu noch auf einem Multihost Slave LXC in Proxmox Debian Bookworm, Node 20.11, NPM 10.2.4 ohne Probleme.
                        Objekte: 46783, Zustände: 41271 mit Redis/Redis
                        Edit:
                        Vis V1.5.4 keine Probleme mit den Werten.
                        • foxriver76F foxriver76
                          guergen
                          schrieb am zuletzt editiert von guergen
                          #472
                          @foxriver76 Leider werden nach dem Update viele Werte nicht ins Vis übernommen, Temperaturen, die definitiv da sind werden als NaN angezeigt, true/false-Werte werden als true übernommen.
                          Auch nach manuellem setzen der Werte auf false, werden die Werte nach Zeit wieder mit true überschrieben.
                          debian boowkworm, alles aktuell und auf latest.
                          Was möchtest Du noch wissen, damit der "Fehler" korrigiert werden kann?
                          foxriver76F 2 Antworten Letzte Antwort
                          • G guergen
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            #473
                            @guergen hm gar nix, kanns nachstellen. 😢
                            • G guergen
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #474
                              @guergen in einem kleinen setup zum reproduzieren scheint es als wären nur aliase betroffen, bei dir auch so?
                              G 1 Antwort Letzte Antwort
                                guergen
                                #475
                                @foxriver76 Ja, scheinen Aliase zu sein. Aber ich habe fast nur Aliase ;-)
                                • G guergen
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #476
                                  @guergen Problem gefunden, ich probiere heute noch einen Fix zu veröffentlichen
                                    foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    #477
                                    @foxriver76 5.0.19 auf dem weg
                                    ? 1 Antwort Letzte Antwort
                                      #478
                                      @foxriver76
                                      vielen Dank! aus dem Admin per Klick installiert, Slave ist ein lxc im Proxmox, Node 20, NPM 10, Admin 6.13.16, das Update ist durchgelaufen, aber es wurde ein Fehler im Fensterchen angezeigt:
                                      Nach dem Klicken auf Schliessen war der Slave wieder online mit der neuen Version.
                                      Anscheinend nur n Syntax error irgendwo.. :-)
                                      Der Fehler kam auch beim updaten des Docker Slave Hosts, weg klicken, warten, dann ware er wieder online..
                                      Ich update immer erst die Slaves, dann den Master.. oder ist das egal oder besser rumgedreht..?
                                      Beim update per Klick im Admin beim Master lief es ohne Probleme im Fensterchen durch:
                                        @foxriver76
                                        FeuersturmF Offline
                                        FeuersturmF Offline
                                        Feuersturm
                                        #479
                                        @ilovegym sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                        Schau Mal in den ersten Post ;-)
                                        fu_zhouF 1 Antwort Letzte Antwort
                                        • FeuersturmF Feuersturm
                                          fu_zhouF Online
                                          fu_zhouF Online
                                          fu_zhou
                                          schrieb am zuletzt editiert von fu_zhou
                                          #480
                                          wie kriege ich denn die 5.0.19 installiert? mit iob upgrade self -f @5.0.19 wird trotzdem die 5.0.18 (neu) installiert. Im admin wird mir nur die 5.0.18 als verfügbar angezeigt.
                                          Synology DS920+ VM, S7-315 PN mit ET200S
