  4. (Gelöst) Javascript Adapter starten plötzlich nicht mehr
20 Beiträge 5 Kommentatoren 1.7k Aufrufe 6 Beobachtet
    @glasfaser sagte in Javascript Adapter starten plötzlich nicht mehr:
    setzte es bitte in Code-Tags ..
    das war ja das Problem 😂 zusätzliche Code-tags
    crepp1967C Offline
    crepp1967C Offline
    crepp1967
    ich war mir sicher CodeTags verwendet zu haben
    • crepp1967C crepp1967
      @glasfaser
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : kvm
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       12:13:57 up 25 min,  2 users,  load average: 0.23, 0.29, 0.50
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Sat 2023-09-02 12:13:57 CEST
                 Universal time: Sat 2023-09-02 10:13:57 UTC
                       RTC time: Sat 2023-09-02 10:13:58
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi cdrom floppy audio dip video plugdev netdev bluetooth scanner iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             11G        3.3G        7.1G         10M        1.3G        8.1G
      Swap:           974M          0B        974M
      Total:           12G        3.3G        8.0G
              11679 M total memory
               3298 M used memory
                471 M active memory
               3804 M inactive memory
               7059 M free memory
                115 M buffer memory
               1207 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  5.7G     0  5.7G   0% /dev
      tmpfs          tmpfs     1.2G  1.2M  1.2G   1% /run
      /dev/sda1      ext4       31G   18G  9.9G  65% /
      tmpfs          tmpfs     5.8G     0  5.8G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.2G  116K  1.2G   1% /run/user/1000
      [Sat Sep  2 11:48:41 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Sep  2 11:48:42 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      3.2G    /var/
      1.6G    /var/log
      1.4G    /var/log/journal/33dc4f3a0bb843a19efcff7c642a250d
      1.4G    /var/cache
      Archived and active journals take up 72.0M in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      1.5M    /opt/iobroker/backups/js
      788K    /opt/iobroker/backups/js/Produktiv
      616K    /opt/iobroker/backups/js/TEST
      288K    /opt/iobroker/backups/js/Produktiv/JS
      /opt/iobroker/iobroker-data:
      980M    /opt/iobroker/iobroker-data/
      505M    /opt/iobroker/iobroker-data/files
      246M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      31M     /opt/iobroker/iobroker-data/states.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
      19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      18M     /opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.8.0
      javascript:     7.0.3
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.0                  : admin                 : iob-test1-proxmox                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iob-test1-proxmox                        -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iob-test1-proxmox                        -  enabled
      + system.adapter.backitup.0               : backitup              : iob-test1-proxmox                        -  enabled
      + system.adapter.bring.0                  : bring                 : iob-test1-proxmox                        -  enabled
        system.adapter.broadlink2.0             : broadlink2            : iob-test1-proxmox                        - disabled
        system.adapter.daswetter.0              : daswetter             : iob-test1-proxmox                        -  enabled
        system.adapter.discovery.0              : discovery             : iob-test1-proxmox                        - disabled
        system.adapter.ds18b20.0                : ds18b20               : iob-test1-proxmox                        - disabled
        system.adapter.dwd.0                    : dwd                   : iob-test1-proxmox                        -  enabled
        system.adapter.email.0                  : email                 : iob-test1-proxmox                        - disabled
        system.adapter.feiertage.0              : feiertage             : iob-test1-proxmox                        - disabled
        system.adapter.flot.0                   : flot                  : iob-test1-proxmox                        - disabled
      + system.adapter.fritzbox.0               : fritzbox              : iob-test1-proxmox                        -  enabled
        system.adapter.fully-tablet-control.0   : fully-tablet-control  : iob-test1-proxmox                        - disabled
        system.adapter.history.0                : history               : iob-test1-proxmox                        - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iob-test1-proxmox                        -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iob-test1-proxmox                        -  enabled, port: 0
      + system.adapter.hue-extended.0           : hue-extended          : iob-test1-proxmox                        -  enabled
      + system.adapter.hue.0                    : hue                   : iob-test1-proxmox                        -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iob-test1-proxmox                        -  enabled
        system.adapter.ical.1                   : ical                  : iob-test1-proxmox                        -  enabled
        system.adapter.ical.2                   : ical                  : iob-test1-proxmox                        -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iob-test1-proxmox                        - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iob-test1-proxmox                        - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iob-test1-proxmox                        - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iob-test1-proxmox                        - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iob-test1-proxmox                        - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob-test1-proxmox                        - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iob-test1-proxmox                        - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob-test1-proxmox                        - disabled
