  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.8k Aufrufe 40 Beobachtet
  • FeuersturmF Feuersturm
    @thomas-braun Sieht gut aus bei mir:
    Skript v.2024-08-18
    *** BASE SYSTEM ***
     Static hostname: ioB-Prod-Testsystem
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.4 LTS
              Kernel: Linux 6.5.13-1-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
    und Summary
                            v.2024-08-18
             Chassis: container
      Virtualization: lxc
    Installation:           lxc
    Kernel:                 x86_64
    Userland:               64 bit
    User-ID:                1001
    Display-Server:         false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:
    /usr/bin/nodejs         v20.16.0
    /usr/bin/node           v20.16.0
    /usr/bin/npm            10.8.1
    /usr/bin/npx            10.8.1
    /usr/bin/corepack       0.28.2
    Recommended versions are nodejs 20.16.0 and npm 10.8.1
    MEMORY:
    Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
    Swap:           2.0G        1.1G        976M
    Total:           10G        3.3G        5.8G
    Active iob-Instances:   31
    Upgrade policy: none
    ioBroker Core:          js-controller           6.0.10
                            admin                   7.0.23
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
    + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    Objects:                14532
    States:                 12032
    Size of iob-Database:
    27M     /opt/iobroker/iobroker-data/objects.jsonl
    17M     /opt/iobroker/iobroker-data/objects.json.migrated
    17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
    1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
    19M     /opt/iobroker/iobroker-data/states.jsonl
    6.3M    /opt/iobroker/iobroker-data/states.json.migrated
    6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    #632
    @feuersturm
    Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
      @feuersturm rein aus Neugier
      welche Farbe hat die Zeile?
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      #633
      @homoran sagte in iob diag - Skript:
      Bei der Langfassung und Summary ist die Information Gelb,
        #634
        @feuersturm sagte in iob diag - Skript:
        So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
        NashraN NegaleinN 2 Antworten Letzte Antwort
          NashraN Offline
          NashraN Offline
          Nashra
          Most Active Forum Testing
          #635
          Moin, hier mit LXC
                                  v.2024-08-18_5
           Static hostname: ioBroker
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-1-pve
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1000
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          MEMORY:
          Mem:             12G        4.1G        7.9G        122K        873M        8.7G
          Swap:             0B          0B          0B
          Total:           12G        4.1G        7.9G
          Active iob-Instances:   45
          ioBroker Core:          js-controller           6.0.9
                                  admin                   7.0.22
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
          Objects:                54190
          States:                 50980
          86M     /opt/iobroker/iobroker-data/objects.jsonl
          88M     /opt/iobroker/iobroker-data/states.jsonl
          Your Operating System is the current Debian stable version 'bookworm'!
          Gruß Ralf
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #636
            hier ein LXC
                                    v.2024-08-18_5
                     Chassis: container
              Virtualization: lxc
                      Kernel: Linux 5.15.30-2-pve
            Installation:           lxc
            Kernel:                 x86_64
            Userland:               64 bit
            Timezone:               Europe/Vienna (CEST, +0200)
            User-ID:                1001
            Pending OS-Updates:     31
            Pending iob updates:    4
            /usr/bin/nodejs         v20.15.0
            /usr/bin/node           v20.15.0
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            /usr/bin/corepack       0.28.1
            MEMORY:
            Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
            Swap:           3.1G        1.1G        2.0G
            Total:           13G        5.8G        6.4G
            Active iob-Instances:   60
            Active repo(s): Beta (latest)
            ioBroker Core:          js-controller           5.0.19
                                    admin                   7.0.24
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects:                32233
            States:                 31404
            53M     /opt/iobroker/iobroker-data/objects.jsonl
            29M     /opt/iobroker/iobroker-data/objects.json.migrated
            29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            0       /opt/iobroker/iobroker-data/objects.json.broken
            54M     /opt/iobroker/iobroker-data/states.jsonl
            9.4M    /opt/iobroker/iobroker-data/states.json.migrated
            9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
            Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
            ° Fixer ---> iob fix
            • S Abwesend
              S Abwesend
              Shadowhunter23
              #637
              Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
              Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
              USB-Devices by-id:
              No Devices found 'by-id'
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              HINT:
              Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              HINT:
              Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
              ioBroker Backup Analyzer
              • S Shadowhunter23
                USB-Devices by-id:
                HINT:
                tcp
                HINT:
                tcp
                HINT:
                tcp
                #638
                @shadowhunter23
                Ich war davon ausgeganen, das 3 zigbee-Instanzen ausreichend sein sollten.
                Ich würde da auch eher per Router ein Zigbee-Netz draus weben, an deiner Stelle.
                Und ich vergleiche auch nur die EInträge von 'by-id' mit den Ports aus dem Adapter.
                Ob die Einstellungen dann die richtigen sind musst du selber prüfen.
                Ist ja auch nur ein Hinweis.
                Kurz: Won't fix.
                  @shadowhunter23
                  Kurz: Won't fix.
                  S Abwesend
                  S Abwesend
                  Shadowhunter23
                  schrieb am zuletzt editiert von Shadowhunter23
                  #639
                  Auch hier, Won't fix 🙂 . Das ist schon mit Absicht so gemacht.
                  Kurz: Won't fix.
                  OK, war ja auch nur ein Hinweis.
                  • S Shadowhunter23
                    Kurz: Won't fix.
                    #640
                    Da ich das Skript in den letzten Tagen um einige Funktionen (Anlage eines users, wenn es als root oder 'iobroker' aufgerufen wird; setzen der Zeitzone, wenn eine vermutlich falsche (wie Europe/London oder UTC) erkannt wird) und kritische Fehler im Kernel Ring Puffer (dmesg) jetzt gemeldet werden würde ich gerne ein paar Läufe auf anderen Systemen als meinen Testkisten sehen. Insbesondere LXC und Docker ist da interessant für mich.
                    Es gibt auch ein paar Meldungen auf deutsch, wenn das Skript mit der Option '--de' aufgerufen wird. Auch dazu wäre Feedback willkommen. Gleich vorweg: Es kann keine vollständige Übersetzung geben, da einige Kommandos nur englische Ausgaben liefern.
                    Bitte diese Beta-Version wie im ersten Beitrag gezeigt lokal ausführen, im ioBroker selber ist diese Version v.2024-09-07 natürlich noch nicht implementiert.
                      TT-Tom
                      #641
                      Hallo Thomas,
                      habe das Script aus dem Standartuser Ordner Tom gestartet. Musste zwischen durch das Password für sudo eingeben. System LXC-Container mit einem Testsystem auf Beta-Repro.
                      Script v.2024-09-07
                      *** BASE SYSTEM ***
                       Static hostname: iobtest
                        Virtualization: lxc
                      OS is similar to:
                      model name	: Intel(R) N100
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       14:11:14 up 24 days, 36 min,  1 user,  load average: 0.06, 0.08, 0.01
                      CPU threads: 4
                      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                      *** TIME AND TIMEZONES ***
                                     Local time: Sun 2024-09-08 14:11:14 CEST
                                 Universal time: Sun 2024-09-08 12:11:14 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      tom
                      HOME=/home/tom
                      GROUPS=tom sudo users iobroker
                      iobroker
                      [sudo] password for tom:
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** DISPLAY-SERVER SETUP ***
                      Desktop:
                      Terminal: 	tty
                      Boot Target: 	graphical.target
                      *** MEMORY ***
                      Mem:            8.4G        1.6G        5.2G        131K        1.6G        6.8G
                      Swap:           536M          0B        536M
                      Total:          8.9G        1.6G        5.7G
                      Active iob-Instances: 	10
                               8000 M total memory
                               1507 M used memory
                               1442 M active memory
                               1464 M inactive memory
                               4944 M free memory
                                  0 M buffer memory
                               1547 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      top - 14:11:34 up 24 days, 36 min,  1 user,  load average: 0.05, 0.07, 0.01
                      Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   8000.0 total,   4944.3 free,   1508.0 used,   1547.8 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6492.0 avail Mem
                      *** FAILED SERVICES ***
                        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                      2 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      dmesg: read kernel buffer failed: Operation not permitted
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--101--disk--0 ext4       63G  6.0G   54G  10% /
                      none                             tmpfs     492K  4.0K  488K   1% /dev
                      udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
                      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                      tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                      Show mounted filesystems:
                      TARGET SOURCE                           FSTYPE OPTIONS
                      /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      463M	/var/
                      250M	/var/cache
                      246M	/var/cache/apt
                      170M	/var/cache/apt/archives
                      154M	/var/lib
                      Archived and active journals take up 16.4M in the file system.
                      /opt/iobroker/backups:
                      46M	/opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      767M	/opt/iobroker/iobroker-data/
                      645M	/opt/iobroker/iobroker-data/files
                      493M	/opt/iobroker/iobroker-data/files/javascript.admin
                      461M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                      460M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      30M	/opt/iobroker/iobroker-data/objects.jsonl
                      19M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
                      14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                      8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      USB-Devices by-id:
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs 	v20.17.0
                      /usr/bin/node 		v20.17.0
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      /usr/bin/corepack 	0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Candidate: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310623)
                      Core adapters versions
                      js-controller: 	6.0.11
                      admin: 		7.1.0
                      javascript: 	8.8.2
                      nodejs modules from github: 	2
                      +-- iobroker.iosapp@1.0.3 (git+ssh://git@github.com/tt-tom17/ioBroker.iosapp.git#57aa9615040d4d80b735ca0fb4beddc5aee69c9d)
                      +-- iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                      Adapter State
                        system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                      + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                      + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                        system.adapter.devices.0                : devices               : iobtest                                  - disabled
                      + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                        system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                      + system.adapter.iosapp.0                 : iosapp                : iobtest                                  -  enabled
                      + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                      + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                        system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                        system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                      + system.adapter.sql.0                    : sql                   : iobtest                                  -  enabled
                        system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                        system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): beta
                      Installed ioBroker-Instances
                      Used repository: beta
                      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                      Adapter    "admin"        : 7.1.0    , installed 7.1.0
                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                      Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                      Adapter    "javascript"   : 8.8.3    , installed 8.8.2  [Updatable]
                      Controller "js-controller": 6.0.11   , installed 6.0.11
                      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                      Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                      Adapter    "sql"          : 3.0.1    , installed 3.0.1
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "web"          : 6.3.0    , installed 6.3.0
                      Adapter    "yahka"        : 1.0.8    , installed 1.0.8
                      Objects and States
                      Objects: 	4034
                      States: 	3519
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                      Reading package lists... Done
                      Pending Updates: 2
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13079      1/systemd
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13990      296/master
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       29389306   35190/iobroker.js-c
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29389311   35190/iobroker.js-c
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13991      296/master
                      tcp6       0      0 :::9192                 :::*                    LISTEN      1001       29392405   35471/io.iosapp.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13081      1/systemd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13201      1/systemd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60327454   91363/io.admin.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13080      1/systemd
                      udp6       0      0 :::111                  :::*                                0          13082      1/systemd
                      2024-09-08 14:02:49.853  - info: javascript.1 (61255) Start JavaScript script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch (JavaScript/js)
                      2024-09-08 14:02:49.860  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                      2024-09-08 14:02:49.864  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Connected!
                      2024-09-08 14:02:49.899  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch:  ist das eine zahl false
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Tagesverbrauch: 5.1 kWh
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Wochenverbrauch: 39.3 kWh
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Monatsverbrauch: 47.3 kWh
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Quartalsverbrauch: 455.6 kWh
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Jahrsverbrauch: 2018.2 kWh
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Betroffene Zeilen: 0
                      2024-09-08 14:02:49.900  - info: javascript.1 (61255) script.js.common.SQL_Daten.Abfrage_aktueller_Verbrauch: Serverstatus: 34
                      2024-09-08 14:05:39.663  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                      2024-09-08 14:05:39.895  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                      2024-09-08 14:05:48.012  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127484
                      2024-09-08 14:05:48.620  - info: netatmo-crawler.0 (127484) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                      2024-09-08 14:05:48.637  - info: netatmo-crawler.0 (127484) Getting data for stationid:70:ee:50:35:dc:b6
                      2024-09-08 14:06:07.272  - info: netatmo-crawler.0 (127484) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                      2024-09-08 14:06:07.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127484 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-09-08 14:10:44.041  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                      2024-09-08 14:10:44.229  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                      2024-09-08 14:10:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 127529
                      2024-09-08 14:10:48.618  - info: netatmo-crawler.0 (127529) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                      2024-09-08 14:10:48.635  - info: netatmo-crawler.0 (127529) Getting data for stationid:70:ee:50:35:dc:b6
                      2024-09-08 14:10:59.398  - info: netatmo-crawler.0 (127529) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                      2024-09-08 14:10:59.907  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 127529 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      			v.2024-09-07
                        Virtualization: lxc
                      Installation: 		lxc
                      Kernel: 		x86_64
                      Userland: 		64 bit
                      User-ID: 		1000
                      Pending OS-Updates: 	2
                      Pending iob updates: 	1
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      Recommended versions are nodejs 20.17.0 and npm 10.8.2
                      nodeJS installation is correct
                      MEMORY:
                      Mem:            8.4G        1.7G        5.0G        131K        1.6G        6.7G
                      Swap:           536M          0B        536M
                      Total:          8.9G        1.7G        5.6G
                      ioBroker Core: 		js-controller 		6.0.11
                      			admin 			7.1.0
                      ioBroker Status: 	iobroker is running on this host.
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		4034
                      States: 		3519
                      6.0M	/opt/iobroker/iobroker-data/states.jsonl
                      in deutsch
                      *** ioBroker Diagnose ***
                      Das Fenster des Terminalprogramms (puTTY) bitte so groß wie möglich ziehen oder den Vollbildmodus verwenden.
                      Die nachfolgenden Prüfungen liefern Hinweise zu etwaigen Fehlern, bitte im Forum hochladen:
                      https://forum.iobroker.net
                      Bitte die vollständige Ausgabe, einschließlich der ``` Zeichen am Anfang und am Ende markieren und kopieren.
                      Es hilft beim helfen!
                      Bitte eine Taste drücken
                      ========== Langfassung ab hier markieren und kopieren ===========
                      Skript v.2024-09-07
                      *** GRUNDSYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       14:17:19 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                      CPU threads: 4
                      *** LEBENSZYKLUS STATUS ***
                      Das Betriebssystem mit dem Codenamen '' ist unbekannt. Bitte den Status der Unterstützung eigenständig prüfen.
                      *** ZEIT UND ZEITZONEN ***
                                     Local time: Sun 2024-09-08 14:17:19 CEST
                                 Universal time: Sun 2024-09-08 12:17:19 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      *** User und Gruppen ***
                      User der 'iob diag' aufgerufen hat:
                      tom
                      HOME=/home/tom
                      User der den 'js-controller' ausführt:
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Swap:           536M          0B        536M
                               8000 M total memory
                               1507 M used memory
                               1439 M active memory
                               1471 M inactive memory
                               4936 M free memory
                                  0 M buffer memory
                               1555 M swap cache
                                512 M total swap
                                  0 M used swap
                                512 M free swap
                      top - 14:17:20 up 24 days, 42 min,  1 user,  load average: 0.25, 0.19, 0.07
                      MiB Mem :   8000.0 total,   4935.5 free,   1509.3 used,   1555.3 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   6490.7 avail Mem
                      Es wurden keine kritischen Fehler gefunden
                      *** FILESYSTEM ***
                      /var:
                      463M	/var/
                      250M	/var/cache
                      246M	/var/cache/apt
                      154M	/var/lib
                      768M	/opt/iobroker/iobroker-data/
                      USB-Devices by-id:
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobtest             iobtest (version: 6.0.11, hostname: iobtest       , alive, uptime: 1310968)
                      admin: 		7.1.0
                      javascript: 	8.8.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	3978
                      States: 	3463
                      Hit:2 http://security.debian.org bookworm-security InRelease
                      Offene Systemupdates: 2
                      2024-09-08 14:15:47.449  - info: fahrplan.0 (72820) Updated 2 routes, 2 enabled and 0 disabled
                      2024-09-08 14:15:47.640  - info: fahrplan.0 (72820) Updated 1 departure timetables, 1 enabled and 0 disabled
                      2024-09-08 14:15:48.011  - info: host.iobtest instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 128557
                      2024-09-08 14:15:48.614  - info: netatmo-crawler.0 (128557) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.17.0, js-controller: 6.0.11
                      2024-09-08 14:15:48.630  - info: netatmo-crawler.0 (128557) Getting data for stationid:70:ee:50:35:dc:b6
                      2024-09-08 14:15:58.272  - info: netatmo-crawler.0 (128557) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                      2024-09-08 14:15:58.781  - info: host.iobtest instance system.adapter.netatmo-crawler.0 having pid 128557 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      ============ Langfassung bis hier markieren =============
                      iob diag hat das System inspiziert.
                      Beliebige Taste für eine Zusammenfassung drücken
                      Zusammfassung ab hier markieren und kopieren:
                      ===================== ZUSAMMENFASSUNG =====================
                      			v.2024-09-07
                        Virtualization: lxc
                      Installation: 		lxc
                      Kernel: 		x86_64
                      Userland: 		64 bit
                      User-ID: 		1000
                      Offene OS-Updates: 	2
                      Offene iob updates: 	1
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      Empfohlene Versionen sind zurzeit nodejs 20.17.0 und npm 10.8.2
                      nodeJS ist korrekt installiert
                      MEMORY:
                      Mem:            8.4G        1.6G        5.1G        131K        1.6G        6.8G
                      Swap:           536M          0B        536M
                      			admin 			7.1.0
                      Objects type: jsonl
                      States  type: jsonl
                      Objects: 		3978
                      States: 		3463
                      6.4M	/opt/iobroker/iobroker-data/states.jsonl
                      =================== ENDE DER ZUSAMMENFASSUNG ====================
                      === Ausgabe bis hier markieren und kopieren ===
                      tom@iobtest:~$
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                      • T TT-Tom
                        Hallo Thomas,
                        Script v.2024-09-07
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        tom
                        HOME=/home/tom
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Swap:           536M          0B        536M
                                 8000 M total memory
                                 1507 M used memory
                                 4944 M free memory
                                    0 M buffer memory
                                 1547 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        *** FILESYSTEM ***
                        /var:
                        463M	/var/
                        250M	/var/cache
                        246M	/var/cache/apt
                        154M	/var/lib
                        USB-Devices by-id:
                        /usr/bin/npm 		10.8.2
                        /usr/bin/npx 		10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin: 		7.1.0
                        javascript: 	8.8.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects: 	4034
                        States: 	3519
                        Pending Updates: 2
                        			v.2024-09-07
                          Virtualization: lxc
                        Installation: 		lxc
                        Kernel: 		x86_64
                        Userland: 		64 bit
                        User-ID: 		1000
                        /usr/bin/npm 		10.8.2
                        /usr/bin/npx 		10.8.2
                        MEMORY:
                        Swap:           536M          0B        536M
                        			admin 			7.1.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		4034
                        States: 		3519
                        in deutsch
                        Skript v.2024-09-07
                        *** GRUNDSYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        tom
                        HOME=/home/tom
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal: 	tty
                        *** MEMORY ***
                        Swap:           536M          0B        536M
                                 8000 M total memory
                                 1507 M used memory
                                 4936 M free memory
                                    0 M buffer memory
                                 1555 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        *** FILESYSTEM ***
                        /var:
                        463M	/var/
                        250M	/var/cache
                        246M	/var/cache/apt
                        154M	/var/lib
                        USB-Devices by-id:
                        /usr/bin/npm 		10.8.2
                        /usr/bin/npx 		10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin: 		7.1.0
                        javascript: 	8.8.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects: 	3978
                        States: 	3463
                        			v.2024-09-07
                          Virtualization: lxc
                        Installation: 		lxc
                        Kernel: 		x86_64
                        Userland: 		64 bit
                        User-ID: 		1000
                        /usr/bin/npm 		10.8.2
                        /usr/bin/npx 		10.8.2
                        MEMORY:
                        Swap:           536M          0B        536M
                        			admin 			7.1.0
                        Objects type: jsonl
                        States  type: jsonl
                        Objects: 		3978
                        States: 		3463
                        tom@iobtest:~$
                        #642
                        @tt-tom sagte in iob diag - Skript:
                        Hm. Da sollte eigentlich dann 'bookworm' gemeldet werden. Muss ich dann im LXC mal schauen, ob und wo ich die Info anderweitig bekomme.
                        Kannst du mal bitte
                        lsb_release -a
                        cat /etc/debian_version
                        hostnamectl
                        im Container ausführen?
                          Kannst du mal bitte
                          lsb_release -a
                          hostnamectl
                          TT-Tom
                          #643
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, permitted by applicable law.
                          Letzte Anmeldung: Sonntag, den 08. September 2024,
                          tom@iobtest:~$ lsb_release
                          -bash: Isb_release: Kommando nicht gefunden.
                          tom@iobtest:~$ lsb_release -a
                          tom@iobtest:~$cat /etc/debian_version
                          12.7
                          tom@iobtest:*$ hostnamectl
                          Chassis: container
                          Machine ID: 661945b8c6614fe89d03fba976fb627e
                          Boot ID: 9650d956e3ce42b185dda1a4dcaa22f4
                          Virtualization: lxc
                          Operating System: ;;https://www.debian.org/Debian GNU/Linux 12 (bookworm);;
                          tom@iobtest:~$
                          Edit: hostnamectl aktualisiert.
                          Gruß Tom
                          Public Transport
                          • S Abwesend
                            S Abwesend
                            Shadowhunter23
                            #644
                            Proxmox lxc
                            Script v.2024-09-07
                            *** BASE SYSTEM ***
                             Static hostname: iobroker
                              Virtualization: lxc
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             16:16:01 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                            CPU threads: 4
                            Operating System is the current Debian stable version codenamed 'bookworm'!
                                           Local time: Sun 2024-09-08 16:16:01 CEST
                                       Universal time: Sun 2024-09-08 14:16:01 UTC
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            tobias
                            HOME=/home/tobias
                            GROUPS=tobias sudo users iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev redis
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:             10G        4.4G        4.9G        499K        1.4G        6.4G
                            Swap:             0B          0B          0B
                            Total:           10G        4.4G        4.9G
                            Active iob-Instances:   50
                                    10240 M total memory
                                     4176 M used memory
                                     1435 M active memory
                                     3875 M inactive memory
                                     4689 M free memory
                                        0 M buffer memory
                                     1374 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            top - 16:16:02 up 9 days, 19:35,  1 user,  load average: 0.58, 0.25, 0.20
                            Tasks:  80 total,   1 running,  79 sleeping,   0 stopped,   0 zombie
                            MiB Mem :  10240.0 total,   4687.7 free,   4178.0 used,   1374.8 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6062.0 avail Mem
                            1 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--400--disk--0 ext4       16G   11G  4.1G  73% /
                            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                            tmpfs                            tmpfs     3.1G  144K  3.1G   1% /run
                            /      /dev/mapper/pve-vm--400--disk--0 ext4   rw,relatime,stripe=16
                            /var:
                            1.1G    /var/
                            491M    /var/lib
                            340M    /var/lib/redis
                            307M    /var/cache
                            303M    /var/cache/apt
                            Archived and active journals take up 48.9M in the file system.
                            248M    /opt/iobroker/backups/
                            706M    /opt/iobroker/iobroker-data/
                            573M    /opt/iobroker/iobroker-data/files
                            299M    /opt/iobroker/iobroker-data/files/javascript.admin
                            265M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            264M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            40M     /opt/iobroker/iobroker-data/objects.jsonl
                            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                            29M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.448016d7.js.map
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.4ff93037.js.map
                            19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                            USB-Devices by-id:
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                            tcp
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            At least one iobroker host is running.
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848141)
                            admin:          7.1.0
                            javascript:     8.8.3
                            nodejs modules from github:     0
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                            + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
                            + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                            + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                            + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                            + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                            + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 - disabled
                            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.mytime.0                 : mytime                : iobroker                                 -  enabled
                            + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                            + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                            + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                              system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                              system.adapter.octoprint.2              : octoprint             : iobroker                                 - disabled
                            + system.adapter.operating-hours.0        : operating-hours       : iobroker                                 -  enabled
                            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                            + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
                            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                            + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                            + system.adapter.pushover.2               : pushover              : iobroker                                 -  enabled
                            + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                            + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                            + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                            + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                            + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                              system.adapter.sayit.4                  : sayit                 : iobroker                                 - disabled
                            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                            + system.adapter.text2command.1           : text2command          : iobroker                                 -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.64:20108
                            + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.69:20108
                            + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.79:20108
                            + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.63:20108
                            + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.0.99:20108
                            + instance is alive
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                            Adapter    "awtrix-light" : 1.3.0    , installed 1.3.0
                            Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                            Adapter    "email"        : 1.3.1    , installed 1.3.1
                            Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
                            Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                            Adapter    "iot"          : 3.4.0    , installed 3.4.0
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Adapter    "lg-thinq"     : 1.0.1    , installed 1.0.1
                            Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                            Adapter    "notification-manager": 1.2.1, installed 1.2.1
                            Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                            Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                            Adapter    "ping"         : 1.7.3    , installed 1.7.3
                            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                            Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                            Adapter    "shelly"       : 8.1.1    , installed 8.1.1
                            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                            Adapter    "text2command" : 3.0.3    , installed 3.0.3
                            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                            Adapter    "vis-icontwo"  : 1.6.3    , installed 1.6.3
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                            Adapter    "wireguard"    : 1.6.4    , installed 1.6.4
                            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                            Objects and States
                            Objects:        11315
                            States:         10115
                            Hit:5 https://packages.redis.io/deb bookworm InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          118935115  1/systemd
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       156490584  651521/io.mqtt.0
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       118947555  877/io.shelly.1
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        118941820  170/redis-server 12
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          118940237  404/master
                            tcp        0      0 192.168.0.222:9092      0.0.0.0:*               LISTEN      1001       118943133  781/io.nuki.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          118937351  1/systemd
                            tcp6       0      0 :::80                   :::*                    LISTEN      0          135858214  294782/apache2
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          118935117  1/systemd
                            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       118951273  1120/io.fullybrowse
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          118940238  404/master
                            tcp6       0      0 ::1:6379                :::*                    LISTEN      106        118941821  170/redis-server 12
                            tcp6       0      0 :::8093                 :::*                    LISTEN      1001       118953403  1186/io.rest-api.0
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       118953652  1281/io.simple-api.
