  4. Kein Backup aufgrund fehlender Permissions
    5.4k
44 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
    @joergh sagte in Kein Backup aufgrund fehlender Permissions:
    load average: 6.41, 6.45, 8.04
    was treibst du da?
    JoergH
    @homoran Was besagt das? CPU Last?
    • J JoergH
      @glasfaser sagte in Kein Backup aufgrund fehlender Permissions:
      @joergh
      die Full - Ausgabe bitte ( am Anfang )
      Ok, Du hast es so gewollt ;-)
      ======== Start marking the full check here =========
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : v8.0.0
      Virtualization  : Unknown (buanet/Synology?)
      Distributor ID: Debian
      Description:    Debian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       19:24:19 up 2 days,  3:25,  0 users,  load average: 6.41, 6.45, 8.04
      CPU threads: 16
      *** Time and Time Zones ***
      Mon Apr 17 17:24:19 UTC 2023
      Mon Apr 17 19:24:19 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             31G        5.6G        390M        1.2G         25G         24G
      Swap:             0B          0B          0B
      Total:           31G        5.6G        390M
              31977 M total memory
               5596 M used memory
              19817 M active memory
               6499 M inactive memory
                399 M free memory
                  0 M buffer memory
              25981 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Filesystem            Type       Size  Used Avail Use% Mounted on
      /dev/mapper/nvme0n1p1 btrfs      932G   66G  866G   8% /
      tmpfs                 tmpfs       64M     0   64M   0% /dev
      tmpfs                 tmpfs       16G     0   16G   0% /sys/fs/cgroup
      shm                   tmpfs       64M     0   64M   0% /dev/shm
      shfs                  fuse.shfs  932G   66G  866G   8% /opt/iobroker
      /dev/mapper/nvme0n1p1 btrfs      932G   66G  866G   8% /etc/hosts
      Show mounted filesystems (real ones only):
      TARGET SOURCE        FSTYPE OPTIONS
      /      /dev/mapper/nvme0n1p1[/system/docker/installed/btrfs/subvolumes/a764796ea53e73d4d1a7bbfd7a7da26a4361d52997353dccddc58ff2325abd33]
      |        btrfs  rw,noat
      |-/opt/iobroker
      |      shfs[/appdata/iobroker/data]        fuse.s rw,nosu
      |-/opt/userscripts
      |      shfs[/appdata/iobroker/scripts]        fuse.s rw,nosu
      |-/etc/resolv.conf
      |      /dev/mapper/nvme0n1p1[/system/docker/installed/containers/2b4afc16c5c329d95cb401eea18df52817839c7478076788de46b9bdcc5c629a/resolv.conf]
      |        btrfs  rw,noat
      |-/etc/hostname
      |      /dev/mapper/nvme0n1p1[/system/docker/installed/containers/2b4afc16c5c329d95cb401eea18df52817839c7478076788de46b9bdcc5c629a/hostname]
      |        btrfs  rw,noat
      `-/etc/hosts
             /dev/mapper/nvme0n1p1[/system/docker/installed/containers/2b4afc16c5c329d95cb401eea18df52817839c7478076788de46b9bdcc5c629a/hosts]
        btrfs  rw,noat
      /var:
      33M     /var/
      30M     /var/lib
      18M     /var/lib/apt/lists
      18M     /var/lib/apt
      13M     /var/lib/dpkg
      /opt/iobroker/backups:
      16K     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      308M    /opt/iobroker/iobroker-data/
      274M    /opt/iobroker/iobroker-data/files
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/telegram.admin
      32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      8.5M    /opt/iobroker/iobroker-data/files/vis.0/Homematic_Steuerung/img/Eigene_Bilder/20180322_153925_HDR.jpg
      7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
      7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.16.0
      /usr/bin/node           v18.16.0
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Installed: 18.16.0-deb-1nodesource1
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
       *** 18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      MULTIHOSTSERVICE/enabled: false
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : 2b4afc16c5c3                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : 2b4afc16c5c3                             -  enabled
        system.adapter.birthdays.0              : birthdays             : 2b4afc16c5c3                             - disabled
        system.adapter.daikin-cloud.0           : daikin-cloud          : 2b4afc16c5c3                             - disabled
        system.adapter.denon.0                  : denon                 : 2b4afc16c5c3                             - disabled
        system.adapter.discovery.0              : discovery             : 2b4afc16c5c3                             - disabled
        system.adapter.dwd.0                    : dwd                   : 2b4afc16c5c3                             - disabled
        system.adapter.exchangerates.0          : exchangerates         : 2b4afc16c5c3                             - disabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : 2b4afc16c5c3                             - disabled
        system.adapter.firetv.0                 : firetv                : 2b4afc16c5c3                             - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : 2b4afc16c5c3                             - disabled
        system.adapter.go-e.0                   : go-e                  : 2b4afc16c5c3                             - disabled
        system.adapter.ham.0                    : ham                   : 2b4afc16c5c3                             - disabled
        system.adapter.hm-rega.0                : hm-rega               : 2b4afc16c5c3                             - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : 2b4afc16c5c3                             - disabled, port: 18701
        system.adapter.hm-rpc.3                 : hm-rpc                : 2b4afc16c5c3                             - disabled, port: 0
        system.adapter.hm-rpc.4                 : hm-rpc                : 2b4afc16c5c3                             - disabled, port: 0
        system.adapter.hm-rpc.5                 : hm-rpc                : 2b4afc16c5c3                             - disabled, port: 0
        system.adapter.ical.0                   : ical                  : 2b4afc16c5c3                             - disabled
        system.adapter.ical.1                   : ical                  : 2b4afc16c5c3                             - disabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: 2b4afc16c5c3                             - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : 2b4afc16c5c3                             - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : 2b4afc16c5c3                             - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : 2b4afc16c5c3                             - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : 2b4afc16c5c3                             - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : 2b4afc16c5c3                             - disabled
        system.adapter.influxdb.0               : influxdb              : 2b4afc16c5c3                             - disabled, port: 8086
        system.adapter.info.0                   : info                  : 2b4afc16c5c3                             - disabled
        system.adapter.javascript.0             : javascript            : 2b4afc16c5c3                             - disabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : 2b4afc16c5c3                             - disabled
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : 2b4afc16c5c3                             - disabled, port: 54321
        system.adapter.modbus.0                 : modbus                : 2b4afc16c5c3                             - disabled
        system.adapter.mqtt.0                   : mqtt                  : 2b4afc16c5c3                             - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : 2b4afc16c5c3                             - disabled
        system.adapter.octoprint.0              : octoprint             : 2b4afc16c5c3                             - disabled
        system.adapter.odl.0                    : odl                   : 2b4afc16c5c3                             - disabled
        system.adapter.openweathermap.0         : openweathermap        : 2b4afc16c5c3                             - disabled
        system.adapter.pollenflug.0             : pollenflug            : 2b4afc16c5c3                             - disabled
        system.adapter.powerfox2.0              : powerfox2             : 2b4afc16c5c3                             - disabled
        system.adapter.pvforecast.0             : pvforecast            : 2b4afc16c5c3                             - disabled
        system.adapter.renault.0                : renault               : 2b4afc16c5c3                             - disabled
        system.adapter.sayit.0                  : sayit                 : 2b4afc16c5c3                             - disabled, port: 0
        system.adapter.schoolfree.0             : schoolfree            : 2b4afc16c5c3                             - disabled
        system.adapter.shelly.0                 : shelly                : 2b4afc16c5c3                             - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : 2b4afc16c5c3                             - disabled
        system.adapter.telegram.0               : telegram              : 2b4afc16c5c3                             - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tesla-motors.0           : tesla-motors          : 2b4afc16c5c3                             - disabled
        system.adapter.tr-064.0                 : tr-064                : 2b4afc16c5c3                             - disabled
        system.adapter.trashschedule.0          : trashschedule         : 2b4afc16c5c3                             - disabled
        system.adapter.vaillant.0               : vaillant              : 2b4afc16c5c3                             - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : 2b4afc16c5c3                             - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : 2b4afc16c5c3                             - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : 2b4afc16c5c3                             - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : 2b4afc16c5c3                             - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : 2b4afc16c5c3                             - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : 2b4afc16c5c3                             - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : 2b4afc16c5c3                             - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : 2b4afc16c5c3                             - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : 2b4afc16c5c3                             - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : 2b4afc16c5c3                             - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : 2b4afc16c5c3                             - disabled
        system.adapter.vis-weather.0            : vis-weather           : 2b4afc16c5c3                             - disabled
        system.adapter.vis.0                    : vis                   : 2b4afc16c5c3                             - disabled
        system.adapter.web.0                    : web                   : 2b4afc16c5c3                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.3.5
      Adapter    "backitup"     : 2.6.16   , installed 2.6.16
      Adapter    "birthdays"    : 2.2.0    , installed 2.2.0
      Adapter    "denon"        : 1.15.0   , installed 1.15.0
      Adapter    "discovery"    : 3.1.0    , installed 3.1.0
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "exchangerates": 0.0.14   , installed 0.0.14
      Adapter    "fb-checkpresence": 1.1.26, installed 1.1.26
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "go-e"         : 1.0.27   , installed 1.0.27
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
      Adapter    "ical"         : 1.13.2   , installed 1.13.2
      Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-png": 0.1.0, installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.24   , installed 4.0.24
      Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
      Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
      Adapter    "odl"          : 2.0.5    , installed 2.0.5
      Adapter    "openweathermap": 0.3.3   , installed 0.3.3
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "powerfox2"    : 0.0.12   , installed 0.0.12
      Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
      Adapter    "renault"      : 0.0.15   , installed 0.0.15
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "schoolfree"   : 1.1.1    , installed 1.1.1
      Adapter    "shelly"       : 6.3.1    , installed 6.3.1
      Adapter    "socketio"     : 4.2.0    , installed 4.2.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "tr-064"       : 4.2.18   , installed 4.2.18
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vaillant"     : 0.1.2    , installed 0.1.2
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 4.3.0    , installed 4.3.0
      Adapter    "ws"           : 1.3.0    , installed 1.3.0
      Objects and States
      Objects:        28188
      States:         23406
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists... Done
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      99         15054269   132/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      99         15040174   132/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      99         15056164   161/io.admin.0
      2023-04-17 19:15:30.255  - error: host.2b4afc16c5c3 iobroker npm-install: host.2b4afc16c5c3 Unknown packetName sourceanalytix. Please install packages from outside the repository using npm!
      2023-04-17 19:15:31.267  - info: host.2b4afc16c5c3 iobroker npm-install: exit 12
      2023-04-17 19:15:32.267  - warn: host.2b4afc16c5c3 startInstance cannot find adapter "daikin-cloud@0.2.3". Try to install it... 2 attempt
      2023-04-17 19:15:32.267  - info: host.2b4afc16c5c3 iobroker install daikin-cloud@0.2.3 using installedFrom
      2023-04-17 19:15:33.985  - info: host.2b4afc16c5c3 iobroker npm-install: NPM version: 9.5.1
      2023-04-17 19:15:33.986  - info: host.2b4afc16c5c3 iobroker npm-install: Installing iobroker.daikin-cloud@0.2.3... (System call)
      2023-04-17 19:15:35.511  - error: host.2b4afc16c5c3 iobroker npm-install: host.2b4afc16c5c3 Cannot install iobroker.daikin-cloud@0.2.3: 1
      2023-04-17 19:15:36.521  - info: host.2b4afc16c5c3 iobroker npm-install: exit 25
      2023-04-17 19:15:36.944  - debug: backitup.0 (215) mount activ... umount in 2 Seconds!!
      2023-04-17 19:15:37.522  - warn: host.2b4afc16c5c3 startInstance cannot find adapter "daikin-cloud@0.2.3". Try to install it... 3 attempt
      2023-04-17 19:15:37.522  - info: host.2b4afc16c5c3 iobroker install daikin-cloud@0.2.3 using installedVersion
      2023-04-17 19:15:38.970  - debug: backitup.0 (215) umount successfully completed
      2023-04-17 19:15:39.259  - info: host.2b4afc16c5c3 iobroker npm-install: NPM version: 9.5.1
      2023-04-17 19:15:39.259  - info: host.2b4afc16c5c3 iobroker npm-install: Installing iobroker.daikin-cloud@0.2.3... (System call)
      2023-04-17 19:15:40.405  - info: admin.0 (161) ==> Connected system.user.admin from ::ffff:172.17.0.1
      2023-04-17 19:15:41.082  - error: host.2b4afc16c5c3 iobroker npm-install: host.2b4afc16c5c3 Cannot install iobroker.daikin-cloud@0.2.3: 1
      2023-04-17 19:15:41.578  - info: admin.0 (161) ==> Connected system.user.admin from ::ffff:172.17.0.1
      2023-04-17 19:15:42.096  - info: host.2b4afc16c5c3 iobroker npm-install: exit 25
      2023-04-17 19:15:43.096  - warn: host.2b4afc16c5c3 startInstance cannot find adapter "daikin-cloud@0.2.3". Try to install it... 4 attempt
      2023-04-17 19:15:43.096  - info: host.2b4afc16c5c3 iobroker install daikin-cloud@0.2.3 using installedVersion
      2023-04-17 19:15:44.895  - info: host.2b4afc16c5c3 iobroker npm-install: NPM version: 9.5.1
      2023-04-17 19:15:44.896  - info: host.2b4afc16c5c3 iobroker npm-install: Installing iobroker.daikin-cloud@0.2.3... (System call)
      2023-04-17 19:15:46.375  - error: host.2b4afc16c5c3 iobroker npm-install: host.2b4afc16c5c3 Cannot install iobroker.daikin-cloud@0.2.3: 1
      2023-04-17 19:15:47.384  - info: host.2b4afc16c5c3 iobroker npm-install: exit 25
      2023-04-17 19:15:48.384  - error: host.2b4afc16c5c3 Cannot download and install adapter "daikin-cloud@0.2.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      Auszug :
      Der röddelt aber ganz schön nach deinem Log
      Dazu gibt es zb. ein Thread :
      https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update
      J 1 Antwort Letzte Antwort
      • J JoergH
        nicht nur, auch I/O Vorgänge.
