  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. [gelöst] Keine Verbindung zu mqtt-Server/Broker
    2.8k
    4.9k
    4.1k
37 Beiträge 5 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • M MiPl
    @crunchip
    sudo netstat -ltp liefert:
    Aktive Internetverbindungen (Nur Server)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
    tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      494/iobroker.js-con
    tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      494/iobroker.js-con
    tcp        0      0 localhost:mysql         0.0.0.0:*               LISTEN      589/mysqld
    tcp        0      0 0.0.0.0:tproxy          0.0.0.0:*               LISTEN      762/motion
    tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      516/sshd
    tcp        0      0 localhost:ipp           0.0.0.0:*               LISTEN      435/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      886/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      886/io.mqtt.0
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      392/python
    tcp        0      0 localhost:7999          0.0.0.0:*               LISTEN      762/motion
    tcp6       0      0 [::]:8082               [::]:*                  LISTEN      789/io.admin.0
    tcp6       0      0 [::]:8083               [::]:*                  LISTEN      976/io.web.0
    tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      516/sshd
    tcp6       0      0 localhost:3350          [::]:*                  LISTEN      525/xrdp-sesman
    tcp6       0      0 localhost:ipp           [::]:*                  LISTEN      435/cupsd
    tcp6       0      0 [::]:3389               [::]:*                  LISTEN      545/xrdp
    und zum ble.0-Adapter sieht das Protokoll so aus:
    2023-05-21 11:05:20.210	error	Terminating because A dependency requires a rebuild.
    2023-05-21 11:05:18.823	info	starting scanner process...
    2023-05-21 11:05:18.763	info	monitored services: fe95
    2023-05-21 11:05:18.758	info	enabled plugins: mi-flora, _default
    2023-05-21 11:05:18.753	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2023-05-21 11:05:18.633	info	starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.16.0, js-controller: 4.0.24
    2023-05-21 11:05:18.116	debug	States connected to redis: 127.0.0.1:9000
    2023-05-21 11:05:18.087	debug	States create User PubSub Client
    2023-05-21 11:05:18.083	debug	States create System PubSub Client
    2023-05-21 11:05:18.063	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    2023-05-21 11:05:18.012	debug	Objects connected to redis: 127.0.0.1:9001
    2023-05-21 11:05:17.990	debug	Objects client initialize lua scripts
    2023-05-21 11:05:17.919	debug	Objects create User PubSub Client
    2023-05-21 11:05:17.903	debug	Objects create System PubSub Client
    2023-05-21 11:05:17.898	debug	Objects client ready ... initialize now
    2023-05-21 11:05:17.813	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    crunchipC Abwesend
    crunchipC Abwesend
    @mipl sagte in Keine Verbindung zu mqtt-Server/Broker:
    da wundert mich die Auslastung nicht, wenn motioneye auch noch darauf läuft
    ansonsten passen die Ports
    und du bist sicher das die Zugangsdaten für mqtt stimmen, möglicher Kopierfehler Leerzeichen oder so?
    wenn er kein automatisches erfolgreiches rebuild tätigt, dann installier in neu bzw selbst wie oben erwähnt ein rebuild anstoßen
    Thomas BraunT M 2 Antworten Letzte Antwort
      @crunchip sagte in Keine Verbindung zu mqtt-Server/Broker:
      Und Cups und MySQL und RemoteDesktop...
        MiPl
        @crunchip
        bin mir sicher. Habe es jetzt nochmal eingegeben:
        @Thomas Braun
        CUPS und rDesktop könnte ich noch terminieren. MySQL und motion wird aber genutzt.
          leider nur teuer zu bekommen
          aktuell für 176€,
          allerdings bekommt man für den Preis sogar fast ne bessere gebrauchte alternative
          aktuell für 176€,
          oder @MiPl denkt pber einen sofort verfügbaren Odroid C4 nach
          • M MiPl
            @crunchip
            @Thomas Braun
            Dafür ist ein Pi3 mit 1Gb RAM unterdimensioniert. Wie man sieht.
              aktuell für 176€,
              MiPl
              ich bin da gerade parallel an einem Kauf eines Raspi dran. Habe dafür 7"-Display und möchte das nach Möglichkeit weiter nutzen.
              • M MiPl
                MiPl
                @mipl
                da das System (mehr oder weniger) läuft sollte aber dennoch auch der mqtt sich verbinden können, oder? Gibt es dazu noch eine Anregung?
                Marc BergM crunchipC 2 Antworten Letzte Antwort
                • M MiPl
                  @mipl
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  Websockets auf jeden Fall abschalten, das brauchst du hier nicht. Dann würde ich mal testen, ob ich mit einem MQTT Client wie "MQTT Explorer" auf den Broker zugreifen kann. Ist umgekehrt das Gerät, von welchem aus zugegriffen werden soll, anpingbar?
