  4. Zigbee: TS0601_soil funktioniert, aber mit Warnings
zigbee sensor
22 Beiträge 6 Kommentatoren 3.2k Aufrufe 7 Beobachtet
  • GaspodeG Offline
    GaspodeG Offline
    Gaspode
    schrieb am zuletzt editiert von Gaspode
    ich bin begeisterter Nutzer vom Zigbee Adapter von @arteck
    Funktioniert super und zuverlässig.
    Jetzt habe ich mir einen Bodenfeuchte-Sensor zugelegt: https://de.aliexpress.com/item/1005005388244280.html
    Das Pairing hat auch auf Anhieb geklappt und Feuchte und Temperatur werden mit plausiblen Werten aktualisiert. allerdings sind beim Pairing ein paar Warnings aufgetaucht, besteht da Handlungsbedarf?
    2023-08-12 10:55:05.228 - info: zigbee.0 (2228) Starting interview of '0xXXXXXXXXXXXXXXXX'
    2023-08-12 10:55:05.313 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
    2023-08-12 10:55:06.064 - error: zigbee.0 (2228) Device 0xXXXXXXXXXXXXXXXX "TS0601" not described in statesMapping.
    2023-08-12 10:55:08.474 - info: zigbee.0 (2228) Successfully interviewed '0xXXXXXXXXXXXXXXXX', device has successfully been paired
    2023-08-12 10:55:08.474 - info: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' is supported, identified as: TuYa Soil sensor (TS0601_soil)
    2023-08-12 10:55:08.477 - info: zigbee.0 (2228) Configuring 0xXXXXXXXXXXXXXXXX TS0601
    2023-08-12 10:55:08.497 - warn: zigbee.0 (2228) download icon from https://www.zigbee2mqtt.io/images/devices/TS0601_soil.jpg saved into C:/ioBroker/node_modules/iobroker.zigbee/admin/img/TS0601_soil.png
    2023-08-12 10:55:08.530 - warn: zigbee.0 (2228) Object XXXXXXXXXXXXXXXX.temperature_unit is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-08-12 10:55:08.531 - warn: zigbee.0 (2228) This object will not be created in future versions. Please report this to the developer.
    2023-08-12 10:55:08.531 - warn: zigbee.0 (2228) Object XXXXXXXXXXXXXXXX.battery_state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) Object zigbee.0.XXXXXXXXXXXXXXXX.temperature_unit is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) This object will not be created in future versions. Please report this to the developer.
    2023-08-12 10:55:08.573 - warn: zigbee.0 (2228) Object zigbee.0.XXXXXXXXXXXXXXXX.battery_state is invalid: obj.common.states has an invalid type! Expected "object", received "string"
    2023-08-12 10:55:08.850 - info: zigbee.0 (2228) DeviceConfigure successful 0xXXXXXXXXXXXXXXXX TS0601
    2023-08-12 10:55:54.441 - info: zigbee.0 (2228) Zigbee: stop joining
    2023-08-12 10:57:19.827 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
    Ich wäre auch gerne bereit per PR mit zu helfen, aber leider fehlt mir hier eine Menge Hintergrundwissen. Ich nehme mal an, es muss hier etwas angepasst werden: tuya.ts
    Nur was und wie?
    • GaspodeG Gaspode
      Nur was und wie?
      arteckA Offline
      arteckA Offline
      arteck
      @gaspode sagte in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
      TS0601
      kommen die jetzt auch noch oder nur einmalig bei pairing ?
      GaspodeG 2 Antworten Letzte Antwort
      • arteckA arteck
        TS0601
        GaspodeG Offline
        GaspodeG Offline
        Gaspode
        @arteck said in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
        Kamen bisher nur einmalig beim Pairing. Gerade ist mir aber aufgefallen, dass etwa ein mal am Tag diese Meldung für das Gerät auftaucht:
        2023-08-14 08:41:02.527 - warn: zigbee.0 (2228) Device '0xXXXXXXXXXXXXXXXX' announced itself
        Hat das was zu sagen?
        Ansonsten sieht der Objektbaum für das Gerät so aus:
        Und die Kachel so:
        • GaspodeG Gaspode
          Und die Kachel so:
          arteckA Offline
          arteckA Offline
          arteck
          @gaspode der meldet sich vom Netz ab.. und kommt dan weider ... warum auch immer.. manche Geräte machen das
          GaspodeG 1 Antwort Letzte Antwort
          • arteckA arteck
            GaspodeG Offline
            GaspodeG Offline
            Gaspode
            Danke, also nix ungewöhnliches.
            Und es funktioniert ja alles, abgesehen von der temperature_unit und den Meldungen beim Pairing.
            • arteckA arteck
              TS0601
              GaspodeG Offline
              GaspodeG Offline
              Gaspode
              @arteck
              Darf ich nochmal vorsichtig nachfragen? :)
              Besteht Handlungsbedarf? Kann ich was beisteuern (da bräuchte ich aber etwas Starthilfe)? Soll ich irgendwo ein Issue anlegen?
              Im Tree im Admin fehlt auch das Symbol für das Device, obwohl es auf der Kachel angezeigt wird. Hat das damit zu tun?
              • GaspodeG Gaspode
                @arteck
                arteckA Offline
                arteckA Offline
                arteck
                also
                https://github.com/ioBroker/ioBroker.zigbee/wiki/Missing-icons-after-adatapter-Update
                was hast du für coordinator ?? welche Fimrmwareversion ?
                • GaspodeG Offline
                  GaspodeG Offline
                  Gaspode
                  Oh, Danke. Hatte ich übersehen. Das Symbol ist jetzt schon mal da. :)
                  Den hier: https://www.amazon.de/gp/product/B09KXTCMSC
                  type: zStack3x0
                  version: 2-1.2.7.1.
                  revision: 20210708
                  AtomicIXA 1 Antwort Letzte Antwort
                  • GaspodeG Gaspode
                    type: zStack3x0
                    version: 2-1.2.7.1.
                    revision: 20210708
                    AtomicIXA Online
                    AtomicIXA Online
                    AtomicIX
                    @arteck
                    Ich habe den selber Fühler.
                    Bei mir wird er aber gar nicht erkannt.
                    Also erkannt schon, aber nicht verbunden.
                    Hab ihn schon 2 mal gelöscht und neu gekoppelt.
                    Jedes mal das selbe. Was kann ich da noch machen.?
                    Ich nutze einen sonoff zigbee Stick.
                    type:zStack3x0
                    version:2-1.2.7.1.
                    revision:20211217
                    Der Zigbee adapter hat die Version 1.10.3
                    • AtomicIXA AtomicIX
                      @arteck
                      type:zStack3x0
                      version:2-1.2.7.1.
                      revision:20211217
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @atomicix
                      Versuch mal bitte die 1.10.5 von github.
                      Da sollte auch deine Variante erkannt werden.
                      A.
                      P.s. Willkommen in der Hölle von TuYa. Was gleich aussieht ist nicht gleich. Dafür sind Dinge gleich die unterschiedlich aussehen. Du hast also nicht den selben Fühler, sondern nur einen der genau so aussieht,
                      • AsgothianA Asgothian
                        @atomicix
                        A.
                        AtomicIXA Online
                        AtomicIXA Online
                        AtomicIX
                        @asgothian danke, läuft. Musste das nicht einmal neu einrichten.
                        B 1 Antwort Letzte Antwort
                          bastler
                          @Asgothian Moin, grätsche mal dazwischen :-). Bei mir ist heute der gleiche Fühler aufgeschlagen. Habe ihn angemeldet bekommen, allerdings ohne irgend welche Messwerte? dcc2382d-02ea-452f-8eaa-f327919bc183-image.jpeg
                          Hinten Steht noch die Bezeichnung QT-07S.
                          Unter dem Punkt msg_from_zigbee in den Objekten gibt es diesen Eintrag
                          {"type":"commandDataReport","data":{"seq":25856,"dpValues":[{"dp":14,"datatype":4,"data":{"type":"Buffer","data":[2]}}]},"linkquality":255,"groupID":null,"cluster":"manuSpecificTuya","meta":{"zclTransactionSequenceNumber":228,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                          Nutze den Conbee2 Koordinator für meine Zigbee Geräte.
                          Gibt es eine Möglichkeit den Sensor irgendwie zum Laufen zu bekommen?
                          • B bastler
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @bastler
                            • welche Adapter Version nutzt du ?
                            • was steht auf der „Info“ Kachel ?
                            A.
                              @bastler
                              A.
                              bastler
                              @asgothian Der Adapter hat die Version 1.10.3 und das steht unter Info auf der Kachel IMG_7385.jpeg
                              • B bastler
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @bastler dann hast du 2 Möglichkeiten
                                • warten
                                • meine Test-Version von hier installieren und berichten was passiert
                                A.
                                  • warten
                                  A.
                                  bastler
                                  @asgothian Wow er funktioniert!! Vielen Dank für deine Bemühungen!
                                  B AsgothianA 2 Antworten Letzte Antwort
                                  • B bastler
                                    bastler
                                    @Asgothian Er sendet etwa alle 24 Minuten neue Werte.
                                    • B bastler
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @bastler sagte in Zigbee: TS0601_soil funktioniert, aber mit Warnings:
                                      welche Version hast du installiert ?
                                      A.
                                        A.
                                        bastler
                                        @asgothian 1.10.5 die von Github
                                        ? 1 Antwort Letzte Antwort
                                        • B bastler
                                          Hallo @bastler ,
                                          welche Firmware hat Dein Stick?