      + system.adapter.influxdb.0               : influxdb              : iob-test1-proxmox                        -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iob-test1-proxmox                        -  enabled
      + system.adapter.iot.0                    : iot                   : iob-test1-proxmox                        -  enabled
        system.adapter.javascript.0             : javascript            : iob-test1-proxmox                        -  enabled
        system.adapter.javascript.1             : javascript            : iob-test1-proxmox                        -  enabled
      + system.adapter.kodi.0                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
      + system.adapter.kodi.1                   : kodi                  : iob-test1-proxmox                        -  enabled, port: 9090
      + system.adapter.lgtv.0                   : lgtv                  : iob-test1-proxmox                        -  enabled
        system.adapter.luftdaten.0              : luftdaten             : iob-test1-proxmox                        -  enabled
        system.adapter.mobile.0                 : mobile                : iob-test1-proxmox                        - disabled
      + system.adapter.moma.0                   : moma                  : iob-test1-proxmox                        -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iob-test1-proxmox                        -  enabled, port: 1886, bind: 192.168.1.203
        system.adapter.mqtt.1                   : mqtt                  : iob-test1-proxmox                        - disabled, port: 1884, bind: 192.168.1.203
      + system.adapter.nina.0                   : nina                  : iob-test1-proxmox                        -  enabled
        system.adapter.node-red.0               : node-red              : iob-test1-proxmox                        - disabled, port: 1880, bind: 192.168.1.203
        system.adapter.openweathermap.0         : openweathermap        : iob-test1-proxmox                        -  enabled
        system.adapter.owfs.0                   : owfs                  : iob-test1-proxmox                        - disabled, port: 4304
        system.adapter.parser.0                 : parser                : iob-test1-proxmox                        - disabled
      + system.adapter.pi-hole.0                : pi-hole               : iob-test1-proxmox                        -  enabled
      + system.adapter.proxmox.0                : proxmox               : iob-test1-proxmox                        -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iob-test1-proxmox                        -  enabled
      + system.adapter.radar2.0                 : radar2                : iob-test1-proxmox                        -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iob-test1-proxmox                        - disabled
      + system.adapter.sayit.0                  : sayit                 : iob-test1-proxmox                        -  enabled
        system.adapter.scenes.0                 : scenes                : iob-test1-proxmox                        - disabled
      + system.adapter.senec.0                  : senec                 : iob-test1-proxmox                        -  enabled
      + system.adapter.shelly.0                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iob-test1-proxmox                        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.socketio.0               : socketio              : iob-test1-proxmox                        -  enabled, port: 8084, bind: 192.168.1.203, run as: admin
        system.adapter.solarwetter.0            : solarwetter           : iob-test1-proxmox                        - disabled
      + system.adapter.sonoff.0                 : sonoff                : iob-test1-proxmox                        -  enabled, port: 1883, bind: 192.168.1.203
      + system.adapter.spotify-premium.0        : spotify-premium       : iob-test1-proxmox                        -  enabled
      + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iob-test1-proxmox                        -  enabled, port: 9000
      + system.adapter.statistics.0             : statistics            : iob-test1-proxmox                        -  enabled
        system.adapter.telegram.0               : telegram              : iob-test1-proxmox                        - disabled, port: 8443
      + system.adapter.tr-064.0                 : tr-064                : iob-test1-proxmox                        -  enabled
        system.adapter.traccar.0                : traccar               : iob-test1-proxmox                        - disabled
      + system.adapter.trashschedule.0          : trashschedule         : iob-test1-proxmox                        -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iob-test1-proxmox                        - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob-test1-proxmox                        - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob-test1-proxmox                        - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob-test1-proxmox                        - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iob-test1-proxmox                        -  enabled
        system.adapter.vis-history.0            : vis-history           : iob-test1-proxmox                        - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob-test1-proxmox                        - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iob-test1-proxmox                        - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iob-test1-proxmox                        -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob-test1-proxmox                        - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iob-test1-proxmox                        - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iob-test1-proxmox                        - disabled
        system.adapter.vis-map.0                : vis-map               : iob-test1-proxmox                        - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob-test1-proxmox                        - disabled
        system.adapter.vis-metro.0              : vis-metro             : iob-test1-proxmox                        - disabled
        system.adapter.vis-players.0            : vis-players           : iob-test1-proxmox                        - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iob-test1-proxmox                        - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob-test1-proxmox                        - disabled
        system.adapter.vis-weather.0            : vis-weather           : iob-test1-proxmox                        - disabled
        system.adapter.vis.0                    : vis                   : iob-test1-proxmox                        -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iob-test1-proxmox                        -  enabled
      + system.adapter.web.0                    : web                   : iob-test1-proxmox                        -  enabled, port: 8082, bind: 192.168.1.203, run as: admin
        system.adapter.windows-control.0        : windows-control       : iob-test1-proxmox                        - disabled
      + system.adapter.wled.0                   : wled                  : iob-test1-proxmox                        -  enabled
      + system.adapter.worx.0                   : worx                  : iob-test1-proxmox                        -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iob-test1-proxmox                        -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Installed ioBroker-Instances
      Adapter    "admin"        : 6.8.0    , installed 6.8.0
      Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hue"          : 3.9.5    , installed 3.9.5
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "kodi"         : 2.0.9    , installed 2.0.9
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "openweathermap": 0.3.9   , installed 0.3.9
      Adapter    "operating-hours": 1.0.4  , installed 1.0.4
      Adapter    "owfs"         : 0.7.0    , installed 0.7.0
      Adapter    "parser"       : 1.3.2    , installed 1.3.2
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "socketio"     : 6.5.2    , installed 6.5.2
      Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "spotify-premium": 1.2.2  , installed 1.2.2
      Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
      Adapter    "statistics"   : 2.3.0    , installed 2.3.0
      Adapter    "swiss-weather-api": 1.0.5, installed 1.0.5
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "traccar"      : 0.0.12   , installed 0.0.12
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "web"          : 6.1.0    , installed 6.1.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.5.3    , installed 2.5.3
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Objects and States
      Objects:        27197
      States:         25018
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Get:7 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
      Fetched 4586 B in 1s (4901 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.1.203:1883      0.0.0.0:*               LISTEN      1001       30565      3592/io.sonoff.0
      tcp        0      0 192.168.1.203:8701      0.0.0.0:*               LISTEN      1001       19309      2672/io.hm-rpc.1
      tcp        0      0 192.168.1.203:1886      0.0.0.0:*               LISTEN      1001       25737      3366/io.mqtt.0
      tcp        0      0 192.168.1.203:1887      0.0.0.0:*               LISTEN      1001       25738      3366/io.mqtt.0
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       3000       505/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       525        505/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          16551      1/init
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      998        18195      1911/monitorix-http
      tcp        0      0 192.168.1.203:2001      0.0.0.0:*               LISTEN      1001       24691      2506/io.hm-rpc.0
      tcp        0      0 192.168.1.203:8082      0.0.0.0:*               LISTEN      1001       33466      5230/io.web.0
      tcp        0      0 192.168.1.203:8084      0.0.0.0:*               LISTEN      1001       37427      6517/io.socketio.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14001      543/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2477       504/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       22188      3805/io.shelly.1
      tcp6       0      0 :::111                  :::*                    LISTEN      0          116        1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20697      1123/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14003      543/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2476       504/cupsd
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30488      3515/io.shelly.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       22446      4423/io.radar2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12729      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2836       524/cups-browsed
      udp        0      0 0.0.0.0:59462           0.0.0.0:*                           112        13921      464/avahi-daemon: r
      udp        0      0 0.0.0.0:3483            0.0.0.0:*                           1001       35642      6544/io.squeezeboxr
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       37622      6615/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        13919      464/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          2352       1/init
      udp6       0      0 fe80::1e95:cc09:f9a:546 :::*                                0          13133      467/NetworkManager
      udp6       0      0 :::54050                :::*                                112        13922      464/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                112        13920      464/avahi-daemon: r
