  4. [gelöst]Deconz Adapter Conbee2 findet keine Geräte
    5.5k
137 Beiträge 6 Kommentatoren 9.4k Aufrufe 4 Beobachtet
    @jwedenig
    wiringpi wird nur für den Raspbee benötigt.
    jwedenig
    bei diesem Befehl:
    sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
    passiert das:
    Reboot device /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 (ConBee II)
    retry, failed
    952: Error: failed to open device, status: Permission error while locking the device (2)
    pi@raspberrypi:~ $
    • J jwedenig
      bei diesem Befehl:
      passiert das:
      retry, failed
      pi@raspberrypi:~ $
      @jwedenig
      Bitte vollständig in CodeTags setzen.
      groups
      sagt?
      • J jwedenig
        cd /tmp
        wget https://project-downloads.drogon.net/wiringpi-latest.deb
        sudo dpkg -i wiringpi-latest.deb
        1 Login to your machine and stop the deCONZ service.
sudo systemctl stop deconz (Headless version), or
sudo systemctl stop deconz-gui (GUI version)
        2 Download latest deCONZ firmware. Check https://deconz.dresden-elektronik.de/deconz-firmware for the latest release and replace the filename accordingly.
ConBee II
wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
        3 Flash deCONZ firmware.
Before starting the update, stop ModemManager: sudo systemctl stop ModemManager.
Change the filename according to your download in step 2. If you are using multiple USB devices, use ls -la /dev/serial/by-id/ to check for the correct serial port.
ConBee II
        5 [Optional] Update the deCONZ package as well.
wget -O deconz-latest-beta.deb https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb (Latest Beta Version), or
wget -O deconz-latest.deb https://deconz.dresden-elektronik.de/raspbian/stable/deconz-latest.deb (Latest Stable Version)
sudo dpkg -i deconz-latest-beta.deb or sudo dpkg -i deconz-latest.deb
        6 [Optional] Check if deCONZ II still uses the desired port and will start after a reboot of the Pi
sudo nano /lib/systemd/system/deconz.service
Check existing of following line (minimal and port at your desire)
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=8081
        7 Have deCONZ up and running again.
sudo systemctl start deconz (Headless version), or
sudo systemctl start deconz-gui (GUI version)
        Ro75R Offline
        Ro75R Offline
        Ro75
        schrieb am zuletzt editiert von Ro75
        @jwedenig
        Voraussetzung Conbee II und dieser erreichbar als "/dev/ttyACM0". Das kann geprüft werden mit:
        DANN:
        cd /home/pi/
        Wenn erfolgreich wird der Stick neu gebootet. Warten, ca. 30 Sekunden. Dann den Stick neu einstecken. Danach.
          @jwedenig
          groups
          sagt?
          jwedenig
          pi@raspberrypi:~ $ sudo systemctl stop ModemManager
          Failed to stop ModemManager.service: Unit ModemManager.service not loaded.
          pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
          insgesamt 0
          drwxr-xr-x 2 root root 60 Feb 17 14:08 .
          drwxr-xr-x 4 root root 80 Feb 17 14:08 ..
          lrwxrwxrwx 1 root root 13 Feb 17 14:08 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 -> ../../ttyACM0
          pi@raspberrypi:~ $ sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
          GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
          retry, failed
          pi@raspberrypi:~ $ sudo systemctl start deconz-gui
          pi@raspberrypi:~ $
          • Ro75R Ro75
            @jwedenig
            DANN:
            cd /home/pi/
            jwedenig
            @ro75
            is probiers dann, danke
            Thomas BraunT J 2 Antworten Letzte Antwort
            • J jwedenig
              @ro75
              @jwedenig
              Bist du mit dem Pi in der passenden Gruppe drin?
              dialout müsste das sein
              Iobroker-Adapter gestoppt?
              • J jwedenig
                @ro75
                jwedenig
                so update geklappt, Problem das Gleiche!
                FabioF Thomas BraunT 2 Antworten Letzte Antwort
                • J jwedenig
                  FabioF Offline
                  FabioF Offline
                  Fabio
                  schrieb am zuletzt editiert von Fabio
                  #66
                  @jwedenig prima jetzt hast du die neue Firmware und jetzt musst du noch auf
                  Version 2.20.01 / 19.9.2022
                  schau mal hier https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually
                  Iobroker:
                  • Matter over Thread Hilfe
                  • J jwedenig
                    #67
                    @jwedenig
                    Offenbar setzt du deconz ein und nicht den zigbee-Adapter.
                    sudo apt update
                    apt policy deconz*
                    sagt?
                      @jwedenig
                      sudo apt update
                      apt policy deconz*
                      sagt?
                      jwedenig
                      #68
                      @thomas-braun sagte in Deconz Adapter Conbee2 findet keine Geräte:
                      apt policy deconz*
                      pi@raspberrypi:~ $ sudo apt update
                      Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                      OK:2 http://phoscon.de/apt/deconz buster InRelease
                      Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                      Holen:4 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
                      Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                      Holen:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                      Holen:7 https://deb.nodesource.com/node_16.x buster/main armhf Packages [783 B]
                      Es wurden 13,5 MB in 8 s geholt (1.615 kB/s).
                      Aktualisierung für 175 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      pi@raspberrypi:~ $ apt policy deconz*
                      N: Paket deconz-latest.deb kann nicht gefunden werden.
                      N: Mittels des Musters »deconz-latest.deb« konnte kein Paket gefunden werden.
