  4. Performance Probleme im iobroker Admin auf pi4
    5.1k
111 Beiträge 6 Kommentatoren 16.3k Aufrufe 5 Beobachtet
  • M maxpd
    @thomas-braun sorry, ist Zeit vergangen. Viel um die Ohren.
    Ich habe an der Stelle nochmal weiter angeknüpft, aber leider kann ich auch nopy nicht installieren.
    npm i nopy
    npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.sma-em.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.chromecast.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1337/ioBroker.doorbird.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm ERR! code 1
    npm ERR! git dep preparation failed
    npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
    npm ERR! > iobroker.esphome@0.2.4 install
    npm ERR! > npip install
    npm ERR!
    npm ERR! No python_modules directory; installing pip locally if needed.
    npm ERR! Successfully completed pip check.
    npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
    npm ERR! Collecting esphome>=2021.8
    npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2023.8.2-py2.py3-none-any.whl (2.8 MB)
    npm ERR! Collecting tornado>=3.2
    npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.3.3-cp38-abi3-linux_armv7l.whl (426 kB)
    npm ERR! Collecting voluptuous==0.13.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
    npm ERR! Collecting PyYAML==6.0.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0.1-cp39-cp39-linux_armv7l.whl (45 kB)
    npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
    npm ERR! Collecting colorama==0.4.6 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
    npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.3.2-cp38-abi3-linux_armv7l.whl (425 kB)
    npm ERR! Collecting tzlocal==5.0.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-5.0.1-py3-none-any.whl (20 kB)
    npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
    npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
    npm ERR! Collecting platformio==6.1.9 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-6.1.9-py3-none-any.whl (418 kB)
    npm ERR! Collecting esptool==4.6.2 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-4.6.2-py3-none-any.whl (338 kB)
    npm ERR! Collecting click==8.1.6 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.1.6-py3-none-any.whl (97 kB)
    npm ERR! Collecting esphome-dashboard==20230711.0 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20230711.0-py3-none-any.whl (5.6 MB)
    npm ERR! Collecting aioesphomeapi==15.0.0 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-15.0.0-py2.py3-none-any.whl (58 kB)
    npm ERR! Collecting zeroconf==0.80.0 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.80.0-cp39-cp39-manylinux_2_31_armv7l.whl (2.5 MB)
    npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
    npm ERR! Collecting pyparsing>=3.0 (from esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/pyparsing/pyparsing-3.1.1-py3-none-any.whl (103 kB)
    npm ERR! Collecting protobuf>=3.19.0 (from aioesphomeapi==15.0.0->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-4.24.1-cp39-cp39-linux_armv7l.whl (906 kB)
    npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==15.0.0->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
    npm ERR! Collecting async-timeout>=4.0 (from aioesphomeapi==15.0.0->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
    npm ERR! Collecting bitstring>=3.1.6 (from esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.1-py3-none-any.whl (56 kB)
    npm ERR! Collecting cryptography>=2.1.4 (from esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
    npm ERR!   Installing build dependencies: started
    npm ERR!   Installing build dependencies: finished with status 'done'
    npm ERR!   Getting requirements to build wheel: started
    npm ERR!   Getting requirements to build wheel: finished with status 'done'
    npm ERR!   Preparing metadata (pyproject.toml): started
    npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
    npm ERR! Collecting ecdsa>=0.16.0 (from esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
    npm ERR! Collecting reedsolo<1.8,>=1.5.3 (from esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.7.0-py3-none-any.whl (32 kB)
    npm ERR! Collecting bottle==0.12.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
    npm ERR! Collecting pyelftools==0.29 (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
    npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.9->esphome>=2021.8) (2.25.1)
    npm ERR! Collecting semantic-version==2.10.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
    npm ERR! Collecting tabulate==0.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
    npm ERR! Collecting aiofiles>=0.8.0 (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-23.2.1-py3-none-any.whl (15 kB)
    npm ERR! Collecting ajsonrpc==1.2.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
    npm ERR! Collecting marshmallow==3.19.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
    npm ERR! Collecting starlette==0.28.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.28.0-py3-none-any.whl (68 kB)
    npm ERR! Collecting uvicorn==0.22.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.22.0-py3-none-any.whl (58 kB)
    npm ERR! Collecting wsproto==1.2.* (from platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
    npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.80.0->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
    npm ERR! Collecting packaging>=17.0 (from marshmallow==3.19.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
    npm ERR! Collecting anyio<5,>=3.4.0 (from starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
