  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 285.6k Aufrufe 40 Beobachtet
    TT-Tom
    #641
    Hallo Thomas,
    habe das Script aus dem Standartuser Ordner Tom gestartet. Musste zwischen durch das Password für sudo eingeben. System LXC-Container mit einem Testsystem auf Beta-Repro.
    Script v.2024-09-07
    *** BASE SYSTEM ***
     Static hostname: iobtest
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-1-pve
        Architecture: x86-64
    OS is similar to:
    model name	: Intel(R) N100
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:11:14 up 24 days, 36 min,  1 user,  load average: 0.06, 0.08, 0.01
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-09-08 14:11:14 CEST
               Universal time: Sun 2024-09-08 12:11:14 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    tom
    HOME=/home/tom
    GROUPS=tom sudo users iobroker
    iobroker
    [sudo] password for tom:
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    Boot Target: 	graphical.target
    *** MEMORY ***
    Mem:            8.4G        1.6G        5.2G        131K        1.6G        6.8G
    Swap:           536M          0B        536M
    Total:          8.9G        1.6G        5.7G
    Active iob-Instances: 	10
             8000 M total memory
             1507 M used memory
             1442 M active memory
             1464 M inactive memory
             4944 M free memory
                0 M buffer memory
             1547 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 14:11:34 up 24 days, 36 min,  1 user,  load average: 0.05, 0.07, 0.01
    Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8000.0 total,   4944.3 free,   1508.0 used,   1547.8 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6492.0 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--101--disk--0 ext4       63G  6.0G   54G  10% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
    /var:
    463M	/var/
    250M	/var/cache
    246M	/var/cache/apt
    170M	/var/cache/apt/archives
    154M	/var/lib
    Archived and active journals take up 16.4M in the file system.
    /opt/iobroker/backups:
    46M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    767M	/opt/iobroker/iobroker-data/
    645M	/opt/iobroker/iobroker-data/files
    493M	/opt/iobroker/iobroker-data/files/javascript.admin
    461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    30M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
    14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
    8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.17.0
    /usr/bin/node 		v20.17.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.29.3
    nodejs:
      Installed: 20.17.0-1nodesource1
      Candidate: 20.17.0-1nodesource1
      Version table:
     *** 20.17.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
            100 /var/lib/dpkg/status
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310623)
    Core adapters versions
    js-controller: 	6.0.11
    admin: 		7.1.0
    javascript: 	8.8.2
    nodejs modules from github: 	2
    +-- iobroker.iosapp@1.0.3 (git+ssh://git@github.com/tt-tom17/ioBroker.iosapp.git#57aa9615040d4d80b735ca0fb4beddc5aee69c9d)
    +-- iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
    Adapter State
      system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
    + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
    + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
      system.adapter.devices.0                : devices               : iobtest                                  - disabled
    + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
      system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
    + system.adapter.iosapp.0                 : iosapp                : iobtest                                  -  enabled
    + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
    + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
      system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
      system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
    + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
      system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
    Adapter    "admin"        : 7.1.0    , installed 7.1.0
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 3.0.22   , installed 3.0.22
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
    Adapter    "ical"         : 1.15.0   , installed 1.15.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.2  [Updatable]
    Controller "js-controller": 6.0.11   , installed 6.0.11
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 6.3.0    , installed 6.3.0
    Adapter    "ws"           : 2.6.2    , installed 2.6.2
    Adapter    "yahka"        : 1.0.8    , installed 1.0.8
    Objects and States
    Objects: 	4034
    States: 	3519
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists... Done
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13079      1/systemd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13990      296/master
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29389306   35190/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29389311   35190/iobroker.js-c
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13991      296/master
    tcp6       0      0 :::9192                 :::*                    LISTEN      1001       29392405   35471/io.iosapp.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13081      1/systemd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13201      1/systemd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60327454   91363/io.admin.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13080      1/systemd
    udp6       0      0 :::111                  :::*                                0          13082      1/systemd
    2024-09-08 14:02:49.853  - info: javascript.1 (61255) Start JavaScript script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch (JavaScript/js)
    2024-09-08 14:02:49.860  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2024-09-08 14:02:49.864  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Connected!
    2024-09-08 14:02:49.899  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch:  ist das eine zahl false
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Tagesverbrauch: 5.1 kWh
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Wochenverbrauch: 39.3 kWh
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Monatsverbrauch: 47.3 kWh
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Quartalsverbrauch: 455.6 kWh
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Jahrsverbrauch: 2018.2 kWh
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Betroffene Zeilen: 0
    2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Serverstatus: 34
    2024-09-08 14:05:39.663  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
    2024-09-08 14:05:39.895  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
    2024-09-08 14:05:48.012  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127484
    2024-09-08 14:05:48.620  - info: netatmo-crawler.0 (127484) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 14:05:48.637  - info: netatmo-crawler.0 (127484) Getting data for stationid:70:ee:50:35:dc:b6
    2024-09-08 14:06:07.272  - info: netatmo-crawler.0 (127484) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-09-08 14:06:07.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127484 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2024-09-08 14:10:44.041  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
    2024-09-08 14:10:44.229  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
    2024-09-08 14:10:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127529
    2024-09-08 14:10:48.618  - info: netatmo-crawler.0 (127529) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 14:10:48.635  - info: netatmo-crawler.0 (127529) Getting data for stationid:70:ee:50:35:dc:b6
    2024-09-08 14:10:59.398  - info: netatmo-crawler.0 (127529) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-09-08 14:10:59.907  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127529 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    			v.2024-09-07
      Virtualization: lxc
    Installation: 		lxc
    Kernel: 		x86_64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Pending OS-Updates: 	2
    Pending iob updates: 	1
    Nodejs-Installation:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    Recommended versions are nodejs 20.17.0 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.4G        1.7G        5.0G        131K        1.6G        6.7G
    Swap:           536M          0B        536M
    Total:          8.9G        1.7G        5.6G
    ioBroker Core: 		js-controller 		6.0.11
    			admin 			7.1.0
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		4034
    States: 		3519
    Size of iob-Database:
    6.0M	/opt/iobroker/iobroker-data/states.jsonl
    in deutsch
    *** ioBroker Diagnose ***
    Das Fenster des Terminalprogramms (puTTY) bitte so groß wie möglich ziehen oder den Vollbildmodus verwenden.
