  4. [gelöst]Deconz Adapter Conbee2 findet keine Geräte
    5.5k
137 Beiträge 6 Kommentatoren 9.4k Aufrufe 4 Beobachtet
  • J jwedenig
    Also das hätte ich gemacht - aber leider ist die Version die Alte geblieben:
    cd /tmp
    wget https://project-downloads.drogon.net/wiringpi-latest.deb
    sudo dpkg -i wiringpi-latest.deb
    	1	Login to your machine and stop the deCONZ service.
sudo systemctl stop deconz (Headless version), or
sudo systemctl stop deconz-gui (GUI version)
    	2	Download latest deCONZ firmware. Check https://deconz.dresden-elektronik.de/deconz-firmware for the latest release and replace the filename accordingly.
ConBee II
wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_ConBeeII_0x26780700.bin.GCF
    	3	Flash deCONZ firmware.
Before starting the update, stop ModemManager: sudo systemctl stop ModemManager.
Change the filename according to your download in step 2. If you are using multiple USB devices, use ls -la /dev/serial/by-id/ to check for the correct serial port.
ConBee II
sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
    	5	[Optional] Update the deCONZ package as well.
wget -O deconz-latest-beta.deb https://deconz.dresden-elektronik.de/raspbian/beta/deconz-latest-beta.deb (Latest Beta Version), or
wget -O deconz-latest.deb https://deconz.dresden-elektronik.de/raspbian/stable/deconz-latest.deb (Latest Stable Version)
sudo dpkg -i deconz-latest-beta.deb or sudo dpkg -i deconz-latest.deb
    	6	[Optional] Check if deCONZ II still uses the desired port and will start after a reboot of the Pi
sudo nano /lib/systemd/system/deconz.service
Check existing of following line (minimal and port at your desire)
ExecStart=/usr/bin/deCONZ -platform minimal --http-port=8081
    	7	Have deCONZ up and running again.
sudo systemctl start deconz (Headless version), or
sudo systemctl start deconz-gui (GUI version)
    jwedenig
    cd /tmp
ConBee II
ConBee II
    Thomas BraunT Ro75R 2 Antworten Letzte Antwort
    • J jwedenig
      cd /tmp
ConBee II
ConBee II
      @jwedenig
      wiringpi wird nur für den Raspbee benötigt.
        @jwedenig
        jwedenig
        bei diesem Befehl:
        passiert das:
        Reboot device /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 (ConBee II)
        retry, failed
        952: Error: failed to open device, status: Permission error while locking the device (2)
        pi@raspberrypi:~ $
        • J jwedenig
          bei diesem Befehl:
          passiert das:
          retry, failed
          pi@raspberrypi:~ $
          @jwedenig
          Bitte vollständig in CodeTags setzen.
          groups
          sagt?
          • J jwedenig
            cd /tmp
ConBee II
ConBee II
            Ro75R Offline
            Ro75R Offline
            Ro75
            schrieb am zuletzt editiert von Ro75
            @jwedenig
            Voraussetzung Conbee II und dieser erreichbar als "/dev/ttyACM0". Das kann geprüft werden mit:
            DANN:
            cd /home/pi/
            Wenn erfolgreich wird der Stick neu gebootet. Warten, ca. 30 Sekunden. Dann den Stick neu einstecken. Danach.
              @jwedenig
              groups
              sagt?
              jwedenig
              pi@raspberrypi:~ $ sudo systemctl stop ModemManager
              Failed to stop ModemManager.service: Unit ModemManager.service not loaded.
              pi@raspberrypi:~ $ ls -la /dev/serial/by-id/
              insgesamt 0
              drwxr-xr-x 2 root root 60 Feb 17 14:08 .
              drwxr-xr-x 4 root root 80 Feb 17 14:08 ..
              lrwxrwxrwx 1 root root 13 Feb 17 14:08 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2450739-if00 -> ../../ttyACM0
              pi@raspberrypi:~ $ sudo GCFFlasher_internal -t 60 -d /dev/ttyACM0 -f deCONZ_ConBeeII_0x26780700.bin.GCF
              GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
              retry, failed
              pi@raspberrypi:~ $ sudo systemctl start deconz-gui
              pi@raspberrypi:~ $
              • Ro75R Ro75
                @jwedenig
                DANN:
                cd /home/pi/
                jwedenig
                @ro75
                is probiers dann, danke
                Thomas BraunT J 2 Antworten Letzte Antwort
                • J jwedenig
                  @ro75
                  @jwedenig
                  Bist du mit dem Pi in der passenden Gruppe drin?
                  dialout müsste das sein
                  Iobroker-Adapter gestoppt?
                  • J jwedenig
                    @ro75
                    jwedenig
                    so update geklappt, Problem das Gleiche!
                    FabioF Thomas BraunT 2 Antworten Letzte Antwort
                    • J jwedenig
                      FabioF Offline
                      FabioF Offline
                      Fabio
                      schrieb am zuletzt editiert von Fabio
                      #66
                      @jwedenig prima jetzt hast du die neue Firmware und jetzt musst du noch auf
                      Version 2.20.01 / 19.9.2022
                      schau mal hier https://github.com/dresden-elektronik/deconz-rest-plugin/wiki/Update-deCONZ-manually
                      Iobroker:
                      • Matter over Thread Hilfe
                      • J jwedenig
                        #67
                        @jwedenig
                        Offenbar setzt du deconz ein und nicht den zigbee-Adapter.
                        sudo apt update
                        apt policy deconz*
                        sagt?
                          @jwedenig
                          sudo apt update
                          apt policy deconz*
                          sagt?
                          jwedenig
                          #68
                          @thomas-braun sagte in Deconz Adapter Conbee2 findet keine Geräte:
                          apt policy deconz*
                          pi@raspberrypi:~ $ sudo apt update
                          Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                          OK:2 http://phoscon.de/apt/deconz buster InRelease
                          Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                          Holen:4 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
                          Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                          Holen:6 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                          Holen:7 https://deb.nodesource.com/node_16.x buster/main armhf Packages [783 B]
                          Es wurden 13,5 MB in 8 s geholt (1.615 kB/s).
                          Aktualisierung für 175 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                          pi@raspberrypi:~ $ apt policy deconz*
                          N: Paket deconz-latest.deb kann nicht gefunden werden.
                          N: Mittels des Musters »deconz-latest.deb« konnte kein Paket gefunden werden.
                          N: Mittels regulärem Ausdruck »deconz-latest.deb« konnte kein Paket gefunden werden.
                          pi@raspberrypi:~ $
                          • FabioF Fabio
                            jwedenig
                            #69
                            @fa-bio sagte in Deconz Adapter Conbee2 findet keine Geräte:
                            aber das habe ich ja genau gemacht und das kam dann dabei raus!
                            FabioF 1 Antwort Letzte Antwort
                            • J jwedenig
                              apt policy deconz*
                              pi@raspberrypi:~ $
                              #70
                              @jwedenig
                              Dein System ist sträflich ungepflegt.
                              rm deconz-latest.deb
                              sudo apt update
                              apt policy deconz*
                              Davon abgesehen ist Buster tot, installier da das aktuelle stable-Release Bullseye / Debian 11.
                              • J Offline
                                jwedenig
                                #71
                                uiuiui, gibts da ein How to.., sorry
                                Ro75R 1 Antwort Letzte Antwort
                                • J jwedenig
                                  Ro75R Offline
                                  Ro75R Offline
                                  Ro75
                                  #72
                                  @jwedenig Deswegen würde ich die SD-Karte so lassen wie sie ist. Bevor die dann nicht mehr geht.
                                  Setze ein aktuelles System mit der SSD auf. Dann hast du alles frisch, OS, ioBroker, deconz, ...
                                  • Ro75R Ro75
                                    jwedenig
                                    #73
                                    @ro75
                                    ok, gibt es hierfür ein how to?
                                    Ich verstehe jetzt nicht ganz - mein Iobroker ist doch alles aktuell nodejs, npm
                                    Ist jetzt nur der deconz adeapter veraltert? oder Wie!
                                    Kenn mich gerade gar nicht aus, habe eigentlich immer auch alle Updates, welche bei IOBroker auftauchten, durchgeführt!
                                    • J jwedenig
                                      FabioF Offline
                                      FabioF Offline
                                      Fabio
                                      #74
                                      @jwedenig du hast die Firmware des Conbee upgedatet jetzt musst du Deconz updaten auf die letzte Version das ist das was dann die Phoscon App am laufen lässt etc. Schau dir den link an.
                                      Aber du solltest wirklich überlegen alles neu zu machen damit du ein sauberes System hast. Also zuerst den Raspi danach machst du ioBroker und deine Adapter. Zum Schluss dann den Stick auf die letzte Version von Deconz anheben..
                                      Iobroker:
                                      • J Offline
                                        jwedenig
                                        #75
                                        @fa-bio
                                        ok, also ich werde es mal mit der SSD versuchen, damit die SD Karte safe bleibt!
                                        Also, welches OS würdest du empfehlen? oder hast Du einen Link für ein Install?
                                        • J jwedenig
                                          @fa-bio
                                          FabioF Offline
                                          FabioF Offline
                                          Fabio
                                          #76
                                          @jwedenig versuche bitte erst die Phoscon Deconz auf die letzte Version zu heben damit wir sehen ob das dann klappt mit dem anlernen der Geräte. @Thomas-Braun wird dir bestimmt aufzeigen wie du ne saubere Installation hin bekommst für den Raspi. Auch sehr hilfreich die links in seiner Signatur da musste ich auch durch. 😂😉
                                          Ich habe einen NUC darauf läuft Debian Bullseye ohne Desktop und iBroker. https://www.debian.org/releases/bullseye/
                                          Hier findest du alles über Raspi https://www.raspberrypi.com/software/operating-systems/
                                          Iobroker:
