  4. Performance Probleme im iobroker Admin auf pi4
    5.1k
111 Beiträge 6 Kommentatoren 16.3k Aufrufe 5 Beobachtet
  • M maxpd
    @thomas-braun Habe mich an einen Beitrag weiter vorne erinnert und es für den Adapter nun auch so probiert ja. Für den SMA Adapter hat es übers Interface funktioniert. Für Chromecast nun auch über die Konsole. Aber 8 Min egal über welche Variante kommt mir seeehr lang vor, wobei wir wieder beim ursprünglichen Performance Problem sind ^^
    pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
    Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
    Update chromecast from @3.0.3 to @3.0.3
    NPM version: 9.6.7
    Installing iobroker.chromecast@3.0.3... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and        does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.        new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in        0.5.0
    removed 861 packages, and changed 1482 packages in 8m
    141 packages are looking for funding
      run `npm fund` for details
    upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
    upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
    upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
    upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
    #61
    @maxpd
    Wo stehen wir denn nun?
    cd /opt/iobroker && npm ls
    und
    iob update
    sagt?
      @maxpd
      und
      iob update
      sagt?
      maxpd
      #62
      Ich bin noch beim Austausch der Adapter, habe aber Probleme mit npm.
      pi@iobroker:~ $ cd /opt/iobroker && npm ls
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
      npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
      npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
      npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      iobroker.inst@2.0.3 /opt/iobroker
      ├── @types/caseless@0.12.2 extraneous
      ├── @types/request@2.48.8 extraneous
      ├── @types/tough-cookie@4.0.2 extraneous
      ├── coffeescript@1.12.7 extraneous
      ├── colors@1.4.0
      ├── fs-extra@7.0.1
      ├── iobroker.admin@6.3.5
      ├── iobroker.alias-manager@1.2.6
      ├── iobroker.backitup@2.6.19
      ├── iobroker.chromecast@3.0.3
      ├── iobroker.cloud@4.3.0
      ├── iobroker.coronavirus-statistics@0.8.7
      ├── iobroker.daswetter@3.1.8
      ├── iobroker.denon@1.15.0
      ├── iobroker.devices@1.1.2
      ├── iobroker.discovery@3.1.0
      ├── iobroker.doorbird@1.2.3
      ├── iobroker.feiertage@1.1.0
      ├── iobroker.flot@1.11.0
      ├── iobroker.go-e@1.0.27
      ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root project
      ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
      ├── iobroker.history@2.2.4
      ├── iobroker.hm-rega@3.0.46
      ├── iobroker.hm-rpc@1.15.16
      ├── iobroker.ical@1.13.2
      ├── iobroker.info@1.9.26
      ├── iobroker.iot@1.14.2
      ├── iobroker.javascript@6.1.4
      ├── iobroker.js-controller@4.0.24
      ├── iobroker.lgtv@1.1.12
      ├── iobroker.lovelace@3.0.1
      ├── iobroker.mihome-vacuum@3.9.5
      ├── iobroker.modbus@5.0.11
      ├── iobroker.mqtt-client@1.6.3
      ├── iobroker.mqtt@4.0.7
      ├── iobroker.net-tools@0.2.0
      ├── iobroker.pi-hole@1.3.4
      ├── iobroker.ping@1.5.3
      ├── iobroker.rpi2@1.3.2
      ├── iobroker.sayit@1.13.0
      ├── iobroker.shelly@6.3.1
      ├── iobroker.shuttercontrol@1.4.29
      ├── iobroker.simple-api@2.7.2
      ├── iobroker.sma-em@0.7.0
      ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root project
      ├── iobroker.socketio@4.2.0
      ├── iobroker.sonoff@2.5.1
      ├── iobroker.spotify-premium@1.2.1
      ├── iobroker.sunnyportal@0.1.5
      ├── iobroker.synology@2.1.13
      ├── iobroker.systeminfo@0.3.1
      ├── iobroker.telegram@1.15.2
      ├── iobroker.terminal@1.0.0
      ├── iobroker.text2command@2.3.0
      ├── iobroker.tr-064@4.2.17
      ├── iobroker.tuya@3.13.1
      ├── iobroker.web@4.3.0
      ├── iobroker.whatsapp-cmb@0.2.3
      ├── iobroker.wifilight@1.1.4
      ├── iobroker.wled@0.6.7
      ├── iobroker.yeelight-2@1.2.1
      ├── iobroker.youtube@4.1.0
      ├── iobroker.zigbee@1.8.10
      ├── jsonata@1.8.6 extraneous
      ├── node-inspect@2.0.0 extraneous
      ├── semver@5.7.2
      ├── typescript@4.7.4 extraneous
      ├── virtual-tsc@0.6.2 extraneous
      ├── wake_on_lan@1.0.0 extraneous
      └── yargs@7.1.2
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T04_51_22_964Z-debug-0.log
      pi@iobroker:/opt/iobroker $ iobroker upgrade sma-speedwire@0.7.0 --debug
      Adapter "sma-speedwire" is not in the repository and cannot be updated.
      Cannot upgrade: Cannot read properties of undefined (reading 'controller')
      pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@2.1.5 --debug
      Adapter "google-sharedlocations" is not in the repository and cannot be updated.
      pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@1.5.2 --debu        g
      z.B. der sharedlocations Adapter. Dieser ist bei npm in einer 5 Jahre alten Version. Seit dem hat sich sehr viel bei dem Adapter getan. Aber auch die 5 Jahre alte Version findet er nicht.
      Den sma-speedwire kann man auch löschen, wird nicht benötigt.
      maxpd
      Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
      • M maxpd
        ├── colors@1.4.0
        ├── fs-extra@7.0.1
        ├── semver@5.7.2
        └── yargs@7.1.2
        #63
        @maxpd
        Dann schmeiß das raus, was nicht benötigt wird.
        Den Rest in aktueller Version drüber installieren.
          @maxpd
          maxpd
          #64
          @thomas-braun bevor ich es wieder falsch mache. wie installiere ich den Google shared locations über npm? dort wird der nicht gefunden.
          und wie installiere ich die aktuelle Version drüber, wenn auf npm nur die 5 Jahre alte liegt?
          maxpd
          • M maxpd
            #65
            @maxpd
            Keine Ahnung. Hab den selber nicht im Einsatz. Wo haste den denn her?
            Der?
            https://github.com/t4qjXH8N/ioBroker.google-sharedlocations
            Dann installier den nochmal frisch aus GitHub
              @maxpd
              Der?
              maxpd
              #66
              @thomas-braun genau den. aber ich habe es jetzt so verstanden, dass man nichts aus GitHub installieren darf, da offensichtlich 😂 das System kaputt geht.
              maxpd
              • M maxpd
                #67
                @maxpd
                Man vermeidet es und hat nur so wenig wie möglich aus GitHub geangeltes im System.
                Aber wenn es nicht anders geht...
                  @maxpd
                  maxpd
                  #68
                  @thomas-braun warum bringen die Entwickler ihre Adapter nicht zu npm? oder halten sie dort aktuell?
                  maxpd
                  • M maxpd
                    #69
                    @maxpd
                    Das musst du dort fragen. Der Adapter sieht auch etwas verwaist aus.
                    Gilt auch für den govee.
                    Schau mal ob der nicht durch govee-app oder govee-local ersetzt werden kann.
                      maxpd
                      #70
                      @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
                      @maxpd
                      und
                      iob update
                      sagt?
                      npm ERR! invalid: iobroker.google-sharedlocations@2.1.3 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                      ├── colors@1.4.0
                      ├── fs-extra@7.0.1
                      ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations" from the root project
                      ├── semver@5.7.2
                      └── yargs@7.1.2
                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T19_59_46_695Z-debug-0.log
                      pi@iobroker:/opt/iobroker $ iob update
                      Used repository: stable
                      Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                      Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                      Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
                      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                      Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
                      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                      Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
                      Adapter    "denon"        : 1.15.3   , installed 1.15.0 [Updatable]
                      Adapter    "devices"      : 1.1.5    , installed 1.1.2  [Updatable]
                      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                      Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                      Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                      Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                      Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                      Adapter    "info"         : 1.9.26   , installed 1.9.26
                      Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
                      Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
                      Controller "js-controller": 4.0.24   , installed 4.0.24
                      Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
                      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                      Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
                      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                      Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
                      Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
                      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                      Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                      Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
                      Adapter    "shuttercontrol": 1.6.1   , installed 1.4.29 [Updatable]
                      Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
                      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
                      Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
                      Adapter    "synology"     : 2.1.13   , installed 2.1.13
                      Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
                      Adapter    "telegram"     : 1.16.0   , installed 1.15.2 [Updatable]
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "text2command" : 3.0.2    , installed 2.3.0  [Updatable]
                      Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
                      Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
                      Adapter    "web"          : 4.3.0    , installed 4.3.0
                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                      Adapter    "wled"         : 0.6.7    , installed 0.6.7
                      Adapter    "ws"           : 1.3.0    , installed 1.3.0
                      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                      Adapter    "youtube"      : 4.2.1    , installed 4.1.0  [Updatable]
                      Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
                      Die einzelnen Adapter habe ich noch nicht geupdated, da jeder 8 Minuten benötigt und es wohl woanders noch klemmt.
                      maxpd
                      • M maxpd
                        @maxpd
                        und
                        iob update
                        sagt?