    Die nachfolgenden Prüfungen liefern Hinweise zu etwaigen Fehlern, bitte im Forum hochladen:
    https://forum.iobroker.net
    Bitte die vollständige Ausgabe, einschließlich der ``` Zeichen am Anfang und am Ende markieren und kopieren.
    Es hilft beim helfen!
    Bitte eine Taste drücken
    ========== Langfassung ab hier markieren und kopieren ===========
    Skript v.2024-09-07
    *** GRUNDSYSTEM ***
      Virtualization: lxc
    OS is similar to:
    Docker          : false
    Kernel          : x86_64
    Userland        : 64 bit
     14:17:19 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
    CPU threads: 4
    *** LEBENSZYKLUS STATUS ***
    Das Betriebssystem mit dem Codenamen '' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
    *** ZEIT UND ZEITZONEN ***
                   Local time: Sun 2024-09-08 14:17:19 CEST
               Universal time: Sun 2024-09-08 12:17:19 UTC
                     RTC time: n/a
              RTC in local TZ: no
    *** User und Gruppen ***
    User der 'iob diag' aufgerufen hat:
    tom
    HOME=/home/tom
    User der den 'js-controller' ausführt:
    iobroker
    HOME=/home/iobroker
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Swap:           536M          0B        536M
             8000 M total memory
             1507 M used memory
             1439 M active memory
             1471 M inactive memory
             4936 M free memory
                0 M buffer memory
             1555 M swap cache
              512 M total swap
                0 M used swap
              512 M free swap
    top - 14:17:20 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
    MiB Mem :   8000.0 total,   4935.5 free,   1509.3 used,   1555.3 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6490.7 avail Mem
    Es wurden keine kritischen Fehler gefunden
    *** FILESYSTEM ***
    /var:
    463M	/var/
    250M	/var/cache
    246M	/var/cache/apt
    154M	/var/lib
    768M	/opt/iobroker/iobroker-data/
    USB-Devices by-id:
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    nodejs:
      Version table:
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310968)
    admin: 		7.1.0
    javascript: 	8.8.2
    Adapter State
    + instance is alive
    Objects and States
    Objects: 	3978
    States: 	3463
    Hit:2 http://security.debian.org bookworm-security InRelease
    Offene Systemupdates: 2
    2024-09-08 14:15:47.449  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
    2024-09-08 14:15:47.640  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
    2024-09-08 14:15:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 128557
    2024-09-08 14:15:48.614  - info: netatmo-crawler.0 (128557) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
    2024-09-08 14:15:48.630  - info: netatmo-crawler.0 (128557) Getting data for stationid:70:ee:50:35:dc:b6
    2024-09-08 14:15:58.272  - info: netatmo-crawler.0 (128557) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2024-09-08 14:15:58.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 128557 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    ============ Langfassung bis hier markieren =============
    iob diag hat das System inspiziert.
    Beliebige Taste für eine Zusammenfassung drücken
    Zusammfassung ab hier markieren und kopieren:
    ===================== ZUSAMMENFASSUNG =====================
    			v.2024-09-07
      Virtualization: lxc
    Installation: 		lxc
    Kernel: 		x86_64
    Userland: 		64 bit
    User-ID: 		1000
    Offene OS-Updates: 	2
    Offene iob updates: 	1
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
    nodeJS ist korrekt installiert
    MEMORY:
    Mem:            8.4G        1.6G        5.1G        131K        1.6G        6.8G
    Swap:           536M          0B        536M
    			admin 			7.1.0
    Objects type: jsonl
    States  type: jsonl
    Objects: 		3978
    States: 		3463
    6.4M	/opt/iobroker/iobroker-data/states.jsonl
    =================== ENDE DER ZUSAMMENFASSUNG ====================
    === Ausgabe bis hier markieren und kopieren ===
    tom@iobtest:~$
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    • T TT-Tom
      Hallo Thomas,
      Script v.2024-09-07
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      tom
      HOME=/home/tom
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               8000 M total memory
               1507 M used memory
               4944 M free memory
                  0 M buffer memory
               1547 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      463M	/var/
      250M	/var/cache
      246M	/var/cache/apt
      154M	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.1.0
      javascript: 	8.8.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	4034
      States: 	3519
      Pending Updates: 2
      			v.2024-09-07
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1000
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      MEMORY:
      Swap:           536M          0B        536M
      			admin 			7.1.0
      Objects type: jsonl
      States  type: jsonl
      Objects: 		4034
      States: 		3519
      in deutsch
      Skript v.2024-09-07
      *** GRUNDSYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      tom
      HOME=/home/tom
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               8000 M total memory
               1507 M used memory
               4936 M free memory
                  0 M buffer memory
               1555 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      463M	/var/
      250M	/var/cache
      246M	/var/cache/apt
      154M	/var/lib
      USB-Devices by-id:
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.1.0
      javascript: 	8.8.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	3978
      States: 	3463
      			v.2024-09-07
        Virtualization: lxc
      Installation: 		lxc
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1000
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      MEMORY:
      Swap:           536M          0B        536M
      			admin 			7.1.0
      Objects type: jsonl
      States  type: jsonl
      Objects: 		3978
      States: 		3463
      tom@iobtest:~$
      #642
      @tt-tom sagte in iob diag - Skript:
      Hm. Da sollte eigentlich dann 'bookworm' gemeldet werden. Muss ich dann im LXC mal schauen, ob und wo ich die Info anderweitig bekomme.
      Kannst du mal bitte
      lsb_release -a
      cat /etc/debian_version
      hostnamectl
      im Container ausführen?
        Kannst du mal bitte
        lsb_release -a
        hostnamectl
        TT-Tom
        #643
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, permitted by applicable law.
        Letzte Anmeldung: Sonntag, den 08. September 2024,
        tom@iobtest:~$ lsb_release
        -bash: Isb_release: Kommando nicht gefunden.
        tom@iobtest:~$ lsb_release -a
        tom@iobtest:~$cat /etc/debian_version
        12.7
        tom@iobtest:*$ hostnamectl
        Chassis: container
        Machine ID: 661945b8c6614fe89d03fba976fb627e
        Boot ID: 9650d956e3ce42b185dda1a4dcaa22f4
        Virtualization: lxc
        Operating System: ;;https://www.debian.org/Debian GNU/Linux 12 (bookworm);;
        tom@iobtest:~$
        Edit: hostnamectl aktualisiert.
        Gruß Tom
        Public Transport
        • S Abwesend
          S Abwesend
          Shadowhunter23
          schrieb am zuletzt editiert von Shadowhunter23
          #644
          Proxmox lxc
          Script v.2024-09-07
          *** BASE SYSTEM ***
           Static hostname: iobroker
            Virtualization: lxc
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           16:16:01 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
          CPU threads: 4
          Operating System is the current Debian stable version codenamed 'bookworm'!
                         Local time: Sun 2024-09-08 16:16:01 CEST
                     Universal time: Sun 2024-09-08 14:16:01 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          tobias
          HOME=/home/tobias
          GROUPS=tobias sudo users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev redis
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             10G        4.4G        4.9G        499K        1.4G        6.4G
          Swap:             0B          0B          0B
          Total:           10G        4.4G        4.9G
          Active iob-Instances:   50
                  10240 M total memory
                   4176 M used memory
                   1435 M active memory
                   3875 M inactive memory
                   4689 M free memory
                      0 M buffer memory
                   1374 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 16:16:02 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
          Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
          MiB Mem :  10240.0 total,   4687.7 free,   4178.0 used,   1374.8 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6062.0 avail Mem
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/mapper/pve-vm--400--disk--0 ext4       16G   11G  4.1G  73% /
          udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
          tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
          /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
          /var:
          1.1G    /var/
          491M    /var/lib
          340M    /var/lib/redis
          307M    /var/cache
          303M    /var/cache/apt
          Archived and active journals take up 48.9M in the file system.
          248M    /opt/iobroker/backups/
          706M    /opt/iobroker/iobroker-data/
          573M    /opt/iobroker/iobroker-data/files
          299M    /opt/iobroker/iobroker-data/files/javascript.admin
          265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          40M     /opt/iobroker/iobroker-data/objects.jsonl
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
          USB-Devices by-id:
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848141)
          admin:          7.1.0
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
          + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
          + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
            system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
            system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
          + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
          + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
          + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
          + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
          + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
            system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
          + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
          + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
          + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
          + instance is alive
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
          Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "iot"          : 3.4.0    , installed 3.4.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
          Adapter    "mytime"       : 0.7.12   , installed 0.7.12
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "notification-manager": 1.2.1, installed 1.2.1
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "operating-hours": 1.1.0  , installed 1.1.0
          Adapter    "ping"         : 1.7.3    , installed 1.7.3
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
          Adapter    "sayit"        : 5.0.0    , installed 5.0.0
          Adapter    "shelly"       : 8.1.1    , installed 8.1.1
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
          Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
          Objects and States
          Objects:        11315
          States:         10115
          Hit:5 https://packages.redis.io/deb bookworm InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118935115  1/systemd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       156490584  651521/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       118947555  877/io.shelly.1
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        118941820  170/redis-server 12
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118940237  404/master
          tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       118943133  781/io.nuki.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          118937351  1/systemd
          tcp6       0      0 :::80                   :::*                    LISTEN      0          135858214  294782/apache2
          tcp6       0      0 :::111                  :::*                    LISTEN      0          118935117  1/systemd
          tcp6       0      0 :::3000                 :::*                    LISTEN      1001       118951273  1120/io.fullybrowse
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118940238  404/master
          tcp6       0      0 ::1:6379                :::*                    LISTEN      106        118941821  170/redis-server 12
          tcp6       0      0 :::8093                 :::*                    LISTEN      1001       118953403  1186/io.rest-api.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       118953652  1281/io.simple-api.
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       149284472  525475/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       118956323  1397/io.web.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          118935218  90/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118935116  1/systemd
          udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          118937414  180/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          118937412  180/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          118937408  180/ntpd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       118946983  661/io.chromecast.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       118947492  857/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       118943201  897/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       118943202  897/io.tuya.0
          udp6       0      0 :::111                  :::*                                0          118935118  1/systemd
          udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        118940387  180/ntpd
          udp6       0      0 ::1:123                 :::*                                0          118937416  180/ntpd
          udp6       0      0 :::123                  :::*                                0          118937405  180/ntpd
          2024-09-08 14:00:00.013  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1049671
          2024-09-08 14:00:04.018  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1049691
          2024-09-08 14:00:08.105  - info: host.iobroker instance system.adapter.ical.1 having pid 1049671 terminated with code 0 (NO_ERROR)
          2024-09-08 14:00:10.686  - info: host.iobroker instance system.adapter.ical.0 having pid 1049691 terminated with code 0 (NO_ERROR)
          2024-09-08 14:30:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1051935
          2024-09-08 14:30:04.019  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1051950
          2024-09-08 14:30:06.665  - info: host.iobroker instance system.adapter.ical.0 having pid 1051935 terminated with code 0 (NO_ERROR)
          2024-09-08 14:30:12.176  - info: host.iobroker instance system.adapter.ical.1 having pid 1051950 terminated with code 0 (NO_ERROR)
          2024-09-08 15:00:00.022  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1054104
          2024-09-08 15:00:04.027  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1054124
          2024-09-08 15:00:08.093  - info: host.iobroker instance system.adapter.ical.1 having pid 1054104 terminated with code 0 (NO_ERROR)
          2024-09-08 15:00:10.660  - info: host.iobroker instance system.adapter.ical.0 having pid 1054124 terminated with code 0 (NO_ERROR)
          2024-09-08 15:30:00.016  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1056283
          2024-09-08 15:30:04.021  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1056303
          2024-09-08 15:30:06.698  - info: host.iobroker instance system.adapter.ical.0 having pid 1056283 terminated with code 0 (NO_ERROR)
          2024-09-08 15:30:12.224  - info: host.iobroker instance system.adapter.ical.1 having pid 1056303 terminated with code 0 (NO_ERROR)
          2024-09-08 16:00:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1058656
          2024-09-08 16:00:04.021  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1058676
          2024-09-08 16:00:08.144  - info: host.iobroker instance system.adapter.ical.1 having pid 1058656 terminated with code 0 (NO_ERROR)
          2024-09-08 16:00:10.674  - info: host.iobroker instance system.adapter.ical.0 having pid 1058676 terminated with code 0 (NO_ERROR)
                                  v.2024-09-07
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1000
          Pending OS-Updates:     0
          Pending iob updates:    0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Mem:             10G        4.4G        4.9G        524K        1.4G        6.3G
          Swap:             0B          0B          0B
                                  admin                   7.1.0
          Objects type: redis
          States  type: redis
          Objects:                11315
          States:                 10115
          4.0M    /opt/iobroker/iobroker-data/states.jsonl
          Deutsch:
          Skript v.2024-09-07
          *** GRUNDSYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
          CPU threads: 4
          Das Betriebssystem ist das aktuelle, stabile Debian 'bookworm'!
                         Local time: Sun 2024-09-08 16:20:31 CEST
                     Universal time: Sun 2024-09-08 14:20:31 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          tobias
          HOME=/home/tobias
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:             0B          0B          0B
                   4186 M used memory
                   1444 M active memory
                   4678 M free memory
                      0 M buffer memory
                   1375 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          top - 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
          Tasks:  86 total,   2 running,  83 sleeping,   0 stopped,   1 zombie
          %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  10240.0 total,   4677.1 free,   4187.5 used,   1375.9 buff/cache
          MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6052.5 avail Mem
          *** FILESYSTEM ***
          tmpfs                            tmpfs     3.1G  168K  3.1G   1% /run
          tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/0
          /var:
          1.1G    /var/
          491M    /var/lib
          340M    /var/lib/redis
          307M    /var/cache
          303M    /var/cache/apt
          USB-Devices by-id:
          HINT:
          tcp
          HINT:
          tcp
          HINT:
          tcp
          HINT:
          tcp
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: redis
          States  type: redis
          Hosts:
          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848411)
          admin:          7.1.0
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11315
          States:         10115
          Offene Systemupdates: 0
          (Not all processes could be identified, non-owned process info
           will not be shown, you would have to be root to see it all.)
                                  v.2024-09-07
            Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1000
          Offene OS-Updates:      0
          Offene iob updates:     0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:             0B          0B          0B
                                  admin                   7.1.0
          Objects type: redis
          States  type: redis
          Objects:                11315
          States:                 10115
          Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
          ioBroker Backup Analyzer
          • S Shadowhunter23
            Proxmox lxc
            Script v.2024-09-07
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                             RTC time: n/a
                          NTP service: n/a
                      RTC in local TZ: no
            tobias
            HOME=/home/tobias
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     4176 M used memory
                     4689 M free memory
                        0 M buffer memory
                     1374 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            1.1G    /var/
            491M    /var/lib
            340M    /var/lib/redis
            307M    /var/cache
            303M    /var/cache/apt
            USB-Devices by-id:
            HINT:
            tcp
            HINT:
            tcp
            HINT:
            tcp
            HINT:
            tcp
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: redis
            States  type: redis
            Hosts:
            admin:          7.1.0
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        11315
            States:         10115
            Pending Updates: 0
                                    v.2024-09-07
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                1000
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            MEMORY:
            Swap:             0B          0B          0B
                                    admin                   7.1.0
            Objects type: redis
            States  type: redis
            Objects:                11315
            States:                 10115
            Deutsch:
            Skript v.2024-09-07
            *** GRUNDSYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 4
                             RTC time: n/a
                          NTP service: n/a
                      RTC in local TZ: no
            tobias
            HOME=/home/tobias
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:             0B          0B          0B
                     4186 M used memory
                     4678 M free memory
                        0 M buffer memory
                     1375 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            1.1G    /var/
            491M    /var/lib
            340M    /var/lib/redis
            307M    /var/cache
            303M    /var/cache/apt
            USB-Devices by-id:
            HINT:
            tcp
            HINT:
            tcp
            HINT:
            tcp
            HINT:
            tcp
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: redis
            States  type: redis
            Hosts:
            admin:          7.1.0
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        11315
            States:         10115
                                    v.2024-09-07
              Virtualization: lxc
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            User-ID:                1000
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            MEMORY:
            Swap:             0B          0B          0B
                                    admin                   7.1.0
            Objects type: redis
            States  type: redis
            Objects:                11315
            States:                 10115
            #645
            @shadowhunter23 sagte in iob diag - Skript:
            fehlende Gruppe für den user (adm?)
              Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
              Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
              Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
              Meister MopperM Offline
              Meister Mopper
              #646
              Habe mal einen Proxmox Test LXC angeschmissen und das Skript laufen lassen:
              Langfassung:
              Script v.2024-09-07
              *** BASE SYSTEM ***
              Static hostname: ioTest
               Virtualization: lxc
              OS is similar to:
              model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
              CPU threads: 1
                            Local time: Sun 2024-09-08 17:01:44 CEST
                        Universal time: Sun 2024-09-08 15:01:44 UTC
                              RTC time: n/a
                       RTC in local TZ: no
              thomas
              HOME=/home/thomas
              GROUPS=thomas adm sudo iobroker
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            2.1G        1.1G        982M        118K        102M        1.1G
              Swap:             0B          0B          0B
              Total:          2.1G        1.1G        982M
                      2048 M total memory
                      1013 M used memory
                      1090 M active memory
                         0 M inactive memory
                       936 M free memory
                         0 M buffer memory
                        98 M swap cache
                         0 M total swap
                         0 M used swap
                         0 M free swap
              top - 17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
              Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
              MiB Mem :   2048.0 total,    935.0 free,   1014.9 used,     98.1 buff/cache
              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1033.1 avail Mem
              * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
              3 loaded units listed.