                  • M MiPl
                    @mipl
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @mipl mach mal alle Haken raus in der mqtt Instanz-Einstellung und websocket aus
                    andernfalls, liegt es möglicherweise an deinem Netzwerk
                      MiPl
                      @crunchip
                      Web-Sockets aus, alle Haken bei Einstellungen entfernt. Keine Änderung.
                      @Marc-Berg MQTT-LayZSpa ist anpingbar. MQTT-Explorer: Werde mich damit auseinandersetzen.
                        Dann mach das.
                        iobroker rebuild ble
                        Zur Not den Adapter nochmal neu installieren.
                        MiPl
                        hatte den Beitrag nicht gesehen.
                        Rebuilding native module "ble" ...
                        rebuilt dependencies successfully
                        Rebuilding native modules done
                        bleibt trotzdem rot. Neuinstallation des Adapters - weiterhin rot. Rebuild successfully - weiterhin rot. :-(
                        • Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          Naja, "auseinandersetzen" muss sich damit nicht, einfach die Portable-Version runterladen, starten, IP+Port+User+PW eingeben, fertig. Und schwupps, hat man 50% der möglichen Fehlerursachen ausgeschlossen.
                          Außerdem ist es noch ratsam, das Log-Level des MQTT Adapters auf "debug" hochzusetzen, dann sieht man jeden Verbindungsversuch, ob erfolgeich oder nicht.
                          • Marc BergM Marc Berg
                            MiPl
                            schrieb am zuletzt editiert von MiPl
                            @marc-berg
                            damit ist eine Verbindung möglich. MQTT ist grün.
                            2023-05-21 13:15:17.800	debug	Client [mqtt-explorer-4852ba5f] pingreq
                            mqtt.0
                            	2023-05-21 13:14:17.748	debug	Client [mqtt-explorer-4852ba5f] pingreq
                            mqtt.0
                            	2023-05-21 13:13:17.735	info	Client [mqtt-explorer-4852ba5f] subscribes on "$SYS/#" with regex /^mqtt\.0\.\$SYS(\..*)?/
                            mqtt.0
                            	2023-05-21 13:13:17.734	info	Client [mqtt-explorer-4852ba5f] subscribes on "$SYS/#" with regex /^\$SYS(\..*)?/
                            mqtt.0
                            	2023-05-21 13:13:17.733	debug	Client [mqtt-explorer-4852ba5f] Handle subscribe: {"topic":"$SYS/#","qos":0}
                            mqtt.0
                            	2023-05-21 13:13:17.729	info	Client [mqtt-explorer-4852ba5f] subscribes on "#" with regex /^mqtt\.0(\..*)?/
                            mqtt.0
                            	2023-05-21 13:13:17.728	info	Client [mqtt-explorer-4852ba5f] subscribes on "#" with regex /.*/
                            mqtt.0
                            	2023-05-21 13:13:17.724	debug	Client [mqtt-explorer-4852ba5f] Handle subscribe: {"topic":"#","qos":0}
                            mqtt.0
                            	2023-05-21 13:13:17.714	debug	stateChange mqtt.0.info.connection: {"val":"mqtt-explorer-4852ba5f","ack":true,"ts":1684667597709,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1684667597709}
                            mqtt.0
                            	2023-05-21 13:13:17.683	debug	Client [mqtt-explorer-4852ba5f] with keepalive 60 set timeout to 90 seconds
                            mqtt.0
                            	2023-05-21 13:13:17.459	info	Client [mqtt-explorer-4852ba5f] connected with secret 1684667597443_6267
                            • M MiPl
                              @marc-berg
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              mqtt.0
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              Dann wird der Fehler wohl auf Client-Seite zu suchen sein, wenn beim Broker nicht mal ein Verbindungsversuch zu sehen ist.
                                MiPl
                                @marc-berg
                                schlussfolgere ich auch. Ist ja ein Github-Projekt - sollte ich da ein Issue aufmachen, obwohl es bei zahlreichen Nutzern scheinbar klappt?
                                • M MiPl
                                  @marc-berg
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @mipl ggf noch mal alle Netzwerkeinstellungen deiner Spa Platine prüfen, Neustart bringt auch nichts?
                                    MiPl
                                    @crunchip
                                    IP's nochmal gecheckt - kein Fehler gefunden. ESP restartet - MQTT weiterhin gelb.
                                    Falsch - ist jetzt grün geworden!
                                    Danke Euch für die Hilfe.
                                    Setze den Thread auf gelöst.