                        ├── colors@1.4.0
                        ├── fs-extra@7.0.1
                        ├── semver@5.7.2
                        └── yargs@7.1.2
                        #71
                        @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
                        Nochmal installieren.
                        iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                          maxpd
                          #72
                          @thomas-braun Ich hatte es wieder über das Admin Interface gemacht und hatte den Adapter auch zuvor komplett gelöscht. Jetzt habe ich es über deinen Befehl gemacht. Das Ergebnis ist aber das gleiche.
                          pi@iobroker:/opt/iobroker $ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                          install t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1
                          NPM version: 9.6.7
                          Installing t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1... (System call)
                          npm WARN skipping integrity check for git dependency ssh://git@github.com/t4qjXH8N/ioBroker.google-sharedlocations.git
                          npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                          npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                          npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                          npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                          npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                          npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
                          npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                          npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                          npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                          npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                          npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                          removed 863 packages, and changed 1482 packages in 8m
                          upload [3] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-cookie.JPG google-cookie.JPG image/jpeg
                          upload [2] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-sharedlocations.png google-sharedlocations.png image/png
                          upload [1] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/index_m.html index_m.html text/html
                          upload [0] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/words.js words.js application/javascript
                          pi@iobroker:/opt/iobroker $ ^C
                          pi@iobroker:/opt/iobroker $ cd /opt/iobroker && npm ls
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── iobroker.backitup@2.6.23
                          ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1" from the root project
                          ├── semver@5.7.2
                          └── yargs@7.1.2
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T20_42_24_072Z-debug-0.log
                          maxpd
                          Thomas BraunT 3 Antworten Letzte Antwort
                          • M maxpd
                            NPM version: 9.6.7
                            ├── colors@1.4.0
                            ├── fs-extra@7.0.1
                            ├── semver@5.7.2
                            └── yargs@7.1.2
                            #73
                            @maxpd
                            Keine Ahnung warum das bei dir nicht sauber läuft.
                            Der ist hier in 7 Sekunden sauber installiert.
                            echad@chet:/opt/iobroker $  iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --host chet --debug
                            NPM version: 9.6.7
                            added 2 packages in 7s
                            96 packages are looking for funding
                            • M maxpd
                              NPM version: 9.6.7
                              ├── colors@1.4.0
                              ├── fs-extra@7.0.1
                              ├── semver@5.7.2
                              └── yargs@7.1.2
                              #74
                              @maxpd
                              Zeig nochmal die Langfassung von
                              iob diag
                              • M maxpd
                                NPM version: 9.6.7
                                ├── colors@1.4.0
                                ├── fs-extra@7.0.1
                                ├── semver@5.7.2
                                └── yargs@7.1.2
                                #75
                                @maxpd
                                Und lösch mal den npm cache.
                                npm cache clean --force
                                sudo -H -u iobroker npm cache clean --force
                                  ticaki
                                  #76
                                  @thomas-braun sagte in Performance Probleme im iobroker Admin auf pi4:
                                  tim@iobroker:~$ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                  NPM version: 9.6.7
                                  added 3 packages in 6s
                                  158 packages are looking for funding
                                  ups wollte nur bestätigen ist aber schon ne stunde her :)
                                  Spenden
                                    @maxpd
                                    NPM version: 9.6.7
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #77
                                    war das nicht früher mal aus einer bestimmten Konstellation mit nodejs und npm, das es so lange gedauert hat.
                                      #78
                                      @crunchip
                                      Ja, aber das war ein npm@6, wenn ich mich recht erinnere. Das wird was anderes sein. Ich vermute eine nicht abgeschlossener Kompilierung.
                                        @crunchip
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #79
                                        @thomas-braun ja schon, ich dachte daher eher daran, das bei ihm eventuell noch irgendwelche npm Altlasten dies verursachen
                                        würde es denn nicht etwas bringen, nodejs neu zu installieren?
                                        Thomas BraunT M 2 Antworten Letzte Antwort
                                          #80
                                          @crunchip
                                          Möglich. Aber er meldet sich ja immer nur so sporadisch zurück.