    npm ERR! Collecting typing-extensions>=3.10.0 (from starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
    npm ERR! Collecting h11>=0.8 (from uvicorn==0.22.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
    npm ERR! Collecting bitarray<3.0.0,>=2.8.0 (from bitstring>=3.1.6->esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.1-cp39-cp39-linux_armv7l.whl (227 kB)
    npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp39-cp39-linux_armv7l.whl (364 kB)
    npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.6.2->esphome>=2021.8) (1.16.0)
    npm ERR! Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8) (2.10)
    npm ERR! Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
    npm ERR! Collecting exceptiongroup (from anyio<5,>=3.4.0->starlette==0.28.*->platformio==6.1.9->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
    npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==4.6.2->esphome>=2021.8)
    npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
    npm ERR! Building wheels for collected packages: cryptography
    npm ERR!   Building wheel for cryptography (pyproject.toml): started
    npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
    npm ERR! Failed to build cryptography
    npm ERR! npm WARN using --force Recommended protections disabled.
    npm ERR! npm WARN old lockfile
    npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
    npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
    npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
    npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
    npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
    npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
    npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
    npm ERR! Cache entry deserialization failed, entry ignored
    npm ERR!   error: subprocess-exited-with-error
    npm ERR!
    npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
    npm ERR!   │ exit code: 1
    npm ERR!   ╰─> [170 lines of output]
    npm ERR!       running bdist_wheel
    npm ERR!       running build
    npm ERR!       running build_py
    npm ERR!       creating build
    npm ERR!       creating build/lib.linux-armv7l-cpython-39
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/x509
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat
    npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
    npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
    npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
    npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/openssl
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/backends/openssl
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/ciphers
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/asymmetric
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/kdf
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/serialization
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/primitives/twofactor
    npm ERR!       running egg_info
    npm ERR!       writing src/cryptography.egg-info/PKG-INFO
    npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
    npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
    npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
    npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
    npm ERR!       reading manifest template 'MANIFEST.in'
    npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
    npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
    npm ERR!       no previously-included directories found matching 'docs/_build'
    npm ERR!       warning: no previously-included files found matching 'vectors'
    npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
    npm ERR!       warning: no previously-included files found matching 'src/rust/target'
    npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
    npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
    npm ERR!       warning: no previously-included files found matching 'release.py'
    npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
    npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
    npm ERR!       warning: no previously-included files found matching 'mypy.ini'
    npm ERR!       adding license file 'LICENSE'
    npm ERR!       adding license file 'LICENSE.APACHE'
    npm ERR!       adding license file 'LICENSE.BSD'
    npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
    npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-39/cryptography
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust
    npm ERR!       creating build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-39/cryptography/hazmat/bindings/_rust/openssl
    npm ERR!       running build_ext
    npm ERR!       running build_rust
    npm ERR!
    npm ERR!           =============================DEBUG ASSISTANCE=============================
    npm ERR!           If you are seeing a compilation error please try the following steps to
    npm ERR!           successfully install cryptography:
    npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
    npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
    npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
    npm ERR!              instructions for your platform.
    npm ERR!           3) Check our frequently asked questions for more information:
    npm ERR!              https://cryptography.io/en/latest/faq/
    npm ERR!           4) Ensure you have a recent Rust toolchain installed:
    npm ERR!              https://cryptography.io/en/latest/installation/#rust
    npm ERR!