      2023-09-02 12:00:27.705  - info: host.iob-test1-proxmox instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-02 12:00:28.118  - info: host.iob-test1-proxmox instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-09-02 12:00:31.870  - info: awtrix-light.0 (6905) error ECONNABORTED from /api/custom?name=pvakt: timeout of 3000ms exceeded
      2023-09-02 12:00:31.871  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
      2023-09-02 12:00:41.886  - warn: awtrix-light.0 (6905) (custom?name=pvakt) Unable to update custom app "pvakt": AxiosError: timeout of 3000ms exceeded
      2023-09-02 12:03:34.236  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
      2023-09-02 12:03:34.278  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
      2023-09-02 12:05:00.086  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 14652
      2023-09-02 12:05:04.112  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 14696
      2023-09-02 12:05:06.024  - info: dwd.0 (14696) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
      2023-09-02 12:05:07.733  - info: dwd.0 (14696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-02 12:05:08.251  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-02 12:05:12.934  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2023-09-02 12:07:04.291  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
      2023-09-02 12:07:04.327  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
      2023-09-02 12:10:00.038  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 started with pid 17562
      2023-09-02 12:10:02.028  - info: dwd.0 (17562) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 4.0.24
      2023-09-02 12:10:02.981  - info: dwd.0 (17562) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-02 12:10:03.512  - info: host.iob-test1-proxmox instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-02 12:10:04.062  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 started with pid 17624
      2023-09-02 12:10:11.494  - info: host.iob-test1-proxmox instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
      2023-09-02 12:10:34.342  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
      2023-09-02 12:10:34.377  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
      2023-09-02 12:14:04.395  - info: hm-rpc.1 (2672) xmlrpc -> listDevices 0
      2023-09-02 12:14:04.453  - info: hm-rpc.1 (2672) new CUxD devices/channels after filter: 0
      crunchipC Abwesend
      crunchipC Abwesend
      @crepp1967 sagte in Javascript Adapter starten plötzlich nicht mehr:
      'adm', 'systemd-journal'
      dein user ist nicht in der Gruppe
      gibt es einen Grund warum sämtliches vis "zubehör" deaktiviert ist?
      cupsd
      läuft da noch Desktop/Drucker zeugs?
      crepp1967C 1 Antwort Letzte Antwort
        @crepp1967
        Schmeiß die bullseye-backports raus und stell das nodesoure-Repo auf die aktuelle Struktur um.
        crepp1967C Offline
        crepp1967C Offline
        crepp1967
        Wie mache ich das?
        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
          Wie mache ich das?
          Wie mache ich das?
          Backports musst du mal selber freigeschaltet haben. Einfach wieder rückgängig machen, was damals getan wurde. Hat vermutlich mit udev zu tun gehabt.
          Zu nodesource:
          Schau in meine Signatur.
            Wie mache ich das?
            GlasfaserG Offline
            GlasfaserG Offline
            Wie mache ich das?
            ist der Fehler bei dir mit
            2023-09-02 11:46:36.090 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            schon behoben !?
            Thomas BraunT crepp1967C 2 Antworten Letzte Antwort
            • GlasfaserG Glasfaser
              Wie mache ich das?
              schon behoben !?
              schon behoben !?
              Hatte ich nie.
                schon behoben !?
                Hatte ich nie.
                GlasfaserG Offline
                GlasfaserG Offline
                ich habe dich doch nicht angeschrieben !!!!?
                das war für @crepp1967
                  @glasfaser
                  Axo...
                  Ja, eins mach dem anderen machen.
                    crunchipC Abwesend
                    crunchipC Abwesend
                    aber markiert/benachrichtigt wurde er durch
                      cupsd
                      crepp1967C Offline
                      crepp1967C Offline
                      crepp1967
                      @crunchip
                      Hab das System unter Proxmox (Ubuntu) aufgesetzt (mit dem iobroker script)
                      Hab dann nichts mehr angepasst (betriebssystemseitig)
                      cupsd kann wohl deaktivieren, da hängt kein Drucker dran.
                      in der shell mit purge oder wie werde ich das los?
                        Wie mache ich das?
                        schon behoben !?
                        crepp1967C Offline
                        crepp1967C Offline
                        crepp1967
                        @glasfaser
                        Also mein Grundproblem (nicht startende Javascript Adapter) ist nun zum Glück behoben, vielen Dank für die schnelle Hilfe und die Tips zum fixen.
                        Die hier im Thread noch so erwähnten Probleme werde ich im Anschluss beheben.
                        Damit kann ich den Thread auf "Gelöst" setzen.
                        Torsten
                          @crepp1967 sagte in (Gelöst) Javascript Adapter starten plötzlich nicht mehr:
                          ja, eben!
                          Code-tags sind in der Ausgabe bereits drin, an den richtigen Stellen.
                          Du hast zusätzliche verwendet
                            @crepp1967
                            crepp1967C Offline
                            crepp1967C Offline
                            crepp1967
                            @thomas-braun Wie kann ich das anstellen?
                              @crepp1967
                              Was genau meinst du?
