  4. (Gelöst) Javascript Adapter starten plötzlich nicht mehr
20 Beiträge 5 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • crepp1967C Offline
    crepp1967C Offline
    crepp1967
    schrieb am zuletzt editiert von crepp1967
    Seit heute startet meine beiden Javascript Adapter nicht mehr.
    Ich hatte gestern ein Update des socet.io u. des Web Adapters gemacht.
    Neustart habe ich gemacht und auch ein iob fix.
    Keine Besserung.
    Hier die Fehlermeldungen:
    host.iob-test1-proxmox
    2023-09-02 11:46:36.090	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-02 11:46:36.090	error	Caught by controller[0]: Node.js v18.17.1
    2023-09-02 11:46:36.090	error	Caught by controller[0]: }
    2023-09-02 11:46:36.090	error	Caught by controller[0]: requestPath: 'sshpk'
    2023-09-02 11:46:36.090	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/package.json',
    2023-09-02 11:46:36.090	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2023-09-02 11:46:36.090	error	Caught by controller[0]: {
    2023-09-02 11:46:36.090	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.089	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:11:21)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/index.js:3:14)
    2023-09-02 11:46:36.088	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/parser.js:5:13)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/utils.js:4:13)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:27)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:680:18)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
    2023-09-02 11:46:36.087	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/index.js'. Please verify that the package.json has a valid "main" entry
    2023-09-02 11:46:36.087	error	Caught by controller[0]: ^
    2023-09-02 11:46:36.087	error	Caught by controller[0]: throw err;
    2023-09-02 11:46:36.087	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
    2023-09-02 11:46:36.046	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-02 11:46:36.046	error	Caught by controller[0]: Node.js v18.17.1
    2023-09-02 11:46:36.046	error	Caught by controller[0]: }
    2023-09-02 11:46:36.045	error	Caught by controller[0]: requestPath: 'sshpk'
    2023-09-02 11:46:36.045	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/package.json',
    2023-09-02 11:46:36.045	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2023-09-02 11:46:36.045	error	Caught by controller[0]: {
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at node:internal/main/run_main_module:23:47
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.033	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.032	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:11:21)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/index.js:3:14)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/parser.js:5:13)
    2023-09-02 11:46:36.031	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature/lib/utils.js:4:13)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:922:27)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1063:27)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:680:18)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:438:19)
    2023-09-02 11:46:36.030	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/sshpk/lib/index.js'. Please verify that the package.json has a valid "main" entry
    2023-09-02 11:46:36.030	error	Caught by controller[0]: ^
    2023-09-02 11:46:36.030	error	Caught by controller[0]: throw err;
    2023-09-02 11:46:36.030	error	Caught by controller[0]: node:internal/modules/cjs/loader:446
    Weiss jemand Rat?
    Verzweifelte Grüße
    Torsten
    • crepp1967C crepp1967
      Keine Besserung.
      Weiss jemand Rat?
      Verzweifelte Grüße
      Torsten
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @crepp1967 sagte in Javascript Adapter starten plötzlich nicht mehr:
      Zeige erstmal was du hast ,
      dann kann ich dir auch helfen , weil was bringt dir schon die Lösung wenn der Rest nicht stimmt :
      bitte die Full-Ausgabe von
      iob diag
      crepp1967C 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        iob diag
        crepp1967C Offline
        crepp1967C Offline
        crepp1967
        @glasfaser
        ======== Start marking the full check here =========
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Architecture    : x86_64
        Docker          : false
        Virtualization  : kvm
        Distributor ID: Debian
        Description:    Debian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
        NAME="Debian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=debian
        HOME_URL="https://www.debian.org/"
        SUPPORT_URL="https://www.debian.org/support"
        BUG_REPORT_URL="https://bugs.debian.org/"
        Systemuptime and Load:
         12:13:57 up 25 min,  2 users,  load average: 0.23, 0.29, 0.50
        CPU threads: 8
        *** Time and Time Zones ***
                       Local time: Sat 2023-09-02 12:13:57 CEST
                   Universal time: Sat 2023-09-02 10:13:57 UTC
                         RTC time: Sat 2023-09-02 10:13:58
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi cdrom floppy audio dip video plugdev netdev bluetooth scanner iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:             11G        3.3G        7.1G         10M        1.3G        8.1G
        Swap:           974M          0B        974M
        Total:           12G        3.3G        8.0G
                11679 M total memory
                 3298 M used memory
                  471 M active memory
                 3804 M inactive memory
                 7059 M free memory
                  115 M buffer memory
                 1207 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        udev           devtmpfs  5.7G     0  5.7G   0% /dev
        tmpfs          tmpfs     1.2G  1.2M  1.2G   1% /run
        /dev/sda1      ext4       31G   18G  9.9G  65% /
        tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     1.2G  116K  1.2G   1% /run/user/1000
        [Sat Sep  2 11:48:41 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
        [Sat Sep  2 11:48:42 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems (real ones only):
        TARGET SOURCE    FSTYPE OPTIONS
        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
        /var:
        3.2G    /var/
        1.6G    /var/log
        1.4G    /var/log/journal/33dc4f3a0bb843a19efcff7c642a250d
        1.4G    /var/cache
        Archived and active journals take up 72.0M in the file system.
        /opt/iobroker/backups:
        2.2G    /opt/iobroker/backups/
        1.5M    /opt/iobroker/backups/js
        788K    /opt/iobroker/backups/js/Produktiv
        616K    /opt/iobroker/backups/js/TEST
        288K    /opt/iobroker/backups/js/Produktiv/JS
        /opt/iobroker/iobroker-data:
        980M    /opt/iobroker/iobroker-data/
        505M    /opt/iobroker/iobroker-data/files
        246M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        39M     /opt/iobroker/iobroker-data/objects.jsonl
        31M     /opt/iobroker/iobroker-data/states.jsonl
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
        18M     /opt/iobroker/iobroker-data/objects.json.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.17.1
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
             12.22.12~dfsg-1~deb11u3 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        MULTIHOSTSERVICE/enabled: false
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.8.0
        javascript:     7.0.3
        Adapters from github:   4
        Adapter State
        + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iob-test1-proxmox                        -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iob-test1-proxmox                        -  enabled
        + system.adapter.backitup.0               : backitup              : iob-test1-proxmox                        -  enabled
        + system.adapter.bring.0                  : bring                 : iob-test1-proxmox                        -  enabled
          system.adapter.broadlink2.0             : broadlink2            : iob-test1-proxmox                        - disabled
          system.adapter.daswetter.0              : daswetter             : iob-test1-proxmox                        -  enabled
          system.adapter.discovery.0              : discovery             : iob-test1-proxmox                        - disabled
          system.adapter.ds18b20.0                : ds18b20               : iob-test1-proxmox                        - disabled
          system.adapter.dwd.0                    : dwd                   : iob-test1-proxmox                        -  enabled
          system.adapter.email.0                  : email                 : iob-test1-proxmox                        - disabled
          system.adapter.feiertage.0              : feiertage             : iob-test1-proxmox                        - disabled
          system.adapter.flot.0                   : flot                  : iob-test1-proxmox                        - disabled
        + system.adapter.fritzbox.0               : fritzbox              : iob-test1-proxmox                        -  enabled
          system.adapter.fully-tablet-control.0   : fully-tablet-control  : iob-test1-proxmox                        - disabled
          system.adapter.history.0                : history               : iob-test1-proxmox                        - disabled
        + system.adapter.hm-rega.0                : hm-rega               : iob-test1-proxmox                        -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
        + system.adapter.hue-extended.0           : hue-extended          : iob-test1-proxmox                        -  enabled
        + system.adapter.hue.0                    : hue                   : iob-test1-proxmox                        -  enabled, port: 80
          system.adapter.ical.0                   : ical                  : iob-test1-proxmox                        -  enabled
          system.adapter.ical.1                   : ical                  : iob-test1-proxmox                        -  enabled
          system.adapter.ical.2                   : ical                  : iob-test1-proxmox                        -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-test1-proxmox                        - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test1-proxmox                        - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : iob-test1-proxmox                        - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : iob-test1-proxmox                        - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test1-proxmox                        - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-test1-proxmox                        - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob-test1-proxmox                        - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-test1-proxmox                        - disabled
        + system.adapter.influxdb.0               : influxdb              : iob-test1-proxmox                        -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iob-test1-proxmox                        -  enabled
        + system.adapter.iot.0                    : iot                   : iob-test1-proxmox                        -  enabled
          system.adapter.javascript.0             : javascript            : iob-test1-proxmox                        -  enabled
          system.adapter.javascript.1             : javascript            : iob-test1-proxmox                        -  enabled
        + system.adapter.kodi.0                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
        + system.adapter.kodi.1                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
        + system.adapter.lgtv.0                   : lgtv                  : iob-test1-proxmox                        -  enabled
          system.adapter.luftdaten.0              : luftdaten             : iob-test1-proxmox                        -  enabled
          system.adapter.mobile.0                 : mobile                : iob-test1-proxmox                        - disabled
        + system.adapter.moma.0                   : moma                  : iob-test1-proxmox                        -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iob-test1-proxmox                        -  enabled, port: 1886, bind: 192.168.1.203
          system.adapter.mqtt.1                   : mqtt                  : iob-test1-proxmox                        - disabled, port: 1884, bind: 192.168.1.203
        + system.adapter.nina.0                   : nina                  : iob-test1-proxmox                        -  enabled
          system.adapter.node-red.0               : node-red              : iob-test1-proxmox                        - disabled, port: 1880, bind: 192.168.1.203
          system.adapter.openweathermap.0         : openweathermap        : iob-test1-proxmox                        -  enabled
          system.adapter.owfs.0                   : owfs                  : iob-test1-proxmox                        - disabled, port: 4304
          system.adapter.parser.0                 : parser                : iob-test1-proxmox                        - disabled
        + system.adapter.pi-hole.0                : pi-hole               : iob-test1-proxmox                        -  enabled
        + system.adapter.proxmox.0                : proxmox               : iob-test1-proxmox                        -  enabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iob-test1-proxmox                        -  enabled
        + system.adapter.radar2.0                 : radar2                : iob-test1-proxmox                        -  enabled
          system.adapter.rpi2.0                   : rpi2                  : iob-test1-proxmox                        - disabled
        + system.adapter.sayit.0                  : sayit                 : iob-test1-proxmox                        -  enabled
          system.adapter.scenes.0                 : scenes                : iob-test1-proxmox                        - disabled
        + system.adapter.senec.0                  : senec                 : iob-test1-proxmox                        -  enabled
        + system.adapter.shelly.0                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.socketio.0               : socketio              : iob-test1-proxmox                        -  enabled, port: 8084, bind: 192.168.1.203, run as: admin
          system.adapter.solarwetter.0            : solarwetter           : iob-test1-proxmox                        - disabled
        + system.adapter.sonoff.0                 : sonoff                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 192.168.1.203
        + system.adapter.spotify-premium.0        : spotify-premium       : iob-test1-proxmox                        -  enabled
        + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iob-test1-proxmox                        -  enabled, port: 9000
        + system.adapter.statistics.0             : statistics            : iob-test1-proxmox                        -  enabled
          system.adapter.telegram.0               : telegram              : iob-test1-proxmox                        - disabled, port: 8443
        + system.adapter.tr-064.0                 : tr-064                : iob-test1-proxmox                        -  enabled
          system.adapter.traccar.0                : traccar               : iob-test1-proxmox                        - disabled
        + system.adapter.trashschedule.0          : trashschedule         : iob-test1-proxmox                        -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iob-test1-proxmox                        - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-test1-proxmox                        - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-test1-proxmox                        - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-test1-proxmox                        - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iob-test1-proxmox                        -  enabled
          system.adapter.vis-history.0            : vis-history           : iob-test1-proxmox                        - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-test1-proxmox                        - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test1-proxmox                        - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test1-proxmox                        -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-test1-proxmox                        - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iob-test1-proxmox                        - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iob-test1-proxmox                        - disabled
          system.adapter.vis-map.0                : vis-map               : iob-test1-proxmox                        - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test1-proxmox                        - disabled
          system.adapter.vis-metro.0              : vis-metro             : iob-test1-proxmox                        - disabled
          system.adapter.vis-players.0            : vis-players           : iob-test1-proxmox                        - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iob-test1-proxmox                        - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test1-proxmox                        - disabled
          system.adapter.vis-weather.0            : vis-weather           : iob-test1-proxmox                        - disabled
          system.adapter.vis.0                    : vis                   : iob-test1-proxmox                        -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iob-test1-proxmox                        -  enabled
        + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
          system.adapter.windows-control.0        : windows-control       : iob-test1-proxmox                        - disabled
        + system.adapter.wled.0                   : wled                  : iob-test1-proxmox                        -  enabled
        + system.adapter.worx.0                   : worx                  : iob-test1-proxmox                        -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iob-test1-proxmox                        -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Installed ioBroker-Instances
        Adapter    "admin"        : 6.8.0    , installed 6.8.0
        Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "bring"        : 1.8.1    , installed 1.8.1
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "history"      : 2.2.6    , installed 2.2.6
        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hue"          : 3.9.5    , installed 3.9.5
        Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "info"         : 1.9.26   , installed 1.9.26
        Adapter    "iot"          : 1.14.5   , installed 1.14.5
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "kodi"         : 2.0.9    , installed 2.0.9
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "openweathermap": 0.3.9   , installed 0.3.9
        Adapter    "operating-hours": 1.0.4  , installed 1.0.4
        Adapter    "owfs"         : 0.7.0    , installed 0.7.0
        Adapter    "parser"       : 1.3.2    , installed 1.3.2
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "radar2"       : 2.0.7    , installed 2.0.7
        Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
        Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "scenes"       : 2.3.9    , installed 2.3.9
        Adapter    "shelly"       : 6.4.1    , installed 6.4.1
        Adapter    "socketio"     : 6.5.2    , installed 6.5.2
        Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
        Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
        Adapter    "statistics"   : 2.3.0    , installed 2.3.0
        Adapter    "swiss-weather-api": 1.0.5, installed 1.0.5
        Adapter    "telegram"     : 1.16.0   , installed 1.16.0
        Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
        Adapter    "traccar"      : 0.0.12   , installed 0.0.12
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis"          : 1.4.16   , installed 1.4.16
        Adapter    "vis-colorpicker": 2.0.3  , installed 2.0.3
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.4.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.3
        Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 6.1.0    , installed 6.1.0
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "worx"         : 2.3.2    , installed 2.3.2
        Adapter    "ws"           : 2.5.3    , installed 2.5.3
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Objects and States
        Objects:        27197
        States:         25018
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://repos.influxdata.com/debian bullseye InRelease
        Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
        Fetched 4586 B in 1s (4901 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.1.203:1883      0.0.0.0:*               LISTEN      1001       30565      3592/io.sonoff.0
        tcp        0      0 192.168.1.203:8701      0.0.0.0:*               LISTEN      1001       19309      2672/io.hm-rpc.1
        tcp        0      0 192.168.1.203:1886      0.0.0.0:*               LISTEN      1001       25737      3366/io.mqtt.0
        tcp        0      0 192.168.1.203:1887      0.0.0.0:*               LISTEN      1001       25738      3366/io.mqtt.0
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       3000       505/iobroker.js-con
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       525        505/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16551      1/init
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      998        18195      1911/monitorix-http
        tcp        0      0 192.168.1.203:2001      0.0.0.0:*               LISTEN      1001       24691      2506/io.hm-rpc.0
        tcp        0      0 192.168.1.203:8082      0.0.0.0:*               LISTEN      1001       33466      5230/io.web.0
        tcp        0      0 192.168.1.203:8084      0.0.0.0:*               LISTEN      1001       37427      6517/io.socketio.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14001      543/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2477       504/cupsd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22188      3805/io.shelly.1
        tcp6       0      0 :::111                  :::*                    LISTEN      0          116        1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20697      1123/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14003      543/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2476       504/cupsd
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30488      3515/io.shelly.0
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22446      4423/io.radar2.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12729      1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2836       524/cups-browsed
        udp        0      0 0.0.0.0:59462           0.0.0.0:*                           112        13921      464/avahi-daemon: r
        udp        0      0 0.0.0.0:3483            0.0.0.0:*                           1001       35642      6544/io.squeezeboxr
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37622      6615/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        13919      464/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          2352       1/init
        udp6       0      0 fe80::1e95:cc09:f9a:546 :::*                                0          13133      467/NetworkManager
        udp6       0      0 :::54050                :::*                                112        13922      464/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                112        13920      464/avahi-daemon: r
        2023-09-02 12:00:27.705  - info: host.iob-test1-proxmox instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-02 12:00:28.118  - info: host.iob-test1-proxmox instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2023-09-02 12:00:31.870  - info: awtrix-light.0 (6905) error ECONNABORTED from /api/custom?name=pvakt: timeout of 3000ms exceeded
        2023-09-02 12:00:31.871  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
        2023-09-02 12:00:41.886  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
        2023-09-02 12:03:34.236  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
        2023-09-02 12:03:34.278  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
        2023-09-02 12:05:00.086  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 14652
        2023-09-02 12:05:04.112  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 14696
        2023-09-02 12:05:06.024  - info: dwd.0 (14696) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
        2023-09-02 12:05:07.733  - info: dwd.0 (14696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-02 12:05:08.251  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-02 12:05:12.934  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-09-02 12:07:04.291  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
        2023-09-02 12:07:04.327  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
        2023-09-02 12:10:00.038  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 17562
        2023-09-02 12:10:02.028  - info: dwd.0 (17562) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
        2023-09-02 12:10:02.981  - info: dwd.0 (17562) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-09-02 12:10:03.512  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-09-02 12:10:04.062  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 17624
        2023-09-02 12:10:11.494  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-09-02 12:10:34.342  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
        2023-09-02 12:10:34.377  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
        2023-09-02 12:14:04.395  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
        2023-09-02 12:14:04.453  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
        GlasfaserG Thomas BraunT crunchipC 3 Antworten Letzte Antwort
          @glasfaser
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 8
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           974M          0B        974M
                   3298 M used memory
                    471 M active memory
                   7059 M free memory
                    115 M buffer memory
                   1207 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          3.2G    /var/
          1.6G    /var/log
          1.4G    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.8.0
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        27197
          States:         25018
          Pending Updates: 0
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @crepp1967
          setzte es bitte in Code-Tags ... kann man schlecht lesen !
          so dann
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          iobroker restart
            @crepp1967
            so dann
            cd /opt/iobroker
            iobroker restart
            @glasfaser sagte in Javascript Adapter starten plötzlich nicht mehr:
            das war ja das Problem 😂 zusätzliche Code-tags
              @glasfaser
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=debian
              CPU threads: 8
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           974M          0B        974M
                       3298 M used memory
                        471 M active memory
                       7059 M free memory
                        115 M buffer memory
                       1207 M swap cache
                        974 M total swap
                          0 M used swap
                        974 M free swap
              *** FILESYSTEM ***
              /var:
              3.2G    /var/
              1.6G    /var/log
              1.4G    /var/cache
              /usr/bin/npm            9.6.7
              /usr/bin/npx            9.6.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.8.0
              javascript:     7.0.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        27197
              States:         25018
              Pending Updates: 0
              @crepp1967
              Schmeiß die bullseye-backports raus und stell das nodesoure-Repo auf die aktuelle Struktur um.
              crepp1967C 2 Antworten Letzte Antwort
                crepp1967C Offline
                crepp1967C Offline
                crepp1967
                ich war mir sicher CodeTags verwendet zu haben
                  @glasfaser
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 8
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:           974M          0B        974M
                           3298 M used memory
                            471 M active memory
                           7059 M free memory
                            115 M buffer memory
                           1207 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  *** FILESYSTEM ***
                  /var:
                  3.2G    /var/
                  1.6G    /var/log
                  1.4G    /var/cache
                  /usr/bin/npm            9.6.7
                  /usr/bin/npx            9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.8.0
                  javascript:     7.0.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        27197
                  States:         25018
                  Pending Updates: 0
                  crunchipC Abwesend
                  crunchipC Abwesend
                  'adm', 'systemd-journal'
                  dein user ist nicht in der Gruppe
                  gibt es einen Grund warum sämtliches vis "zubehör" deaktiviert ist?
                  cupsd
                  läuft da noch Desktop/Drucker zeugs?
                    @crepp1967
                    crepp1967C Offline
                    crepp1967C Offline
                    crepp1967
                    Wie mache ich das?
                      Wie mache ich das?
                      Wie mache ich das?
                      Backports musst du mal selber freigeschaltet haben. Einfach wieder rückgängig machen, was damals getan wurde. Hat vermutlich mit udev zu tun gehabt.
                      Zu nodesource:
                      Schau in meine Signatur.
                        Wie mache ich das?
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        Wie mache ich das?
                        ist der Fehler bei dir mit
                        schon behoben !?
                        Thomas BraunT crepp1967C 2 Antworten Letzte Antwort
                          Wie mache ich das?
                          schon behoben !?
                          schon behoben !?
                          Hatte ich nie.
                            schon behoben !?
                            Hatte ich nie.
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            ich habe dich doch nicht angeschrieben !!!!?
                            das war für @crepp1967
                              @glasfaser
                              Axo...
                              Ja, eins mach dem anderen machen.
                                crunchipC Abwesend
                                crunchipC Abwesend
                                aber markiert/benachrichtigt wurde er durch
                                  cupsd
                                  crepp1967C Offline
                                  crepp1967C Offline
                                  crepp1967
                                  @crunchip
                                  Hab das System unter Proxmox (Ubuntu) aufgesetzt (mit dem iobroker script)
                                  Hab dann nichts mehr angepasst (betriebssystemseitig)
                                  cupsd kann wohl deaktivieren, da hängt kein Drucker dran.
                                  in der shell mit purge oder wie werde ich das los?
                                    Wie mache ich das?
                                    schon behoben !?
                                    crepp1967C Offline
                                    crepp1967C Offline
                                    crepp1967
                                    @glasfaser
                                    Also mein Grundproblem (nicht startende Javascript Adapter) ist nun zum Glück behoben, vielen Dank für die schnelle Hilfe und die Tips zum fixen.
                                    Die hier im Thread noch so erwähnten Probleme werde ich im Anschluss beheben.
                                    Damit kann ich den Thread auf "Gelöst" setzen.
                                    Torsten
                                      @crepp1967 sagte in (Gelöst) Javascript Adapter starten plötzlich nicht mehr:
                                      ja, eben!
                                      Code-tags sind in der Ausgabe bereits drin, an den richtigen Stellen.
                                      Du hast zusätzliche verwendet
                                        @crepp1967
                                        crepp1967C Offline
                                        crepp1967C Offline
                                        crepp1967
                                        @thomas-braun Wie kann ich das anstellen?
                                          @crepp1967
                                          Was genau meinst du?
