  4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
    5.4k
1.0k Beiträge 49 Kommentatoren 424.1k Aufrufe 52 Beobachtet
  • BertDerKleineB BertDerKleine
    @mcm1957
    Siehe den Hinweis von @BananaJoe hier:
    https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/274
    Und die "Lösung" genau im Github:
    https://github.com/foxriver76/ioBroker.puppeteer/issues/13
    I've fixed the problem by first installing chromium (Debian 12 / ARM64 in my case):
    sudo apt install chromium
    Change the adapter's main.js onReady() function to load the correct binary (chromium in my case):
    async onReady() {
        this.browser = await import_puppeteer.default.launch({ headless: "new", defaultViewport: null, executablePath: '/usr/bin/chromium', args: ['--no-sandbox', '--disable-setuid-sandbox'] });
        this.subscribeStates("url");
        this.log.info("Ready to take screenshots");
    Now everything works as expected.
    Mein Fehlerlog:
    $ iobroker add puppeteer auto --host iobrokerpi4b --debug
    NPM version: 10.8.2
    Installing iobroker.puppeteer@0.4.0... (System call)
    > puppeteer@23.11.1 postinstall> node install.mjs
    **INFO** Skipping Firefox download as instructed.
    Error: ERROR: Failed to set up chrome-headless-shell v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async Promise.all (index 1) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}
    npm error code 1
    npm error path /opt/iobroker/node_modules/puppeteer
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-13T19_22_49_037Z-debug-0.log
    Error: ERROR: Failed to set up chrome-headless-shell v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 1) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}npm error code 1npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-13T19_22_49_037Z-debug-0.loghost.iobrokerpi4b Cannot install iobroker.puppeteer@0.4.0: 1
    ERROR: Process exited with code 25
    Beowolf
    schrieb am zuletzt editiert von Beowolf
    #1001
    @bertderkleine
    {1}
    async onReady() {
    Das ist schon lange überholt. Mit einem aktuellen System wird einfach Chromium installiert
    sudo apt install chromium-browser -y
    Mache danach event. noch das hier
    sudo apt update && sudo apt full-upgrade
    Mache einen reboot und danach im ioBroker der Puppeteer Adapter. Fertig.
    Die Natur braucht nicht unseren Schutz, sie braucht unsere Abwesenheit.
    BertDerKleineB 1 Antwort Letzte Antwort
    • B Beowolf
      @bertderkleine
      {1}
      async onReady() {
      BertDerKleineB Offline
      BertDerKleine
      #1002
      @beowolf sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
      @bertderkleine
      {1}
      async onReady() {
      Habe ich alles gemacht, es führt leider nicht zum Ziel, weiter Fehler:
      NPM version: 10.8.2
      Error: ERROR: Failed to set up chrome v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 0) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}
      npm error code 1
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T06_42_00_915Z-debug-0.log
      Error: ERROR: Failed to set up chrome v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 0) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}npm error code 1npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T06_42_00_915Z-debug-0.log
        @bertderkleine
        {1}
        async onReady() {
        NPM version: 10.8.2
        npm error code 1
        Beowolf
        #1003
        @bertderkleine
        Ich habe mal gerade auf meinem Test-Raspberry das aktuelle PI-Image aufgespielt. Danach iobroker, dann Chromium und natürlich den Adapter Puppeteer in ioBroker installiert. Alles lief ohne Problem durch.
        Keine Ahnung was du wo auf deinem System schon gemacht hast, aber ich glaube, das der Fehler ganz woanders liegt.
        Mach doch mal ein Backup, nimm zum Testen eine neue SD-Karte, installiere das aktuelle Image, usw.
        Du wirst sehen, das das alles so durchläuft.
        Möchtest du das nicht, wäre es glaube ich besser, wenn du einen eigenen Beitrag öffnest. Das führt hier wohl etwas zu weit.
        • B Beowolf
          @bertderkleine
          BertDerKleine
          schrieb am zuletzt editiert von BertDerKleine
          #1004
          @beowolf
          Danke Dir. Problem ist mittlerweile auch gelöst.
