  4. js-controller 5.0.x jetzt für alle User im STABLE!
    1.0k
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.5k Aufrufe 65 Beobachtet
  • S sonnenfreund
    @thomas-braun sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
    @sonnenfreund
    Dann versuch einen 4er-js-controller zu installieren.
    Nach
    iobroker update
    iobroker fix
    gleiches Problem bei iobroker upgrade self:
    pi@raspberrypi4-iob:/home $ iobroker upgrade self
    Update js-controller from @3.1.6 to @5.0.16
    NPM version: 10.2.3
    npm install iobroker.js-controller@5.0.16 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
     Objects 127.0.0.1:59744 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
     States 127.0.0.1:37004 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
     Objects 127.0.0.1:59744 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
     States 127.0.0.1:37004 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
     Objects 127.0.0.1:59744 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
     Objects 127.0.0.1:59744 Error from InMemDB: Error: scan NOT SUPPORTED
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
    npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
    npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
    npm ERR!         throw e;
    npm ERR!         ^
    npm ERR!
    npm ERR! ReplyError: Error scan NOT SUPPORTED
    npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
    npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
    npm ERR! Emitted 'error' event on ScanStream instance at:
    npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
    npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
    npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
    npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
    npm ERR!   command: {
    npm ERR!     name: 'scan',
    npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
    npm ERR!   }
    npm ERR! }
    npm ERR!
    npm ERR! Node.js v18.19.0
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-07T20_23_32_051Z-debug-0.log
    Starting node restart.js
    Diamand2k22
    #454
    kann mir jemand sagen, was das zum Teufel ist?
    ich habe den Fehler seit dem Update auf JS-Controller 5.0.17
    • D Diamand2k22
      #455
      @diamand2k22 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
      Ein Screenshot, den man nur umständlich lesen kann.
      Deswegen Texte aus dem Log immer als Text in CodeTags eingebettet hier rein
        Diamand2k22
        #456
        ok mach dann ich in Zukunft so!
        javascript.0
        2023-12-08 14:46:00.157	error	Error: read ECONNRESET at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.javascript/node_modules/axios/lib/adapters/http.js:606:25) at RedirectableRequest.emit (node:events:517:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:529:35) at ClientRequest.emit (node:domain:489:12) at TLSSocket.socketErrorListener (node:_http_client:501:9) at TLSSocket.emit (node:events:517:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at processTicksAndRejections (node:internal/process/task_queues:82:21)
        javascript.0
        javascript.0
        2023-12-08 14:46:00.156	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
        Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
        • D Diamand2k22
          javascript.0
          javascript.0
          javascript.0
          #457
          @diamand2k22
          Die Meldung kommt vom javascript, nicht vom js-controller. Mach einen eigenen Thread auf. Und schau dir zuvor deine Skripte an, da wird es vermutlich einen Fehler geben.
          • D Diamand2k22
            javascript.0
            javascript.0
            javascript.0
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            #458
            @diamand2k22
            Liegt wie mein Vorredner schon schrub, mit hoher Wahrscheinlichkeit an einem deiner Scripte. Such mal nach einem, das alle 10 Minuten irgendeinen Zugriff per Axios macht.
            Wenn der Fehler tatsächlich erst seit Controller Update besteht, lehne mich mal weit aus dem Fenster und tippe, dass da gleich mehrere Aufrufe "gleichzeitig" gemacht werden. ECONNRESET heißt, dass eine bestehende Verbindung abgebrochen wurde.
            Das hatte ich seinerzeit auch mal nach einem Controller Update (ich glaube auf 3). Da prügelte ich in einem Script bis zu 50 Requests auf einmal raus. Mit dem Vorgänger Controller klappte das, mit der Folgeversion kam es zu ähnlichen Fehlern. Warum der Controller darauf Einfluss haben kann, entzieht sich allerdings meiner Kenntnis.
            Solltest du weitere Unterstützung brauchen, wäre ein eigener Thread dafür sicher hilfreich.
            • foxriver76F foxriver76
              Hallo ioBroker-Community,
              Heute möchten wir Euch den js-controller 5.0 endlich auch im STABLE Repository zur Verfügung stellen. Dieser Post enthält alle wichtigen Infos. Bitte unbedingt lesen!!
              Wir bedanken uns bei allen Usern die bisher die neue Version bereits als Alpha oder Beta getestet und Feedback gegeben haben.
              Node.js Versions-Anforderungen
              In diesem Release entfällt Node.js 12.x welches seit April letztem Jahr nicht mehr gepflegt wird und Node.js 14.x welches seit April diesem Jahres EOL ist. Node.js 18.x ist dazugekommen. Die unterstützten Node.js Versionen sind: 16.4.0+ und 18.x und nach aktuellem Stand Node.js 20.x, wobei hier noch erfahrungen fehlen. Die empfohlene Node.js Version für ioBroker haben wir vor kurzem auf 18.x angehoben.
              Bitte beachtet weiterhin bei Node.js Updates die Anleitung im Forum unter https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18 !
              Informationen zur Version
              Es gibt EINIGE Adapter die aktualisiert werden müssen!! Bitte weiter unten lesen!
              In dieser Version wurde die Umstellung des Quellcodes auf TypeScript sehr stark vorangetrieben (inzwischen bei 88%), wodurch am Ende die Stabilität weiter steigt weil viele Code-Fehler nicht mehr auftreten können. Natürlich sind neben Optimierungen und Fehlerbehebungen auch ein paar neue Features hinzugekommen. Auch wenn mit dieser Version keine neuen Prüfungen hinzukommen, die zu Log-Ausgaben bei Adaptern führen, meldet aktuelle Logausgaben bitte weiterhin bei den Adaptern.
              Detailliertere Informationen zu allen Änderungen und Features findet Ihr weiter unten und im Changelog.
              Für die aktive Mitarbeit an dieser Version des js-controller bedanke mich diesmal wieder besonders bei Apollon77, AlCalzone und natürlich Bluefox und auch ein paar weiteren Entwicklern!
              ACHTUNG backups inkompatibel bei Downgrades!!
              Neben der Node.js Version gibt es eine wichtige Inkompatibilität: Backups die mit der 5.0 des js-controller erstellt wurden lassen sich nicht mit einem js-controller 4 oder kleiner wieder restoren!
              Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt. Wer überlegt die Node.js Version anzuheben bitte weiter unten im Abschnitt "Was ist zu testen" lesen 🙂
              Aufgrund einiger internen Umstellungen brauchen wieder einige Adapter Updates. Diese sollten am besten VOR dem Update installiert werden!
              Bitte dazu die Informationen weiter unten beachten!
              Installation
              VOR der Installation
              Wie bei jedem Upgrade dieser Art: Bitte macht ein Backup! iobroker backup bzw kopieren des iobroker-data Verzeichnisses reichen an sich aus. Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt. Eine alte 4.0.x-Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version ("version" durch die gewünschte Versionsnummer ersetzen) installiert werden und sollte alles wieder herstellen (Vorheriger Stable Stand ist die 4.0.24)
              Nötige Adapter-Aktualisierungen
              Am besten dennoch VOR dem js-controller Update alle verfügbaren Adapter-Updates prüfen und alle Updates installieren, die im Changelog auf Optimierungen oder Anpassungen für den js-controller 4.0 oder höher hinweisen.
              Diesmal sind doch einige Adapter auf der Liste die man updaten muss -falls installiert! Siehe Spoiler!
              • ✅ acme - required: none / 0.1.0 - released
              • ✅ admin - required: 6.8.0 - released
              • ✅ anelhut - required: 1.0.15 - released
              • ✅b-control-em - required: 0.3.1 - released
              • ⚪ bosch-ebike - required: none
              • ✅ cul - required: 2.2.0 - released (no change)
              • ✅ daikin-cloud - required: 0.3.0 - released
              • ✅ doorbird - required: 0.1.7 - newer released
              • ✅ ds18b20 - required: 2.0.4 - released
              • ✅ energymanager - required: 1.4.2 - released
              • ⚪ enigma2 - required: none - not at stable yet
              • ✅ fakeroku - required: 0.2.2+ - released
              • ✅ fhem - required: 2.0.5 - released
              • ✅ history - required: 2.2.6 - released
              • ✅ iqontrol - required: 2.3.0 - released
              • ⚪ javascript - required: none
              • 🚫 km200 - deprecated - Ersatz: ems-esp
              • ✅ lgtv - required: 1.1.12 - released
              • ❗linux-control - required: ???
              • ✅ maxcul - required: 1.3.1 (no change)
              • ⚪ miio - required: none - not at stable
              • ✅ mydlink - required: 1.3.4 - released
              • ✅ nanoleaf-lightpanales - required: 1.4.0 - released
              • ✅ node-red - required: 4.03+ (no change)
              • ✅ notification.manager - required: 0.1.1 - released
              • ✅ pi-hole - required: 1.3.6+ - released
              • ✅ ping - required: 1.6.2 - released
              • ✅ pushbullet - required: 1.0.1 - released
              • 🚫 samsung_tyzen - stale repo - deprecated with js-controller 5
              • ✅ socketio - required: 6.5.2 - released
              • ✅ stiebel-isg - required: 1.7.6+ - newer released
              • ✅ systeminfo - required: 1.0.0 - released
              • ✅ viessmann - required: 1.4.4+ - released
              • ✅ web - required: 6.1.0 - released
              • ✅ ws - required: 2.5.3 - released
              • ✅yahka - required: 1.0.1 - newer version released
              • ✅ zigbee - required: 1.8.23 - released
              Achtung: MASTER-Systeme Reihenfolgen beachten!
              Bei einem Multi-Host-System, welches auf js-controller 2.2, 3.x oder 4.0.x läuft, ist es beim Update auf Version 5.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
              Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher Bitte die jeweiligen Update Threads der empfohlenen Zwischenversionen prüfen.
              Windows
              Generell muss das Update manuell via npm installiert werden.
              Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl iob upgrade self ausführen.
              Linux
              • ioBroker stoppen (iobroker stop)
              • Prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
              • cd /opt/iobroker
              • Das Update erfolgt via iob upgrade self
              • ioBroker starten (iobroker start)
              Bei Fehlern:
              Wenn bei der Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer (iobroker fix wer schon einen js-controller 2.x oder höher hat, alternativ weiterhin manuell via curl -sL https://iobroker.net/fix.sh | bash -) nutzen und die Installation wiederholen.
              Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
              NACH der Installation
              Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt.
              Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
              Was hat sich geändert, was besonders ansehen/beachten?
              Neben einiger weiterer Bugfixes gibt es folgende Änderungen und Fixes zu erwähnen:
              • generell siehe Changelog, speziell auch für die Features
              • generell bitte im CLI und auch sonst überall drüber schauen. Die Typescript Umstellungen haben sehr viel Code angefasst.
              • Falls jemand sporadisch Alias Fehler im Log hatte bitte versuchen diese mit der neuen version wieder zu provoziere und rückmelden
              Speziell die Entwickler sollten bitte die genannten Deprecations und neuen Features anschauen und beachten.
              Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
              5.0. Release Jana
              BREAKING CHANGES
              • Support for Node.js 12 and 14 is dropped! Supported are Node.js 16.4.0+ and 18.x and hopefully 20.x
              • Backups created with the new js-controller version cannot be restored on hosts with lower js-controller version!
              • Update recommended npm version to 8
              • Deprecate binary states, Adapters will change to use Files instead!
              Features
              • (foxriver76) Show npm error message on failing adapter installations and update also without debug parameter
              • (foxriver76) Introduce iobroker setting (dnsResolution) to choose between verbatim and ipv4 first dns resolution order
              • (foxriver76) Add support for windows for iob fix
              • (bluefox) Added CLI option to restart/start/stop all instances of an adapter (e.g. iob stop admin now also works)
              • (foxriver76) Allow to use iob host oldname command when new host already exists but has no instances
              • (foxriver76) Added an admin notification if redis is misconfigured and info how to fix it
              • (foxriver76) Enable upgrade of js-controller via Admin UI (Linux only)
              Optimizations and Fixes
              • (foxriver76) Speedup "getStates" calls with many IDs often used by visualizations: JSONL 17 times faster, Redis 23 times faster
              • (foxriver76) significantly reduce backup size
              • (foxriver76) Enhance CLI help for list command to show all possible types to list
              • (foxriver76) Also stop instances before updating from GitHub
              • (foxriver76) Conversion of big parts of the js-controller codebase to typeScript and address all found issues
              • (Apollon77) Only log error on "enable/disable via .alive" if there is an error
              • (foxriver76) Optimize adapter unload and stop handling for edge cases
              • (AlCalzone) Carefully normalize jsonlOptions
              • (bluefox) Do not show warning on a requested adapter stop/termination
              • (bluefox) Make sure that the first log line is not missing in Admin
              • (foxriver76) Fix wrong formatting of cli get binary state if no encoding is passed
              • (foxriver76) Fix restoring backups from pre js-controller 4.x which were created without config.system
              • (foxriver76) Preserve tier setting on adapter upload
              • (foxriver76) update apt sources before installing os dependencies
              • (foxriver76) Only skip erase on upload if opted out explicitly to always cleanup unneeded files
              • (foxriver76) Try to fix strange alias errors, inform us if it happens again!
              • (foxriver76) Remove windows bat files completely, installer will create them when needed
              • (AlCalzone/Apollon77) Update jsonl db to prevent locking issues
              • (foxriver76) Fixes iob file sync not working for jsonl
              • (foxriver76) Do not crash if we cannot initialize db backup directory on start
              • (foxriver76) Fixed issue with certificate validity on leap years
              • (Apollon77/foxriver76) Make sure that all relevant files are removed when eraseOnUpload is used
              • (foxriver76) fix wrong hostname after backup restore
              • (bluefox) allow CLI vendor update without explicitly specifying vendor file (default file is used)
              • (Apollon77, foxriver76, bluefox, AlCalzone) Several fixes and refactorings to prevent potential crash cases reported by Sentry and other sources
              Developer relevant DEPRECATIONS/WARNINGS
              • Deprecate binary states, Migrate your adapters to use Files instead!
              • If you need to access special js-controller common tools please use adapter-core instead of js-controller directly - see https://github.com/ioBroker/adapter-core#commontools
              • Parameter that contain patterns (e.g. mqtt.*) are now checked for allowed characters and general correctness!
              Developer relevant new Features
              • (bluefox) Added options to subscribe to file changes: subscribeForeignFiles, unsubscribeForeignFiles, onAdapterFileChanged (event contains id, fileName, size and not the whole content of the file!)
              • (foxriver76) Introduce on("install") handler for adapter which is automatically called when adapter process is started with --install
              • (foxriver76) Introduce io-package flag common.nodeProcessParams to allow to pass adapter specific nodejs process parameters (disables compact mode for the adapter!)
              • (foxriver76) Respect dns resolution (ipv4/ipv6 first) from config internally and provide relevant methods via adapter-core
              • (foxriver76) Add JSON-Schema for iobroker.json
              • (bluefox) Allowed export of password.js (to be used with adapter-core)
              • (bluefox) Added _design/chart to the system designs
              • (foxriver76) Automatically generated Code-Docs for Adapter class https://github.com/ioBroker/ioBroker.js-controller/tree/master/packages/controller/doc
              • (foxriver76) Added (foreign)objectExists to adapter methods
              • (bluefox) Extend getSuitableLicenses to look for other licenses
              • (buefox/foxriver76) Added new category for notifications: blocked and respect js-controller common.blockedVersions to block versions from starting
              • (bluefox) Added new system view "custom-full" to return the full objects for objects with a custom part and not only the custom details
              • (foxriver76) Added support for getForeignObjects with an array of strings as pattern
              • (AlCalzone) Preparations to allow js-controller Dev version to be used with dev-server
              • (foxriver76) Validate max timeout value (max 32bit max number) on setTimeout/setInterval and throw on error to prevent issues
              • (foxriver76) new io-package flag common.supportedMessages to replace messagebox and other messagebox-related properties
              • (foxriver76) adapter.sendTo now accepts an optional timeout argument
              • Developer relevant Optimizations and Fixes
              • (foxriver76) Ensure setObjectNotExists returns id on success
              • (foxriver76) Fix Typings for sendTo/sendToHost
              • (Bluefox) Add User permission check to requireLog
              • (foxriver76) added nonEdit property of objects to types and document functionality
              • (foxriver76) introduced constants for state quality
              • (foxriver76) subscribeStates now also accepts an array of ids
              • general dependency updates
              • code style optimizations and streamline code
              Generell ist zu testen, ob alles noch so funktioniert wie vorher auch. Das ist das wichtigste!
              Wie Fehler melden?
              Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
              Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
              Bitte postet auch die Ausgabe von iob diag mit rein.
              Wir wünschen allen viel Spaß mit dem neuen Controller und vielen Dank für Eure Unterstützung!
              fox
              Architect0711
              schrieb am zuletzt editiert von Architect0711
              #459
              @foxriver76 @Thomas-Braun Bei mir startet der admin adapter nicht mehr seit dem Update. Unten ist der output von "iob diag". Ganz unten steht ja Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually., aber das hat leider keine Abhilfe gebracht.
              pi@raspberrypi:/opt/iobroker/node_modules/iobroker.admin $ npm install --production
              npm WARN config production Use `--omit=dev` instead.
              up to date, audited 141 packages in 5s
              13 packages are looking for funding
                run `npm fund` for details
              4 moderate severity vulnerabilities
              To address issues that do not require attention, run:
                npm audit fix
              To address all issues possible (including breaking changes), run:
                npm audit fix --force
              Some issues need review, and may require choosing
              a different dependency.
              Run `npm audit` for details.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: raspberrypi
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 10 (buster)
                          Kernel: Linux 5.10.103-v7l+
                    Architecture: arm
              Model		: Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
               17:27:27 up  1:07,  2 users,  load average: 1.61, 1.93, 1.26
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Sat 2023-12-23 17:27:27 CET
                         Universal time: Sat 2023-12-23 16:27:27 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server: 	true
              Desktop: 	LXDE-pi
              Terminal: 	x11
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:           3.8G        705M        2.2G         21M        968M        3.0G
              Swap:           99M          0B         99M
              Total:         3.9G        705M        2.3G
                       3838 M total memory
                        705 M used memory
                        417 M active memory
                       1076 M inactive memory
                       2164 M free memory
                        128 M buffer memory
                        839 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed. Pass --all to see loaded but inactive units, too.
              To show all installed unit files use 'systemctl list-unit-files'.
              *** FILESYSTEM ***
              /dev/root      ext4       59G  5.0G   51G   9% /
              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
              tmpfs          tmpfs     1.9G   17M  1.9G   1% /run
              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     384M   12K  384M   1% /run/user/1000
              [Sat Dec 23 16:20:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:60:A4:C4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=676d1976-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Sat Dec 23 16:20:11 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Sat Dec 23 16:20:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sat Dec 23 16:20:13 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              TARGET                SOURCE         FSTYPE          OPTIONS
              /                     /dev/mmcblk0p2 ext4            rw,noatime
              |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
              |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              1.3G	/var/
              644M	/var/lib
              521M	/var/cache
              515M	/var/lib/piVCCU3
              509M	/var/cache/apt
              Archived and active journals take up 16.0M in the file system.
              /opt/iobroker/backups:
              du: cannot access '/opt/iobroker/backups/': No such file or directory
              /opt/iobroker/iobroker-data:
              157M	/opt/iobroker/iobroker-data/
              53M	/opt/iobroker/iobroker-data/node-red
              52M	/opt/iobroker/iobroker-data/node-red/node_modules
              46M	/opt/iobroker/iobroker-data/files
              41M	/opt/iobroker/iobroker-data/backup-objects
              21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
              5.6M	/opt/iobroker/iobroker-data/objects.jsonl
              5.4M	/opt/iobroker/iobroker-data/objects.json.migrated
              5.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
              USB-Devices by-id:
              find: '/dev/serial/by-id/': No such file or directory
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v18.16.1
              /usr/bin/node 		v18.16.1
              /usr/bin/npm 		9.5.1
              /usr/bin/npx 		9.5.1
              /usr/bin/corepack 	0.17.0
              nodejs:
                Installed: 18.16.1-deb-1nodesource1
                Candidate: 18.17.1-deb-1nodesource1
                Version table:
                   18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
               *** 18.16.1-deb-1nodesource1 100
                   10.24.0~dfsg-1~deb10u3 500
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller: 	5.0.17
              admin: 		5.1.28
              javascript: 	"javascript" not found
              Adapters from github: 	0
              Adapter State
                system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
              + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
              + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.20.100
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 5.1.28 [Updatable]
              Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
              Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
              Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.18 [Updatable]
              Adapter    "hs100"        : 2.2.0    , installed 2.1.2  [Updatable]
              Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
              Adapter    "node-red"     : 4.0.3    , installed 3.3.1  [Updatable]
              Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
              Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
              Adapter    "socketio"     : 6.6.0    , installed 6.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Objects and States
              Objects: 	2298
              States: 	860
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Hit:3 https://deb.nodesource.com/node_18.x buster InRelease
              Hit:4 https://www.pivccu.de/piVCCU stable InRelease
              Reading package lists...
              Pending Updates: 155
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17270      582/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18683      420/cupsd
              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       61793      7787/node-red
              tcp        0      0 192.168.20.100:1882     0.0.0.0:*               LISTEN      1001       64971      8166/io.shelly.0
              tcp        0      0 192.168.20.100:2010     0.0.0.0:*               LISTEN      1001       63568      7826/io.hm-rpc.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          15251      558/mosquitto
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       61619      7722/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       61612      7722/iobroker.js-co
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15349      577/vncserver-x11-c
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       62790      8041/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          17272      582/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18682      420/cupsd
              tcp6       0      0 :::1883                 :::*                    LISTEN      0          15252      558/mosquitto
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          15348      577/vncserver-x11-c
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20657      545/cups-browsed
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16086      402/avahi-daemon: r
              udp        0      0 0.0.0.0:35206           0.0.0.0:*                           108        16088      402/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        16087      402/avahi-daemon: r
              udp6       0      0 :::50048                :::*                                108        16089      402/avahi-daemon: r
              2023-12-23 17:26:35.046  - info: host.raspberrypi iobroker npm-rebuild: Rebuilding native modules done
              2023-12-23 17:26:36.060  - info: host.raspberrypi iobroker npm-rebuild: exit 0
              2023-12-23 17:26:36.236  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 9252
              2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1080
              2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]:   throw err;
              2023-12-23 17:26:38.169  - error: host.raspberrypi Caught by controller[0]:   ^
              2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js'
              2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: Require stack:
              2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.admin/main.js
              2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
              2023-12-23 17:26:38.170  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:922:27)
              2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
              2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:110:18)
              2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/main.js:18:18)
              2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
              2023-12-23 17:26:38.171  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
              2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
              2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
              2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
              2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
              2023-12-23 17:26:38.172  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.admin/main.js' ]
              2023-12-23 17:26:38.173  - error: host.raspberrypi Caught by controller[0]: }
              2023-12-23 17:26:38.173  - error: host.raspberrypi Caught by controller[0]: Node.js v18.16.1
              2023-12-23 17:26:38.173  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2023-12-23 17:26:38.173  - info: host.raspberrypi Rebuild for adapter system.adapter.admin.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              mcm1957M Thomas BraunT GlasfaserG 3 Antworten Letzte Antwort
              • A Architect0711
                  npm audit fix
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server: 	true
                Desktop: 	LXDE-pi
                Terminal: 	x11
                *** MEMORY ***
                Swap:           99M          0B         99M
                         3838 M total memory
                          705 M used memory
                          417 M active memory
                         2164 M free memory
                          128 M buffer memory
                          839 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.3G	/var/
                644M	/var/lib
                521M	/var/cache
                509M	/var/cache/apt
                USB-Devices by-id:
                /usr/bin/npm 		9.5.1
                /usr/bin/npx 		9.5.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin: 		5.1.28
                Adapter State
                + instance is alive
                Objects and States
                Objects: 	2298
                States: 	860
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #460
                @architect0711
                Wie im Einleitungsposting steht brauchen einige Adapter ein Update. Dein admin (5.X.X) Ist zu alt.
                Ambesten lies das ETSTE Posting nochmal durch.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • A Architect0711
                    npm audit fix
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : armhf
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server: 	true
                  Desktop: 	LXDE-pi
                  Terminal: 	x11
                  *** MEMORY ***
                  Swap:           99M          0B         99M
                           3838 M total memory
                            705 M used memory
                            417 M active memory
                           2164 M free memory
                            128 M buffer memory
                            839 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.3G	/var/
                  644M	/var/lib
                  521M	/var/cache
                  509M	/var/cache/apt
                  USB-Devices by-id:
                  /usr/bin/npm 		9.5.1
                  /usr/bin/npx 		9.5.1
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		5.1.28
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects: 	2298
                  States: 	860
                  #461
                  @architect0711
                  Installier da NEU! Raspberry OS 12 Bookworm. Und zwar in der Lite-Version für 64Bit. Dann dein
                  iob-Backup einspielen. Zuvor den ganzen Sums auf Stand bringen.
                  Künftig REGELMÄSSIG Systempflege betreiben.
                  • A Architect0711
                      npm audit fix
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server: 	true
                    Desktop: 	LXDE-pi
                    Terminal: 	x11
                    *** MEMORY ***
                    Swap:           99M          0B         99M
                             3838 M total memory
                              705 M used memory
                              417 M active memory
                             2164 M free memory
                              128 M buffer memory
                              839 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.3G	/var/
                    644M	/var/lib
                    521M	/var/cache
                    509M	/var/cache/apt
                    USB-Devices by-id:
                    /usr/bin/npm 		9.5.1
                    /usr/bin/npx 		9.5.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		5.1.28
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	2298
                    States: 	860
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #462
                    @architect0711
                    ist das richtig ... das du kein backitup Adapter hast !?
                    Wo sind deine Backups !?
                    • GlasfaserG Glasfaser
                      @architect0711
                      Architect0711
                      #463
                      ich habe neben dem iobroker noch andere sachen auf dem raspi, deshalb mache ich immer sd card images als backup.
                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                      • A Architect0711
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #464
                        @architect0711
                        Keine gute Lösung !
                        • A Architect0711
                          #465
                          @architect0711
                          Dann ist dein 'Backup-Konzept' genau jetzt an seine Grenzen gestoßen...
                          • mcm1957M mcm1957
                            @architect0711
                            Architect0711
                            #466
                            @mcm57 danke, habe die Liste mit den Adaptern gefunden :) nach dem Upgrade vom Admin und vom Node Red Adapter hat wieder alles funktioniert wie gehabt :)
                              torti0111
                              schrieb am zuletzt editiert von torti0111
                              #467
                              Hi Zusammen,
                              Ich habe heute morgen auf 5.0.17 geupdated…
                              Habe 2 Shelly Adapter laufen. Einer für die ältere Generation, eine für die neuen über mqtt.
                              Nach dem Update auf den 5.0.17 sind mir die „alten“ Shelly’s via coap eingefroren.
                              Sie zeigen grün, sieht alles gut aus, aber sie machen nichts. Weder die schaltenden, noch die messenden.
                              Hab die Testweise via mqtt angebunden, dann geht alles. Sobald sie via coap verbunden sind, keine Reaktion.
                              Ich sehe keine Fehlermeldungen nichts im log.
                              Hat jemand die gleichen Probleme?
                              Edit: coap ist bei den alten wichtig, damit ich sie weiter über die cloud steuern kann.
                              P 1 Antwort Letzte Antwort
                              • T torti0111
                                Hi Zusammen,
                                pfahlenbauer
                                schrieb am zuletzt editiert von pfahlenbauer
                                #468
                                @torti0111
                                Ist das ein generelles Problem und konnte es gelöst werden? Ich habe meine Shelly's auch über COAP laufen und würde sonst mit dem Update noch warten.
                                Dr. BakteriusD 1 Antwort Letzte Antwort
                                • P pfahlenbauer
                                  @torti0111
                                  Dr. BakteriusD Online
                                  Dr. Bakterius
                                  schrieb am zuletzt editiert von Dr. Bakterius
                                  #469
                                  @pfahlenbauer sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                  Also ich habe mit meinen Shelly 1 die alle mit COAP unter dem js-controller v5.0.17 laufen keine Probleme. Funktioniert alles wie immer. Allerdings verwende ich die Cloud nicht.
                                  • foxriver76F Offline
                                    foxriver76F Offline
                                    foxriver76
                                    schrieb am zuletzt editiert von foxriver76
                                    #470
                                    js-controller 5.0.18 ab heute im Latest:
                                    • Das Problem, dass vis States am Anfang nicht aktualisiert wurden wenn ein OBjekt null auf top level existiert wurde gefixt
                                    • Wir haben versucht den hohen RAM Verbrauch zu fixen der bei manchen Adapters unter Proxmox bei Uploads auftritt
                                    • CPU Verbrauch von JSONL optimiert
                                    • Problem behoben dass multihost enable/disable nie "fertig" wird
                                    Videotutorials & mehr
                                    G FeuersturmF 2 Antworten Letzte Antwort
                                    • ? Offline
                                      #471
                                      @foxriver76 5.0.18 laeuft hier unter Docker als Multihost Master mit buanet V9.0.1 und gleiches als Slave ohne Auffaelligkeiten ( Node 18.19.0, NPM 10.2.3)
                                      Dazu noch auf einem Multihost Slave LXC in Proxmox Debian Bookworm, Node 20.11, NPM 10.2.4 ohne Probleme.
                                      Objekte: 46783, Zustände: 41271 mit Redis/Redis
                                      Edit:
                                      Vis V1.5.4 keine Probleme mit den Werten.
                                        guergen
                                        #472
                                        @foxriver76 Leider werden nach dem Update viele Werte nicht ins Vis übernommen, Temperaturen, die definitiv da sind werden als NaN angezeigt, true/false-Werte werden als true übernommen.
                                        Auch nach manuellem setzen der Werte auf false, werden die Werte nach Zeit wieder mit true überschrieben.
                                        debian boowkworm, alles aktuell und auf latest.
                                        Was möchtest Du noch wissen, damit der "Fehler" korrigiert werden kann?
                                        foxriver76F 2 Antworten Letzte Antwort
                                        • G guergen
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          #473
                                          @guergen hm gar nix, kanns nachstellen. 😢
