  4. Performance Probleme im iobroker Admin auf pi4
    5.1k
111 Beiträge 6 Kommentatoren 16.3k Aufrufe 5 Beobachtet
  • M maxpd
    @thomas-braun Habe mich an einen Beitrag weiter vorne erinnert und es für den Adapter nun auch so probiert ja. Für den SMA Adapter hat es übers Interface funktioniert. Für Chromecast nun auch über die Konsole. Aber 8 Min egal über welche Variante kommt mir seeehr lang vor, wobei wir wieder beim ursprünglichen Performance Problem sind ^^
    pi@iobroker:~ $ iobroker upgrade chromecast@3.0.3 --debug
    Would you like to reinstall version 3.0.3 of chromecast now? [(y)es, (n)o]: y
    Update chromecast from @3.0.3 to @3.0.3
    NPM version: 9.6.7
    Installing iobroker.chromecast@3.0.3... (System call)
    npm WARN skipping integrity check for git dependency ssh://git@github.com/nbueng        er/ioBroker.govee.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/Garfon        so/ioBroker.google-sharedlocations.git
    npm WARN skipping integrity check for git dependency ssh://git@github.com/BuZZy1        337/ioBroker.doorbird.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reason        s. As it's a core Node module, we will not transfer it over to other users. You        may safely remove the package from your dependencies.
    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now        a built-in Node module. If you've depended on crypto, you should switch to the o        ne that's built-in.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provide        s its own type definitions, so you do not need this installed.
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @h        api/topo. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has bee        n deprecated because it extends the now deprecated request package, see https://        github.com/request/request/issues/3142
    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated        in favor of babel-cli. Check https://opencollective.com/babel to support the Bab        el maintainers
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated b        ecause it extends the now deprecated request package, see https://github.com/req        uest/request/issues/3142
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @h        api/hoek. Please update your dependencies as this version is no longer maintaine        d an may contain bugs and security issues.
    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JS        ON 3
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, fl        atted is its successor.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and        does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 hav        e a low-severity ReDos regression when used in a Node.js environment. It is reco        mmended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/iss        ues/797)
    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy.        new code should use the URLSearchParams API instead.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @h        api/joi. Please update your dependencies as this version is no longer maintained        an may contain bugs and security issues.
    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in        0.5.0
    removed 861 packages, and changed 1482 packages in 8m
    141 packages are looking for funding
      run `npm fund` for details
    upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
    upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
    upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
    upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
    @maxpd sagte in Performance Probleme im iobroker Admin auf pi4:
    Dein Setup ist ja vermutlich noch nicht wieder senkrecht.
    • M maxpd
      NPM version: 9.6.7
      @maxpd
      Wo stehen wir denn nun?
      cd /opt/iobroker && npm ls
      und
      iob update
      sagt?
        @maxpd
        und
        iob update
        sagt?
        maxpd
        Ich bin noch beim Austausch der Adapter, habe aber Probleme mit npm.
        pi@iobroker:~ $ cd /opt/iobroker && npm ls
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.google-sharedlocations@2.1.5 /opt/iobroker/node_modules/iobroker.google-sharedlocations
        npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
        npm ERR! invalid: iobroker.sma-speedwire@0.7.0 /opt/iobroker/node_modules/iobroker.sma-speedwire
        npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        iobroker.inst@2.0.3 /opt/iobroker
        ├── @types/caseless@0.12.2 extraneous
        ├── @types/request@2.48.8 extraneous
        ├── @types/tough-cookie@4.0.2 extraneous
        ├── coffeescript@1.12.7 extraneous
        ├── colors@1.4.0
        ├── fs-extra@7.0.1
        ├── iobroker.admin@6.3.5
        ├── iobroker.alias-manager@1.2.6
        ├── iobroker.backitup@2.6.19
        ├── iobroker.chromecast@3.0.3
        ├── iobroker.cloud@4.3.0
        ├── iobroker.coronavirus-statistics@0.8.7
        ├── iobroker.daswetter@3.1.8
        ├── iobroker.denon@1.15.0
        ├── iobroker.devices@1.1.2
        ├── iobroker.discovery@3.1.0
        ├── iobroker.doorbird@1.2.3
        ├── iobroker.feiertage@1.1.0
        ├── iobroker.flot@1.11.0
        ├── iobroker.go-e@1.0.27
        ├── iobroker.google-sharedlocations@2.1.5 invalid: "github:Garfonso/ioBroker.google-sharedlocations#73f8c9bd627e81518dec7e659d98332bd84d9e69" from the root project
        ├── iobroker.govee@0.0.5 invalid: "github:nbuenger/ioBroker.govee#0d983c49135b87ac2f88f9d832a6d632c4889606" from the root project
        ├── iobroker.history@2.2.4
        ├── iobroker.hm-rega@3.0.46
        ├── iobroker.hm-rpc@1.15.16
        ├── iobroker.ical@1.13.2
        ├── iobroker.info@1.9.26
        ├── iobroker.iot@1.14.2
        ├── iobroker.javascript@6.1.4
        ├── iobroker.js-controller@4.0.24
        ├── iobroker.lgtv@1.1.12
        ├── iobroker.lovelace@3.0.1
        ├── iobroker.mihome-vacuum@3.9.5
        ├── iobroker.modbus@5.0.11
        ├── iobroker.mqtt-client@1.6.3
        ├── iobroker.mqtt@4.0.7
        ├── iobroker.net-tools@0.2.0
        ├── iobroker.pi-hole@1.3.4
        ├── iobroker.ping@1.5.3
        ├── iobroker.rpi2@1.3.2
        ├── iobroker.sayit@1.13.0
        ├── iobroker.shelly@6.3.1
        ├── iobroker.shuttercontrol@1.4.29
        ├── iobroker.simple-api@2.7.2
        ├── iobroker.sma-em@0.7.0
        ├── iobroker.sma-speedwire@0.7.0 invalid: "https://github.com/Apollon77/iobroker.sma-speedwire/tarball/3dce8e5d3fb9112502ba697a0f41ec0ab0aa90f4" from the root project
        ├── iobroker.socketio@4.2.0
        ├── iobroker.sonoff@2.5.1
        ├── iobroker.spotify-premium@1.2.1
        ├── iobroker.sunnyportal@0.1.5
        ├── iobroker.synology@2.1.13
        ├── iobroker.systeminfo@0.3.1
        ├── iobroker.telegram@1.15.2
        ├── iobroker.terminal@1.0.0
        ├── iobroker.text2command@2.3.0
        ├── iobroker.tr-064@4.2.17
        ├── iobroker.tuya@3.13.1
        ├── iobroker.web@4.3.0
        ├── iobroker.whatsapp-cmb@0.2.3
        ├── iobroker.wifilight@1.1.4
        ├── iobroker.wled@0.6.7
        ├── iobroker.yeelight-2@1.2.1
        ├── iobroker.youtube@4.1.0
        ├── iobroker.zigbee@1.8.10
        ├── jsonata@1.8.6 extraneous
        ├── node-inspect@2.0.0 extraneous
        ├── semver@5.7.2
        ├── typescript@4.7.4 extraneous
        ├── virtual-tsc@0.6.2 extraneous
        ├── wake_on_lan@1.0.0 extraneous
        └── yargs@7.1.2
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T04_51_22_964Z-debug-0.log
        pi@iobroker:/opt/iobroker $ iobroker upgrade sma-speedwire@0.7.0 --debug
        Adapter "sma-speedwire" is not in the repository and cannot be updated.
        Cannot upgrade: Cannot read properties of undefined (reading 'controller')
        pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@2.1.5 --debug
        Adapter "google-sharedlocations" is not in the repository and cannot be updated.
        pi@iobroker:/opt/iobroker $ iobroker upgrade google-sharedlocations@1.5.2 --debu        g
        z.B. der sharedlocations Adapter. Dieser ist bei npm in einer 5 Jahre alten Version. Seit dem hat sich sehr viel bei dem Adapter getan. Aber auch die 5 Jahre alte Version findet er nicht.
        Den sma-speedwire kann man auch löschen, wird nicht benötigt.
        maxpd
        • M maxpd
          ├── colors@1.4.0
          ├── fs-extra@7.0.1
          ├── semver@5.7.2
          └── yargs@7.1.2
          @maxpd
          Dann schmeiß das raus, was nicht benötigt wird.
          Den Rest in aktueller Version drüber installieren.
            @maxpd
            maxpd
            @thomas-braun bevor ich es wieder falsch mache. wie installiere ich den Google shared locations über npm? dort wird der nicht gefunden.
            und wie installiere ich die aktuelle Version drüber, wenn auf npm nur die 5 Jahre alte liegt?
            maxpd
            • M maxpd
              @maxpd
              Keine Ahnung. Hab den selber nicht im Einsatz. Wo haste den denn her?
              Der?
              https://github.com/t4qjXH8N/ioBroker.google-sharedlocations
              Dann installier den nochmal frisch aus GitHub
                @maxpd
                Der?
                maxpd
                #66
                @thomas-braun genau den. aber ich habe es jetzt so verstanden, dass man nichts aus GitHub installieren darf, da offensichtlich 😂 das System kaputt geht.
                maxpd
                • M maxpd
                  #67
                  @maxpd
                  Man vermeidet es und hat nur so wenig wie möglich aus GitHub geangeltes im System.
                  Aber wenn es nicht anders geht...
                    @maxpd
                    maxpd
                    #68
                    @thomas-braun warum bringen die Entwickler ihre Adapter nicht zu npm? oder halten sie dort aktuell?
                    maxpd
                    • M maxpd
                      #69
                      @maxpd
                      Das musst du dort fragen. Der Adapter sieht auch etwas verwaist aus.
                      Gilt auch für den govee.
                      Schau mal ob der nicht durch govee-app oder govee-local ersetzt werden kann.
                        maxpd
                        #70
                        @thomas-braun said in Performance Probleme im iobroker Admin auf pi4:
                        @maxpd
                        und
                        iob update
                        sagt?
                        npm ERR! invalid: iobroker.google-sharedlocations@2.1.3 /opt/iobroker/node_modules/iobroker.google-sharedlocations
                        ├── colors@1.4.0
                        ├── fs-extra@7.0.1
                        ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations" from the root project
                        ├── semver@5.7.2
                        └── yargs@7.1.2
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T19_59_46_695Z-debug-0.log
                        pi@iobroker:/opt/iobroker $ iob update
                        Used repository: stable
                        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                        Adapter    "alias-manager": 1.2.4    , installed 1.2.6
                        Adapter    "backitup"     : 2.6.23   , installed 2.6.19 [Updatable]
                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                        Adapter    "cloud"        : 4.4.1    , installed 4.3.0  [Updatable]
                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.8  [Updatable]
                        Adapter    "denon"        : 1.15.3   , installed 1.15.0 [Updatable]
                        Adapter    "devices"      : 1.1.5    , installed 1.1.2  [Updatable]
                        Adapter    "doorbird"     : 1.2.3    , installed 1.2.3
                        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
                        Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                        Adapter    "history"      : 2.2.4    , installed 2.2.4
                        Adapter    "hm-rega"      : 3.0.47   , installed 3.0.46 [Updatable]
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
                        Adapter    "ical"         : 1.13.3   , installed 1.13.2 [Updatable]
                        Adapter    "iot"          : 1.14.5   , installed 1.14.2 [Updatable]
                        Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
                        Adapter    "lgtv"         : 1.1.10   , installed 1.1.12
                        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                        Adapter    "mihome-vacuum": 3.11.0   , installed 3.9.5  [Updatable]
                        Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                        Adapter    "mqtt"         : 4.1.1    , installed 4.0.7  [Updatable]
                        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
                        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
                        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                        Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
                        Adapter    "shelly"       : 6.4.1    , installed 6.3.1  [Updatable]
                        Adapter    "shuttercontrol": 1.6.1   , installed 1.4.29 [Updatable]
                        Adapter    "sma-em"       : 0.7.0    , installed 0.7.0
                        Adapter    "sonoff"       : 2.5.3    , installed 2.5.1  [Updatable]
                        Adapter    "spotify-premium": 1.2.2  , installed 1.2.1  [Updatable]
                        Adapter    "synology"     : 2.1.13   , installed 2.1.13
                        Adapter    "systeminfo"   : 1.0.0    , installed 0.3.1  [Updatable]
                        Adapter    "telegram"     : 1.16.0   , installed 1.15.2 [Updatable]
                        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                        Adapter    "text2command" : 3.0.2    , installed 2.3.0  [Updatable]
                        Adapter    "tr-064"       : 4.2.18   , installed 4.2.17 [Updatable]
                        Adapter    "tuya"         : 3.14.2   , installed 3.13.1 [Updatable]
                        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                        Adapter    "wled"         : 0.6.7    , installed 0.6.7
                        Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
                        Adapter    "youtube"      : 4.2.1    , installed 4.1.0  [Updatable]
                        Adapter    "zigbee"       : 1.8.23   , installed 1.8.10 [Updatable]
                        Die einzelnen Adapter habe ich noch nicht geupdated, da jeder 8 Minuten benötigt und es wohl woanders noch klemmt.
                        maxpd
                        • M maxpd
                          @maxpd
                          und
                          iob update
                          sagt?
                          ├── colors@1.4.0
                          ├── fs-extra@7.0.1
                          ├── semver@5.7.2
                          └── yargs@7.1.2
                          #71
                          Nochmal installieren.
                          iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                            maxpd
                            #72
                            @thomas-braun Ich hatte es wieder über das Admin Interface gemacht und hatte den Adapter auch zuvor komplett gelöscht. Jetzt habe ich es über deinen Befehl gemacht. Das Ergebnis ist aber das gleiche.
                            pi@iobroker:/opt/iobroker $ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                            install t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1
                            NPM version: 9.6.7
                            Installing t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1... (System call)
                            npm WARN skipping integrity check for git dependency ssh://git@github.com/t4qjXH8N/ioBroker.google-sharedlocations.git
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                            npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                            npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                            npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
                            removed 863 packages, and changed 1482 packages in 8m
                            upload [3] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-cookie.JPG google-cookie.JPG image/jpeg
                            upload [2] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/google-sharedlocations.png google-sharedlocations.png image/png
                            upload [1] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/index_m.html index_m.html text/html
                            upload [0] google-sharedlocations.admin /opt/iobroker/node_modules/iobroker.google-sharedlocations/admin/words.js words.js application/javascript
                            pi@iobroker:/opt/iobroker $ ^C
                            pi@iobroker:/opt/iobroker $ cd /opt/iobroker && npm ls
                            ├── colors@1.4.0
                            ├── fs-extra@7.0.1
                            ├── iobroker.backitup@2.6.23
                            ├── iobroker.google-sharedlocations@2.1.3 invalid: "github:t4qjXH8N/ioBroker.google-sharedlocations#d5a738e822ba42066fee93246f5a1f9c6621bca1" from the root project
                            ├── semver@5.7.2
                            └── yargs@7.1.2
                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-08-26T20_42_24_072Z-debug-0.log
                            maxpd
                            Thomas BraunT 3 Antworten Letzte Antwort
                            • M maxpd
                              NPM version: 9.6.7
                              ├── colors@1.4.0
                              ├── fs-extra@7.0.1
                              ├── semver@5.7.2
                              └── yargs@7.1.2
                              #73
                              @maxpd
                              Keine Ahnung warum das bei dir nicht sauber läuft.
                              Der ist hier in 7 Sekunden sauber installiert.
                              echad@chet:/opt/iobroker $  iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --host chet --debug
                              NPM version: 9.6.7
                              added 2 packages in 7s
                              96 packages are looking for funding
                              • M maxpd
                                NPM version: 9.6.7
                                ├── colors@1.4.0
                                ├── fs-extra@7.0.1
                                ├── semver@5.7.2
                                └── yargs@7.1.2
                                #74
                                @maxpd
                                Zeig nochmal die Langfassung von
                                iob diag
                                • M maxpd
                                  NPM version: 9.6.7
                                  ├── colors@1.4.0
                                  ├── fs-extra@7.0.1
                                  ├── semver@5.7.2
                                  └── yargs@7.1.2
                                  #75
                                  @maxpd
                                  Und lösch mal den npm cache.
                                  npm cache clean --force
                                  sudo -H -u iobroker npm cache clean --force
                                  • T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    #76
                                    @thomas-braun sagte in Performance Probleme im iobroker Admin auf pi4:
                                    tim@iobroker:~$ iobroker url https://github.com/t4qjXH8N/ioBroker.google-sharedlocations --debug
                                    NPM version: 9.6.7
                                    added 3 packages in 6s
                                    158 packages are looking for funding
                                    ups wollte nur bestätigen ist aber schon ne stunde her :)
                                    Spenden
                                      @maxpd
                                      NPM version: 9.6.7
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #77
                                      war das nicht früher mal aus einer bestimmten Konstellation mit nodejs und npm, das es so lange gedauert hat.
                                        #78
                                        @crunchip
                                        Ja, aber das war ein npm@6, wenn ich mich recht erinnere. Das wird was anderes sein. Ich vermute eine nicht abgeschlossener Kompilierung.
                                          @crunchip
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #79
                                          @thomas-braun ja schon, ich dachte daher eher daran, das bei ihm eventuell noch irgendwelche npm Altlasten dies verursachen
                                          würde es denn nicht etwas bringen, nodejs neu zu installieren?
                                          Thomas BraunT M 2 Antworten Letzte Antwort