    npm ERR!           Python: 3.9.2
    npm ERR!           platform: Linux-6.1.21-v7l+-armv7l-with-glibc2.31
    npm ERR!           pip: n/a
    npm ERR!           setuptools: 68.1.2
    npm ERR!           setuptools_rust: 1.7.0
    npm ERR!           rustc: n/a
    npm ERR!
    npm ERR!       error: can't find Rust compiler
    npm ERR!
    npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
    npm ERR!
    npm ERR!       To update pip, run:
    npm ERR!
    npm ERR!           pip install --upgrade pip
    npm ERR!
    npm ERR!       and then retry package installation.
    npm ERR!
    npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
    npm ERR!
    npm ERR!       This package requires Rust >=1.56.0.
    npm ERR!       [end of output]
    npm ERR!
    npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
    npm ERR!   ERROR: Failed building wheel for cryptography
    npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
    npm ERR! npm ERR! code 1
    npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clone7oQ0I7
    npm ERR! npm ERR! command failed
    npm ERR! npm ERR! command sh -c npip install
    npm ERR!
    npm ERR! npm ERR! A complete log of this run can be found in:
    npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-24T18_39_23_609Z-debug-0.log
    npm ERR!     /home/iobroker/.npm/_logs/2023-08-24T18_35_44_775Z-debug-0.log
    Es lassen sich auch keine Adapter Updates mehr über das iobroker interface installieren.
    $ iobroker upgrade backitup@2.6.23 --debug
    Update backitup from @2.6.19 to @2.6.23
    host.iobroker Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 9.5.1Installing iobroker.backitup@2.6.23... (System call)
    npm ERR! code 1
    npm ERR! /home/iobroker/.npm/_logs/2023-08-24T18_29_21_549Z-debug-0.log
    upload [21] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.iobroker Adapter "system.adapter.backitup.0" is started
    Process exited with code 0
    Ich deinstalliere nun das vermeintliche Problemkind ESP Home Adapter. Dauer 9 Minuten. Gefühlt noch immer Performance Probleme, trotz neuem Netzteil mit mehr Power und externer HDD an separatem Hub.
    Nach der Deinstallation erneut versucht den Backup Adapter zu aktualisieren.
    Wirft leider weiterhin gleiche Fehlermeldungen.
    crunchipC Abwesend
    crunchipC Abwesend
    #41
    @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
    sind das 2 Adapter direkt von git?
    • M maxpd
      npm i nopy
      npm ERR! code 1
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!           pip: n/a
      npm ERR!           rustc: n/a
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR!
      npm ERR! code 1
      #42
      @maxpd
      Ich weiß, das hilft dir nicht, aber hier läuft das 1A durch:
      echad@chet:/opt/iobroker $ iob add esphome
      NPM version: 9.6.7
      Installing iobroker.esphome@0.2.4... (System call)
      added 96 packages in 3m
      106 packages are looking for funding
        run `npm fund` for details
      host.chet install adapter esphome
      upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
      upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/esphome.png esphome.png image/png
      upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
      upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
      upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
      upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
      host.chet object system.adapter.esphome created/updated
      host.chet create instance esphome
      host.chet object system.adapter.esphome.0.alive created
      host.chet object system.adapter.esphome.0.connected created
      host.chet object system.adapter.esphome.0.compactMode created
      host.chet object system.adapter.esphome.0.cpu created
      host.chet object system.adapter.esphome.0.cputime created
      host.chet object system.adapter.esphome.0.memHeapUsed created
      host.chet object system.adapter.esphome.0.memHeapTotal created
      host.chet object system.adapter.esphome.0.memRss created
      host.chet object system.adapter.esphome.0.uptime created
      host.chet object system.adapter.esphome.0.inputCount created
      host.chet object system.adapter.esphome.0.outputCount created
      host.chet object system.adapter.esphome.0.eventLoopLag created
      host.chet object system.adapter.esphome.0.sigKill created
      host.chet object system.adapter.esphome.0.logLevel created
      host.chet object esphome.0.info created
      host.chet object esphome.0.info.connection created
      host.chet Set default value of esphome.0.info.connection: false
      host.chet object system.adapter.esphome.0 created
        Update ist keine 2 Monate her. Gibts da eine Auto Update Funktion?
        Nein, wozu auch?
        Das will ja niemand. Du musst schon sehen was da alles aktualisiert wird. Man will ja keinen Blindflug bei nachträglichem komischen Verhalten des Systems. Daher die Updates in übersichtlichen Häppchen einspielen.
        T Nicht stören
        T Nicht stören
        ticaki
        #43
        @thomas-braun sagte in Performance Probleme im iobroker Admin auf pi4:
        Nein, wozu auch?
        Es gibt unattended-upgrades für Container ganz nützlich, würde ich aber nicht auf dem iobroker hauptsystem verwenden.
        Spenden
        • T ticaki
          Nein, wozu auch?
          #44
          @ticaki
          Ich weiß das es sowas gibt. Nur setzt man sowas tunlichst nicht ein, wenn man eingermaßen wissen will, was da neu installiert oder aktualisiert wird. Gut, gibt natürlich logs für alles, aber dennoch...
          • M maxpd
            npm i nopy
            npm ERR! code 1
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!           pip: n/a
            npm ERR!           rustc: n/a
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR!
            npm ERR! code 1
            #45
            @maxpd
            Du hast da wohl auch mehrere BAUstellen offen, wenn ich das richtig sehe.
            cd /opt/iobroker && npm ls
            schaut wie aus?
              maxpd
              schrieb am zuletzt editiert von maxpd
              #46
              @crunchip Ja, da gibt es noch mehrere, weil es sie über npm nicht gibt oder damals nicht gab. Da sieht man welche:
              @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
              @maxpd
              schaut wie aus?
              pi@iobroker:~ $ cd /opt/iobroker && npm ls
              npm ERR! code ELSPROBLEMS
              npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/ca        seless
              npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/req        uest
              npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types        /tough-cookie
              npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
              npm ERR! invalid: iobroker.backitup@2.6.23 /opt/iobroker/node_modules/iobroker.b        ackitup
              npm ERR! invalid: iobroker.chromecast@3.0.3 /opt/iobroker/node_modules/iobroker.        chromecast
              npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.do        orbird
              npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modul        es/iobroker.google-sharedlocations
              npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
              npm ERR! invalid: iobroker.sma-em@0.6.4 /opt/iobroker/node_modules/iobroker.sma-        em
              npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobrok        er.sma-speedwire
              npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
              npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
              npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
              npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
              npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
              iobroker.inst@2.0.3 /opt/iobroker
              ├── @types/caseless@0.12.2 extraneous
              ├── @types/request@2.48.8 extraneous
              ├── @types/tough-cookie@4.0.2 extraneous
              ├── coffeescript@1.12.7 extraneous
              ├── colors@1.4.0
              ├── fs-extra@7.0.1
              ├── iobroker.admin@6.3.5
              ├── iobroker.alias-manager@1.2.6
              ├── iobroker.backitup@2.6.23 invalid: "2.6.19" from the root project
              ├── iobroker.chromecast@3.0.3 invalid: "github:iobroker-community-adapters/ioBro        ker.chromecast#426f5814382158fd28b785badf08773ea412dcb5" from the root project
              ├── iobroker.cloud@4.3.0
              ├── iobroker.coronavirus-statistics@0.8.7
              ├── iobroker.daswetter@3.1.8
              ├── iobroker.denon@1.15.0
              ├── iobroker.devices@1.1.2
              ├── iobroker.discovery@3.1.0
              ├── iobroker.doorbird@0.1.5 invalid: "github:BuZZy1337/ioBroker.doorbird#47440dd        ff9a9074ef1e0beb8ff7b7f2a6e368efb" from the root project
              ├── iobroker.feiertage@1.1.0
              ├── iobroker.flot@1.11.0
              ├── iobroker.go-e@1.0.27
              ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.goo        gle-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root proj        ect
              ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87        ac2f88f9d832a6d632c4889606" from the root project
              ├── iobroker.history@2.2.4
              ├── iobroker.hm-rega@3.0.46
              ├── iobroker.hm-rpc@1.15.16
              ├── iobroker.ical@1.13.2
              ├── iobroker.info@1.9.26
              ├── iobroker.iot@1.14.2
              ├── iobroker.javascript@6.1.4
              ├── iobroker.js-controller@4.0.24
              ├── iobroker.lgtv@1.1.12
              ├── iobroker.lovelace@3.0.1
              ├── iobroker.mihome-vacuum@3.9.5
              ├── iobroker.modbus@5.0.11
              ├── iobroker.mqtt-client@1.6.3
              ├── iobroker.mqtt@4.0.7
              ├── iobroker.net-tools@0.2.0
              ├── iobroker.pi-hole@1.3.4
              ├── iobroker.ping@1.5.3
              ├── iobroker.rpi2@1.3.2
              ├── iobroker.sayit@1.13.0
              ├── iobroker.shelly@6.3.1
              ├── iobroker.shuttercontrol@1.4.29
              ├── iobroker.simple-api@2.7.2
              ├── iobroker.sma-em@0.6.4 invalid: "github:iobroker-community-adapters/ioBroker.        sma-em#4b2a4a1f3736ca56d1dae532e47219647609799f" from the root project
              ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker        .sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root p        roject
              ├── iobroker.socketio@4.2.0
              ├── iobroker.sonoff@2.5.1
              ├── iobroker.spotify-premium@1.2.1
              ├── iobroker.sunnyportal@0.1.5
              ├── iobroker.synology@2.1.13
              ├── iobroker.systeminfo@0.3.1
              ├── iobroker.telegram@1.15.2
              ├── iobroker.terminal@1.0.0
              ├── iobroker.text2command@2.3.0
              ├── iobroker.tr-064@4.2.17
              ├── iobroker.tuya@3.13.1
              ├── iobroker.web@4.3.0
              ├── iobroker.whatsapp-cmb@0.2.3
              ├── iobroker.wifilight@1.1.4
              ├── iobroker.wled@0.6.7
              ├── iobroker.yeelight-2@1.2.1
              ├── iobroker.youtube@4.1.0
              ├── iobroker.zigbee@1.8.10
              ├── jsonata@1.8.6 extraneous
              ├── node-inspect@2.0.0 extraneous
              ├── semver@5.7.2
              ├── typescript@4.7.4 extraneous
              ├── virtual-tsc@0.6.2 extraneous
              ├── wake_on_lan@1.0.0 extraneous
              └── yargs@7.1.2
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2        023-08-25T03_43_11_993Z-debug-0.log
              Ich habe angefangen die Adapter manuell zu deinstallieren, läuft aber auf Fehler, auch wenn manche aus der Adapterliste fliegen.
              $ iobroker del doorbird --debug
              Delete adapter "doorbird"
              host.iobroker Counted 1 instances of doorbird
              host.iobroker Counted 1 meta of doorbird
              host.iobroker Counted 1 adapter for doorbird
              host.iobroker Counted 1 channels of doorbird
              host.iobroker Counted 14 states of system.adapter.doorbird
              host.iobroker Counted 9 states (io.doorbird.*) from states
              host.iobroker Counted 15 states (system.adapter.doorbird.*) from states
              host.iobroker object doorbird.admin deletedhost.iobroker Deleting 28 object(s).
              host.iobroker Deleting 24 state(s).