                      N: Mittels regulärem Ausdruck »deconz-latest.deb« konnte kein Paket gefunden werden.
                      pi@raspberrypi:~ $
                      • FabioF Fabio
                        jwedenig
                        #69
                        @fa-bio sagte in Deconz Adapter Conbee2 findet keine Geräte:
                        aber das habe ich ja genau gemacht und das kam dann dabei raus!
                        FabioF 1 Antwort Letzte Antwort
                        • J jwedenig
                          apt policy deconz*
                          pi@raspberrypi:~ $
                          #70
                          @jwedenig
                          Dein System ist sträflich ungepflegt.
                          rm deconz-latest.deb
                          sudo apt update
                          apt policy deconz*
                          Davon abgesehen ist Buster tot, installier da das aktuelle stable-Release Bullseye / Debian 11.
                          • J Offline
                            jwedenig
                            #71
                            uiuiui, gibts da ein How to.., sorry
                            Ro75R 1 Antwort Letzte Antwort
                            • J jwedenig
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              #72
                              @jwedenig Deswegen würde ich die SD-Karte so lassen wie sie ist. Bevor die dann nicht mehr geht.
                              Setze ein aktuelles System mit der SSD auf. Dann hast du alles frisch, OS, ioBroker, deconz, ...
                              • Ro75R Ro75
                                jwedenig
                                #73
                                @ro75
                                ok, gibt es hierfür ein how to?
                                Ich verstehe jetzt nicht ganz - mein Iobroker ist doch alles aktuell nodejs, npm
                                Ist jetzt nur der deconz adeapter veraltert? oder Wie!
                                Kenn mich gerade gar nicht aus, habe eigentlich immer auch alle Updates, welche bei IOBroker auftauchten, durchgeführt!
                                • J jwedenig
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #74
                                  @jwedenig du hast die Firmware des Conbee upgedatet jetzt musst du Deconz updaten auf die letzte Version das ist das was dann die Phoscon App am laufen lässt etc. Schau dir den link an.
                                  Aber du solltest wirklich überlegen alles neu zu machen damit du ein sauberes System hast. Also zuerst den Raspi danach machst du ioBroker und deine Adapter. Zum Schluss dann den Stick auf die letzte Version von Deconz anheben..
                                  Iobroker:
                                  • J Offline
                                    jwedenig
                                    #75
                                    @fa-bio
                                    ok, also ich werde es mal mit der SSD versuchen, damit die SD Karte safe bleibt!
                                    Also, welches OS würdest du empfehlen? oder hast Du einen Link für ein Install?
                                    • J jwedenig
                                      @fa-bio
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #76
                                      @jwedenig versuche bitte erst die Phoscon Deconz auf die letzte Version zu heben damit wir sehen ob das dann klappt mit dem anlernen der Geräte. @Thomas-Braun wird dir bestimmt aufzeigen wie du ne saubere Installation hin bekommst für den Raspi. Auch sehr hilfreich die links in seiner Signatur da musste ich auch durch. 😂😉
                                      Ich habe einen NUC darauf läuft Debian Bullseye ohne Desktop und iBroker. https://www.debian.org/releases/bullseye/
                                      Hier findest du alles über Raspi https://www.raspberrypi.com/software/operating-systems/
                                      Iobroker:
                                      • FabioF Fabio
                                        jwedenig
                                        #77
                                        @fa-bio
                                        so, das habe ich jetzt gemacht:
                                        pi@raspberrypi:~ $ sudo systemctl stop deconz-gui
                                        pi@raspberrypi:~ $ wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
                                        --2023-02-17 17:49:55--  https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
                                        Auflösen des Hostnamens deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)… 144.76.96.194
                                        Verbindungsaufbau zu deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)|144.76.96.194|:443 … verbunden.
                                        HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
                                        Länge: 163244 (159K) [application/octet-stream]
                                        Wird in »deCONZ_ConBeeII_0x26780700.bin.GCF.4« gespeichert.
                                        deCONZ_ConBeeII_0x2 100%[===================>] 159,42K   309KB/s    in 0,5s
                                        2023-02-17 17:49:56 (309 KB/s) - »deCONZ_ConBeeII_0x26780700.bin.GCF.4« gespeichert [163244/163244]
                                        deCONZ firmware version 26780700
                                        R21B18 Bootloader
                                        Vers: 2.07
                                        build: Jun 17 2019
                                        flashing 163230 bytes: |==============================|
                                        verify: .
                                        SUCCESS
                                        Wait 10 seconds until application starts
                                        pi@raspberrypi:~ $ wget -O deconz-latest-beta.deb https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
                                        --2023-02-17 17:51:08--  https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb
                                        Länge: 6709164 (6,4M) [application/octet-stream]
                                        Wird in »deconz-latest-beta.deb« gespeichert.
                                        deconz-latest-beta. 100%[===================>]   6,40M  1,06MB/s    in 13s
                                        2023-02-17 17:51:22 (504 KB/s) - »deconz-latest-beta.deb« gespeichert [6709164/6709164]
                                        pi@raspberrypi:~ $ sudo nano /lib/systemd/system/deconz.service
                                        Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                                        pi@raspberrypi:~ $ sudo reboot
                                        • J jwedenig
                                          @fa-bio
                                          R21B18 Bootloader
                                          Vers: 2.07
                                          build: Jun 17 2019
                                          verify: .
                                          SUCCESS
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #78
                                          @jwedenig was steht jetzt in der Phoscon App. Das nächste mal nicht Beta nehmen sondern stable.
                                          Iobroker:
