  4. [gelöst]Deconz Adapter Conbee2 findet keine Geräte
137 Beiträge 6 Kommentatoren 9.4k Aufrufe 4 Beobachtet
  • J jwedenig
    cd /tmp
    wget https://project-downloads.drogon.net/wiringpi-latest.deb
    sudo dpkg -i wiringpi-latest.deb
    1 Login to your machine and stop the deCONZ service.
sudo systemctl stop deconz (Headless version), or
sudo systemctl stop deconz-gui (GUI version)
    2 Download latest deCONZ firmware. Check https://deconz.dresden-elektronik.de/deconz-firmware for the latest release and replace the filename accordingly.
ConBee II
wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
    3 Flash deCONZ firmware.
Before starting the update, stop ModemManager: sudo systemctl stop ModemManager.
Change the filename according to your download in step 2. If you are using multiple USB devices, use ls -la /dev/serial/by-id/ to check for the correct serial port.
ConBee II
sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
    5 [Optional] Update the deCONZ package as well.
wget -O deconz-latest-beta.deb https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb (Latest Beta Version), or
wget -O deconz-latest.deb https://deconz.dresden-elektronik.de/raspbian/stable/deconz-latest.deb (Latest Stable Version)
sudo dpkg -i deconz-latest-beta.deb or sudo dpkg -i deconz-latest.deb
    6 [Optional] Check if deCONZ II still uses the desired port and will start after a reboot of the Pi
sudo nano /lib/systemd/system/deconz.service
Check existing of following line (minimal and port at your desire)
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=8081
    7 Have deCONZ up and running again.
sudo systemctl start deconz (Headless version), or
sudo systemctl start deconz-gui (GUI version)
    Ro75R Offline
    Ro75R Offline
    Ro75
    schrieb am zuletzt editiert von Ro75
    #61
    @jwedenig
    Voraussetzung Conbee II und dieser erreichbar als "/dev/ttyACM0". Das kann geprüft werden mit:
    DANN:
    cd /home/pi/
    Wenn erfolgreich wird der Stick neu gebootet. Warten, ca. 30 Sekunden. Dann den Stick neu einstecken. Danach.
    J 1 Antwort Letzte Antwort
      @jwedenig
      Bitte vollständig in CodeTags setzen.
      groups
      sagt?
      J Online
      J Online
      jwedenig
      #62
      pi@raspberrypi:~ $ sudo systemctl stop ModemManager
      Failed to stop ModemManager.service: Unit ModemManager.service not loaded.
      pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
      insgesamt 0
      drwxr-xr-x 2 root root 60 Feb 17 14:08 .
      drwxr-xr-x 4 root root 80 Feb 17 14:08 ..
      lrwxrwxrwx 1 root root 13 Feb 17 14:08 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 -> ../../ttyACM0
      pi@raspberrypi:~ $ sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
      GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
      Reboot device /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 (ConBee II)
      retry, failed
      952: Error: failed to open device, status: Permission error while locking the device (2)
      pi@raspberrypi:~ $ sudo systemctl start deconz-gui
      pi@raspberrypi:~ $
      • Ro75R Ro75
        @jwedenig
        DANN:
        cd /home/pi/
        J Online
        J Online
        jwedenig
        #63
        @ro75
        is probiers dann, danke
        Thomas BraunT J 2 Antworten Letzte Antwort
        • J jwedenig
          @ro75
          #64
          @jwedenig
          Bist du mit dem Pi in der passenden Gruppe drin?
          dialout müsste das sein
          Iobroker-Adapter gestoppt?
          • J jwedenig
            @ro75
            J Online
            J Online
            jwedenig
            #65
            so update geklappt, Problem das Gleiche!
            FabioF Thomas BraunT 2 Antworten Letzte Antwort
            • J jwedenig
              FabioF Offline
              FabioF Offline
              Fabio
              schrieb am zuletzt editiert von Fabio
              #66
              @jwedenig prima jetzt hast du die neue Firmware und jetzt musst du noch auf
              Version 2.20.01 / 19.9.2022
              schau mal hier https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually
              Iobroker:
              • Matter over Thread Hilfe
              • J jwedenig
                #67
                @jwedenig
                Offenbar setzt du deconz ein und nicht den zigbee-Adapter.
                sudo apt update
                apt policy deconz*
                sagt?
                  @jwedenig
                  sudo apt update
                  apt policy deconz*
                  sagt?
                  J Online
                  J Online
                  jwedenig
                  #68
                  @thomas-braun sagte in Deconz Adapter Conbee2 findet keine Geräte:
                  apt policy deconz*
                  pi@raspberrypi:~ $ sudo apt update
                  Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                  OK:2 http://phoscon.de/apt/deconz buster InRelease
                  Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                  Holen:4 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
                  Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                  Holen:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                  Holen:7 https://deb.nodesource.com/node_16.x buster/main armhf Packages [783 B]
                  Es wurden 13,5 MB in 8 s geholt (1.615 kB/s).
                  Aktualisierung für 175 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                  pi@raspberrypi:~ $ apt policy deconz*
                  N: Paket deconz-latest.deb kann nicht gefunden werden.
                  N: Mittels des Musters »deconz-latest.deb« konnte kein Paket gefunden werden.
                  N: Mittels regulärem Ausdruck »deconz-latest.deb« konnte kein Paket gefunden werden.
                  pi@raspberrypi:~ $
                  • FabioF Fabio
                    J Online
                    J Online
                    jwedenig
                    #69
                    @fa-bio sagte in Deconz Adapter Conbee2 findet keine Geräte:
                    aber das habe ich ja genau gemacht und das kam dann dabei raus!
                    • J jwedenig
                      apt policy deconz*
                      pi@raspberrypi:~ $
                      #70
                      @jwedenig
                      Dein System ist sträflich ungepflegt.
                      rm deconz-latest.deb
                      sudo apt update
                      apt policy deconz*
                      Davon abgesehen ist Buster tot, installier da das aktuelle stable-Release Bullseye / Debian 11.
                      • J Online
                        J Online
                        jwedenig
                        #71
                        uiuiui, gibts da ein How to.., sorry
                        Ro75R 1 Antwort Letzte Antwort
                        • J jwedenig
                          Ro75R Offline
                          Ro75R Offline
                          Ro75
                          #72
                          @jwedenig Deswegen würde ich die SD-Karte so lassen wie sie ist. Bevor die dann nicht mehr geht.
                          Setze ein aktuelles System mit der SSD auf. Dann hast du alles frisch, OS, ioBroker, deconz, ...
                          • Ro75R Ro75
                            J Online
                            J Online
                            jwedenig
                            #73
                            @ro75
                            ok, gibt es hierfür ein how to?
                            Ich verstehe jetzt nicht ganz - mein Iobroker ist doch alles aktuell nodejs, npm
                            Ist jetzt nur der deconz adeapter veraltert? oder Wie!
                            Kenn mich gerade gar nicht aus, habe eigentlich immer auch alle Updates, welche bei IOBroker auftauchten, durchgeführt!
                            • J jwedenig
                              FabioF Offline
                              FabioF Offline
                              Fabio
                              #74
                              @jwedenig du hast die Firmware des Conbee upgedatet jetzt musst du Deconz updaten auf die letzte Version das ist das was dann die Phoscon App am laufen lässt etc. Schau dir den link an.
                              Aber du solltest wirklich überlegen alles neu zu machen damit du ein sauberes System hast. Also zuerst den Raspi danach machst du ioBroker und deine Adapter. Zum Schluss dann den Stick auf die letzte Version von Deconz anheben..
                              Iobroker:
                              • J Online
                                J Online
                                jwedenig
                                #75
                                @fa-bio
                                ok, also ich werde es mal mit der SSD versuchen, damit die SD Karte safe bleibt!