              *** FILESYSTEM ***
              rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
              udev                         devtmpfs   16G     0   16G   0% /dev/tty
              tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
              tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
              tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
              /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
              /var:
              1.1G    /var/
              603M    /var/log
              602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
              369M    /var/lib
              Archived and active journals take up 601.0M in the file system.
              489M    /opt/iobroker/backups/
              8.5K    /opt/iobroker/backups/scripte0
              164M    /opt/iobroker/iobroker-data/
              105M    /opt/iobroker/iobroker-data/files
              47M     /opt/iobroker/iobroker-data/files/javascript.admin
              40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
              3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
              3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
              3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
              3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
               Version table:
                     500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
              ioBroker Status
              Objects type: redis
              States  type: redis
              Hosts:
              ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
              admin:          7.0.23
              javascript:     8.7.6
              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
              | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
              Adapter State
              + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
               system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
              + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
               system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
               system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
              + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
               system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
               system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
               system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
               system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
               system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
               system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
               system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
               system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
               system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
               system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
               system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
              + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              Active repo(s): stable
              Used repository: stable
              Adapter    "admin"        : 7.0.23   , installed 7.0.23
              Adapter    "backitup"     : 3.0.19   , installed 3.0.19
              Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
              Adapter    "ham"          : 5.3.1    , installed 5.3.1
              Adapter    "heos"         : 2.2.1    , installed 2.2.1
              Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
              Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
              Adapter    "samsung"      : 0.6.0    , installed 0.6.0
              Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
              Adapter    "solax"        : 0.9.9    , installed 0.9.9
              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
              Adapter    "traccar"      : 1.1.4    , installed 1.1.4
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
              Objects and States
              Objects:        453
              States:         337
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
              tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146671441  166/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146672892  237/io.web.0
              tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
              tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
              tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
              udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
              2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
              2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
              2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
              2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
              2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
              Kurzfassung:
                                     v.2024-09-07
               Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                1001
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              MEMORY:
              Mem:            2.1G        1.1G        1.0G        118K         62M        1.1G
              Swap:             0B          0B          0B
              Total:          2.1G        1.1G        1.0G
                                     admin                   7.0.23
              Objects type: redis
              States  type: redis
              Objects:                453
              States:                 337
              1.9M    /opt/iobroker/iobroker-data/objects.json.bak
              221K    /opt/iobroker/iobroker-data/states.json.bak
              Langfassung DE:
              Skript v.2024-09-07
              *** GRUNDSYSTEM ***
               Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
              CPU threads: 1
                            Local time: Sun 2024-09-08 17:04:41 CEST
                        Universal time: Sun 2024-09-08 15:04:41 UTC
                              RTC time: n/a
                       RTC in local TZ: no
              thomas
              HOME=/home/thomas
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:             0B          0B          0B
                      2048 M total memory
                      1018 M used memory
                      1055 M active memory
                         0 M inactive memory
                       970 M free memory
                         0 M buffer memory
                        59 M swap cache
                         0 M total swap
                         0 M used swap
                         0 M free swap
              top - 17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
              %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   2048.0 total,    968.4 free,   1020.2 used,     59.6 buff/cache
              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1027.8 avail Mem
              *** FILESYSTEM ***
              /var:
              1.1G    /var/
              603M    /var/log
              369M    /var/lib
              USB-Devices by-id:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
               Version table:
              ioBroker Status
              Objects type: redis
              States  type: redis
              Hosts:
              ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 466)
              admin:          7.0.23
              javascript:     8.7.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        453
              States:         337
              Kurzfassung DE:
                                     v.2024-09-07
               Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              User-ID:                1001
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              MEMORY:
              Swap:             0B          0B          0B
                                     admin                   7.0.23
              Objects type: redis
              States  type: redis
              Objects:                453
              States:                 337
              Proxmox und HA ...
                #647
                @homoran sagte in iob diag - Skript:
                Nee, LXC-Eigenheit.
                Bei Meister Mopper wird auch richtig Bookworm erkannt...
                Meister MopperM T 3 Antworten Letzte Antwort
                  Nee, LXC-Eigenheit.
                  Meister Mopper
                  #648
                  Jetzt mal die Variante als root user:
                  Script v.2024-09-07
                  *** BASE SYSTEM ***
                   Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
                  CPU threads: 1
                                Local time: Sun 2024-09-08 17:46:56 CEST
                            Universal time: Sun 2024-09-08 15:46:56 UTC
                                  RTC time: n/a
                           RTC in local TZ: no
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/home/iobroker
                  A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                  A root login is not required in most Linux Distributions.
                  Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
                  Enter the password for the new user:
                  Confirm the password for the new user:
                  Adding new user account...
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
                  Swap:             0B          0B          0B
                          2048 M total memory
                          1022 M used memory
                          1048 M active memory
                             0 M inactive memory
                           964 M free memory
                             0 M buffer memory
                            61 M swap cache
                             0 M total swap
                             0 M used swap
                             0 M free swap
                  top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
                  Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                  MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
                  MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
                  *** FILESYSTEM ***
                  tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
                  /var:
                  1.1G    /var/
                  603M    /var/log
                  369M    /var/lib
                  Archived and active journals take up 601.1M in the file system.
                  USB-Devices by-id:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                   Version table:
                  ioBroker Status
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
                  admin:          7.0.23
                  javascript:     8.7.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        453
                  States:         337
                  Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                  Pending Updates: 0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
                  2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
                  2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
                  2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
                  2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
                  2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                  2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
                  2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
                  2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
                  2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
                  Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
                  testuser@ioTest:~$ groups
                  testuser adm dialout sudo audio video plugdev users iobroker
                  Proxmox und HA ...
                    Nee, LXC-Eigenheit.
                    TT-Tom
                    #649
                    @Meister-Mopper
                    @Shadowhunter23
                    von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
                    Gruß Tom
                    Public Transport
                    Meister MopperM W 2 Antworten Letzte Antwort
                    • T TT-Tom
                      @Meister-Mopper
                      @Shadowhunter23
                      Meister Mopper
                      #650
                      @Meister-Mopper
                      @Shadowhunter23
                      ssh vom windows terminal
                      Proxmox und HA ...
                      • T TT-Tom
                        @Meister-Mopper
                        @Shadowhunter23
                        W Online
                        W Online
                        Wildbill
                        #651
                        @tt-tom Das sollte egal sein. Wenn Du Dich per SSH in einem LXC anmeldest landest Du im selben Userspace, als wenn Du Dich über die Proxmox-Konsole im LXC anmeldest.
                        Gruss, Jürgen
                        • W Wildbill
                          Gruss, Jürgen
                          TT-Tom
                          #652
                          @wildbill
                          ich nutze die Konsole von Proxmox nicht, da Safari mich da immer ärgert. Darum die Frage, ob es vielleicht kleine Abweichungen gibt.
                          @Thomas-Braun nutzt du lsb_release -a zur Abfrage des OS?
                          ich habe nur das Standard Template für den LXC genommen und folgende Pakete nach installiert.
                          apt install -y curl gnupg ca-certificates sudo mc
                          Gruß Tom
                          Public Transport
                          W Thomas BraunT 2 Antworten Letzte Antwort
                            Nee, LXC-Eigenheit.
                            Meister Mopper
                            #653
                            So, jetzt noch timedatectl:
                            Auf Normalzeit umgestellt:
                            Current default time zone: 'Etc/UTC'
                            Local time is now:      Sun Sep  8 16:09:36 UTC 2024.
                            Universal Time is now:  Sun Sep  8 16:09:36 UTC 2024.
                            thomas@ioTest:~$
                            Skript gestartet:
                            Script v.2024-09-07
                            *** BASE SYSTEM ***
                             Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            16:12:51 up 4 min,  2 users,  load average: 0.20, 0.27, 0.33
                            CPU threads: 1
                                          Local time: Sun 2024-09-08 16:12:51 UTC
                                      Universal time: Sun 2024-09-08 16:12:51 UTC
                                            RTC time: n/a
                                           Time zone: Etc/UTC (UTC, +0000)
                                     RTC in local TZ: no
                            Timezone is probably wrong. Do you want to reconfigure it? (y/n)
                            Setting up timezone
                            Enter the timezone for the server (default is Europe/Berlin):
                            Setting up time synchronization with systemd-timesyncd
                            thomas
                            HOME=/home/thomas
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            2.1G        1.1G        1.1G        118K         10M        1.1G
                            Swap:             0B          0B          0B
                            Total:          2.1G        1.1G        1.1G
                                    2048 M total memory
                                    1019 M used memory
                                    1009 M active memory
                                       0 M inactive memory
                                    1018 M free memory
                                       0 M buffer memory
                                      10 M swap cache
                                       0 M total swap
                                       0 M used swap
                                       0 M free swap
                            top - 18:13:07 up 4 min,  2 users,  load average: 0.22, 0.27, 0.33
                            Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   2048.0 total,   1016.4 free,   1021.2 used,     10.6 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1026.8 avail Mem
                            *** FILESYSTEM ***
                            /var:
                            1.1G    /var/
                            603M    /var/log
                            369M    /var/lib
                            Archived and active journals take up 601.2M in the file system.
                            USB-Devices by-id:
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                             Version table:
                            ioBroker Status
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            admin:          7.0.23
                            javascript:     8.7.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        453
                            States:         337
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146965130  1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146967666  123/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146967727  113/redis-server 12
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          146965132  1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          146967677  123/sshd: /usr/sbin
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146968429  237/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146967920  151/io.admin.0
                            tcp6       0      0 :::6556                 :::*                    LISTEN      0          146965446  1/init
                            tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146967728  113/redis-server 12
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146965131  1/init
                            udp6       0      0 :::111                  :::*                                0          146965133  1/init
                            2024-09-08 17:56:50.232  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                            2024-09-08 17:56:50.378  - info: javascript.0 (192) requesting all states
                            2024-09-08 17:56:50.379  - info: javascript.0 (192) requesting all objects
                            2024-09-08 17:56:50.395  - info: javascript.0 (192) received all states
                            2024-09-08 17:56:50.615  - info: javascript.0 (192) received all objects
                            2024-09-08 17:58:03.057  - info: javascript.0 (192) terminating
                            2024-09-08 17:58:03.060  - info: javascript.0 (192) Terminated (NO_ERROR): Without reason
                            2024-09-08 17:58:03.071  - info: javascript.0 (192) Got terminate signal TERMINATE_YOURSELF
                            2024-09-08 17:58:03.545  - info: javascript.0 (192) terminating
                            2024-09-08 18:08:28.307  - info: javascript.0 (192) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                            2024-09-08 18:08:28.451  - info: javascript.0 (192) requesting all states
                            2024-09-08 18:08:28.452  - info: javascript.0 (192) requesting all objects
                            2024-09-08 18:08:28.468  - info: javascript.0 (192) received all states
                            2024-09-08 18:08:28.700  - info: javascript.0 (192) received all objects
                            Kontrolle:
                            thomas@ioTest:~$ timedatectl
                                           Local time: So 2024-09-08 18:15:10 CEST
                                       Universal time: So 2024-09-08 16:15:10 UTC
                                             RTC time: n/a
                                      RTC in local TZ: no
                            Ich sag mal: Perfekt!
                            Proxmox und HA ...