        selbst wenn du 16 Kerne hättest, wäre der Rechner zu 50% ausgelastet
        • GlasfaserG Glasfaser
          Auszug :
          JoergH
          Auszug :
          Der Daikin Adapter läuft nicht mit Nodejs 18, ist also "normal"...habe ich noch nicht aus dem iob geschmissen, aber die laufen eh alle nicht bis auf die Grundadapter bisher...
            JoergH
            @homoran sagte in Kein Backup aufgrund fehlender Permissions:
            Ja, ist ein i9 und der macht gerade Backups meiner Rechner, deswegen ist der gut beschäftigt, neben den 15 Dockern oder wie viele es jetzt sind...
            • J JoergH
              @glasfaser
              Das funktioniert im Container anders. Um den iob zu stoppen muss man pkill nehmen und dann den fix laufen lassen und anschliessend den Container stoppen und neu starten.
              Der macht aber bei jedem Start immer einen Check und setzt die Permissions neu.
              diag kann er auch nach dem fix nicht...
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              mache mal bitte jetzt ein Backup Lokal und schau dann nach
              im Verzeichnis:
              opt/iobroker/backups# ls -la
                im Verzeichnis:
                JoergH
                schrieb am zuletzt editiert von JoergH
                @glasfaser
                root@2b4afc16c5c3:/opt/iobroker/backups# ls -la
                total 21484
                drwxrwxrwx+ 1 iobroker users       96 Apr 17 19:37 .
                drwxrwxr-x+ 1 iobroker users      242 Apr 17 19:14 ..
                -rw-r--r--+ 1 iobroker users 21982637 Apr 17 19:37 2023_04_17-19_37_50_backupiobroker.tar.gz
                -rw-r--r--+ 1 root     root     12536 Apr 17 19:24 diag.sh
                Macht er brav. Hatte ich manuell mit ./iobroker backup im Verzeichnis oben drüber ausgelöst...war richtig, oder?
                • J JoergH
                  @glasfaser
                  total 21484
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  Hatte ich manuell
                  Nimm den Button in der Instanz !
                  was ist dann ...
                  • J JoergH
                    Frage an die Linux Freaks: Ich habe mir auf meinem NAS in Unraid den IOB als Docker installiert und möchte nun über CIFS das Backup auf das NAS "rüber"-senden.
                    Die CIFS Verbindung funktioniert inzwischen auch, aber ich erhalte Schreibfehler wegen fehlender Berechtigungen. Ich habe mir die schon angesehen, kenne mich aber nicht so gut aus und muss was übersehen.
                    Die Fehlermeldung sieht so aus:
                    Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2023_04_17-17_52_45_backupiobroker.tar.gz'
                    Die Schreibrechte des Nutzers "iobroker" sind vorhanden, so wie ich das interpretiere oder muss ich den Nutzer im Container auch extra noch anlegen und ihm die Schreibrechte zuweisen?
                    root@xxxxxxxxxxxx:/opt/iobroker/backups# ls -la
                    total 0
                    drwxrwxrwx+ 1 iobroker users   0 Apr 17 17:15 .
                    drwxrwxr-x+ 1 iobroker users 242 Apr 17 17:28 ..
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    Nochmal zur Erklärung von dir , leider verstehe ich es nicht :
                    ist dann :
                    Das ist mein "alter" PC mit Unraid auf USB Stick.
                    aber was ist das :
                    welche NAS , auf die gleiche oder ... !?
                      Hatte ich manuell
                      was ist dann ...