          Ich hatte schon einen eigenen Thread aufgemacht: https://forum.iobroker.net/topic/81640/gelöst-puppeteer-adapter-läuft-auf-raspi-4-nicht
            @beowolf
            Beowolf
            #1005
            @bertderkleine
            Trage doch noch den Link zu deinem neuen Beitrag ein. So kann jeder der event. auch damit ein Problem hat es einfacher finden.
            • B Beowolf
              @bertderkleine
              BertDerKleine
              #1006
              @beowolf
              erledigt.
              • BertDerKleineB Offline
                BertDerKleine
                #1007
                eben mal das Blockly aus Beitrag #274 (https://forum.iobroker.net/topic/66380/e-ink-display-openepaperlink-displayanzeige-mit-batterie/274) versucht laufen zu lassen.
                Das führt aber nur zu Fehler:
                javascript.0	19:04:21.885	warn	request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                javascript.0	19:04:21.918	error	    at Object.<anonymous> (script.js.08_E-Ink_Displays.Bild_an_OpenEpaperLink_Tags_senden:41:13)
                Hat jemand ein Blockly, das heute noch läuft?
                Mit JS habe ich mir auch was hingefrickelt, aber ein Blockly, das Stand heute noch läuft wäre super.
                EisbaeeerE 1 Antwort Letzte Antwort
                  EisbaeeerE Offline
                  EisbaeeerE Offline
                  Eisbaeeer
                  schrieb am zuletzt editiert von Eisbaeeer
                  #1008
                  @bertderkleine
                  Ich habe das ganze von Blockly auf Script konvertiert. Damit funktioniert auch puppeteer und upload wieder.
                  Link: https://forum.iobroker.net/post/1265803
                  Oder wieder zurück nach Blockly basteln.
                  Und jetzt auch besser auffindbar hier: E-INK Display OpenEPaperLink - Blockly, Java-Skripte usw.
                  Kein support per PM. Bitte im Forum Fragen stellen!
                    BertDerKleine
                    #1009
                    So, jetzt habe ich einen Spaghetti AP zusammengebastelt und eine handvoll Displays und konnte aus den theoretischen mal praktische Übungen machen.
                    Dabei stiess ich auf einen bösen Stolperstein bei der Hardware:
                    Es gibt nämlich beim ESP32-S3 Teile, die auf den ersten Block genau passend ausschauen von den Specs, es aber dann doch nicht sind, Beispiel: https://de.aliexpress.com/item/1005009621440783.html
                    Wenn man es weiss, erkennt man die nicht passende Hardware daran, dass es keinen GPIO Pin #20 gibt (und die Pins alle anders sortiert sind).
                    Frage jetzt zur Ansteuerung des Displays:
                    Die Firmware bietet ja eine "copy" Funktion. Irgendwie bekomme ich die aber nicht zum Fliegen.
                    a) gibts dazu irgendwelche Doku Links?
                    b) konkret gefragt: in welchem Format gibt man hier die MAC-Adresse ein? Also eher "00112233..." oder "00:11:22:33..."?
                    Der-JetiD 1 Antwort Letzte Antwort
                      Der-JetiD Offline
                      Der-JetiD Offline
                      Der-Jeti
                      #1010
                      wo bekommt man aktuell noch geflashte Displays?
                      Bräuchte 1/2 Stück zum testen.
                      • Der-JetiD Der-Jeti
                        EisbaeeerE Offline
                        EisbaeeerE Offline
                        Eisbaeeer
                        #1011
                        @der-jeti Ich habe noch welche auf Lager. VG Lars
                        a200A 1 Antwort Letzte Antwort
                        • EisbaeeerE Eisbaeeer
                          a200A Offline
                          a200A Offline
                          a200
                          #1012
                          @eisbaeeer Moin, ich hätte auch Interesse. Was und wie viel würde mich interessieren. 😀
                          • a200A a200
                            EisbaeeerE Offline
                            EisbaeeerE Offline
                            Eisbaeeer
                            #1013
                            @a200 Ich hab dir eine PM geschickt.
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #1014
                              @Eisbaeeer
                              @bimmi
                              @Beowolf
                              Schwupps , aus dem Nichts , hat der Tag den GoogleKalender nicht mehr aktualisiert.
                              function getEventsForNextDay(days) {
                                var start = new Date();
                                var end = new Date();
                                var time_offset = 0;
                                end.setDate(end.getDate() + 8);
                                var calendars = CalendarApp.getAllCalendars();
                                var events = [];
                                for (var i = 0; i < calendars.length; i++) {
                                  var calendar = calendars[i];
                                  var eventsInCalendar = calendar.getEvents(start, end);
                                  for (var j = 0; j < eventsInCalendar.length; j++) {
                                    var event = eventsInCalendar[j];
                                    events.push({
                                      title: event.getTitle(),
                                      start: Math.floor((event.getStartTime().getTime() / 1000)+(time_offset*3600)),
                                      end: Math.floor((event.getEndTime().getTime() / 1000)+(time_offset*3600)),
                                      description: event.getDescription()
                                // Sort events by start date/time
                                events.sort(function(a, b) {
                                  return a.start - b.start;
                                return JSON.stringify(events);
                              function doGet() {
                                var content = getEventsForNextDay();
                                var output = ContentService.createTextOutput(content);
                                output.setMimeType(ContentService.MimeType.JSON);
                                return output;
                              Seit dem 05.10. hat der Tag den Kalender nicht aktualisiert.
                              02:45:37 InvalidInput
                              02:45:27 get calendar
                              Das kommt nun im Log.
                              Hab auch alle Punkte und Anleitungen nochmal durch.
                              Tag bleibt leer, Log haut invalidinput raus.
                              Die anderen Tags laufen einwandfrei.
                              Batterien sind alle neu.
                              • haselchenH haselchen
                                @Eisbaeeer
                                @bimmi
                                @Beowolf
                                  var events = [];
                                      events.push({
                                function doGet() {
                                  return output;
                                EisbaeeerE Offline
                                EisbaeeerE Offline
                                Eisbaeeer
                                #1015
                                @haselchen Hi. Hast du iobroker upgedated? Sowas kenne ich eigentlich nur, wenn man node oder Module updated. Müsste man debuggen, was da schief läuft. Stell mal auf Debug Modus und poste die Ausgabe.
                                VG Lars
                                  VG Lars
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #1016
                                  @eisbaeeer
                                  Moin moin,
                                  Iobroker ist völlig außen vor.
                                  Google Apps Script , wie auf Github beschrieben.
                                  Hier im Thread gab es dazu ein angepasstes Skript, weil das Ursprüngliche ab 2.07b (AP Firmware) nicht mehr funktionierte.
                                  Da wäre es interessant von den Usern, die dieses Kalender Script nutzen ,zu erfahren , ob es bei ihnen noch läuft und wenn ja , wie .
                                    @eisbaeeer
                                    Moin moin,
                                    EisbaeeerE Offline
                                    EisbaeeerE Offline
                                    Eisbaeeer
                                    #1017
                                    @haselchen sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                                    @eisbaeeer
                                    Dann bin ich raus. Sorry. Ich nutze nur iobroker für die Anzeige.
                                      @eisbaeeer
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #1018
                                      @eisbaeeer
                                      @bimmi
                                      @Beowolf
                                      Erledigt.
                                      Der Dev auf Github hat in 5min das Problem gelöst.
                                      https://github.com/OpenEPaperLink/OpenEPaperLink/issues/512
                                      • K Offline
                                        Kai 2
                                        #1019
                                        wo habt ihr denn die ESL Tags her? Auf ebay & Co finde ich keinen von den auf OEPL gelisteten Tags. Gibt es Alternativen?
                                        Danke!!
                                        Kai
                                        • K Kai 2
                                          Danke!!
                                          Kai
                                          EisbaeeerE Offline
                                          EisbaeeerE Offline
                                          Eisbaeeer
                                          #1020
                                          @kai-2 Such mal nach Openepaper und kiduild.
