  4. Performance Probleme im iobroker Admin auf pi4
    5.1k
111 Beiträge 6 Kommentatoren 16.3k Aufrufe 5 Beobachtet
    @maxpd
    Zeig nochmal die Langfassung von
    iob diag
    maxpd
    #81
    @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
    @maxpd
    iob diag
    ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     10:07:32 up 12:12,  2 users,  load average: 0.37, 0.49, 0.40
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=46.2'C
    volt=0.8600V
    *** Time and Time Zones ***
                   Local time: Sun 2023-08-27 10:07:32 CEST
               Universal time: Sun 2023-08-27 08:07:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.9G        1.9G        5.7G        0.0K        324M        5.8G
    Swap:            99M          0B         99M
    Total:          8.0G        1.9G        5.8G
             7897 M total memory
             1902 M used memory
              128 M active memory
             1960 M inactive memory
             5669 M free memory
               36 M buffer memory
              288 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    lifetime oom required: 0 Mbytes
    total time in oom handler: 0 ms
    max time spent in oom handler: 0 ms
    *** FILESYSTEM ***
    /dev/root      ext4       30G   12G   17G  42% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  788K  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sat Aug 26 21:55:13 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:57:31:D7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=e52a9d10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Aug 26 21:55:15 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sat Aug 26 21:55:15 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Aug 26 21:55:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems (real ones only):
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,commit=600
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.7G    /var/
    940M    /var/log
    929M    /var/log/journal/5f09e0dc24364fc8951dcf01ea03774d
    627M    /var/lib
    Archived and active journals take up 928.2M in the file system.
    /opt/iobroker/backups:
    72M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.1G    /opt/iobroker/iobroker-data/
    1.5G    /opt/iobroker/iobroker-data/history
    317M    /opt/iobroker/iobroker-data/files
    249M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/objects.json.migrated
    15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
            100 /var/lib/dpkg/status
         12.22.12~dfsg-1~deb11u4 500
            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    MULTIHOSTSERVICE/enabled: false
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.google-sharedlocations@2.1.3 /opt/iobroker/node_modules/iobroker.google-sharedlocations
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-08-27T08_08_10_199Z-debug-0.log
    Adapters from github:   1
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.info.0                   : info                  : iobroker                                 - disabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
      system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
      system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1884
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 36669, bind: 192.168.178.30
    + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.simple-api.1             : simple-api            : iobroker                                 -  enabled, port: 8101, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
      system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
      system.adapter.synology.1               : synology              : iobroker                                 - disabled, port: 5001
      system.adapter.systeminfo.0             : systeminfo            : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.2               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : iobroker                                 - disabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
    + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
    Adapter    "denon"        : 1.15.3   , installed 1.15.0 [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.2  [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 3.1.0
    Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "history"      : 2.2.6    , installed 2.2.4  [Updatable]
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
    Adapter    "info"         : 1.9.26   , installed 1.9.26
    Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
    Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
    Controller "js-controller": 4.0.24   , installed 4.0.24
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
    Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
    Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
    Adapter    "shuttercontrol": 1.6.1   , installed 1.4.29 [Updatable]
    Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
    Adapter    "socketio"     : 4.2.0    , installed 4.2.0
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
    Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
    Adapter    "telegram"     : 1.16.0   , installed 1.15.2 [Updatable]
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.2    , installed 2.3.0  [Updatable]
    Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
    Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
    Adapter    "web"          : 4.3.0    , installed 4.3.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "ws"           : 1.3.0    , installed 1.3.0
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Adapter    "youtube"      : 4.2.1    , installed 4.1.0  [Updatable]
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
    Objects and States
    Objects:        20162
    States:         17212
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14535      824/dnsmasq
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17180      2095/io.sonoff.0
    tcp        0      0 192.168.178.30:2001     0.0.0.0:*               LISTEN      1001       17086      1916/io.hm-rpc.0
    tcp        0      0 192.168.178.30:2010     0.0.0.0:*               LISTEN      1001       20548      2351/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14867      746/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17622      746/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14514      807/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16934      1701/io.admin.0
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       21902      2749/io.web.1
    tcp6       0      0 :::8101                 :::*                    LISTEN      1001       21922      2819/io.simple-api.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14516      807/sshd: /usr/sbin
    udp        0      0 0.0.0.0:45847           0.0.0.0:*                           108        12188      373/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20609      2403/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20610      2403/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18244      2257/io.shelly.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14534      824/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14531      824/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12909      682/dhclient
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       17924      2011/io.mihome-vacu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       468231     13777/io.chromecast
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20947      2715/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12186      373/avahi-daemon: r
    udp6       0      0 :::42265                :::*                                108        12189      373/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        12187      373/avahi-daemon: r
    2023-08-27 10:09:07.446  - warn: javascript.0 (1840)     at processImmediate (node:internal/timers:476:21)
    2023-08-27 10:09:12.386  - info: mqtt.0 (2421) Reconnected to 192.168.178.106
    2023-08-27 10:09:12.394  - info: mqtt.0 (2421) send2Server mqtt.0.info.connection[info/connection]
    2023-08-27 10:09:15.515  - info: mqtt.0 (2421) Disconnected from 192.168.178.106: undefined
    2023-08-27 10:09:15.541  - info: mqtt.0 (2421) send2Server mqtt.0.info.connection[info/connection]
    2023-08-27 10:09:17.458  - warn: javascript.0 (1840) getState "chromecast.0.38:8b:59:79:d3:db.player.state" not found (3)
    2023-08-27 10:09:17.460  - warn: javascript.0 (1840)     at Object.<anonymous> (script.js.General.Moodmusik:32:9)
    2023-08-27 10:09:17.460  - warn: javascript.0 (1840)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-08-27 10:09:17.460  - warn: javascript.0 (1840)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-08-27 10:09:17.460  - warn: javascript.0 (1840)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-08-27 10:09:17.461  - warn: javascript.0 (1840)     at processImmediate (node:internal/timers:476:21)
    2023-08-27 10:09:17.461  - warn: javascript.0 (1840) State "chromecast.0.38:8b:59:79:d3:db.player.volume" not found
    2023-08-27 10:09:17.462  - warn: javascript.0 (1840)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
    2023-08-27 10:09:17.462  - warn: javascript.0 (1840)     at Object.<anonymous> (script.js.General.Moodmusik:33:7)
    2023-08-27 10:09:17.462  - warn: javascript.0 (1840)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-08-27 10:09:17.463  - warn: javascript.0 (1840)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-08-27 10:09:17.463  - warn: javascript.0 (1840)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-08-27 10:09:17.463  - warn: javascript.0 (1840)     at processImmediate (node:internal/timers:476:21)
    2023-08-27 10:09:17.463  - warn: javascript.0 (1840) State "chromecast.0.38:8b:59:79:d3:db.player.pause" not found
    2023-08-27 10:09:17.464  - warn: javascript.0 (1840)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
    2023-08-27 10:09:17.465  - warn: javascript.0 (1840)     at Object.<anonymous> (script.js.General.Moodmusik:34:7)
    2023-08-27 10:09:17.465  - warn: javascript.0 (1840)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
    2023-08-27 10:09:17.465  - warn: javascript.0 (1840)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
    2023-08-27 10:09:17.465  - warn: javascript.0 (1840)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
    2023-08-27 10:09:17.465  - warn: javascript.0 (1840)     at processImmediate (node:internal/timers:476:21)
    maxpd
    Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
      @maxpd
      Und lösch mal den npm cache.
      npm cache clean --force
      sudo -H -u iobroker npm cache clean --force
      maxpd
      #82
      pi@iobroker:~ $ npm cache clean --force
      npm WARN using --force Recommended protections disabled.
      pi@iobroker:~ $ sudo -H -u iobroker npm cache clean --force
      maxpd
        @thomas-braun ja schon, ich dachte daher eher daran, das bei ihm eventuell noch irgendwelche npm Altlasten dies verursachen
        würde es denn nicht etwas bringen, nodejs neu zu installieren?
        maxpd
        #83
        @crunchip Habt ihr hierzu eine fertige Anleitung, die ich mich runterhangeln kann? :)
        maxpd
        • M maxpd
          #84
          @maxpd
          Schaut eigentlich prima aus.
          Schalt mal den Chromecast testweise aus.
          Ich würde per
          iobroker update
          iobroker upgrade all
          die Kiste einfach mal komplett anheben. Läuft dann halt etwas, aber kann ja z.B. über die Nacht orgeln.
          • M maxpd
            #85
            @maxpd
            Alternativ kannst du auch mal die package.json löschen. Vorher Backup anlegen.
            M 2 Antworten Letzte Antwort
              @maxpd
              Ich würde per
              iobroker update
              maxpd
              #86
              @thomas-braun Der möchte allerdings bei jeden Adapter eine Ja / Nein bestätigung.
              pi@iobroker:~ $ iobroker upgrade all
              This upgrade of "tr-064" will introduce the following changes:
              -> 4.2.18:
              Prepare for future js-controller verisons
              Would you like to upgrade tr-064 from @4.2.17 to @4.2.18 now? [(y)es, (n)o]:
              maxpd
              • M maxpd
                -> 4.2.18:
                #87
                @maxpd
                iob upgrade all -y
                  @maxpd
                  maxpd
                  #88
                  @thomas-braun OK, ist gebackupped und gelöscht
                  maxpd
                    @maxpd
                    maxpd
                    schrieb am zuletzt editiert von maxpd
                    #89
                    @maxpd
                    Hat aber das zur Folge
                    pi@iobroker:~ $ iobroker update
                    node:internal/modules/cjs/loader:1080
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                        at Module._load (node:internal/modules/cjs/loader:922:27)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                        at node:internal/main/run_main_module:23:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    Node.js v18.17.1
                    pi@iobroker:~ $ iobroker upgrade all -y
                      throw err;
                      requireStack: []
                    Node.js v18.17.1
                    pi@iobroker:~ $
                    Reboot?
                    Funktioniert aber auch nicht mehr nach Reboot und nicht wenn ich die package.json nochmal reinlege und reboote. Vielleicht ein Problem mit den Rechten?
                    maxpd
                    • M maxpd
                      @maxpd
                        throw err;
                        requireStack: []
                      Node.js v18.17.1
                        throw err;
                        requireStack: []
                      Node.js v18.17.1
                      pi@iobroker:~ $
                      Reboot?
                      #90
                      @maxpd
                      Klar, die muss dem iobroker gehören.
                        @maxpd
                        maxpd
                        #91
                        @thomas-braun wie gebe ich ihm die wieder. denn über winscp hab ich nicht die rechte dazu.
                        maxpd
                        • M maxpd
                          #92
                          @maxpd
                          Deswegen macht man sowas ja auch im Terminal direkt auf der Kiste
                          Schubs den
                          iob fix
                          drüber.
                            @maxpd
                            Schubs den
                            iob fix
                            drüber.
                            maxpd
                            #93
                            pi@iobroker:~ $ iob fix
                            library: loaded
                            Library version=2022-12-09
                            ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                            maxpd
                            • M maxpd
                              library: loaded
                              #94
                              @maxpd
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                                @maxpd
                                cd /opt/iobroker
                                maxpd
                                #95
                                @thomas-braun Ich habe den js.controller wieder installiert. Habe den Fixer drüber laufen lassen. Die package.json hat wieder ihre Rechte. Die Chromecast Instanz ist deaktiviert. Wenn ich nun etwas updaten will passiert eine halbe Stunde oder länger nichts, bis ein Cannot install kommt.
                                Update text2command from @2.3.0 to @3.0.2
                                NPM version: 9.6.7
                                Installing iobroker.text2command@3.0.2... (System call)
                                host.iobroker Cannot install iobroker.text2command@3.0.2: 217
                                maxpd
                                • M maxpd
                                  NPM version: 9.6.7
                                  #96
                                  @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
                                  Dann schmeiß den zumindest temporär raus.
                                    maxpd
                                    #97
                                    @thomas-braun sieht mir nach einem generischen Problem aus. Vorher hat da der Backup Adapter gestanden. Die Anzeige lief nicht weiter, aber das Update hatte funktioniert.
                                    Nach einem Reboot habe ich dann noch einmal das Update gestartet und er hat sich den text2command geschnappt. Ich habe den text2command jetzt auch deinstalliert. Ist in der Adapterliste nicht mehr sichtbar. Aber über iobroker update wird er weiterhin angezeigt. Starte ich das Upgrade, nimmt er sich trotzdem nochmal den Adapter und versucht ihn upzudaten
                                    maxpd
                                    • M maxpd
                                      #98
                                      @maxpd
                                      Ich vermute, du hast da mal irgendwo / irgendwann / irgendwie eine zweite Installation daneben gesetzt.
                                        maxpd
                                        #99
                                        @thomas-braun also alles neu aufsetzen und hoffen dass diesmal das backup aus dem backup adapter funktioniert? das war letztes Mal nicht der Fall. Letztes Mal ist auch gar nicht so lange her, da war nämlich auch irgendwie einiges Quer. Wüsste auch nicht wie ich eine 2. installation reinbekomme :D
                                        maxpd
                                        • M maxpd
                                          #100
                                          @maxpd
                                          Dann könnte das Backup schon verfummelt sein.