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       149284472  525475/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       118956323  1397/io.web.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          118935218  90/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          118935116  1/systemd
                            udp        0      0 192.168.0.222:123       0.0.0.0:*                           0          118937414  180/ntpd
                            udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          118937412  180/ntpd
                            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          118937408  180/ntpd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       118946983  661/io.chromecast.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       118947492  857/io.shelly.0
                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       118943201  897/io.tuya.0
                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       118943202  897/io.tuya.0
                            udp6       0      0 :::111                  :::*                                0          118935118  1/systemd
                            udp6       0      0 fe80::8c62:1cff:fe4:123 :::*                                105        118940387  180/ntpd
                            udp6       0      0 ::1:123                 :::*                                0          118937416  180/ntpd
                            udp6       0      0 :::123                  :::*                                0          118937405  180/ntpd
                            2024-09-08 14:00:00.013  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1049671
                            2024-09-08 14:00:04.018  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1049691
                            2024-09-08 14:00:08.105  - info: host.iobroker instance system.adapter.ical.1 having pid 1049671 terminated with code 0 (NO_ERROR)
                            2024-09-08 14:00:10.686  - info: host.iobroker instance system.adapter.ical.0 having pid 1049691 terminated with code 0 (NO_ERROR)
                            2024-09-08 14:30:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1051935
                            2024-09-08 14:30:04.019  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1051950
                            2024-09-08 14:30:06.665  - info: host.iobroker instance system.adapter.ical.0 having pid 1051935 terminated with code 0 (NO_ERROR)
                            2024-09-08 14:30:12.176  - info: host.iobroker instance system.adapter.ical.1 having pid 1051950 terminated with code 0 (NO_ERROR)
                            2024-09-08 15:00:00.022  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1054104
                            2024-09-08 15:00:04.027  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1054124
                            2024-09-08 15:00:08.093  - info: host.iobroker instance system.adapter.ical.1 having pid 1054104 terminated with code 0 (NO_ERROR)
                            2024-09-08 15:00:10.660  - info: host.iobroker instance system.adapter.ical.0 having pid 1054124 terminated with code 0 (NO_ERROR)
                            2024-09-08 15:30:00.016  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1056283
                            2024-09-08 15:30:04.021  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1056303
                            2024-09-08 15:30:06.698  - info: host.iobroker instance system.adapter.ical.0 having pid 1056283 terminated with code 0 (NO_ERROR)
                            2024-09-08 15:30:12.224  - info: host.iobroker instance system.adapter.ical.1 having pid 1056303 terminated with code 0 (NO_ERROR)
                            2024-09-08 16:00:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.15.0" started with pid 1058656
                            2024-09-08 16:00:04.021  - info: host.iobroker instance system.adapter.ical.0 in version "1.15.0" started with pid 1058676
                            2024-09-08 16:00:08.144  - info: host.iobroker instance system.adapter.ical.1 having pid 1058656 terminated with code 0 (NO_ERROR)
                            2024-09-08 16:00:10.674  - info: host.iobroker instance system.adapter.ical.0 having pid 1058676 terminated with code 0 (NO_ERROR)
                                                    v.2024-09-07
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1000
                            Pending iob updates:    0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Mem:             10G        4.4G        4.9G        524K        1.4G        6.3G
                            Swap:             0B          0B          0B
                                                    admin                   7.1.0
                            Objects type: redis
                            States  type: redis
                            Objects:                11315
                            States:                 10115
                            4.0M    /opt/iobroker/iobroker-data/states.jsonl
                            Deutsch:
                            Skript v.2024-09-07
                            *** GRUNDSYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                            CPU threads: 4
                            Das Betriebssystem ist das aktuelle, stabile Debian 'bookworm'!
                                           Local time: Sun 2024-09-08 16:20:31 CEST
                                       Universal time: Sun 2024-09-08 14:20:31 UTC
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            tobias
                            HOME=/home/tobias
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:             0B          0B          0B
                                     4186 M used memory
                                     1444 M active memory
                                     4678 M free memory
                                        0 M buffer memory
                                     1375 M swap cache
                                        0 M total swap
                                        0 M used swap
                                        0 M free swap
                            top - 16:20:31 up 9 days, 19:40,  2 users,  load average: 1.88, 1.07, 0.55
                            Tasks:  86 total,   2 running,  83 sleeping,   0 stopped,   1 zombie
                            %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :  10240.0 total,   4677.1 free,   4187.5 used,   1375.9 buff/cache
                            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6052.5 avail Mem
                            *** FILESYSTEM ***
                            tmpfs                            tmpfs     3.1G  168K  3.1G   1% /run
                            tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/0
                            /var:
                            1.1G    /var/
                            491M    /var/lib
                            340M    /var/lib/redis
                            307M    /var/cache
                            303M    /var/cache/apt
                            USB-Devices by-id:
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            HINT:
                            tcp
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: redis
                            States  type: redis
                            Hosts:
                            iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 848411)
                            admin:          7.1.0
                            javascript:     8.8.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        11315
                            States:         10115
                            Offene Systemupdates: 0
                            (Not all processes could be identified, non-owned process info
                             will not be shown, you would have to be root to see it all.)
                                                    v.2024-09-07
                              Virtualization: lxc
                            Installation:           lxc
                            Kernel:                 x86_64
                            Userland:               64 bit
                            User-ID:                1000
                            Offene OS-Updates:      0
                            Offene iob updates:     0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Swap:             0B          0B          0B
                                                    admin                   7.1.0
                            Objects type: redis
                            States  type: redis
                            Objects:                11315
                            States:                 10115
                            • S Shadowhunter23
                              Proxmox lxc
                              Script v.2024-09-07
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                               RTC time: n/a
                                            NTP service: n/a
                                        RTC in local TZ: no
                              tobias
                              HOME=/home/tobias
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:             0B          0B          0B
                                       4176 M used memory
                                       4689 M free memory
                                          0 M buffer memory
                                       1374 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.1G    /var/
                              491M    /var/lib
                              340M    /var/lib/redis
                              307M    /var/cache
                              303M    /var/cache/apt
                              USB-Devices by-id:
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: redis
                              States  type: redis
                              Hosts:
                              admin:          7.1.0
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        11315
                              States:         10115
                              Pending Updates: 0
                                                      v.2024-09-07
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Swap:             0B          0B          0B
                                                      admin                   7.1.0
                              Objects type: redis
                              States  type: redis
                              Objects:                11315
                              States:                 10115
                              Deutsch:
                              Skript v.2024-09-07
                              *** GRUNDSYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                               RTC time: n/a
                                            NTP service: n/a
                                        RTC in local TZ: no
                              tobias
                              HOME=/home/tobias
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:             0B          0B          0B
                                       4186 M used memory
                                       4678 M free memory
                                          0 M buffer memory
                                       1375 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.1G    /var/
                              491M    /var/lib
                              340M    /var/lib/redis
                              307M    /var/cache
                              303M    /var/cache/apt
                              USB-Devices by-id:
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              HINT:
                              tcp
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: redis
                              States  type: redis
                              Hosts:
                              admin:          7.1.0
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        11315
                              States:         10115
                                                      v.2024-09-07
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                              Swap:             0B          0B          0B
                                                      admin                   7.1.0
                              Objects type: redis
                              States  type: redis
                              Objects:                11315
                              States:                 10115
                              #645
                              @shadowhunter23 sagte in iob diag - Skript:
                              fehlende Gruppe für den user (adm?)
                                Meister MopperM Online
                                Meister Mopper
                                #646
                                Habe mal einen Proxmox Test LXC angeschmissen und das Skript laufen lassen:
                                Langfassung:
                                Script v.2024-09-07
                                *** BASE SYSTEM ***
                                Static hostname: ioTest
                                 Virtualization: lxc
                                OS is similar to:
                                model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                CPU threads: 1
                                              Local time: Sun 2024-09-08 17:01:44 CEST
                                          Universal time: Sun 2024-09-08 15:01:44 UTC
                                                RTC time: n/a
                                         RTC in local TZ: no
                                thomas
                                HOME=/home/thomas
                                GROUPS=thomas adm sudo iobroker
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                Boot Target:    multi-user.target
                                *** MEMORY ***
                                Mem:            2.1G        1.1G        982M        118K        102M        1.1G
                                Swap:             0B          0B          0B
                                Total:          2.1G        1.1G        982M
                                        2048 M total memory
                                        1013 M used memory
                                        1090 M active memory
                                           0 M inactive memory
                                         936 M free memory
                                           0 M buffer memory
                                          98 M swap cache
                                           0 M total swap
                                           0 M used swap
                                           0 M free swap
                                top - 17:01:44 up 4 min,  1 user,  load average: 0.98, 0.56, 0.33
                                Tasks:  27 total,   1 running,  26 sleeping,   0 stopped,   0 zombie
                                MiB Mem :   2048.0 total,    935.0 free,   1014.9 used,     98.1 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1033.1 avail Mem
                                * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                                3 loaded units listed.
                                *** FILESYSTEM ***
                                rpool/data/subvol-300-disk-0 zfs        12G  6.0G  6.1G  50% /
                                udev                         devtmpfs   16G     0   16G   0% /dev/tty
                                tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                                tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
                                tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
                                /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
                                /var:
                                1.1G    /var/
                                603M    /var/log
                                602M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                                369M    /var/lib
                                Archived and active journals take up 601.0M in the file system.
                                489M    /opt/iobroker/backups/
                                8.5K    /opt/iobroker/backups/scripte0
                                164M    /opt/iobroker/iobroker-data/
                                105M    /opt/iobroker/iobroker-data/files
                                47M     /opt/iobroker/iobroker-data/files/javascript.admin
                                40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                                3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
                                3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
                                3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
                                3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                       500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                ioBroker Status
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 286)
                                admin:          7.0.23
                                javascript:     8.7.6
                                | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                                | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                 system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
                                + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
                                 system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
                                 system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
                                + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
                                 system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
                                 system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
                                 system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
                                 system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
                                 system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
                                 system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
                                 system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
                                 system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
                                 system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
                                 system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
                                 system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
                                + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + instance is alive
                                Active repo(s): stable
                                Used repository: stable
                                Adapter    "admin"        : 7.0.23   , installed 7.0.23
                                Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                                Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                                Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                Adapter    "heos"         : 2.2.1    , installed 2.2.1
                                Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                                Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                                Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                Adapter    "openligadb"   : 1.4.11   , installed 1.4.11
                                Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                                Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                                Adapter    "solax"        : 0.9.9    , installed 0.9.9
                                Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                                Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                                Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                Adapter    "web"          : 6.2.5    , installed 6.2.5
                                Objects and States
                                Objects:        453
                                States:         337
                                Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                                Pending Updates: 0
                                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        146671219  117/redis-server 12
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          146671191  124/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          146670661  1/systemd
                                tcp6       0      0 :::6556                 :::*                    LISTEN      0          146670958  1/systemd
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146671441  166/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146672892  237/io.web.0
                                tcp6       0      0 ::1:6379                :::*                    LISTEN      107        146671220  117/redis-server 12
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          146671202  124/sshd: /usr/sbin
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          146670663  1/systemd
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          146670662  1/systemd
                                udp6       0      0 :::111                  :::*                                0          146670664  1/systemd
                                2024-09-08 16:57:10.689  - info: javascript.0 (193) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all states
                                2024-09-08 16:57:11.006  - info: javascript.0 (193) requesting all objects
                                2024-09-08 16:57:11.031  - info: javascript.0 (193) received all states
                                2024-09-08 16:57:11.518  - info: javascript.0 (193) received all objects
                                Kurzfassung:
                                                       v.2024-09-07
                                 Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1001
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Mem:            2.1G        1.1G        1.0G        118K         62M        1.1G
                                Swap:             0B          0B          0B
                                Total:          2.1G        1.1G        1.0G
                                                       admin                   7.0.23
                                Objects type: redis
                                States  type: redis
                                Objects:                453
                                States:                 337
                                1.9M    /opt/iobroker/iobroker-data/objects.json.bak
                                221K    /opt/iobroker/iobroker-data/states.json.bak
                                Langfassung DE:
                                Skript v.2024-09-07
                                *** GRUNDSYSTEM ***
                                 Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                CPU threads: 1
                                              Local time: Sun 2024-09-08 17:04:41 CEST
                                          Universal time: Sun 2024-09-08 15:04:41 UTC
                                                RTC time: n/a
                                         RTC in local TZ: no
                                thomas
                                HOME=/home/thomas
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:             0B          0B          0B
                                        2048 M total memory
                                        1018 M used memory
                                        1055 M active memory
                                           0 M inactive memory
                                         970 M free memory
                                           0 M buffer memory
                                          59 M swap cache
                                           0 M total swap
                                           0 M used swap
                                           0 M free swap
                                top - 17:04:41 up 7 min,  1 user,  load average: 0.37, 0.48, 0.35
                                %Cpu(s):  0.0 us,100.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   2048.0 total,    968.4 free,   1020.2 used,     59.6 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1027.8 avail Mem
                                *** FILESYSTEM ***
                                /var:
                                1.1G    /var/
                                603M    /var/log
                                369M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                ioBroker Status
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 466)
                                admin:          7.0.23
                                javascript:     8.7.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        453
                                States:         337
                                Kurzfassung DE:
                                                       v.2024-09-07
                                 Virtualization: lxc
                                Installation:           lxc
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1001
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                MEMORY:
                                Swap:             0B          0B          0B
                                                       admin                   7.0.23
                                Objects type: redis
                                States  type: redis
                                Objects:                453
                                States:                 337
                                Proxmox und HA ...
                                  #647
                                  Nee, LXC-Eigenheit.
                                  Bei Meister Mopper wird auch richtig Bookworm erkannt...
                                  Meister MopperM T 3 Antworten Letzte Antwort
                                    Nee, LXC-Eigenheit.
                                    Meister Mopper
                                    #648
                                    Jetzt mal die Variante als root user:
                                    Script v.2024-09-07
                                    *** BASE SYSTEM ***
                                     Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    17:46:56 up 50 min,  1 user,  load average: 0.65, 0.48, 0.44
                                    CPU threads: 1
                                                  Local time: Sun 2024-09-08 17:46:56 CEST
                                              Universal time: Sun 2024-09-08 15:46:56 UTC
                                                    RTC time: n/a
                                             RTC in local TZ: no
                                    root
                                    HOME=/root
                                    GROUPS=root
                                    iobroker
                                    HOME=/home/iobroker
                                    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                                    A root login is not required in most Linux Distributions.
                                    Enter the username for a new user (Not 'root' and not 'iobroker'!): testuser
                                    Enter the password for the new user:
                                    Confirm the password for the new user:
                                    Adding new user account...
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:            2.1G        1.1G        1.0G        110K         64M        1.1G
                                    Swap:             0B          0B          0B
                                            2048 M total memory
                                            1022 M used memory
                                            1048 M active memory
                                               0 M inactive memory
                                             964 M free memory
                                               0 M buffer memory
                                              61 M swap cache
                                               0 M total swap
                                               0 M used swap
                                               0 M free swap
                                    top - 17:47:31 up 50 min,  1 user,  load average: 0.41, 0.44, 0.43
                                    Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :   2048.0 total,    962.5 free,   1024.3 used,     61.2 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1023.7 avail Mem
                                    *** FILESYSTEM ***
                                    tmpfs                        tmpfs     6.3G  104K  6.3G   1% /run
                                    /var:
                                    1.1G    /var/
                                    603M    /var/log
                                    369M    /var/lib
                                    Archived and active journals take up 601.1M in the file system.
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                     Version table:
                                    ioBroker Status
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    ioTest              ioTest (version: 6.0.11, hostname: ioTest        , alive, uptime: 1351)
                                    admin:          7.0.23
                                    javascript:     8.7.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        453
                                    States:         337
                                    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                    Pending Updates: 0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       146791638  5317/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       146791954  5388/io.web.0
                                    2024-09-08 17:24:26.513  - info: javascript.0 (193) terminating
                                    2024-09-08 17:24:26.514  - info: javascript.0 (193) Terminated (NO_ERROR): Without reason
                                    2024-09-08 17:24:26.518  - info: javascript.0 (193) Got terminate signal TERMINATE_YOURSELF
                                    2024-09-08 17:24:27.005  - info: javascript.0 (193) terminating
                                    2024-09-08 17:25:05.872  - info: javascript.0 (5358) starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.17.0, js-controller: 6.0.11
                                    2024-09-08 17:25:06.028  - info: javascript.0 (5358) requesting all states
                                    2024-09-08 17:25:06.029  - info: javascript.0 (5358) requesting all objects
                                    2024-09-08 17:25:06.044  - info: javascript.0 (5358) received all states
                                    2024-09-08 17:25:06.261  - info: javascript.0 (5358) received all objects
                                    Mein eingerichteter testuser hat auch die richtigen Rechte bekommen.
                                    testuser@ioTest:~$ groups
                                    testuser adm dialout sudo audio video plugdev users iobroker
                                    Proxmox und HA ...
                                      Nee, LXC-Eigenheit.
                                      TT-Tom
                                      #649
                                      @Meister-Mopper
                                      @Shadowhunter23
                                      von welcher Konsole habt ihr das script gestartet? aus der Proxmox oder per ssh aus einem Terminal?
                                      Gruß Tom
                                      Public Transport
                                      Meister MopperM W 2 Antworten Letzte Antwort
                                      • T TT-Tom
                                        @Meister-Mopper
                                        @Shadowhunter23
                                        Meister Mopper
                                        #650
                                        @Meister-Mopper
                                        @Shadowhunter23
                                        ssh vom windows terminal
                                        Proxmox und HA ...
                                        • T TT-Tom
                                          @Meister-Mopper
                                          @Shadowhunter23
                                          W Offline
                                          W Offline
                                          Wildbill
                                          #651
                                          @tt-tom Das sollte egal sein. Wenn Du Dich per SSH in einem LXC anmeldest landest Du im selben Userspace, als wenn Du Dich über die Proxmox-Konsole im LXC anmeldest.
                                          Gruss, Jürgen