                      JoergH
                      @glasfaser Dann passiert "same procedure as last year"
                      Started iobroker ...
                      [DEBUG] [mount] - noserverino option: true
                      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=nas_user,password=****,noserverino,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //xxx.xxx.xxx.xxx/Backup/NAS_iobroker /opt/iobroker/backups"
                      [DEBUG] [mount] - mount successfully completed
                      [DEBUG] [mount] - done
                      [DEBUG] [iobroker] - host.xxxxxxxxxxxxxxxx states saved
                      [DEBUG] [iobroker] - host.xxxxxxxxxxxxxx 28192 objects saved
                      [ERROR] [iobroker] - host.xxxxxxxxxxxxxx Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2023_04_17-19_46_59_backupiobroker.tar.gz'
                      [DEBUG] [iobroker] - done
                      [DEBUG] [grafana] - Start Grafana Backup ...
                      [ERROR] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/grafana_tmp'
                      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                      [ERROR] [grafana] - Grafana Backup cannot created: Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/grafana_tmp'
                      [ERROR] [grafana] - Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/grafana_tmp'
                      [ERROR] [grafana] - Grafana Backup cannot created ...
                      [DEBUG] [grafana] - done
                      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
                      [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
                      [DEBUG] [javascripts] - found Script: Autos@Home
                      [DEBUG] [javascripts] - found Script: Loadmanagement_Kfz
                      [DEBUG] [javascripts] - found Script: PV_Laden
                      [DEBUG] [javascripts] - found Script: Tesla_Zustand_erkennen
                      [DEBUG] [javascripts] - found Script: go-e_Zustand_erkennen
                      [DEBUG] [javascripts] - found Script: Bewaesserung
                      [DEBUG] [javascripts] - found Script: Zisterne
                      [DEBUG] [javascripts] - found Script: Briefkasten_Einwurf
                      [DEBUG] [javascripts] - found Script: Briefkasten_reset
                      [DEBUG] [javascripts] - found Script: Energiedaten_aufbereiten
                      [DEBUG] [javascripts] - found Script: Klimaanlagen
                      [DEBUG] [javascripts] - found Script: Loadmanagement_Geräte
                      [DEBUG] [javascripts] - found Script: PV_Faktor_berechnen
                      [DEBUG] [javascripts] - found Script: PV_Laden_neu
                      [DEBUG] [javascripts] - found Script: Tesla_Zustand_erkennen_neu
                      [DEBUG] [javascripts] - found Script: go-e_Time_Switch
                      [DEBUG] [javascripts] - found Script: go-e_Zustand_erkennen_neu
                      [DEBUG] [javascripts] - found Script: Fenster_Sprachausgabe
                      [DEBUG] [javascripts] - found Script: Fenster_zu_
                      [DEBUG] [javascripts] - found Script: Fenster_zählen_1_6_14
                      [DEBUG] [javascripts] - found Script: Toilette_lüften
                      [DEBUG] [javascripts] - found Script: Anycubic_Vyper
                      [DEBUG] [javascripts] - found Script: Geschirrspüler_Status
                      [DEBUG] [javascripts] - found Script: Trockner_fertig
                      [DEBUG] [javascripts] - found Script: Waschmaschine_fertig
                      [DEBUG] [javascripts] - found Script: Waschmaschine_pausieren
                      [DEBUG] [javascripts] - found Script: Heizungsüberwachung
                      [DEBUG] [javascripts] - found Script: Zirkulationspumpe_Bedarf
                      [DEBUG] [javascripts] - found Script: Leinwand_hoch
                      [DEBUG] [javascripts] - found Script: Leinwand_runter
                      [DEBUG] [javascripts] - found Script: Bewegungsmelder_Keller
                      [DEBUG] [javascripts] - found Script: Esszimmer_Licht_an_bei_Rollladen_runter
                      [DEBUG] [javascripts] - found Script: Hitzeschutz
                      [DEBUG] [javascripts] - found Script: Rollladen_morgens
                      [DEBUG] [javascripts] - found Script: Sonnenschutz
                      [DEBUG] [javascripts] - found Script: Michelle_ist_im_Haus
                      [DEBUG] [javascripts] - found Script: Oana_Radar
                      [DEBUG] [javascripts] - found Script: Alarm_ausgelöst
                      [DEBUG] [javascripts] - found Script: Alarmanlage_Modus
                      [DEBUG] [javascripts] - found Script: Alarmauslösung
                      [DEBUG] [javascripts] - found Script: Garage_schliessen
                      [DEBUG] [javascripts] - found Script: Garagentor_Status
                      [DEBUG] [javascripts] - found Script: Tor_Einfahrt_schliessen
                      [DEBUG] [javascripts] - found Script: Testprogramm
                      [DEBUG] [javascripts] - found Script: Testskript
                      [DEBUG] [javascripts] - found Script: Alarmknopf
                      [DEBUG] [javascripts] - found Script: Fullybrowser
                      [DEBUG] [javascripts] - found Script: Sprachausgabe
                      [DEBUG] [javascripts] - found Script: Wetter_Ebene
                      [DEBUG] [javascripts] - found Script: Zählerstände
                      [DEBUG] [javascripts] - javascript Backup not created
                      [DEBUG] [javascripts] - done
                      [DEBUG] [cifs] - used copy path: /Backup/NAS_iobroker
                      [DEBUG] [cifs] - done
                      [ERROR] [dropbox] - Dropbox: File "/opt/iobroker/backups/iobroker_2023_04_17-19_46_59_backupiobroker.tar.gz" not found
                      [ERROR] [dropbox] - Dropbox: File "/opt/iobroker/backups/javascripts_2023_04_17-19_47_07_backupiobroker.tar.gz" not found
                      [DEBUG] [dropbox] - done
                      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                      [DEBUG] [clean] - done
                      [DEBUG] [historyHTML] - new history html values created
                      [DEBUG] [historyHTML] - done
                      [DEBUG] [historyJSON] - new history json values created
                      [DEBUG] [historyJSON] - done
                      [DEBUG] [umount] - mount activ, umount is started ...
                      [DEBUG] [umount] - umount successfully completed
                      [DEBUG] [umount] - done
                      [EXIT] 9
                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                      • J JoergH
                        [EXIT] 9
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        du solltest mal bitte LOKAL versuchen !
                        siehe :
                          ist dann :
                          aber was ist das :
                          JoergH
                          @glasfaser
                          Also ich lasse auf dem PC Unraid laufen, darauf installiere ich dann den Docker. Da der ja sein eigenes gekapseltes System ist, muss ich ja irgendwie die Daten aus dem Container bekommen, also auf die Festplatte des NAS, deshalb "rüber" senden...aus dem Container auf die Platte, in ein Backup Verzeichnis. Wenn ich jetzt so drüber nachdenke, wäre es eigentlich nicht unbedingt nötig, da die Daten des iob standardmäßig auch auf die Platte außerhalb des Containers gemappt werden, aber irgendwie fände ich es gut alle Backups in einem Share abzulegen...
                            siehe :
                            JoergH
                            @glasfaser Ok, dann hoffe ich er löscht jetzt nicht meinen API Key etc. wenn ich CIFS etc. deaktiviere...
                            • J JoergH
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Glasfaser
                              also hast du ein Mount erstellt , so wie hier :
                              das ist doch so OK .
                              und was du da machen willst ... ist über Rom gehen und das Backup auf die gleiche NAS legen .
                              • J JoergH
                                [EXIT] 9
                                @joergh
                                Vermutlich eine falsche Option: noserverino option: true
                                • J JoergH
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Glasfaser
                                  du kannst auch eine neue Instanz erstellen und mit dieser Testen !
                                    JoergH
                                    Too late. Habs schon gemacht...funktioniert soweit, hat iobroker und javascript gesichert, mit Grafana hat er noch Probleme, hat aber damit wohl nichts zu tun. Da habe ich noch keine templates wieder eingespielt...
                                    Naja, ich speichere einmal "lokal", was außerhalb in die appdata gemappt wird und dann wollte ich eben parallel dazu die Daten in das Backup Share schicken und dort ablegen. Es kam schon öfter vor, dass ich die appdata komplett löschen musste, weil ein Container nicht so wollte und bevor ich vergesse, dass die Backups da liegen....klar, zur Not geht es auch so...fuxt mich aber das nicht hinzubekommen 😁
                                      @joergh
                                      JoergH
                                      @thomas-braun sagte in Kein Backup aufgrund fehlender Permissions:
                                      @joergh
                                      Leider nein. Das war es nicht, schon probiert.
                                      • J JoergH
                                        @joergh
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Glasfaser
                                        @joergh
                                        was ist hiermit :
                                        J 2 Antworten Letzte Antwort
                                          @joergh
                                          was ist hiermit :
                                          JoergH
                                          @joergh
                                          was ist hiermit :
                                          Soweit ich weiss muss das bei CIFS so sein, probiere es aber auch gerne mal aus...