                                Also, welches OS würdest du empfehlen? oder hast Du einen Link für ein Install?
                                • J jwedenig
                                  @fa-bio
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #76
                                  @jwedenig versuche bitte erst die Phoscon Deconz auf die letzte Version zu heben damit wir sehen ob das dann klappt mit dem anlernen der Geräte. @Thomas-Braun wird dir bestimmt aufzeigen wie du ne saubere Installation hin bekommst für den Raspi. Auch sehr hilfreich die links in seiner Signatur da musste ich auch durch. 😂😉
                                  Ich habe einen NUC darauf läuft Debian Bullseye ohne Desktop und iBroker. https://www.debian.org/releases/bullseye/
                                  Hier findest du alles über Raspi https://www.raspberrypi.com/software/operating-systems/
                                  Iobroker:
                                  • FabioF Fabio
                                    J Online
                                    J Online
                                    jwedenig
                                    #77
                                    @fa-bio
                                    so, das habe ich jetzt gemacht:
                                    pi@raspberrypi:~ $ sudo systemctl stop deconz-gui
                                    pi@raspberrypi:~ $ wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
                                    --2023-02-17 17:49:55--  https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
                                    Auflösen des Hostnamens deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)… 144.76.96.194
                                    Verbindungsaufbau zu deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)|144.76.96.194|:443 … verbunden.
                                    HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                                    Länge: 163244 (159K) [application/octet-stream]
                                    Wird in »deCONZ_ConBeeII_0x26780700.bin.GCF.4« gespeichert.
                                    deCONZ_ConBeeII_0x2 100%[===================>] 159,42K   309KB/s    in 0,5s
                                    2023-02-17 17:49:56 (309 KB/s) - »deCONZ_ConBeeII_0x26780700.bin.GCF.4« gespeichert [163244/163244]
                                    deCONZ firmware version 26780700
                                    R21B18 Bootloader
                                    Vers: 2.07
                                    build: Jun 17 2019
                                    flashing 163230 bytes: |==============================|
                                    verify: .
                                    SUCCESS
                                    Wait 10 seconds until application starts
                                    pi@raspberrypi:~ $ wget -O deconz-latest-beta.deb https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
                                    --2023-02-17 17:51:08--  https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
                                    Länge: 6709164 (6,4M) [application/octet-stream]
                                    Wird in »deconz-latest-beta.deb« gespeichert.
                                    deconz-latest-beta. 100%[===================>]   6,40M  1,06MB/s    in 13s
                                    2023-02-17 17:51:22 (504 KB/s) - »deconz-latest-beta.deb« gespeichert [6709164/6709164]
                                    pi@raspberrypi:~ $ sudo nano /lib/systemd/system/deconz.service
                                    Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                                    pi@raspberrypi:~ $ sudo reboot
                                    • J jwedenig
                                      @fa-bio
                                      R21B18 Bootloader
                                      Vers: 2.07
                                      build: Jun 17 2019
                                      verify: .
                                      SUCCESS
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #78
                                      @jwedenig was steht jetzt in der Phoscon App. Das nächste mal nicht Beta nehmen sondern stable.
                                      Iobroker:
                                      • FabioF Fabio
                                        J Online
                                        J Online
                                        jwedenig
                                        #79
                                        @fa-bio
                                        Leider wieder das:
                                        FabioF Thomas BraunT 3 Antworten Letzte Antwort
                                        • J jwedenig
                                          @fa-bio
                                          Leider wieder das:
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #80
                                          @jwedenig Browser leer machen und Phoscon noch mal neu starten.
                                          Wenn das nicht geholfen hat probiers das.
                                          Deconz stoppen
                                          sudo systemctl stop deconz (Headless version),oder sudo systemctl stop deconz-gui (GUI version)
                                          wget -O deconz-latest.deb http://deconz.dresden-elektronik.de/raspbian/stable/deconz-latest.deb
                                          oder sudo systemctl start deconz-gui (GUI version)
                                          Iobroker:
