  4. (Gelöst) Javascript Adapter starten plötzlich nicht mehr
20 Beiträge 5 Kommentatoren 1.7k Aufrufe 6 Beobachtet
  • crepp1967C crepp1967
    @glasfaser
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     12:13:57 up 25 min,  2 users,  load average: 0.23, 0.29, 0.50
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Sat 2023-09-02 12:13:57 CEST
               Universal time: Sat 2023-09-02 10:13:57 UTC
                     RTC time: Sat 2023-09-02 10:13:58
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi cdrom floppy audio dip video plugdev netdev bluetooth scanner iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             11G        3.3G        7.1G         10M        1.3G        8.1G
    Swap:           974M          0B        974M
    Total:           12G        3.3G        8.0G
            11679 M total memory
             3298 M used memory
              471 M active memory
             3804 M inactive memory
             7059 M free memory
              115 M buffer memory
             1207 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    *** FILESYSTEM ***
    udev           devtmpfs  5.7G     0  5.7G   0% /dev
    tmpfs          tmpfs     1.2G  1.2M  1.2G   1% /run
    /dev/sda1      ext4       31G   18G  9.9G  65% /
    tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G  116K  1.2G   1% /run/user/1000
    [Sat Sep  2 11:48:41 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Sep  2 11:48:42 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    3.2G    /var/
    1.6G    /var/log
    1.4G    /var/log/journal/33dc4f3a0bb843a19efcff7c642a250d
    1.4G    /var/cache
    Archived and active journals take up 72.0M in the file system.
    /opt/iobroker/backups:
    2.2G    /opt/iobroker/backups/
    1.5M    /opt/iobroker/backups/js
    788K    /opt/iobroker/backups/js/Produktiv
    616K    /opt/iobroker/backups/js/TEST
    288K    /opt/iobroker/backups/js/Produktiv/JS
    /opt/iobroker/iobroker-data:
    980M    /opt/iobroker/iobroker-data/
    505M    /opt/iobroker/iobroker-data/files
    246M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    31M     /opt/iobroker/iobroker-data/states.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.8.0
    javascript:     7.0.3
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : iob-test1-proxmox                        -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : iob-test1-proxmox                        -  enabled
    + system.adapter.backitup.0               : backitup              : iob-test1-proxmox                        -  enabled
    + system.adapter.bring.0                  : bring                 : iob-test1-proxmox                        -  enabled
      system.adapter.broadlink2.0             : broadlink2            : iob-test1-proxmox                        - disabled
      system.adapter.daswetter.0              : daswetter             : iob-test1-proxmox                        -  enabled
      system.adapter.discovery.0              : discovery             : iob-test1-proxmox                        - disabled
      system.adapter.ds18b20.0                : ds18b20               : iob-test1-proxmox                        - disabled
      system.adapter.dwd.0                    : dwd                   : iob-test1-proxmox                        -  enabled
      system.adapter.email.0                  : email                 : iob-test1-proxmox                        - disabled
      system.adapter.feiertage.0              : feiertage             : iob-test1-proxmox                        - disabled
      system.adapter.flot.0                   : flot                  : iob-test1-proxmox                        - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iob-test1-proxmox                        -  enabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : iob-test1-proxmox                        - disabled
      system.adapter.history.0                : history               : iob-test1-proxmox                        - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iob-test1-proxmox                        -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
    + system.adapter.hue-extended.0           : hue-extended          : iob-test1-proxmox                        -  enabled
    + system.adapter.hue.0                    : hue                   : iob-test1-proxmox                        -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : iob-test1-proxmox                        -  enabled
      system.adapter.ical.1                   : ical                  : iob-test1-proxmox                        -  enabled
      system.adapter.ical.2                   : ical                  : iob-test1-proxmox                        -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-test1-proxmox                        - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test1-proxmox                        - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iob-test1-proxmox                        - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iob-test1-proxmox                        - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test1-proxmox                        - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-test1-proxmox                        - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob-test1-proxmox                        - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-test1-proxmox                        - disabled
    + system.adapter.influxdb.0               : influxdb              : iob-test1-proxmox                        -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iob-test1-proxmox                        -  enabled
    + system.adapter.iot.0                    : iot                   : iob-test1-proxmox                        -  enabled
      system.adapter.javascript.0             : javascript            : iob-test1-proxmox                        -  enabled
      system.adapter.javascript.1             : javascript            : iob-test1-proxmox                        -  enabled
    + system.adapter.kodi.0                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
    + system.adapter.kodi.1                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
    + system.adapter.lgtv.0                   : lgtv                  : iob-test1-proxmox                        -  enabled
      system.adapter.luftdaten.0              : luftdaten             : iob-test1-proxmox                        -  enabled
      system.adapter.mobile.0                 : mobile                : iob-test1-proxmox                        - disabled
    + system.adapter.moma.0                   : moma                  : iob-test1-proxmox                        -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iob-test1-proxmox                        -  enabled, port: 1886, bind: 192.168.1.203
      system.adapter.mqtt.1                   : mqtt                  : iob-test1-proxmox                        - disabled, port: 1884, bind: 192.168.1.203
    + system.adapter.nina.0                   : nina                  : iob-test1-proxmox                        -  enabled
      system.adapter.node-red.0               : node-red              : iob-test1-proxmox                        - disabled, port: 1880, bind: 192.168.1.203
      system.adapter.openweathermap.0         : openweathermap        : iob-test1-proxmox                        -  enabled
      system.adapter.owfs.0                   : owfs                  : iob-test1-proxmox                        - disabled, port: 4304
      system.adapter.parser.0                 : parser                : iob-test1-proxmox                        - disabled
    + system.adapter.pi-hole.0                : pi-hole               : iob-test1-proxmox                        -  enabled
    + system.adapter.proxmox.0                : proxmox               : iob-test1-proxmox                        -  enabled, port: 8006
    + system.adapter.pushover.0               : pushover              : iob-test1-proxmox                        -  enabled
    + system.adapter.radar2.0                 : radar2                : iob-test1-proxmox                        -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iob-test1-proxmox                        - disabled
    + system.adapter.sayit.0                  : sayit                 : iob-test1-proxmox                        -  enabled
      system.adapter.scenes.0                 : scenes                : iob-test1-proxmox                        - disabled
    + system.adapter.senec.0                  : senec                 : iob-test1-proxmox                        -  enabled
    + system.adapter.shelly.0                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.socketio.0               : socketio              : iob-test1-proxmox                        -  enabled, port: 8084, bind: 192.168.1.203, run as: admin
      system.adapter.solarwetter.0            : solarwetter           : iob-test1-proxmox                        - disabled
    + system.adapter.sonoff.0                 : sonoff                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 192.168.1.203
    + system.adapter.spotify-premium.0        : spotify-premium       : iob-test1-proxmox                        -  enabled
    + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iob-test1-proxmox                        -  enabled, port: 9000
    + system.adapter.statistics.0             : statistics            : iob-test1-proxmox                        -  enabled
      system.adapter.telegram.0               : telegram              : iob-test1-proxmox                        - disabled, port: 8443
    + system.adapter.tr-064.0                 : tr-064                : iob-test1-proxmox                        -  enabled
      system.adapter.traccar.0                : traccar               : iob-test1-proxmox                        - disabled
    + system.adapter.trashschedule.0          : trashschedule         : iob-test1-proxmox                        -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iob-test1-proxmox                        - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-test1-proxmox                        - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-test1-proxmox                        - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-test1-proxmox                        - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iob-test1-proxmox                        -  enabled
      system.adapter.vis-history.0            : vis-history           : iob-test1-proxmox                        - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-test1-proxmox                        - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test1-proxmox                        - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test1-proxmox                        -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-test1-proxmox                        - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iob-test1-proxmox                        - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iob-test1-proxmox                        - disabled
      system.adapter.vis-map.0                : vis-map               : iob-test1-proxmox                        - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test1-proxmox                        - disabled
      system.adapter.vis-metro.0              : vis-metro             : iob-test1-proxmox                        - disabled
      system.adapter.vis-players.0            : vis-players           : iob-test1-proxmox                        - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iob-test1-proxmox                        - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test1-proxmox                        - disabled
      system.adapter.vis-weather.0            : vis-weather           : iob-test1-proxmox                        - disabled
      system.adapter.vis.0                    : vis                   : iob-test1-proxmox                        -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iob-test1-proxmox                        -  enabled
    + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
      system.adapter.windows-control.0        : windows-control       : iob-test1-proxmox                        - disabled
    + system.adapter.wled.0                   : wled                  : iob-test1-proxmox                        -  enabled
    + system.adapter.worx.0                   : worx                  : iob-test1-proxmox                        -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iob-test1-proxmox                        -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
    Adapter    "email"        : 1.2.0    , installed 1.2.0
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "kodi"         : 2.0.9    , installed 2.0.9
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "operating-hours": 1.0.4  , installed 1.0.4
    Adapter    "owfs"         : 0.7.0    , installed 0.7.0
    Adapter    "parser"       : 1.3.2    , installed 1.3.2
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "sayit"        : 3.0.5    , installed 3.0.5
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "socketio"     : 6.5.2    , installed 6.5.2
    Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
    Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "swiss-weather-api": 1.0.5, installed 1.0.5
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "traccar"      : 0.0.12   , installed 0.0.12
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 6.1.0    , installed 6.1.0
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.5.3    , installed 2.5.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        27197
    States:         25018
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (4901 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.1.203:1883      0.0.0.0:*               LISTEN      1001       30565      3592/io.sonoff.0
    tcp        0      0 192.168.1.203:8701      0.0.0.0:*               LISTEN      1001       19309      2672/io.hm-rpc.1
    tcp        0      0 192.168.1.203:1886      0.0.0.0:*               LISTEN      1001       25737      3366/io.mqtt.0
    tcp        0      0 192.168.1.203:1887      0.0.0.0:*               LISTEN      1001       25738      3366/io.mqtt.0
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       3000       505/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       525        505/iobroker.js-con
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16551      1/init
    tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      998        18195      1911/monitorix-http
    tcp        0      0 192.168.1.203:2001      0.0.0.0:*               LISTEN      1001       24691      2506/io.hm-rpc.0
    tcp        0      0 192.168.1.203:8082      0.0.0.0:*               LISTEN      1001       33466      5230/io.web.0
    tcp        0      0 192.168.1.203:8084      0.0.0.0:*               LISTEN      1001       37427      6517/io.socketio.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14001      543/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2477       504/cupsd
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22188      3805/io.shelly.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          116        1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20697      1123/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14003      543/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2476       504/cupsd
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30488      3515/io.shelly.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22446      4423/io.radar2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12729      1/init
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2836       524/cups-browsed
    udp        0      0 0.0.0.0:59462           0.0.0.0:*                           112        13921      464/avahi-daemon: r
    udp        0      0 0.0.0.0:3483            0.0.0.0:*                           1001       35642      6544/io.squeezeboxr
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37622      6615/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        13919      464/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          2352       1/init
    udp6       0      0 fe80::1e95:cc09:f9a:546 :::*                                0          13133      467/NetworkManager
    udp6       0      0 :::54050                :::*                                112        13922      464/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                112        13920      464/avahi-daemon: r
    2023-09-02 12:00:27.705  - info: host.iob-test1-proxmox instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-02 12:00:28.118  - info: host.iob-test1-proxmox instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-09-02 12:00:31.870  - info: awtrix-light.0 (6905) error ECONNABORTED from /api/custom?name=pvakt: timeout of 3000ms exceeded
    2023-09-02 12:00:31.871  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
    2023-09-02 12:00:41.886  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
    2023-09-02 12:03:34.236  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
    2023-09-02 12:03:34.278  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
    2023-09-02 12:05:00.086  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 14652
    2023-09-02 12:05:04.112  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 14696
    2023-09-02 12:05:06.024  - info: dwd.0 (14696) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
    2023-09-02 12:05:07.733  - info: dwd.0 (14696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-02 12:05:08.251  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-02 12:05:12.934  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-09-02 12:07:04.291  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
    2023-09-02 12:07:04.327  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
    2023-09-02 12:10:00.038  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 17562
    2023-09-02 12:10:02.028  - info: dwd.0 (17562) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
    2023-09-02 12:10:02.981  - info: dwd.0 (17562) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-09-02 12:10:03.512  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-02 12:10:04.062  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 17624
    2023-09-02 12:10:11.494  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-09-02 12:10:34.342  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
    2023-09-02 12:10:34.377  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
    2023-09-02 12:14:04.395  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
    2023-09-02 12:14:04.453  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
    @crepp1967
    Schmeiß die bullseye-backports raus und stell das nodesoure-Repo auf die aktuelle Struktur um.
    crepp1967C 2 Antworten Letzte Antwort
      @glasfaser sagte in Javascript Adapter starten plötzlich nicht mehr:
      setzte es bitte in Code-Tags ..
      das war ja das Problem 😂 zusätzliche Code-tags
      crepp1967C Offline
      crepp1967C Offline
      crepp1967
      ich war mir sicher CodeTags verwendet zu haben
        @glasfaser
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           974M          0B        974M
                 3298 M used memory
                  471 M active memory
                 7059 M free memory
                  115 M buffer memory
                 1207 M swap cache
                  974 M total swap
                    0 M used swap
                  974 M free swap
        *** FILESYSTEM ***
        /var:
        3.2G    /var/
        1.6G    /var/log
        1.4G    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.8.0
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        27197
        States:         25018
        Pending Updates: 0
        crunchipC Abwesend
        crunchipC Abwesend
        @crepp1967 sagte in Javascript Adapter starten plötzlich nicht mehr:
        'adm', 'systemd-journal'
        dein user ist nicht in der Gruppe
        gibt es einen Grund warum sämtliches vis "zubehör" deaktiviert ist?
        cupsd
        läuft da noch Desktop/Drucker zeugs?
        crepp1967C 1 Antwort Letzte Antwort
          @crepp1967
          crepp1967C Offline
          crepp1967C Offline
          crepp1967
          Wie mache ich das?
          Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
            Wie mache ich das?
            Wie mache ich das?
            Backports musst du mal selber freigeschaltet haben. Einfach wieder rückgängig machen, was damals getan wurde. Hat vermutlich mit udev zu tun gehabt.
            Zu nodesource:
            Schau in meine Signatur.
              Wie mache ich das?
              GlasfaserG Offline
              GlasfaserG Offline
              Wie mache ich das?
              ist der Fehler bei dir mit
              2023-09-02 11:46:36.090 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              schon behoben !?
              Thomas BraunT crepp1967C 2 Antworten Letzte Antwort
              • GlasfaserG Glasfaser
                Wie mache ich das?
                schon behoben !?
                schon behoben !?
                Hatte ich nie.
                  schon behoben !?
                  Hatte ich nie.
                  GlasfaserG Offline
                  GlasfaserG Offline
                  ich habe dich doch nicht angeschrieben !!!!?
                  das war für @crepp1967
                    @glasfaser
                    Axo...
                    Ja, eins mach dem anderen machen.
                      crunchipC Abwesend
                      crunchipC Abwesend
                      aber markiert/benachrichtigt wurde er durch
                        cupsd
                        crepp1967C Offline
                        crepp1967C Offline
                        crepp1967
                        @crunchip
                        Hab das System unter Proxmox (Ubuntu) aufgesetzt (mit dem iobroker script)
                        Hab dann nichts mehr angepasst (betriebssystemseitig)
                        cupsd kann wohl deaktivieren, da hängt kein Drucker dran.
                        in der shell mit purge oder wie werde ich das los?
                          Wie mache ich das?
                          schon behoben !?
                          crepp1967C Offline
                          crepp1967C Offline
                          crepp1967
                          @glasfaser
                          Also mein Grundproblem (nicht startende Javascript Adapter) ist nun zum Glück behoben, vielen Dank für die schnelle Hilfe und die Tips zum fixen.
                          Die hier im Thread noch so erwähnten Probleme werde ich im Anschluss beheben.
                          Damit kann ich den Thread auf "Gelöst" setzen.
                          Torsten
                            @crepp1967 sagte in (Gelöst) Javascript Adapter starten plötzlich nicht mehr:
                            ja, eben!
                            Code-tags sind in der Ausgabe bereits drin, an den richtigen Stellen.
                            Du hast zusätzliche verwendet
                              @crepp1967
                              crepp1967C Offline
                              crepp1967C Offline
                              crepp1967
                              @thomas-braun Wie kann ich das anstellen?
                                @crepp1967
                                Was genau meinst du?