                            • T TT-Tom
                              @wildbill
                              W Online
                              W Online
                              Wildbill
                              #654
                              @tt-tom Läuft bei mir mit Safari problemlos. Wobei ich auch lieber direkt per SSH-Terminal einsteige, da dann manche Funktionalität (z.B. Menüs in mc) funktionieren, die die Proxmox-Konsole nicht hergibt. Aber alle Befehle, die man im Terminal direkt eingibt, ergeben dasselbe. Vorausgesetzt natürlich, man meldet sich per SSH oder in der Proxmox-Konsole mit demselben User an.
                              Aber genug OT.
                              Gruss, Jürgen
                                TT-Tom
                                #655
                                @Thomas-Braun
                                ein Auszug vom User root. Ich habe ein LXC mit Debian 12 neu aufgesetzt und nur den root user. Iobroker habe ich jetzt nicht installiert, wollte nur das Anlegen eines Standarduser testen. Hat so nicht ganz funktioniert, wenn ich es heute noch schaffe, lege ich eine komplette iobroker Installation als root an und teste dann nochmal.
                                root
                                HOME=/root
                                GROUPS=root
                                js-controller is not running
                                Enter the username for a new user (Not 'root' and not 'iobroker'!): tom
                                useradd: group 'iobroker' does not exist
                                chpasswd: (user tom) pam_chauthtok() failed, error:
                                Authentication token manipulation error
                                chpasswd: (line 1, user tom) password not changed
                                Gruß Tom
                                Public Transport
                                T Thomas BraunT 2 Antworten Letzte Antwort
                                • T TT-Tom
                                  @wildbill
                                  #656
                                  Jein, -a gibt alles aus, ich lese den Codename per
                                  lsb_release -sc
                                  aus. Scheint also kein default package zu sein.
                                  • T TT-Tom
                                    @Thomas-Braun
                                    root
                                    HOME=/root
                                    GROUPS=root
                                    TT-Tom
                                    #657
                                    @tt-tom
                                    @Thomas-Braun
                                    nochmal mit iobroker Installation. User tom wurde angelegt und die Timezone wurde geändert.
                                    root@testsystem:~# ./iob_diag.sh
                                    You should not be root on your system!
                                    Better use your standard user!
                                    *** ioBroker Diagnosis ***
                                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                    Just copy and paste the Summary Page, including the ``` characters at start and end.
                                    It helps us to help you!
                                    Press any key to continue
                                    ```bash
                                    Script v.2024-09-07
                                    *** BASE SYSTEM ***
                                     Static hostname: testsystem
                                      Virtualization: lxc
                                    Package configuration
                                                      ┌───────────────────────┤ Configuring tzdata ├───────────────────────┐
                                                      │ Please select the city or region corresponding to your time zone.  │
                                                      │ Time zone:                                                         │
                                                      │                           Amsterdam       -                        │
                                                      │                           Andorra         ▒                        │
                                                      │                           Astrakhan       0                        │
                                                      │                           Athens          ▒                        │
                                                      │                           Belfast         ▒                        │
                                                      │                           Belgrade        ▒                        │
                                                      │                           Berlin          ▒                        │
                                                      │                           Bratislava      ▒                        │
                                                      │                           Brussels        ▒                        │
                                                      │                           Bucharest       ▒                        │
                                                      │                           Budapest        ▒                        │
                                                      │                           Busingen        .                        │
                                                      │                 <Ok>                     <Cancel>                  │
                                    Current default time zone: 'Europe/Berlin'
                                    Local time is now:      Sun Sep  8 20:07:44 CEST 2024.
                                    Universal Time is now:  Sun Sep  8 18:07:44 UTC 2024.
                                    root
                                    HOME=/root
                                    GROUPS=root
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:            2.1G        284M        1.6G        118K        229M        1.9G
                                    Swap:           1.1G          0B        1.1G
                                    Total:          3.2G        284M        2.7G
                                    Active iob-Instances:   4
                                             2048 M total memory
                                              271 M used memory
                                              399 M active memory
                                               66 M inactive memory
                                             1557 M free memory
                                                0 M buffer memory
                                              219 M swap cache
                                             1024 M total swap
                                                0 M used swap
                                             1024 M free swap
                                    top - 20:08:01 up 5 min,  1 user,  load average: 0.04, 0.17, 0.16
                                    Tasks:  25 total,   1 running,  24 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :   2048.0 total,   1555.1 free,    273.6 used,    219.4 buff/cache
                                    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   1774.4 avail Mem
                                    *** FILESYSTEM ***
                                    /dev/mapper/pve-vm--106--disk--0 ext4      7.8G  2.1G  5.3G  29% /
                                    tmpfs                            tmpfs     3.1G  112K  3.1G   1% /run
                                    /      /dev/mapper/pve-vm--106--disk--0 ext4   rw,relatime,stripe=16
                                    /var:
                                    400M    /var/
                                    237M    /var/cache
                                    234M    /var/cache/apt
                                    158M    /var/cache/apt/archives
                                    146M    /var/lib
                                    Archived and active journals take up 16.0M in the file system.
                                    4.0K    /opt/iobroker/backups/
                                    62M     /opt/iobroker/iobroker-data/
                                    57M     /opt/iobroker/iobroker-data/files
                                    31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                    8.4M    /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.70cad8ba.js
                                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                    5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                                    5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                                    5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    testsystem          testsystem (version: 6.0.11, hostname: testsystem    , alive, uptime: 316)
                                    admin:          7.0.23
                                    javascript:     "javascript" not found
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : testsystem                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.backitup.0               : backitup              : testsystem                               -  enabled
                                    + system.adapter.discovery.0              : discovery             : testsystem                               -  enabled
                                    + instance is alive
                                    Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                                    Objects and States
                                    Objects:        148
                                    States:         103
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       80745598   155/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       80745603   155/iobroker.js-con
                                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          80743343   319/master
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          80742867   1/init
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       80751205   436/io.admin.0
                                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          80743344   319/master
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          80742219   1/init
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          80742869   1/init
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          80742305   95/dhclient
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          80742868   1/init
                                    udp6       0      0 :::111                  :::*                                0          80742870   1/init
                                    2024-09-08 18:02:43.093  - info: backitup.0 (371) starting. Version 3.0.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-08 18:02:43.111  - info: backitup.0 (371) [iobroker] backup will be activated at 02:48 every 1 day(s)
                                    2024-09-08 18:02:46.482  - info: host.testsystem instance system.adapter.discovery.0 in version "4.5.0" started with pid 386
                                    2024-09-08 18:02:47.002  - info: discovery.0 (386) starting. Version 4.5.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-08 18:03:34.073  - info: admin.0 (330) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2024-09-08 18:04:30.739  - info: host.testsystem stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2024-09-08 18:04:30.741  - info: admin.0 (330) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-08 18:04:30.741  - info: admin.0 (330) terminating http server on port 8081
                                    2024-09-08 18:04:30.743  - info: admin.0 (330) terminating
                                    2024-09-08 18:04:30.743  - info: admin.0 (330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-09-08 18:04:30.781  - info: host.testsystem stopInstance system.adapter.admin.0 send kill signal
                                    2024-09-08 18:04:31.244  - info: admin.0 (330) terminating
                                    2024-09-08 18:04:31.281  - info: host.testsystem instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-09-08 18:04:34.403  - info: host.testsystem instance system.adapter.admin.0 in version "7.0.23" started with pid 436
                                    2024-09-08 18:04:35.068  - info: admin.0 (436) starting. Version 7.0.23 in /opt/iobroker/node_modules/iobroker.admin, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-08 18:04:35.079  - info: admin.0 (436) requesting all objects
                                    2024-09-08 18:04:35.285  - info: admin.0 (436) received all objects
                                    2024-09-08 18:04:35.382  - info: admin.0 (436) socket.io server listening on port 8081
                                    2024-09-08 18:04:35.383  - info: admin.0 (436) http server listening on port 8081
                                    2024-09-08 18:04:35.383  - info: admin.0 (436) Use link "http://127.0.0.1:8081" to configure.
                                    2024-09-08 18:04:37.576  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                                    2024-09-08 18:04:37.615  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                                    2024-09-08 18:04:37.645  - info: admin.0 (436) failed connection to socket.io from ::ffff:192.168.178.12: Passport was not initialized
                                    2024-09-08 18:04:45.342  - info: admin.0 (436) ==> Connected system.user.admin from ::ffff:192.168.178.12
                                    2024-09-08 18:04:57.657  - info: admin.0 (436) <== Disconnect system.user.admin from ::ffff:192.168.178.12 admin
                                    iob diag has finished.
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @Thomas-Braun
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      root
                                      HOME=/root
                                      GROUPS=root
                                      #658
                                      @tt-tom
                                      Den
                                      kann ich mir gerade nicht so wirklich erklären. Zumal es bei @Meister-Mopper alles wie gedacht funktioniert...
                                      • T TT-Tom
                                        @tt-tom
                                        @Thomas-Braun
                                        ```bash
                                        Script v.2024-09-07
                                        *** BASE SYSTEM ***
                                               Icon name: computer-container
                                                 Chassis: container ☐
                                          Virtualization: lxc
                                                  Kernel: Linux 6.8.12-1-pve
                                            Architecture: x86-64
                                                          │ Time zone:                                                         │
                                                          │                           Amsterdam       -                        │
                                                          │                           Andorra         ▒                        │
                                                          │                           Astrakhan       0                        │
                                                          │                           Athens          ▒                        │
                                                          │                           Belfast         ▒                        │
                                                          │                           Belgrade        ▒                        │
                                                          │                           Berlin          ▒                        │
                                                          │                           Bratislava      ▒                        │
                                                          │                           Brussels        ▒                        │
                                                          │                           Bucharest       ▒                        │
                                                          │                           Budapest        ▒                        │
                                                          │                           Busingen        .                        │
                                                          │                 <Ok>                     <Cancel>                  │
                                        root
                                        HOME=/root
                                        GROUPS=root
                                        iobroker
                                        HOME=/home/iobroker
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Swap:           1.1G          0B        1.1G
                                                 2048 M total memory
                                                  271 M used memory
                                                  399 M active memory
                                                 1557 M free memory
                                                    0 M buffer memory
                                                  219 M swap cache
                                                 1024 M total swap
                                                    0 M used swap
                                                 1024 M free swap
                                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        *** FAILED SERVICES ***
                                          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                                        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                                        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                                        2 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        dmesg: read kernel buffer failed: Operation not permitted
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        Filesystem                       Type      Size  Used Avail Use% Mounted on
                                        none                             tmpfs     492K  4.0K  488K   1% /dev
                                        udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                                        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                                        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                        Show mounted filesystems:
                                        TARGET SOURCE                           FSTYPE OPTIONS
                                        /var:
                                        400M    /var/
                                        237M    /var/cache
                                        234M    /var/cache/apt
                                        146M    /var/lib
                                        /opt/iobroker/backups:
                                        /opt/iobroker/iobroker-data:
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.17.0
                                        /usr/bin/node           v20.17.0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.3
                                        nodejs:
                                          Installed: 20.17.0-1nodesource1
                                          Candidate: 20.17.0-1nodesource1
                                          Version table:
                                         *** 20.17.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                                100 /var/lib/dpkg/status
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u2 500
                                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://security.debian.org bookworm-security/main amd64 Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        Core adapters versions
                                        admin:          7.0.23
                                        Adapter State
                                        + instance is alive
                                        ioBroker-Repositories
                                        Upgrade policy: none
                                        Installed ioBroker-Instances
                                        Objects and States
                                        Objects:        148
                                        States:         103
                                        Pending Updates: 0
                                        #659
                                        Also mit vorheriger Installation des ioBroker funktioniert es?
                                          TT-Tom
                                          #660
                                          ja mit iobroker ist alles sauber durchgelaufen.
                                          Gruß Tom
                                          Public Transport