              Error deleting adapter doorbird from disk: host.iobroker: Cannot uninstall iobroker.doorbird: 217
              You might have to delete it yourself!
              sieht danach weiterhin gleich aus
              ich hangel mich hier mal noch durch: https://forum.iobroker.net/topic/25900/adapter-manuell-deinstallieren-gelöst/3
              maxpd
              Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
              • M maxpd
                @maxpd
                schaut wie aus?
                ├── colors@1.4.0
                ├── fs-extra@7.0.1
                ├── semver@5.7.2
                └── yargs@7.1.2
                crunchipC Abwesend
                crunchipC Abwesend
                #47
                @maxpd für doch nochmal aus
                cd /opt/iobroker
                npm prune
                läuft das Fehlerfrei durch?
                  maxpd
                  #48
                  @crunchip said in Performance Probleme im iobroker Admin auf pi4:
                  cd /opt/iobroker
                  Also, nach dem manuellen deinstallieren der Adapter sieht es jetzt so aus:
                  npm ERR! extraneous: @leichtgewicht/ip-codec@2.0.4 /opt/iobroker/node_modules/@leichtgewicht/ip-codec
                  npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                  npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                  npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                  npm ERR! extraneous: array-find@1.0.0 /opt/iobroker/node_modules/array-find
                  npm ERR! extraneous: castv2-player@2.1.3 /opt/iobroker/node_modules/castv2-player
                  npm ERR! extraneous: dev-null@0.1.1 /opt/iobroker/node_modules/dev-null
                  npm ERR! extraneous: icy@2.1.0 /opt/iobroker/node_modules/icy
                  npm ERR! invalid: iobroker.backitup@2.6.23 /opt/iobroker/node_modules/iobroker.backitup
                  npm ERR! missing: iobroker.chromecast@github:iobroker-community-adapters/ioBroker.chromecast#426f5814382158fd28b785badf08773ea412dcb5, required by iobroker.inst@2.0.3
                  npm ERR! missing: iobroker.doorbird@github:BuZZy1337/ioBroker.doorbird#47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb, required by iobroker.inst@2.0.3
                  npm ERR! missing: iobroker.google-sharedlocations@github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69, required by iobroker.inst@2.0.3
                  npm ERR! missing: iobroker.govee@github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606, required by iobroker.inst@2.0.3
                  npm ERR! missing: iobroker.sma-em@github:iobroker-community-adapters/ioBroker.sma-em#4b2a4a1f3736ca56d1dae532e47219647609799f, required by iobroker.inst@2.0.3
                  npm ERR! missing: iobroker.sma-speedwire@https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4, required by iobroker.inst@2.0.3
                  npm ERR! extraneous: multicast-dns@7.2.5 /opt/iobroker/node_modules/multicast-dns
                  npm ERR! extraneous: playlist-parser@0.0.12 /opt/iobroker/node_modules/playlist-parser
                  npm ERR! extraneous: siginfo@2.0.0 /opt/iobroker/node_modules/siginfo
                  npm ERR! extraneous: stackback@0.0.2 /opt/iobroker/node_modules/stackback
                  npm ERR! extraneous: stream-parser@0.3.1 /opt/iobroker/node_modules/stream-parser
                  npm ERR! extraneous: why-is-node-running@2.2.2 /opt/iobroker/node_modules/why-is-node-running
                  npm ERR! extraneous: xmldom@0.1.16 /opt/iobroker/node_modules/xmldom
                  ├── @leichtgewicht/ip-codec@2.0.4 extraneous
                  ├── array-find@1.0.0 extraneous
                  ├── castv2-player@2.1.3 extraneous
                  ├── colors@1.4.0
                  ├── dev-null@0.1.1 extraneous
                  ├── fs-extra@7.0.1
                  ├── icy@2.1.0 extraneous
                  ├── UNMET DEPENDENCY iobroker.chromecast@github:iobroker-community-adapters/ioBroker.chromecast#426f5814382158fd28b785badf08773ea412dcb5
                  ├── UNMET DEPENDENCY iobroker.doorbird@github:BuZZy1337/ioBroker.doorbird#47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb
                  ├── UNMET DEPENDENCY iobroker.google-sharedlocations@github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69
                  ├── UNMET DEPENDENCY iobroker.govee@github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606
                  ├── UNMET DEPENDENCY iobroker.sma-em@github:iobroker-community-adapters/ioBroker.sma-em#4b2a4a1f3736ca56d1dae532e47219647609799f
                  ├── UNMET DEPENDENCY iobroker.sma-speedwire@https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4
                  ├── multicast-dns@7.2.5 extraneous
                  ├── playlist-parser@0.0.12 extraneous
                  ├── semver@5.7.2
                  ├── siginfo@2.0.0 extraneous
                  ├── stackback@0.0.2 extraneous
                  ├── stream-parser@0.3.1 extraneous
                  ├── why-is-node-running@2.2.2 extraneous
                  ├── xmldom@0.1.16 extraneous
                  └── yargs@7.1.2
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-25T04_29_44_936Z-debug-0.log
                  cd /opt/iobroker
                  npm prune
                  pi@iobroker:/opt/iobroker $ npm prune
                  npm ERR! code ENOTEMPTY
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/acorn
                  npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-25T04_31_32_521Z-debug-0.log
                  maxpd
                  • M maxpd
                    cd /opt/iobroker
                    ├── colors@1.4.0
                    ├── fs-extra@7.0.1
                    ├── semver@5.7.2
                    └── yargs@7.1.2
                    cd /opt/iobroker
                    npm prune
                    npm ERR! errno -39
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #49
                    @maxpd dann jetzt
                    iob fix
                    und anschließend nochmal npm prune
                      @maxpd dann jetzt
                      iob fix
                      maxpd
                      #50
                      @crunchip habe ich durchlaufen lassen.
                      sieht leider noch immer genauso aus.
                      Ein wiederholen von
                      cd /opt/iobroker
                      npm prune
                      wirft nun
                      npm ERR! path /opt/iobroker/node_modules/arraybuffer.prototype.slice
                      npm ERR! dest /opt/iobroker/node_modules/.arraybuffer.prototype.slice-SVsUv6QN
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/arraybuffer.prototype.slice' -> '/opt/iobroker/node_modules/.arraybuffer.prototype.slice-SVsUv6QN'
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-25T04_52_45_628Z-debug-0.log
                      maxpd
                      • M maxpd
                        Ein wiederholen von
                        cd /opt/iobroker
                        npm prune
                        wirft nun
                        npm ERR! errno -39
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #51
                        @maxpd probier es mal mit
                        find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                        wie sieht es dann danach aus?
                          maxpd
                          #52
                          @crunchip
                          pi@iobroker:~ $ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" !        -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
                          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You m                            ay safely remove the package from your dependencies.
                          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the on                            e that's built-in.
                          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://g                            ithub.com/request/request/issues/3142
                          npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babe                            l maintainers
                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/requ                            est/request/issues/3142
                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recom                            mended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be prob                            lematic.  See https://v8.dev/blog/math-random for details.
                          removed 861 packages, and changed 1482 packages in 7m
                          141 packages are looking for funding
                          Ich glaube die gelöschten Adapter hat er wieder Installiert 🍡
                          pi@iobroker:/opt/iobroker $ cd /opt/iobroker && npm ls
                          npm ERR! invalid: iobroker.chromecast@3.0.3 /opt/iobroker/node_modules/iobroker.chromecast
                          npm ERR! invalid: iobroker.doorbird@0.1.5 /opt/iobroker/node_modules/iobroker.doorbird
                          npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                          npm ERR! invalid: iobroker.sma-em@0.6.4 /opt/iobroker/node_modules/iobroker.sma-em
                          npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── iobroker.backitup@2.6.19
                          ├── iobroker.chromecast@3.0.3 invalid: "github:iobroker-community-adapters/ioBroker.chromecast#426f5814382158fd28b785badf08773ea412dcb5" from the root project
                          ├── iobroker.doorbird@0.1.5 invalid: "github:BuZZy1337/ioBroker.doorbird#47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb" from the root project
                          ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root project
                          ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
                          ├── iobroker.sma-em@0.6.4 invalid: "github:iobroker-community-adapters/ioBroker.sma-em#4b2a4a1f3736ca56d1dae532e47219647609799f" from the root project
                          ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root project
                          ├── semver@5.7.2
                          └── yargs@7.1.2
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-25T13_13_20_856Z-debug-0.log
                          maxpd
                          • M maxpd
                            @crunchip
                            ├── colors@1.4.0
                            ├── fs-extra@7.0.1
                            ├── semver@5.7.2
                            └── yargs@7.1.2
                            #53
                            chromecast
                            Installier den z. B. nochmal drüber.
                            Bzw. installier den aus dem stable-Repository.
                            Gleiches gilt für die anderen mit 'invalid' markierten Adapter.
                            chromecast
                            github:	3.1.0 for 9 days
                            latest:	3.0.3 for 12 months
                            stable:	3.0.3 for 12 months
                            doorbird
                            github:	1.2.3
                            latest:	1.2.3 for 7 days
                            stable:	1.2.3 for 7 days
                            sma-em
                            github:	1.0.0
                            latest:	1.0.0 for 6 days
                            stable:	0.7.0 for 5 months
                            • M maxpd
                              @crunchip
                              ├── colors@1.4.0
                              ├── fs-extra@7.0.1
                              ├── semver@5.7.2
                              └── yargs@7.1.2
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #54
                              sollst ja auch nicht unbedingt löschen, nur zusehen, das diese per iobroker installiert sind und keine git versionen aufweisen
                              ursprüngliche Problem war ja, der esphome Adapter, der kein update/installieren zugelassen hat
                                maxpd
                                #55
                                Die installation klappt leider weiterhin nicht.
                                $ iobroker url iobroker.chromecast --host iobroker --debug
                                install iobroker.chromecast
                                NPM version: 9.6.7
                                Installing iobroker.chromecast... (System call)
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.chromecast/admin" was not found! Nothing was uploaded or deleted.
                                Habe auch nicht mitbekommen, an welcher Stelle wir ESP Home wegbekamen. Hatte den genauso gelöscht wie die anderen Adapter, die jetzt wieder da sind.
                                maxpd
                                • M maxpd
                                  NPM version: 9.6.7
                                  #56
                                  Das ist ja auch nicht der Befehl dafür.
                                  Was machst du da bei den Installationen?
                                    maxpd
                                    #57
                                    @thomas-braun sorry, übers interface installieren :(
                                    maxpd
                                    • M maxpd
                                      #58
                                      @maxpd
                                      Versuch es z. B. damit in der Kommandozeile:
                                      iobroker upgrade chromecast@3.0.3
                                        @maxpd
                                        maxpd
                                        #59
                                        @thomas-braun Habe mich an einen Beitrag weiter vorne erinnert und es für den Adapter nun auch so probiert ja. Für den SMA Adapter hat es übers Interface funktioniert. Für Chromecast nun auch über die Konsole. Aber 8 Min egal über welche Variante kommt mir seeehr lang vor, wobei wir wieder beim ursprünglichen Performance Problem sind ^^
                                        pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
                                        Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
                                        Update chromecast from @3.0.3 to @3.0.3
                                        NPM version: 9.6.7
                                        Installing iobroker.chromecast@3.0.3... (System call)
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
                                        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
                                        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
                                        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
                                        npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
                                        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
                                        npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
                                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
                                        npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
                                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
                                        npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
                                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                                        npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
                                        removed 861 packages, and changed 1482 packages in 8m
                                        upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                        upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                        upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                        upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                        maxpd
                                        • M maxpd
                                          NPM version: 9.6.7
                                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                          #60
                                          Dein Setup ist ja vermutlich noch nicht wieder senkrecht.
